How do you copy long code helper information to save
shaun3215
C?ID=49160 (NRRT)
hello i was trying to save all the information from the long code helper ,i could not find anything to save all information , why i am saving it .
I have a audi a4 BCM 1 water damaged ,we have found a used one with the same numbers , i looked at the bcm information on long coder ,but cannot find how to download or save the information so i can compare ,what is ticked and what is not with the original one ,any ideas to do this thanks shaun
What generation / year A4 have you got?
Assuming the replacement module is the correct one, you should be able to copy the coding string from a scan made while the original module is still installed. But you might have Adaptation channels to deal with as well.
Can you please post an Auto-Scan from this car with the original module installed?
shaun3215
C?ID=49160 (NRRT)
Wednesday,30,June,2021,13:40:12:24691
VCDS Version: 20.12.0.1 (x64)
Dealer/Shop Name: AUTO DIAGNOSTIC CENTRE
VIN: WAUZZZ8K4AA001331   License Plate: RS05BAM
Mileage: 221550km-137664mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 3C 42 46 47 52 53 55 56 5F
          62 72
VIN: WAUZZZ8K4AA001331   Mileage: 221550km-137664miles
09-Cent. Elect. -- Status: Malfunction 1010
10-Park/Steer Assist -- Status: Malfunction 1010
20-High Beam Assist. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 RK    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H01 9979
   Revision: 11H01---
   Coding: 0124002C180F2118
   Shop #: WSC 61792 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906022RK A01010
   ROD: EV_ECM20TDI03L906022HN.rod
   VCID: 7F06B883E69D0F7C7B-802A
4922 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [040] - -
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:04
                    Engine RPM: 943.00 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 66 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.780 V
                    Crankshaft speed (RPM): 943.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 12780 mV
                    Coolant temperature: 66.0 °C
                    Fuel temperature: 34.4 °C
                    Control Module temperature: 28.0 °C
                    Engine oil temperature: 53.6 °C
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [032] - Circuit Malfunction
7135 - Body Control Module (Central Electric)
          U0140 00 [040] - No Communications
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Engine RPM: 893.00 /min
                    Normed load value: 42.4 %
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.560 V
                    Crankshaft speed (RPM): 893.0 /min
                    Ambient temperature: 27.7 °C
                    Vehicle voltage terminal 30: 11560 mV
                    Bus Diag st Node 0-Bits 0-7: 0
                    Limitation: accelerator pedal: 64.8 Nm
                    Control Module temperature: 27.9 °C
5558 - Body Control Module (Central Electric 2)
          U0141 00 [040] - No Communications
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:05
                    Engine RPM: 821.00 /min
                    Normed load value: 48.6 %
                    Voltage terminal 30: 13.060 V
                    Crankshaft speed (RPM): 821.0 /min
                    Ambient temperature: 27.3 °C
                    Vehicle voltage terminal 30: 13060 mV
                    Limitation: accelerator pedal: 72.3 Nm
4716 - No Communications with Parking Brake Control Module
          U0128 00 [040] - -
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 03:15:01
                    Engine RPM: 825.50 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 11.360 V
                    Crankshaft speed (RPM): 825.5 /min
                    Ambient temperature: 31.8 °C
                    Vehicle voltage terminal 30: 11360 mV
                    Control Module temperature: 28.5 °C
   Part No SW: 8K9 907 379 A    HW: 8K9 907 379 A
   Component: ESP8 quattro  H06 0050
   Coding: 064D00
   Shop #: WSC 06335 000 00000
   VCID: 4084FB7FD3E3B08442-8014
02214 - Tire Pressure Warning
                    Fault Frequency: 11
                    Reset counter: 4
                    Mileage: 219083 km
                    Date: 2021.05.26
                    Time: 16:48:22
                    Hex Value: 0x5600
                    Hex Value: 0x4006
                    Hex Value: 0x121B
                    Hex Value: 0x0EB8
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0002
                    Hex Value: 0x1D96
                    Hex Value: 0x00FF
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0016
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Fault Frequency: 9
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:03
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x001B
                    Hex Value: 0x33A2
                    Hex Value: 0x00FF
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0002
                    Hex Value: 0x1D96
                    Hex Value: 0x00FF
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0016
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 BP    HW: 8K0 907 064 BP
   Component: BCM2 1.1      H90 0247
   Coding: 031200
