VW golf8 my2020 tow bar coding
DAN COZMIC
Italy
C?ID=441789
hello! i have problem with coding the ecs-eletronics towbar module .my mistake is that i haven't done autoscan prior installing the towbar module so therefore i don't know if something has changed. but anyway i don't think that just plugging in the module will change the coding by itself in any module allready present. anyway i've done the autoscan after fitting the module and powered up the car and it shows a lot of errors in different modules. then when i try to code it's rejecting the code due to security issues. now, do i need the 5 numbers security code, or is there something related to the SFD in the latest models VAG?? i've done a 2020 touareg and it worked just fine. after that i've disconnected the module and done the can rewiring as original but i find my self with faults in the 01,03,13 and others that does not clear. any ideas??
the first autoscan is from when i first fitted the module without any coding.
and for the 01 it does not give a long code
DAN COZMIC
Italy
C?ID=441789
Wednesday,07,July,2021,17:49:11:06492
VIN: WVWZZZCDZLW027600   License Plate: GE492EH
Mileage: 23854km-14822mi   Repair Order: GOLF 8 07/2020 MOT.DSR 110KW 1968CC
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 69 6C
          75 A5 D6 D7 8107 C002 C003
VIN: WVWZZZCDZLW027600   Mileage: 23854km-14822miles
69-Trailer -- Status: Not registered 0001
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DSRB)       Labels: None
   Part No SW: 05L 906 022 BE    HW: 05L 907 309 C
   Component: R4 2.0l TDI   H30 9970
   Revision: E3H30---
   Coding: 012504320364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906022BE 006006
   ROD: EV_ECM20TDI01105L906022BE.rod
   VCID: 6B823AEF530465934A1-803E
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:48
                    Engine RPM: 0.00 /min
                    Coolant temperature: 33 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.940 V
                    Drivetrain coordinator: brake fault status: 517
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
                    Voltage terminal 30: 13.000 V
                    Engine status: COENG_READY
25743 - Engine Oil Level Sensing
          P15A5 00 [096] - Implausible Signal
                    Reset counter: 2
                    Mileage: 21904 km
                    Date: 2021.06.12
                    Time: 19:16:10
                    Engine RPM: 991.50 /min
                    Normed load value: 10.2 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 32 °C
                    Ambient air pressure: 750 mbar
                    Voltage terminal 30: 13.960 V
                    Unlearning counter according OBD: 2
                    Fuel consumption: 0.22 l/h
                    Engine oil temperature: 101.0 °C
                    Oil level: minimum value: compensated: 40.336 mm
                    Oil pressure actual value: 174.2 kPa
                    Oil fill level: 61.904 mm
                    Outside temperature sensor 1: B1: raw value: 13.0 °C
                    Fuel temperature sensor 1: B1: raw value: 54.7 °C
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 555     HW: 0GC 300 045 G
   Component: GSG DQ381     H06 3361
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 78A815A31252DE0BB73-802C
   Subsystem 1 - Part No SW: 5WA 713 033 AG    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1033
   Serial number: 20200210000058728394
   Subsystem 2 - Part No SW: 5H0 713 059 Q    HW: 5H0 713 059 Q
   Component: ZSB_SB_Mono    H03 0013
   Serial number: 92478TAU00648
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810500001818490
   Part No SW: 5WA 614 517 BA    HW: 5WA 614 517 A
   Component: ESC           H09 0020
   Serial number: 60430000000903a
   Coding: 34FC2C9022224473527D600006C361866DB658504AC8670800BCA231218FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
   VCID: 0848656362B2AE8BC73-805C
8519 - Implausible Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [047] - -
          [CCan_ACC_Anhalteweg_inv]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:48
8563 - Power Steering Control Module
          U101D 00 [047] - No Communication
          [CCan_EPS_BLW_QBit]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
          C1146 02 [047] - Signal Failure
          [DemSigIntegy]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:57
0294 - Steering Angle Sensor
          B1168 F2 [167] - Not Initialized
          [Swa_init_fail]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 B    HW: 5WA 959 436 B
   Component: Kessy IOBOX   070 0703
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w.rod
   VCID: 53F2820FEB74DD53621-8006
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 007 K    HW: 5WA 907 007 M
   Component: AC Automat    H31 3130
   Coding: 002010019211120010100000101011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001098
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 4FFA8E7FC75CB9B3469-801A
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H01 0002
   Serial number: 00000000000000073258
