Passat 3C -06 2.0TDI ACC fault
R083RT
Norway
C?ID=400045
Hi,
I've had issues with the adaptive cruise control for some time now. Started with "ACC fault" message and then the cruise control stopped working.
Haven't botherd to adress this until now when the fault message changed to "ACC Environ fault" and it wont go away from the dash and i can't use any buttons on the steering wheel.
The battery has been bad for some time and today i put in a new fresh one. Plugged in the VCDS and did a scan. It says there is a fault on the ACC due to electromagnetic interference.
My guess is the sensor it self in front but can there be anything else affecting this? I have cleaned the lense and checked the plug and cable as far as i can reach without taking everything apart, but no obvious fault to find.
Can the ACC be disabled with the cruise control still operative?
Robert
Saturday,10,July,2021,13:50:13:43716
VIN: WVWZZZ3CZ6E163016   License Plate: ZD11588
Mileage: 286010km-177718mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 13 15 16 17 18 19 25 42 44 46 47 52 53 55 56
          62 65 69 6D 72 76
VIN: WVWZZZ3CZ6E163016   Mileage: 286010km-177718miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 997 020 H    HW: 03G 906 018 CK
   Component: R4 2.0l PPD1.5 G    2552
   Revision: --H05---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 2D070F79811B9223145-8078
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 006 -
                    Fault Status: 01100001
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:12
                    RPM: 800 /min
                    Text:     32    Nm
                    Bin. Bits: 00000000
                    Text: Kein Messwert verfuegbar
                    Raw, Form. N/A: 000 000 000
18061 - Please check DTC Memory of ABS Controller
            P1653 - 006 -
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:12
                    RPM: 800 /min
                    Text:     32    Nm
                    Bin. Bits: 00000000
18104 - Powertrain Data Bus
            P1696 - 008 - Implausible Message from Steering Column Controller
                    Fault Status: 01101000
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:13
                    RPM: 800 /min
                    Text:     32    Nm
                    Text:  0.0    %
                    Voltage: 14.24 V
                    Bin. Bits: 11101100
                    Bin. Bits: 10101010
Readiness: N/A
   Part No SW: 02E 300 042 F    HW: 02E 927 770 AE
   Component: GSG DSG         070 0917
   Revision: 04507000    Serial number: 00000509140456
   Shop #: WSC 01279 785 00200
   VCID: 1675C095148D31FB45F-8042
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 R    HW: 3C0 614 095 R
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0100000734
   Coding: 0029989
   Shop #: WSC 40611 001 1048576
   VCID: 313F13099D23F6C330D-8064
                    Reset counter: 168
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:14
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 629DAC4588451D5BF97-8036
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000005265203
   Coding: EF8A8F0700041A00000A00000F000000000B5D435C0000
   Shop #: WSC 05311 000 00000
   VCID: 3039160D9629FFCB3F3-8064
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 H    HW: 3C0 907 567 H
   Component: AC201  RDW 1    031 0119
   Revision: 00031000    Serial number: 00000000104230
   Coding: 0010000
   Shop #: WSC 49011 001 1048576
00272 - Function Disabled due to Electromagnetic Interference
                    Fault Status: 11101100
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:13
                    Count: 87
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:31:47
                    Count: 3
                    Fault Status: 11101101
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:31:48
                    Count: 5
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Reset counter: 209
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:24:14
                    Count: 3
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:31:48
                    Count: 34
                    Reset counter: 209
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:25:46
                    Count: 3
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 04 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2PSHZB79
   Coding: 0012340
   Subsystem 1 - Serial number: 6332MSME0D5A643A
   Subsystem 2 - Serial number: 6342MSME0D607750
   Subsystem 3 - Serial number: 6351HTS61IKUQLN2
   Subsystem 4 - Serial number: 6361HTS61IKEL2I2
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507Q
   Coding: 0001222
   Shop #: WSC 05311 000 08193
   VCID: 2E0508758C1DE93B2DF-807A
   Component: E0221           007 0050
   Part No SW: 3C0 920 870 Q    HW: 3C0 920 870 Q
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 80093 222 69422
   Part No: 1K0 815 071 P
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   Shop #: WSC 80093 222 183701
   VCID: 323D1C059825CDDB497-8066
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 B    HW: 3C0 907 951
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 1200A05C2101AA
   Coding: 7FFF9E1CCA2002
   Shop #: WSC 00822 218 88782
   VCID: 2019E64DC6C94F4BAF3-8074
   Part No SW: 3C0 959 433 P    HW: 3C0 959 433 P
   Component:    IMMO         043 0364
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 372B2D11734728F37E9-8062
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0000245
   VCID: 36352015744DD1FB65F-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 33331901673FC4D3421-8066
   Component:    KSG PQ46 RDK 043 0213
   Coding: 00900A08D1030E763804941570084F0B601900
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 3C0 035 456
   Component: 08K Audioverst.     0003
   Revision: 00001000    Serial number: 00000000005262
   VCID: 5DE79FB9B13B22A3C45-8008
   Part No: 1K0 959 702 K
   Coding: 0000244
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 G    HW: 3C0 907 801 G
   Component: EPB  VD8HC005   013 0005
   Revision:   013
   Coding: 0000012
   VCID: 2615F055A4EDA17BD5F-8072
Address 55: Headlight Range        Labels: 5M0-907-357-V1.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000001
   VCID: 71BFD3095DA3B6C370D-8024
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X017
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X017
   Coding: 00000035
Address 56: Radio
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: 70B9D60D56A9BFCB7F3-8024
   Component:    RDK              0391
   Coding: 0161211
Address 69: Trailer        Labels: 1K0-907-383-V1.clb
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 001 0020
   Coding: 0000001
   VCID: 6A8DC4657075451B317-803E
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0402
   Revision: 00H19001
   Shop #: WSC 23250 384 715754
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0800H21001001A0270ÿ
   Part No: 3C9 959 704
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930535500605
   Coding: 0011024
   VCID: 2809FE6DAEF9B70BE73-807C
End----------(Elapsed Time: 01:47, VBatt start/end: 12.7V/12.6V)-----------
Hmm, I don't recall ever having seen a "Function Disabled due to Electromagnetic Interference" fault before.