   VCID: 7F06B883EE9D0F7C7B-802A
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000009671017
   Component: ELVAUDIB8  H36 0041
   Serial number: 0209000013075003
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:35
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0150
   Revision: D1000000    Serial number: 01050320090849
   Coding: 34140000
   VCID: 438EF473C2F5AB9C5F-8016
00898 - Control Circuit A/C compressor
                    Fault Frequency: 29
                    Reset counter: 44
                    Mileage: 221436 km
                    Date: 2021.06.18
                    Time: 15:08:24
                    Current: 0.000 A
                    Current: 0.360 A
                    Voltage: 13.90 V
                    Reset counter: 44
                    Mileage: 221478 km
                    Date: 2008.05.27
                    Time: 00:00:47
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:59
                    Temperature: 1.0°C
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:59
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000238674
   Coding: 260050914074AF010001000300001D0D0F1D070800010141000000
   Shop #: WSC 00444 210 91448
   VCID: 3064ABBF63432004B2-8064
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 100309  H05 0070
   Serial number: SWF09030100008
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10411521
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000403091279
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 3
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:38:00
                    Reset counter: 4
                    Mileage: 221506 km
                    Date: 2008.05.27
                    Time: 00:34:00
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Reset counter: 3
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:38:00
01701 - Dimmer for Interior Lighting
                    Fault Status: 00101100
                    Reset counter: 44
                    Mileage: 221545 km
                    Date: 2008.05.27
                    Time: 00:16:00
                    Reset counter: 3
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:38:00
03205 - Control Circuit / Actuator for Left Low-Beam Shutter
                    Reset counter: 3
                    Mileage: 221478 km
                    Date: 2008.05.27
                    Time: 00:02:00
03206 - Control Circuit / Actuator for Right Low-Beam Shutter
                    Reset counter: 3
                    Mileage: 221478 km
                    Date: 2008.05.27
                    Time: 00:02:00
00927 - Terminal 30 (Right)
                    Reset counter: 4
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:08:00
02838 - Solenoid Valve for Servotronic (N119)
                    Reset counter: 3
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:38:00
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140907103400
   Coding: 000004
   VCID: 3C7C8F8FBF0BD4641E-8068
                    Fault Frequency: 20
                    Reset counter: 45
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Temperature: 77.0°C
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1EMHBM
   Coding: 30363435363030303030554A3052384B3053
   VCID: 3C7C8F8FB70BD4641E-8068
   Serial number: 6334MSME4434762EH
   Serial number: 6344MSME446442389
   Serial number: 6352QSME0A1D3F1AU
   Serial number: 6362QSME511A24124
   Serial number: 63732SME241D2122Q
   Serial number: 63832SME711B1C16/
12670208 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Fault Frequency: 18
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
   Revision: --------    Serial number: 90315ICB000GY
   Coding: 000017
   VCID: 3D7A828BA411DD6C29-8068
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:36
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H18 0224
   Revision: 00200000    Serial number: 9E341D539
   Coding: 2F0429020B002600010000
   VCID: 3162AEBB6849290CBD-8064
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:05
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 03:15:01
   Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0095
   Revision: FB600048    Serial number: 4800F09218806E
   Coding: 000303
   VCID: 4FA6C8431EBD5FFCCB-801A
   Component: J367-BDM  H06 0160
   Serial number: 1906A270190209
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 00:00:01
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 01:32:06
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
   Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
   Component: FLA           H04 0003
   Revision: AA001002
   Coding: 02029164747464545425363E
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:03
   Part No SW: 8K0 907 566 D    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-17
   Coding: 0001106
   VCID: 3874939F4B33F844FA-806C
   Subsystem 1 - Part No: 8K0 907 568 D
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-37
   Subsystem 3 - Serial number: 5F07.01.0900H010003CT10791ÿ
   Subsystem 4 - Serial number: T10791ÿ
01024 - Rain Sensor (G213)
                    Fault Frequency: 20
                    Mileage: 221551 km
                    Date: 2009.01.01
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008592083
   Coding: 011C02205001410001