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001110220022055507
459792 - Databus
          [Databus_error_value_received_Botschaft_BEM_02]
                    Reset counter: 19
                    Mileage: 21957 km
                    Date: 2021.06.12
                    Time: 23:00:07
   Part No SW: 5WA 937 086 P    HW: 5WA 937 086 H
   Component: BCM 37W BOSCH 016 0136
   Serial number: BXJ53F280220940
   ASAM Dataset: EV_BCM37w 005001
   ROD: EV_BCM37w_005_VW38.rod
   VCID: 5EE4633B90B6003BDDF-800A
   Subsystem 1 - Part No SW: 5H1 955 119     HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0041
   Serial number: 907453F0402002203500
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           051 0206
   Serial number: SAY20M03D11H17M13S14
   Subsystem 3 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H05 0007
   Serial number: 92471TBJ001XF
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TBO001H1
   Subsystem 5 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92661TBM00714-------
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 Q    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000026022004220257
65536 - Headlight
          C107E 54 [038] - Missing Calibration / Basic Setting
          [Scheinwerfer keine Grundeinstellung]
   Part No SW: 5WA 919 294 A    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0026
   Serial number: 000015022094630
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3800000 002028
   ROD: EV_EPHBO18VW3800000_VW38.rod
   VCID: 50F88D03DA62A64B5F3-8004
13637426 - Databus
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
13647889 - Databus
          [Bremsensteuergerät - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:48
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Coding: 090318FD0077404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003.rod
   VCID: 4CC09973364A82AB23B-8018
8 Faults Found:
1229 - Control Module Incorrectly Coded
          U1014 00 [175] - -
          [FAULT_CODING_AAG]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
1560 - Databus
          U1122 00 [175] - Implausible Message
          [FAULT_VMM_INCONSISTENCY_ACC]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
2055 - Databus
          [FAULT_ALP_STEERING_WHEEL_INIT]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:48
2065 - Databus
          U1122 00 [046] - Implausible Message
          [FAULT_TSK_HANDSHAKE]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
209153 - Databus
          U1123 00 [175] - Received Error Message
          [FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:55
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM_ERROR]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
0577 - Databus
          [FAULT_VZM_SYSTEM_STATUS_ERROR]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:47
0723 - Databus
          [FAULT_BV_RELEVANT_ERROR]
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:55
   Part No SW: 5WA 959 655 A    HW: 5WA 959 655 A
   Component: AirbagVW40    007 0523
   Serial number: 000000003C0DKR6
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
   ROD: EV_AirbaVW40SMEVW38X_VW38.rod
   VCID: 55F67C17E580C3638C5-8000
   Subsystem 1 - Part No SW: -----------    HW: 480 402 702 20
   Component: SideSensor_Dr  002 6149
   Serial number: 35100011A63007B2926O
   Subsystem 2 - Part No SW: -----------    HW: 480 402 602 20
   Component: SideSensor_Pr  002 6149
   Serial number: 35200012A62EBD63F7FT
   Subsystem 3 - Part No SW: -----------    HW: 480 000 302 20
   Serial number: 35700000000D2309254A
   Subsystem 4 - Part No SW: -----------    HW: 480 000 602 20
   Serial number: 35800000000C820D564N
   Subsystem 5 - Part No SW: -----------    HW: 480 402 402 20
   Component: FrontSensor_D  003 614A
   Serial number: 3550001BEF25F1E5679W
1075462 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
                    Reset counter: 4
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:53
1075463 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
                    Reset counter: 4
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:53
1075465 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
                    Reset counter: 4
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:53
1075461 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
                    Reset counter: 4
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:53
1075464 - Databus
          [NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
                    Reset counter: 4
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:53
   Part No SW: 5H0 920 340     HW: 5H0 920 340
   Component: KOMBI         237 1400
   Coding: 04A4004063840008018062032000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 002029
   ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
   VCID: 5F9A5E3F97BC0933D69-800A
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 16
                    Mileage: 21283 km
                    Date: 2021.06.04
                    Time: 16:31:34
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 16
                    Mileage: 21283 km
                    Date: 2021.06.04
                    Time: 16:31:34
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 42
                    Mileage: 21283 km
                    Date: 2021.06.04
                    Time: 16:31:34
   Part No SW: 5WA 907 530 B    HW: 5WA 907 530 B
   Component: GW2020 High   734 7068
   Revision: --------    Serial number: 150160900104240
   Coding: 0000808D0700000000000000010301325301600F02000300030100000001010000000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 47CAA65F2F2C61F30E9-8012
   Generator:
   Component: 2-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 2165424005
   Subsystem 3 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440071354203419
   Subsystem 4 - Part No SW: 5H0 959 542 D    HW: 5H0 959 542 D
   Component: KLR_JSS_1Zone  076 0019
7348481 - invalid data record
          B2005 00 [109] - -
          [Data_set_invalid_NV-EM]
                    Mileage: 23329 km
                    Date: 2021.06.27
                    Time: 20:29:56
3145728 - Databus
          U1124 00 [047] - Additional Installations Detected
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:46
1049121 - Unknown Error Code
          U15DE 00 [032] - -
          [Data_bus_driver_assistance_systems_no_communication]
                    Fault Frequency: 0
                    Reset counter: 0
2097338 - Unknown Error Code
          U1646 00 [040] - -
          [Antenna_control_module_1_no_communication_vlan]
                    Fault Frequency: 245
                    Mileage: 21283 km
                    Date: 2021.06.04
                    Time: 14:55:57
   Part No SW: 5WA 909 059 E    HW: 3Q0 909 059 A
   Component: EBKV          H06 0092
   Serial number: BPA085120220013
   Coding: 1002C100730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
   ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
   VCID: 52FC870BD46ED45B697-8006
107024 - Unknown Error Code
          U14E4 00 [032] - -
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 20000030846012
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323CE78BB4AEF45B497-8066
13637381 - Databus
          [Errorvalue Messagecounter ESP_21]
                    Reset counter: 44
                    Mileage: 21866 km
                    Date: 2021.06.12
                    Time: 17:36:38
                    Result lock conditions: invalid
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: Not operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: OFF
                    Clamp 15: OFF
                    Clamp 15 Status: valid
                    Remote Start: not active
                    Driver door: For
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c timeout
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 11.6 V
                    UMotorBridge: 6.3 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition E2E clamp status: Condition met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition not met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition not met
                    Lock condition E2E distance pulse: Condition not met
                    Lock condition difference distance pulse: Condition not met
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 00000403447890
   Coding: 015892400000A0508803010101010000000000212100000000000000215000
   VCID: 59EE70278998E703A8D-800C
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TAS18196
   Coding: 003B03208200040000001000
   VCID: 49CEA0673938978318D-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 C    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000038416675
   Coding: 110000
                    Reset counter: 4
                    Mileage: 23854 km
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1040
   Serial number: 00085458
   Coding: 0000000000000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 4DC69477CD508BA3345-8018
5423 - Steering Angle Sensor
          B1168 F2 [175] - Not Initialized
                    MonitorId: 01 1F
                    HybridDriveReady: 00000000
                    IgnitionEnabled: 00000000
                    Communication control: 00000000
                    Diagnostic session: 00000001
                    ComM_ModeType: 00000000
                    NM_Signal_Fahrbereit: 00000000
                    NM Signal V gr 7: 00000000
                    System status: 1
                    ECU Status: 1
                    HWLib Status: 0
                    Support power reduction: 0.0 %
                    Voltage terminal 30: 12.344 V
                    Temperature circuit board: 29 °C
                    Output stage temperature: 29 °C
                    Rackposition: 0.00 mm
                    Rackspeed: 0.38 mm/s
                    pinion angle dependent amplitude factor: 0 °
                    Steering wheel angle: 0.375 °/s
                    SupplierFreezeFrameData: 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TAR07795
   Coding: 003B01208E00040000801000
   VCID: 48C8A56322326E8B073-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 C    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000038492325
