MK7.5 NAR GTI - Enable static LED AFS lights when high-beams enabled?
quailallstar
Ormond Beach, FL
C?ID=53119
I often drive on very dark country roads at night and could use some additional side lighting. We have large deer and bears - something I don't want to hit going 85 mph/136 km/h.
I've already coded my LED AFS NAR-spec headlights to enable foglamps on - with high beams (no issues. we don't have vehicle inspections here).
Is it somehow possible to enable the static AFS sidelights when the high beams - are switched on?
This thread is also posted on the GolfMK7 forums, so If I get some answers there, I'll make sure and post findings here and vice versa.
Thank you all in advance! :)
This is a Tweak, not a Retrofit. Moving.
Please post an Adaptation Channel Map from your BCM as currently configured.
quailallstar
Ormond Beach, FL
C?ID=53119
;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
;Component:FCM MQB Low   002 0342     Coding:000000050900214A01113F00CA0000000000000000000000000000000000
;EV_MultiModulContiVW48X    2004    EV_MultiModulContiVW48X_002_VW37.rod
;Thursday    22    July    2021    07:31:51:61205
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210708 DS325.1
;VCID: 3537212475CF87F36C5-8060
IDE00001-Production mode    not active     3
IDE00820-Activating and deactivating all development messages    not active     1
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection    Yes     1
IDE01996-SFT00041-Installation list: specified installations-Left light control    Yes     1
IDE01996-SFT00057-Installation list: specified installations-Right light control    Yes     1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module    Yes     1
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit    No     1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2    Yes     1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2    Yes     1
IDE01996-SFT33031-Installation list: specified installations-Antenna module    No     1
IDE02332-Deactivate production mode    0    3
IDE03641-Presentation run dynamic AFS light    active     1
IDE03642-Presentation mode    not active     1
IDE03679-Adaptive light functions    active     1
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE08418-Matrix light: total dimming    0.00%    1
IDE09156-Matrix headlamp: function at standstill    not active     1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1    OFF     12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2    OFF     12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3    OFF     12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4    OFF     12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5    OFF     12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6    OFF     12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7    OFF     12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8    OFF     12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9    OFF     12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10    OFF     12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11    OFF     12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12    OFF     12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13    OFF     12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14    OFF     12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15    OFF     12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16    OFF     12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17    OFF     12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18    OFF     12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19    OFF     12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20    OFF     12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21    OFF     12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22    OFF     12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23    OFF     12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24    OFF     12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25    OFF     12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26    OFF     12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27    OFF     12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28    OFF     12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29    OFF     12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30    OFF     12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31    OFF     12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32    OFF     12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33    OFF     12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34    OFF     12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35    OFF     12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36    OFF     12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37    OFF     12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38    OFF     12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39    OFF     12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40    OFF     12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41    OFF     12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42    OFF     12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43    OFF     12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44    OFF     12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45    OFF     12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46    OFF     12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47    OFF     12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48    OFF     12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49    OFF     12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50    OFF     12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51    OFF     12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52    OFF     12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53    OFF     12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54    OFF     12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55    OFF     12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56    OFF     12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57    OFF     12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58    OFF     12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59    OFF     12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60    OFF     12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61    OFF     12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62    OFF     12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63    OFF     12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64    OFF     12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65    OFF     12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66    OFF     12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67    OFF     12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68    OFF     12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69    OFF     12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70    OFF     12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71    OFF     12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72    OFF     12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73    OFF     12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74    OFF     12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75    OFF     12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76    OFF     12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77    OFF     12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78    OFF     12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79    OFF     12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80    OFF     12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81    OFF     12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82    OFF     12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83    OFF     12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84    OFF     12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85    OFF     12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86    OFF     12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87    OFF     12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88    OFF     12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89    OFF     12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90    OFF     12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1    OFF     12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2    OFF     12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3    OFF     12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4    OFF     12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5    OFF     12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6    OFF     12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7    OFF     12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8    OFF     12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9    OFF     12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10    OFF     12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11    OFF     12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12    OFF     12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13    OFF     12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14    OFF     12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15    OFF     12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16    OFF     12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17    OFF     12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18    OFF     12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19    OFF     12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20    OFF     12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21    OFF     12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22    OFF     12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23    OFF     12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24    OFF     12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25    OFF     12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26    OFF     12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27    OFF     12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28    OFF     12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29    OFF     12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30    OFF     12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31    OFF     12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32    OFF     12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33    OFF     12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34    OFF     12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35    OFF     12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36    OFF     12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37    OFF     12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38    OFF     12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39    OFF     12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40    OFF     12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41    OFF     12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42    OFF     12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43    OFF     12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44    OFF     12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45    OFF     12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46    OFF     12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47    OFF     12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48    OFF     12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49    OFF     12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50    OFF     12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51    OFF     12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52    OFF     12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53    OFF     12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54    OFF     12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55    OFF     12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56    OFF     12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57    OFF     12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58    OFF     12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59    OFF     12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60    OFF     12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61    OFF     12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62    OFF     12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63    OFF     12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64    OFF     12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65    OFF     12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66    OFF     12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67    OFF     12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68    OFF     12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69    OFF     12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70    OFF     12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71    OFF     12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72    OFF     12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73    OFF     12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74    OFF     12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75    OFF     12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76    OFF     12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77    OFF     12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78    OFF     12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79    OFF     12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80    OFF     12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81    OFF     12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82    OFF     12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83    OFF     12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84    OFF     12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85    OFF     12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86    OFF     12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87    OFF     12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88    OFF     12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89    OFF     12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90    OFF     12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1    OFF     3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2    OFF     3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3    OFF     3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4    OFF     3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5    OFF     3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6    OFF     3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7    OFF     3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8    OFF     3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9    OFF     3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10    OFF     3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11    OFF     3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12    OFF     3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13    OFF     3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14    OFF     3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15    OFF     3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16    OFF     3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17    OFF     3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18    OFF     3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19    OFF     3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20    OFF     3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1    OFF     3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2    OFF     3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3    OFF     3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4    OFF     3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5    OFF     3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6    OFF     3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7    OFF     3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8    OFF     3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9    OFF     3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10    OFF     3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11    OFF     3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12    OFF     3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13    OFF     3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14    OFF     3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15    OFF     3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16    OFF     3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17    OFF     3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18    OFF     3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19    OFF     3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20    OFF     3
IDE13611-Cornering lamp in operation    not active     1
IDE13612-Matrix head lamps: steering angle    9600.00 °    2
ENG124608-Order_Reference_Run_Activation_Effect    No dependency     1
ENG124607-Reference_Run_Activation_Effect    Activation effect disabled     1
ENG103979-Reference_Run_Start_Condition    Engine start     1
Elapsed Time: 00:11
@quailallstar: Hello again!
I'm confused and I need your help in understanding your wants - please.
When you refer to the "static AFS sidelights" in the headlight assemblies, I assume that you mean the lighting system that is used for cornering and which only operates if the car is traveling less-than an upper speed limit (generally 50 km/h on RoW models).
But from my reading of your post- your problem appears to be avoiding local wild-life while the car is traveling on a winding country road at speed (i've hit a kangaroo at speed, but I reckon hitting a bear would be an order of magnitude more exciting!!!).
If I understand correctly, I would have thought that something like Dynamic bend lighting, or Dynamic cornering lights would be more appropriate - these are entirely different systems and they use special equipment in their headlight fittings.
What have I missed?