   VCID: 4182FE7BD8E9B98C4D-8014
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:39
   Revision: 00002001    Serial number: 0117212008
   Coding: 013B0622203904D40020020000000000
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
                    Reset counter: 43
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:41:22
                    Reset counter: 43
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:41:22
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:35
                    Fault Frequency: 9
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:31
   Part No SW: 8T0 035 223 AL    HW: 8T0 035 223 H
   Component: DSP Prem      H04 0200
   Revision: 00004001    Serial number: 34880004555203
   VCID: 78F4539FCBB338443A-802C
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008607443
                    Fault Frequency: 52
                    Reset counter: 23
                    Mileage: 216484 km
                    Date: 2021.05.01
                    Time: 14:01:01
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:17:39
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000193436
   VCID: 336EA4B392551B1CCF-8066
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 01:25:14
                    Voltage: 14.50 V
                    Count: 74
                    Hex Value: 0x0273
                    Hex Value: 0x0081
                    Hex Value: 0x1010
                    Reset counter: 4
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 01:25:14
                    Voltage: 14.50 V
                    Count: 10
                    Hex Value: 0x0273
                    Hex Value: 0x0081
                    Hex Value: 0x1010
00576 - Terminal 15
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 01:25:14
                    Voltage: 14.50 V
                    Count: 48
                    Hex Value: 0x0273
                    Hex Value: 0x0081
                    Hex Value: 0x1010
                    Fault Status: 00101011
                    Reset counter: 4
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 03:14:02
                    Voltage: 12.30 V
                    Count: 38
                    Hex Value: 0x0170
                    Hex Value: 0x0088
                    Hex Value: 0x1010
                    Reset counter: 44
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:01
                    Voltage: 12.00 V
                    Count: 86
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02442 - Function Lamp in Control Head
                    Fault Status: 00101001
                    Reset counter: 152
                    Mileage: 216792 km
                    Date: 2021.05.05
                    Time: 08:35:33
                    Voltage: 14.50 V
                    Count: 72
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0808
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000019
   Shop #: WSC 06334 000 00000
   VCID: 3064ABBFA3432004B2-8064
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 2
                    Mileage: 221474 km
                    Date: 2021.06.18
                    Time: 16:35:21
                    Mileage: 221551 km
                    Date: 2008.05.27
                    Time: 00:18:05
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341C 097556893
   Coding: 010003010000000001
   VCID: 254A4AEB2C8175AC51-8070
   Part No SW: 8T2 035 670 M    HW: 8T2 035 670 D
   Component: H-BNT-EU      H41 0187
   Revision: --------    Serial number: 476AL0AB000016
   Coding: 010101010006A1ED11000B1E000000030000
   Shop #: WSC 00428 210 101831
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H43 0306
   Serial number: 9356CS091072881
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000248098
   Component: CD-Database  1293
                    Reset counter: 143
                    Mileage: 216427 km
                    Date: 2021.05.01
                    Time: 10:44:33
                    Voltage: 12.30 V
                    Reset counter: 4
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 00:00:15
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 44
                    Mileage: 221550 km
                    Date: 2008.05.27
                    Time: 01:32:10
                    Bin. Bits: 00001000 00000100
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000008610977
   Coding: 010C02204001210001
   VCID: 448CF76FC7FBACA466-8010
   Revision:             Serial number: 0000008610929
End-------------------------(Elapsed Time: 04:13)-----------------------
VIN Number
WAUZZZ8K4AA001331
Make
AUDI
Model
Model Year
2010
Drive Type
Manufacturer
AUDI
Engine
Style/BodyAge
9
Manufactured CompnayAUDI
Plant Company Name
Vehicle TypePASSENGER CAR
Coding can just be copied & pasted:
You may also want to make an Adaptation Channel Map from the old module for reference purposes and use compare it to one made from the new module after it is installed.
^^^ is the BCM on an Audi A4 (B7) included in the CP constellation?
HI Don, I thought the same question when I posted the vin "helper" ; I don't believe so. I know the (2008 and up A5,S5, RS5's CCM (aka BCM) are CP. But it seems to me this came up once before and I was mistaken (ie I thought they were CP).