   Coding: 090000
                    Reset counter: 4
                    Mileage: 23854 km
   Part No SW: 5H0 035 816     HW: 5H0 035 816
   Component: MU-O-ND-EU    H56 1668
   Serial number: WG8LGM120220000
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: 649051D3BEDA2AEB0BB-8030
   No subsystems:
   Subsystem 2 - Part No SW: V03 959 806 MG    HW: -----------
   Component: EU 2019/30     --- 202
6725 - Unknown Error Code
          U1745 00 [008] - -
          [rear_view_cam_ethernet_corrupt_signal]
                    Reset counter: 11
                    Mileage: 21514 km
                    Date: 2021.06.08
                    Time: 07:48:19
                    Voltage terminal 30: 12.3 V
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789484424
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3B22CAAF63E435139A1-806E
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 A    HW: 5WA 980 556 A
   Component: RV eCompact   H20 0193
   Serial number: FCL-K2006.02.20
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos.rod
10489856 - No Basic Setting
          B2010 00 [046] - -
          [System not calibrated]
13705507 - Databus
          U1121 00 [109] - Missing Message
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
                    Mileage: 217856 km
                    Date: 2072.15.24
                    Time: 00:12:16
13706006 - Databus
          U1123 00 [047] - Received Error Message
          [Errorvalue-monitoring VMM_02.VZM_Systemstatus]
                    Mileage: 941312 km
                    Date: 2078.14.16
                    Time: 08:00:16
   Part No SW: 5WA 035 284 A    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0067
   Serial number: 0000000002VIWP4
   Coding: 023800009068A8209405460071002E07
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: 44D0B1531E1A4AEBEBB-8010
0080 - Databus
          [Ethernet Databus missing message - Transceiverbox]
                    Mileage: 22224 km
                    Date: 2021.06.15
                    Time: 19:57:31
                    Voltage terminal 30: 12.4 V
1191168 - Ethernet Databus Branch 2
          U122D 00 [008] - No Communication
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:48
                    Ethernet counter checksum error: branch 2: 0
                    Ethernet counter connection interruptions: branch 2: 0
          U1400 00 [008] - -
          [Functional restrictiondue to insufficient voltage]
                    Voltage terminal 30: 5.5 V
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3129
   Serial number: E26735112200700
   Coding: 00000888214C4040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 0
                    Mileage: 23854 km
                    Date: 2021.07.07
                    Time: 00:05:51
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 65964CD7B5E053E31C5-8030
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0078
   Serial number: 0000000003VITD5
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D2B24F1B144DD3D21-8016
0083 - Unknown Error Code
          U1541 00 [032] - -
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
0096 - Unknown Error Code
          U153F 00 [096] - -
          [Car2X_Certificates_Update_failed]
1637905 - 5Ghz WiFi Antenna in Roof Module
          B18FE 11 [032] - Short to Ground
End----------(Elapsed Time: 01:38, VBatt start/end: 12.7V/12.7V)-----------
DAN COZMIC
Italy
C?ID=441789
this one is after I've eliminated the towbar module and got back as original but with all the faults that does not clear.
Thursday,08,July,2021,12:18:35:06492
Mileage: 23859km-14825mi   Repair Order: DOPO RIMOZIONE CENTRALINA TRAILER 2 PARTE
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 6C 75
VIN: WVWZZZCDZLW027600   Mileage: 23859km-14825miles
   Revision: E3H30---
23753 - No Communication with Towing System Control Module (J345)
          U1003 00 [039] - -
          [Towing recognition control moduleNo Communication]
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:09:37
                    Coolant temperature: 58 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 11.620 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
Readiness: 0 0 0 1 1
          U0433 00 [047] - -
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:09:37
   Air quality sensor:
   Coding: 0040010011
1560 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:09:33
2068 - Databus
          [FAULT_TSK_IRREV_ERROR]
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:09:33
   Generator:
   Coding: 110000
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:09:38
   Coding: 090000
   No subsystems:
          B2010 00 [046] - -
                    Mileage: 220416 km
                    Date: 2080.13.06
                    Time: 01:04:00
13705507 - Databus
          U1121 00 [047] - Missing Message
                    Mileage: 220416 km
                    Date: 2080.13.06
                    Time: 01:36:00
End----(Elapsed Time: 01:30, VBatt start/end: 11.5V/11.5V. VIgn 11.6V)-----
Have you tried clearing faults directly in the ECU?