Did you recently get a new 5G phone? (Just kidding).
I'm really no sure what to make of that whole combination of fault codes.
Is this car all stock, or have there been retrofits and/or coding changes?
R083RT
Norway
C?ID=400045
Wrap it up in tinfoil maybe :D
It has been tuned at some point from 140bhp to 180bhp. I have no knowledge of any previous coding, so stock as far as i know. If it weren't for the insane price of a new lense i would have switched it, even a used on is about 600USD.... i never use the ACC so if it can be altered from ACC to CC that will bee perfect.
I would think it can, but I don't know everything involved. If it was mine and I wanted to revert it to regular cruise, I would disconnect the ACC module and remove it from the Gateway Installation List. Then I would clear all the fault codes, cycle the ignition, and do another scan to see what other modules are now unhappy about the missing ACC.
R083RT
Norway
C?ID=400045
Tried this today, only pulled the fuse though. Removed it from gateway list, clear fault code, cycled ignition, new scan. Got a fault on ABS module about ACC, cleared faults and its gone.
Did a test drive, no fault codes/messages, everything works except cruise control. No error or faults when i operate the CC besides a exclamation mark next to the CC icon in the MFD. I'm now stuck with the first fault on the Engine, dosen't seem to affect anything. So far so good, next mission is reviving the CC :)
Sunday,11,July,2021,11:34:09:43716
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 47 52 53 55 56 62
          65 69 6D 72 76
   Coding: 0000078
            P1647 - 006 -
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:34:43
                    Text:      0    Nm
                    Bin. Bits: 00000000
            P1653 - 006 -  - Intermittent
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:34:43
                    Text:      0    Nm
                    Bin. Bits: 00000000
                    Reset counter: 169
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:34:44
                    Text:      0    Nm
                    Text:  0.0    %
                    Voltage: 12.43 V
                    Bin. Bits: 11101100
                    Bin. Bits: 10101010
Readiness: N/A
   Coding: 0029989
                    Reset counter: 168
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 00:35:00
01319 - Control Module for Distance Control (J428)
                    Reset counter: 168
                    Mileage: 286011 km
                    Date: 2021.06.30
                    Time: 22:06:05
   Coding: 00063445
   Shop #: WSC 05311
   Coding: 00208933
   Shop #: WSC 05311
   Coding: 0012340
   Coding: 0001222
   Coding: 0007105
   Coding: 0000011
   Coding: 7FFD9E1CCA2002
   Coding: 0000245
   Coding: 0000244
   Revision:   013
   Coding: 0000012
   Coding: 0000001
   Coding: 00000035
   Coding: 00000035
Address 56: Radio
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0161211
   Coding: 0000001
   Revision: 00H19001
   Coding: 0000144
   Coding: 0011024
End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.3V)-----------
Address 01: DTCs cleared
Gateway Installation List:  3C0 907 530 B
Looks like you already tried to adjust the ECU from ACC to regular cruise?
I believe the ABS coding will need to be adjusted. I'm not very good with those. Perhaps @Dana can help sort that one.
In addition, I think the coding in 16-Steering Wheel should be adjusted. Try chainging 0001222 to 0001212 there. The catch here is that you might need a different stalk or controls, but I'm not certain about that.
If you haven't done so already I would try turning OFF CCS entirely in 01-Engine via the login/coding-II function using code 16167. Cycle the ignition, verify the letter G is gone
i.e.​
Component: R4 2.0l PPD1.5 G 2552​
versus​
Component: R4 2.0l PPD1.5 2552​
.. and then turn it back on again using 11463 = Cruise Control System (CCS) Activation and another ignition cycle.
In regards to 03-ABS I don't believe Coding is needed.
I agree with Uwe's Coding suggestion in address 16-Steering wheel however if that stalk is a special one (offering a button to set the distance for ACC) you may have a hardware issue/conflict with the stalk. Do get back to us if the above followed by locking the car for a 5 - 15 min CAN Nap doesn't fix it.
NEtech
Denmark
C?ID=56995
Me to, if you look-up VIN at Partslink24, 3C0 614 095 R is showed for PR-8T3 (ACC).
3C0 614 095 K and several other for PR 8T0, 8T2, 8T3
3C0 614 095 P and several other for PR 8T0, 8T2 (CCS)
So I guess it somewhere programmed in the ABS.
R083RT
Norway
C?ID=400045
Had a go this evening and did all of the above, and eureka! cruise control works perfectly and no fault codes at all. Thanks for all help and support everybody :thumbs:
