VW golf8 my2020 tow bar coding
   #21
DAN COZMIC
Italy
C?ID=441789
thank you all for the reply's!! so my main concern remains the acc not working. today i will try NEtech suggestion and will see what happens:)
   #22
VWT6
Finland
C?ID=295527
Have you driven the car (15+ minutes) - to see if it would clear the ACC fault.
I have no experience of Golf but e.g. new T6.1 clears faults (on dash) itself after power outage - just by driving it a bit. Of course then the fault memory needs to be cleared.
   #23
DAN COZMIC
Italy
C?ID=441789
yes i have tried drivenit for more then 15 min but doesn't clear.and done dtc clear.
   #24
DAN COZMIC
Italy
C?ID=441789
Use the coding I posted.
Or do not use Byte 02 Bit 2 in [13-ACC]
Is there a problem with [6C], besides there is an DTC?
Delete DTC in [6C], ign OFF
Drive a trip and use rear camera.
yes,yes,and yes it's working.:thumbs::thumbs:
got to thank all of you for the support and a special thanks to NEtech which has pointed me the right direction.
so ,from the last autoscan i have only changed the Byte 2 Bit 2 in the 13 which it was causing the Acc malfunction.doing that the Acc turned right one and after a few KM of driving and clearing dtc's i'm left with the old 6c dtc,a 19 ethernet fault,a 5f that doesn't show a fault and a 23 that cleared off after few attempts.
anyway in 13 if changed the Byte1 bit 7 which was causing also a fault and a mil on acc related.
following is the last autoscan i have done on the working car.
Tuesday,13,July,2021,18:24:16:06492
VCDS Version: 21.7.1.0 (x64)  HEX-V2 CB: 0.4548.4
Data version: 20210706 DS329.0
VIN: WVWZZZCDZLW027600   License Plate: GE492EH
Mileage: 24281km-15087mi   Repair Order: final one working ok(ecs module)
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 69 6C
          75 A5 D6 D7 8107 C002 C003
VIN: WVWZZZCDZLW027600   Mileage: 24281km-15087miles
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DSRB)       Labels: None
   Part No SW: 05L 906 022 BE    HW: 05L 907 309 C
   Component: R4 2.0l TDI   H30 9970
   Revision: E3H30---    CVN: 54E0D639644B2C53FDCF42ED644B2C5343FB2DAA
   Coding: 012504320364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906022BE 006006
   ROD: EV_ECM20TDI01105L906022BE.rod
   VCID: 6B823AEF530465935A9-803E
   VINID: 9E69EAAAA4D4A9C9C008718000D43C6A25
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 555     HW: 0GC 300 045 G
   Component: GSG DQ381     H06 3361
   CVN: 60475D66
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062.rod
   VCID: 78A815A31252DE0BA7B-802C
   Subsystem 1 - Part No SW: 5WA 713 033 AG    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1033
   Serial number: 20200210000058728394
   Subsystem 2 - Part No SW: 5H0 713 059 Q    HW: 5H0 713 059 Q
   Component: ZSB_SB_Mono    H03 0013
   Serial number: 92478TAU00648
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810500001818490
   Part No SW: 5WA 614 517 BA    HW: 5WA 614 517 A
   Component: ESC           H09 0020
   Serial number: 60430000000903a
   Coding: 34FC2C9022224473527D600006C361866DB658504AC8670800BCA231218FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
   VCID: 0848656362B2AE8BD7B-805C SFD
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 B    HW: 5WA 959 436 B
   Component: Kessy IOBOX   070 0703
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003.rod
   VCID: 53F2820FEB74DD53729-8006
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 007 K    HW: 5WA 907 007 M
   Component: AC Automat    H31 3130
   Coding: 002010019211120010100000101011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001098
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 4FFA8E7FC75CB9B3561-801A
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H01 0002
   Serial number: 00000000000000073258
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001110220022055507
   Part No SW: 5WA 937 086 P    HW: 5WA 937 086 H
   Component: BCM 37W BOSCH 016 0136
   Serial number: BXJ53F280220940
   ASAM Dataset: EV_BCM37w 005001
   ROD: EV_BCM37w_005_VW38.rod
   VCID: 5EE4633B90B6003BCD7-800A SFD
   Subsystem 1 - Part No SW: 5H1 955 119     HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0041
   Serial number: 907453F0402002203500
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           051 0206
   Serial number: SAY20M03D11H17M13S14
   Subsystem 3 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H05 0007
   Serial number: 92471TBJ001XF
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TBO001H1
   Subsystem 5 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92661TBM00714-------
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 Q    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000026022004220257
   Part No SW: 5WA 919 294 A    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0026
   Serial number: 000015022094630
   Coding: 0040010111
   ASAM Dataset: EV_EPHBO18VW3800000 002028
   ROD: EV_EPHBO18VW3800000_VW38.rod
   VCID: 50F88D03DA62A64B4FB-8004
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Coding: 098318FD0077404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003.rod
   VCID: 4CC09973364A82AB333-8018
   Part No SW: 5WA 959 655 A    HW: 5WA 959 655 A
   Component: AirbagVW40    007 0523
   Serial number: 000000003C0DKR6
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 55F67C17E580C3639CD-8000 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 402 702 20
   Component: SideSensor_Dr  002 6149
   Serial number: 35100011A63007B2926O
   Subsystem 2 - Part No SW: -----------    HW: 480 402 602 20
   Component: SideSensor_Pr  002 6149
   Serial number: 35200012A62EBD63F7FT
   Subsystem 3 - Part No SW: -----------    HW: 480 000 302 20
   Serial number: 35700000000D2309254A
   Subsystem 4 - Part No SW: -----------    HW: 480 000 602 20
   Serial number: 35800000000C820D564N