PS: Yes, SFD is almost certainly going to be a problem with this retrofit.
DAN COZMIC
Italy
C?ID=441789
yes i've tried directly to the various ecu's but nothing to do.they keep turning back.
question if i may, cause i haven't found any thread related.
does VCds works with SFD or it's just an ODIS thing for now? is there a procedure to do? i've just got vw clearence for sfd as a workshop.
NEtech
Denmark
C?ID=56995
Normally it is possible on Golf 8 platform, at least with Westfalia controller, I don't know how it is with ECS..
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 111 23456
[Save]
[Close VCDS]
Start VCDS
Use battery charger, therefor front hood open!
[10] > 0040010111 (First SA 20103)
[13] > 098318FD0077404512474000000040054E4020000000000000000000000000 (First SA 20103)
[6C] > 02030104E43000
[A5] > 00000888215C4040109E00001020002000418000000000000000000000000000 (First SA 20103)
[01] > 012504320374150830080000000000000000000000000000
I have not tested this engine, if message is: Need Security Access (SA), then not possible.
[19] and [09] should be SFD, so no change
Ignition OFF, wait 30sec.
Ignition On
But normally should be okay, even [01] [09] [19] is not possible.
Drive on highway road.
Delete all DTC
Ignition On
Check DTC's
But of course, an original VW tow bar, done online with odis, is most optimal.
But factory cannot deliver Tow bars controllers, no IC available :facepalm:
DAN COZMIC
Italy
C?ID=441789
so! i have tried to do the coding with the beta version.
it works just fine with the SFD and i manage to unlock the 09 and the 19.
in 19 i've done the coding without problems BUT!!
and here is my problem and sort of emergency as i have to give the car to costumer tomorrow.
in the 09 central electronics the SFD acces worked just fine but the 07-CODING doesn't turn on .it stays grey.and i can't do the coding.
i haven't drove 'it on the road i will in the morning just to see if it clears the dtc's.
as most of the dtc's are related to databus i'm thinking that the problem lies within 09.
for the 01 engine no long code available
03 abs no long code available
after i've done most of the coding i did a key cycle on/off and after that in entering the 09 pop'ut up the Uds not available and if i let vcds chosse it will not show the SFD option but if i chosse manualy the ROD it will turn available again.
that's most of the info i have right now.
if you have any ideas that will be great!
Friday,09,July,2021,19:05:42:06492
VCDS Version: 21.7.1.0 (x64)  HEX-V2 CB: 0.4548.4
Data version: 20210706 DS329.0
Mileage: 23859km-14825mi   Repair Order: dopo la prima codifica con versione beta
   Revision: E3H30---    CVN: 54E0D639644B2C53FDCF42ED644B2C5343FB2DAA
   VCID: 6B823AEF530465935A9-803E
   VINID: 9E69EAAAA4D4A9C9C008718000D43C6A25
17156 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
                    Coolant temperature: 28 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.400 V
          U0416 00 [039] - -
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:54
                    Voltage terminal 30: 12.420 V
          U1003 00 [036] - -
          [Trailer recognition control moduleNo communication]
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:57:36
                    Coolant temperature: 52 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.960 V
   CVN: 60475D66
   ROD: EV_TCMDQ381062.rod
   VCID: 78A815A31252DE0BA7B-802C
41691 - Unknown Error Code
          P082B 00 [044] - -
          [Selector lever transmission range display Supply voltage]
                    Reset counter: 10
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 18:26:29
                    Coolant temperature: 32 °C
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -100 Nm
                    Control Module temperature: 31 °C
                    Accelerator pedal position: 14.1 %
                    DTC memory status: 8
   VCID: 0848656362B2AE8BD7B-805C SFD
          U0433 00 [047] - -
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:57:37
          [CCan_EPS_BLW_QBit]
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
          [DemSigIntegy]
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:05
          [Swa_init_fail]
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
   ROD: EV_Kessy37w_003.rod
   VCID: 53F2820FEB74DD53729-8006
   VCID: 4FFA8E7FC75CB9B3561-801A
   Air quality sensor:
          B10CD 00 [008] - -
          [Function limitation due to energy management 03]
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:58:38
                    Voltage terminal 30: 12.0 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
   VCID: 5EE4633B90B6003BCD7-800A SFD
15403264 - Release / Enable Active
          B184C 00 [047] - -
          [Freischaltung aktiv]
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 18:30:49
   Coding: 0040010111
   VCID: 50F88D03DA62A64B4FB-8004
13637426 - Databus
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 18:50:32
13647889 - Databus
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 18:50:32
   Coding: 09031CFD0077404512474000000040054E4020000000000000000000000000
   VCID: 4CC09973364A82AB333-8018
9 Faults Found:
          U1014 00 [175] - -
          [FAULT_CODING_AAG]
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
1560 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:57:34
2055 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
2065 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
2068 - Databus
          U1123 00 [044] - Received Error Message
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:57:34
209153 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:03
2101 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
0577 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:55
0723 - Databus
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:03
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 55F67C17E580C3639CD-8000 SFD
1075462 - Databus
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:01
1075463 - Databus
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:01
1075465 - Databus
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:01
1075461 - Databus
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:01
1075464 - Databus
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:54:01
   VCID: 5F9A5E3F97BC0933C61-800A SFD
   Coding: 0000808D0700000000000000010301725701600F02000300030100000001010000000000000000000000000000000000
   VCID: 47CAA65F2F2C61F31E1-8012 SFD
   Generator:
3145728 - Databus
          [Multiple_plug_CAN_and_Ethernet]
                    Mileage: 23859 km
                    Date: 2021.07.09
2097338 - Ethernet Antenna Module
          U1646 00 [046] - No Communication
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 13:05:00
          B184C 00 [047] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 18:17:05
   VCID: 52FC870BD46ED45B79F-8006 SFD
107024 - Transmission Control Module
          U14E4 00 [034] - Received Malfunction Value
   VCID: 323CE78BB4AEF45B59F-8066
   VCID: 59EE70278998E703B85-800C
   VCID: 49CEA06739389783085-801C
   Coding: 110000
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.08
                    Time: 12:57:34
   VCID: 4DC69477CD508BA324D-8018
          [DTC_RACKPOS_NOINIT]
                    MonitorId: 01 1F
                    System status: 1
                    ECU Status: 1
                    HWLib Status: 0
                    Voltage terminal 30: 11.875 V
                    Temperature circuit board: 26 °C
                    Output stage temperature: 26 °C
                    Rackspeed: 0.00 mm/s
                    Steering wheel angle: 0 °/s
   VCID: 48C8A56322326E8B17B-801C
   Coding: 090000
                    Reset counter: 5
                    Mileage: 23859 km
   VCID: 649051D3BEDA2AEB1B3-8030 SFD
   No subsystems:
   VCID: 3B22CAAF63E435138A9-806E
          B2010 00 [046] - -
13705507 - Databus
                    Mileage: 220416 km
                    Date: 2080.13.09
                    Time: 15:44:00
13706006 - Databus
                    Mileage: 220416 km
                    Date: 2082.14.24
                    Time: 27:56:16
   VCID: 44D0B1531E1A4AEBFB3-8010 SFD
          U1400 00 [008] - -
1123173 - Databus
                    Reset counter: 0
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 17:53:58
   VCID: 65964CD7B5E053E30CD-8030
   VCID: 43D2B24F1B144DD3C29-8016 SFD
0096 - Data Transfer Car2X
          U153F 00 [047] - Certificate Update Failed
                    Reset counter: 5
                    Mileage: 23859 km
                    Date: 2021.07.09
                    Time: 14:20:54
                    11.30 V
End----------(Elapsed Time: 01:32, VBatt start/end: 12.5V/12.5V)-----------
VWT6
Finland
C?ID=295527
All done via adaptations in these newer BCMs?