Stand by, I'm sure we will get a clarification soon!
Hmm... This is a B8, not a B7. But TBH, I'm not sure whether it is or isn't in this car.
+ Reply to Thread
Results 1 to 6 of 6
Thread: Thanks to your support I can move to the next level of programming
  1. 05-01-2011 05:42 PM#1
    DavidB8
    DavidB8 is offline
    Veteran MemberFour Rings DavidB8's Avatar Join DateNov 06 2009AZ Member #50351LocationOakville, ON, CanadaBlog Entries2
    My Photo Gallery: 0
    Thanks to your support I can move to the next level of programming​
    Well one of the biggest issues I have where I am is no dealer support. This means any project that deals with component protection is impossible for me to undertake. Such as completing my Adaptive cruise control install or replacing my BCM to try and install the rear window blind.
  • Informative
shaun3215
C?ID=49160 (NRRT)
Is stefdds working on the same car as me
shaun3215
C?ID=49160 (NRRT)
+ Reply to Thread
Results 1 to 6 of 6
    DavidB8
    DavidB8 is offline
    Veteran MemberFour Rings DavidB8's Avatar's Avatar Join DateNov 06 2009AZ Member #50351LocationOakville, ON, CanadaBlog Entries2
    My Photo Gallery: 0
Are you working on the same car as me
HI Shaun , I have a 2009 (prod. date 08/08) B8 S5 ; my CCM / BCM IS component protected.
shaun3215
C?ID=49160 (NRRT)
how can you view the maps i have made the maps but cannot open them
shaun3215
C?ID=49160 (NRRT)
;SW:8K0-907-063-D   HW:8K0-907-063-D ---  Cent. Elect. --- SA: 20113
;Component:BCM1 1.0      H26 0253, Coding:260050914074AF010001000300001D0D0F1D070800010141000000
;Tuesday,13,July,2021,10:37:33:24691
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 3064ABBF6343200B73-8064
;01 N/A
;02 N/A
A03,0,
;9
A03,1,
A03,2,
A03,3,
;0.0 %
A03,4,
;0.0 %
;04 N/A
;05 N/A
A06,0,
;1800
A06,1,
;OFF
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;900
A07,1,
;OFF
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;600
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;650
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;450
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
A11,0,
;500
A11,1,
;N/A
A11,2,
;N/A
A11,3,
;N/A
A11,4,
;N/A
A12,0,
;120
A12,1,
;N/A
A12,2,
;N/A
A12,3,
;N/A
A12,4,
;N/A
A13,0,
;60
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
;14 N/A
;15 N/A
A16,0,
;3
A16,1,
;N/A
A16,2,
;N/A
A16,3,
;N/A
A16,4,
;N/A
;17 N/A
A18,0,
;255
A18,1,
;N/A
A18,2,
;N/A
A18,3,
;N/A
A18,4,
;N/A
A19,0,
;1
A19,1,
;N/A
A19,2,
;N/A
A19,3,
;N/A
A19,4,
;N/A
;20 N/A
A21,0,
;1
A21,1,
;N/A
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;1
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;1
A23,1,
;N/A
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;1
A24,1,
;N/A
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
A25,0,
;2000
A25,1,
;N/A
A25,2,
;N/A
A25,3,
;N/A
A25,4,
;N/A
A26,0,
;5
A26,1,
;N/A
A26,2,
;N/A
A26,3,
;N/A
A26,4,
;N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
A34,0,
;0
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
;0
A35,1,
;N/A
A35,2,
;N/A
A35,3,
;N/A
A35,4,
;N/A
;36 N/A
A37,0,
;3
A37,1,
;N/A
A37,2,
;N/A
A37,3,
;N/A
A37,4,
;N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
A43,0,
;40
A43,1,
;N/A
A43,2,
;N/A
A43,3,
;N/A
A43,4,
;N/A
A44,0,
;0
A44,1,
;N/A
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
A45,0,
;0
A45,1,
;N/A
A45,2,
;N/A
A45,3,
;N/A
A45,4,
;N/A
A46,0,
;1
A46,1,
;N/A
A46,2,
;N/A
A46,3,
;N/A
A46,4,
;N/A
A47,0,
;0
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
A48,0,
;120
A48,1,
;N/A
A48,2,
;N/A
A48,3,
;N/A
A48,4,
;N/A
A49,0,
;120
A49,1,
;N/A
A49,2,
;N/A
A49,3,
;N/A
A49,4,
;N/A
A50,0,
;120
A50,1,
;N/A
A50,2,
;N/A
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;120
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;120
A52,1,
;N/A
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
A53,0,
;0
A53,1,
;N/A
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
;54 N/A
A55,0,
;1
A55,1,
;N/A
A55,2,
;N/A
A55,3,
;N/A
A55,4,
;N/A
A56,0,
;1
A56,1,
;N/A
A56,2,
;N/A
A56,3,
;N/A
A56,4,
;N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
shaun3215
C?ID=49160 (NRRT)
;Component:BCM1 1.0      H21 0253, Coding:668060B90034A7010001000300005F5F0F1D460800000141000000
;Tuesday,13,July,2021,12:07:41:24691
A01,0,
;100
A01,1,
;100.0 %
A01,2,
;100.0 %
A01,3,
A01,4,
;02 N/A
A03,0,
;9
A03,1,
;100.0 %
A03,2,
;100.0 %
A03,3,
A03,4,
A04,0,
;37
A04,1,
;100.0 %
A04,2,
;100.0 %
A04,3,
;100.0 %
A04,4,
;100.0 %
;05 N/A
;06 N/A
;07 N/A
A08,0,
;600
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;650
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;450
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
A11,0,
;500
A11,1,
;N/A
A11,2,
;N/A
A11,3,
;N/A
A11,4,
;N/A
A12,0,
;120
A12,1,
;N/A
A12,2,
;N/A
A12,3,
;N/A
A12,4,
;N/A
A13,0,
;60
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
;14 N/A
;15 N/A
A16,0,
;3
A16,1,
;N/A
A16,2,
;N/A
A16,3,
;N/A
A16,4,
;N/A
;17 N/A
A18,0,
;255
A18,1,
;N/A
A18,2,
;N/A
A18,3,
;N/A
A18,4,
;N/A
A19,0,
;1
A19,1,
;N/A
A19,2,
;N/A
A19,3,
;N/A
A19,4,
;N/A
;20 N/A
A21,0,
;1
A21,1,
;N/A
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;1
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;1
A23,1,
;N/A
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;1
A24,1,
;N/A
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
A34,0,
;0
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
;0
A35,1,
;N/A
A35,2,
;N/A
A35,3,
;N/A
A35,4,
;N/A
;36 N/A
A37,0,
;3
A37,1,
;N/A
A37,2,
;N/A
A37,3,
;N/A
A37,4,
;N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
A43,0,
;30
A43,1,
;N/A
A43,2,
;N/A
A43,3,
;N/A
A43,4,
;N/A
A44,0,
;1
A44,1,
;N/A
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
A45,0,
;0
A45,1,
;N/A
A45,2,
;N/A
A45,3,
;N/A
A45,4,
;N/A
A46,0,
;1
A46,1,
;N/A
A46,2,
;N/A
A46,3,
;N/A
A46,4,
;N/A
A47,0,
;1
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
A48,0,
;120
A48,1,
;N/A
A48,2,
;N/A
A48,3,
;N/A
A48,4,
;N/A
A49,0,
;120
A49,1,
;N/A
A49,2,
;N/A
A49,3,
;N/A
A49,4,
;N/A
A50,0,
;120
A50,1,
;N/A
A50,2,
;N/A
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;120
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;120
A52,1,
;N/A
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
A53,0,
;0
A53,1,
;N/A
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
;54 N/A
A55,0,
;1
A55,1,
;N/A
A55,2,
;N/A
A55,3,
;N/A
A55,4,
;N/A
A56,0,
;1
A56,1,
;N/A
A56,2,
;N/A
A56,3,
;N/A
A56,4,
;N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
shaun3215
C?ID=49160 (NRRT)
above are the maps of the 09 central elec one is the original ecu starting 2600 on the long code helper