   Subsystem 5 - Part No SW: -----------    HW: 480 402 402 20
   Component: FrontSensor_D  003 614A
   Serial number: 3550001BEF25F1E5679W
   Part No SW: 5H0 920 340     HW: 5H0 920 340
   Component: KOMBI         237 1400
   Coding: 04A4004063840008018062032000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 002029
   ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
   VCID: 5F9A5E3F97BC0933C61-800A SFD
   Part No SW: 5WA 907 530 B    HW: 5WA 907 530 B
   Component: GW2020 High   734 7068
   Revision: --------    Serial number: 150160900104240
   Coding: 0000808D0700000000000000010301725B01600F02000300030100000001010000000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 47CAA65F2F2C61F31E1-8012 SFD
   Generator:
   Component: 2-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 2165424005
   Subsystem 3 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440071354203419
   Subsystem 4 - Part No SW: 5H0 959 542 D    HW: 5H0 959 542 D
   Component: KLR_JSS_1Zone  076 0019
2097338 - Ethernet Antenna Module
          U1646 00 [046] - No Communication
          [Antenna_control_module_1_no_communication_vlan]
                    Mileage: 24281 km
                    Date: 2021.07.13
                    Time: 18:20:59
   Part No SW: 5WA 909 059 E    HW: 3Q0 909 059 A
   Component: EBKV          H06 0092
   Serial number: BPA085120220013
   Coding: 1002C100730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
   ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
   VCID: 52FC870BD46ED45B79F-8006 SFD
107024 - Transmission Control Module
          U14E4 00 [032] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 20000030846012
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323CE78BB4AEF45B59F-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 00000403447890
   Coding: 015892400000A0508803010101010000000000212100000000000000215000
   VCID: 59EE70278998E703B85-800C
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TAS18196
   Coding: 003B03208200040000001000
   VCID: 49CEA06739389783085-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 C    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000038416675
   Coding: 110000
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1040
   Serial number: 00085458
   Coding: 0000000000000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 4DC69477CD508BA324D-8018
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TAR07795
   Coding: 003B01208E00040000801000
   VCID: 48C8A56322326E8B17B-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 C    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000038492325
   Coding: 090000
   Part No SW: 5H0 035 816     HW: 5H0 035 816
   Component: MU-O-ND-EU    H56 1668
   Serial number: WG8LGM120220000
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: 649051D3BEDA2AEB1B3-8030 SFD
   No subsystems:
   Subsystem 2 - Part No SW: V03 959 806 MG    HW: -----------
   Component: EU 2019/30     --- 202
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789484424
   Coding: 0101000101000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3B22CAAF63E435138A9-806E
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 A    HW: 5WA 980 556 A
   Component: RV eCompact   H20 0193
   Serial number: FCL-K2006.02.20
   Coding: 02030104E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos.rod
10489856 - No Basic Setting
          B2010 00 [046] - -
          [System not calibrated]
                    Mileage: 24064 km
                    Date: 2090.14.08
                    Time: 21:20:16
   Part No SW: 5WA 035 284 A    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0067
   Serial number: 0000000002VIWP4
   Coding: 023800009068A8209405460071002E07
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: 44D0B1531E1A4AEBFB3-8010 SFD
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3129
   Serial number: E26735112200700
   Coding: 00000888215C4040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 65964CD7B5E053E30CD-8030
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0078
   Serial number: 0000000003VITD5
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D2B24F1B144DD3C29-8016 SFD
0083 - Ethernet Databus
          U1541 00 [040] - Missing Message from Information Electronics
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
                    Reset counter: 11
                    Mileage: 24272 km
                    Date: 2021.07.13
                    Time: 17:56:25
                    13.90 V
0096 - Data Transfer Car2X
          U153F 00 [047] - Certificate Update Failed
                    Reset counter: 12
                    Mileage: 24277 km
                    Date: 2021.07.13
                    Time: 18:01:47
                    14.00 V
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
   #25
DAN COZMIC
Italy
C?ID=441789
HELLO !
is there a way to test or to modify the autoscan? do a long code offline?? a program of some kind that you can see in the various ecu and byte's ? without being hooked 'up to the car i mean.
   #26
hadez16
C?ID=289891
Could anybody give a statement what coding/adaptation definitely is NOT possible due to SFD stuff?
I heard it is possible to change the gateway installation list???
Can the adaptation channel in BCM be changed?
We know already that it is definitely possible to exclude some codings or adaptation from the SFD lock. (e.g. instrument cluster)
   #27
Auto-Scans from upcoming VCDS versions will show which modules have SFD, but I suspect the only way to find out exactly what things are blocked by it within such a module will be via trial and error.
hadez16
C?ID=289891
That is nice.
I was amazed I could change the design adaptation channels in a Golf MK8 Active Info Display in order to activate Golf R Design and so on...
So all this seems to be precised on bit/channel layer and not on "whole unit"-layer.