DAN COZMIC
Italy
C?ID=441789
i'm not familiar with the adaptations just using long code were is available but i will giveìit a try tomorrow
Yup. This control module doesn't have a coding string:
I suppose the Adaptation channel the OP is looking for is:
ENG122979-ENG141968 -- Networking - Anhaengeranschlussgeraet (not installed / installed)
DAN COZMIC
Italy
C?ID=441789
hello to everyone!
so, after doing some little changes i'm left with the mil on for the TRAVEL ASSISTANT and the ACC is not availabel. this is my last Autoscan.
any ideas of what could cause the fault?
and the 6C " no basic settings"
Saturday,10,July,2021,13:52:48:06492
Mileage: 23927km-14867mi   Repair Order: con travel assistant mil on
VIN: WVWZZZCDZLW027600   Mileage: 23927km-14867miles
   CVN: 60475D66
   Air quality sensor:
   Coding: 0040010111
   Coding: 09831CFD0077404512474000000040054E4020000000000000000000000000
0730 - Databus
          [FAULT_TIMEOUT_ARA_STATUS_01]
                    Mileage: 23927 km
                    Date: 2021.07.10
                    Time: 13:48:18
   Coding: 0000808D0700000000000000010301725B01600F02000300030100000001010000000000000000000000000000000000
   Generator:
                    Mileage: 23927 km
                    Date: 2021.07.10
                    Time: 13:35:03
          U14E4 00 [032] - Received Malfunction Value
   Coding: 110000
   Coding: 090000
   No subsystems:
   Coding: 0101000101000000
   Coding: 02030104E43000
          B2010 00 [046] - -
                    Mileage: 482560 km
                    Date: 2084.13.22
                    Time: 20:48:16
   Coding: 00000888215C4040109E00001020002000418000000000000000000000000000
End----------(Elapsed Time: 01:28, VBatt start/end: 12.4V/12.4V)-----------
NEtech
Denmark
C?ID=56995
Use the coding I posted.
Or do not use Byte 02 Bit 2 in [13-ACC]
Is there a problem with [6C], besides there is an DTC?
Delete DTC in [6C], ign OFF
Drive a trip and use rear camera.
DAN COZMIC
Italy
C?ID=441789
[6C] working fine.no problem.just that dtc always present which doesn't clear, even trying deleting from 6c.
there were other's dtc's that wasn't clearing but i used another diagnostic tool and i managed to clear the most of them.VCDS was showing them always present.
i haven't tried without using Byte2 but i will try it as soon i have the car back.
the [69] is working fine with all the function and the cluster is showing the trailer when attached and disengage the parking sensors.
IWMTom
C?ID=313572
hello to everyone!
   CVN: 60475D66
   Air quality sensor:
   Coding: 0040010111
0730 - Databus
                    Mileage: 23927 km
                    Date: 2021.07.10
                    Time: 13:48:18
   Generator:
                    Mileage: 23927 km
                    Date: 2021.07.10
                    Time: 13:35:03
   Coding: 110000
   Coding: 090000
   No subsystems:
          B2010 00 [046] - -
                    Mileage: 482560 km
                    Date: 2084.13.22
                    Time: 20:48:16
That fault won't clear until you calibrate the reversing camera.
DAN COZMIC
Italy
C?ID=441789
it's something that i can do or it needs target like the Adas systems?
IWMTom
C?ID=313572
Whilst I can't confirm it, I would be very surprised if the procedure was any different to the Mk7. On that assumption, you require the appropriate calibration board(s).
NEtech
Denmark
C?ID=56995
5 out of 8 Autoscans I have from Golf 8, has this DTC in [6C], so I don't think it is important, or there is an TPI explaining it.
massimo23
Ireland
C?ID=364379
Yes the DTC error B201000 "no basic setting" in [6C] is present in the Ignore list in the TPI: 2058071/6.
