2017 Audi Q3 Rear View Camera
kjrehsi
C?ID=287868
Hi Guys,
This is my second attempt at fitting a RVC to a Q3. My father changed from a standard 1.4 TFSI to a 2.0 TDI Quattro and the new Q3 didn't come with a RVC so it only made
sense to remove the previous retrofit and add it to the new Q3.
My first retrofit was trouble free and everything worked as it was meant to. I used a premade harness from a reputable company.
Now I repeated the install exactly the same way as I did in the old Q3 but this time hit a brick wall.
Basically VCD scan is showing the following error
Tuesday,06,July,2021,22:06:28:14442
VIN:    License Plate: Q3 CAMERA
                Address 6C: Back-up Cam.       Labels: 4H0-907-441.clb
Control Module Part Number: 8U0 907 441     HW: 8U0 907 441
  Component and/or Version: SG Rueckfahrkamera  0031
           Software Coding: 1000015
            Work Shop Code: WSC 02391 785 00013
                      VCID: 76B5E4D674C4BB1BA5F-8022
03006 - Back-up Camera System not calibrated
                    Reset counter: 69
02203 - Audio / Video Input 1
                    Reset counter: 69
                    Mileage: 51047 km
                    Date: 2021.07.06
                    Time: 22:05:49
                        Reverse OFF
                    Count: 3
02203 - Audio / Video Input 1 - This being the main issue preventing the camera to display video
I have checked the wiring thrice, connections are intact and I can't see any visible broken wire :confused:
This is the coding I performed after the install and again it is no different to the one I applied to the old Q3
Address 19 (CANbus unit) -> Installation list -> 6C Reverse Camera [SELECT]
Address 5F (For vehicles with navigation +) -> Long coding -> Byte 7 -> set Bit 1 to 1
Address 6C (reverse camera) -> 1020015 = APS+, without automatic trailer coupling
The new car has MMI-3G.
On putting the car on reverse the OPS image comes on MMI with option for 'Rear View'. When I click on 'Rear View' it just shows a dark image???
Now before I rip the interior out AGAIN and try to trace a broken video cable, I want to make sure the coding is correct?
If the wiring is not the issue then I may resort to getting a new camera module :( What do you suggest guys?
kjrehsi
C?ID=287868
Here is the full scan for the new Q3
Wednesday,07,July,2021,23:26:05:14442
VIN: WAUZZZ8U9JR002123   License Plate:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 5F 62
          6C 6D 72
VIN: WAUZZZ8U9JR002123   Mileage: 51210km-31820miles
Address 01: Engine (J623-DFUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 FL    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 3201
   Revision: 8EH20---
   Coding: 02250012043701082000
   Shop #: WSC 00049 770 00116
   ASAM Dataset: EV_ECM20TDI01104L906016FL 004003
   ROD: EV_ECM20TDI011_AU21.rod
   VCID: 78A9EAEE7250CD6BB73-802C
   Part No SW: 0BH 300 013 D    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5302
   Revision: 00H11V01
   VCID: 2517F39A95628083DC5-8070
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CJ
   Component: ESC-EBC460iV1 H12 0013
   Serial number: A01H7WA
   Coding: 21F124A1C920C36E2078840224C693C304345700508B4885
   Shop #: WSC 00049 770 00150
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71BFD7CA112A9C2370D-8024
   Part No SW: 8U0 820 043 H    HW: 8U0 820 043 H
   Component: E87  Klimavoll      0220
   Revision: 00H05000    Serial number: 8U0820043H
   VCID: 363524D63444FB1B65F-8062
   Part No SW: 8X0 907 063 AK    HW: 8X0 907 063 AF
   Component: BCM PQ35  M   113 0827
   Revision: AB113821
   Coding: 0E000A2CA817F1C0201849C02184014C43F327AA216F812BE408878400C1
   Shop #: WSC 46606 001 104857
   VCID: 0557931A3522A083BC5-8050
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 170330  H38 0090
   Serial number:         170425124206
   Coding: 0047F7
   Serial number: 62807490
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AK    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0090
   Revision: 11001001    Serial number: 61031714201501
   Coding: 88C30F
   ASAM Dataset: EV_EPHVA18AU21X0000 003009
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 0F7BB13267DEEAD3069-805A
   Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
   Component: AirbagVW-AU10 H12 0910
   Serial number: 003S0R0HTGC3
   Coding: 30523232333030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 48C95A2E42307DEB073-801C
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME4F351543ZZZ-
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME54031543ZZZD
   Serial number: 3516KSME5F131543ZZZQ
   Serial number: 3526KSME28513D42ZZZS
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME373C2242ZZZ.
   Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
   Revision: FF010018    Serial number: 20170512100280
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 0059820E2A8085AB8F3-8054
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 27 04 2017  C0044847
   Part No SW: 8U0 920 990 M    HW: 8U0 920 990 M
   Component: KOMBI_COLOUR  H04 0430
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 47CB59124F2E72930E9-8012
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P170044    Serial number: 4441P17430000B
   Coding: FBCF1A5A000108610353
   VCID: 117FB74A716AFC2310D-8044
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 44137G53095831428881
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 170315000000000007A0
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00028.03.17
   Coding: 0001
   VCID: 52FD7846B46CC73B697-8006
   Component: IMMO          H04 0430
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011806205C01000000
   VCID: 52FD7846B4ECC73B697-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 295    3501
   Revision: 00H22000
   VCID: 40D9420E668045ABCF3-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011806205E01000000
   VCID: 51FF774AB1EABC2350D-8004
Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0031
   Coding: 08AE00102B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
   ROD: EV_HeadlRegulLEDAFSPt.rod
   VCID: 38292AEE32D00D6B773-806C
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02500
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02500
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E02500
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E02500
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109DM0H5021025
   Coding: 010105020100000002
   VCID: 2D070BBACD12B8C3145-8078
   Part No SW: 8U1 035 670 F    HW: 8U1 035 670 E
   Component: H-BNT-EU      H43 1072
   Revision: --------    Serial number: 486D/0HB004145
   Coding: 0E010106000AE1EB05800F3600000001000000000000000000
   VCID: 392F2FEA095A146388D-806C
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H43 0018
   Serial number: AUZ8ZDHCR01MAY$
   Subsystem 3 - Part No: 8R0 060 961 G
   Component: CD-Database  9040
                    Reset counter: 71
                    Mileage: 51215 km
                    Date: 2021.07.07
                    Time: 23:24:19
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010006200001000000
   VCID: 4FFB7132A7DEAAD3469-801A
   Part No SW: 8U0 907 441     HW: 8U0 907 441
   Component: SG Rueckfahrkamera  0031
   Revision: --H11---    Serial number: 525 PA8JC7H060
   Coding: 1020015
   Shop #: WSC 02391 785 00013
                    Reset counter: 71
                    Reset counter: 71
                    Mileage: 51215 km
                    Date: 2021.07.07
                    Time: 23:24:11
                        Reverse OFF
                    Count: 3
   Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
   Component: HDSG-Modul    H02 0552
   Revision: 15001001    Serial number: 108700270
   Coding: 183307C002
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 3D273BFA1DF22843A45-8068
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H08 0415
End----------(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.1V)-----------
kjrehsi
C?ID=287868
Ok think I may have forgotten to code 10-Park/Steer Assist :rolleyes:?? Going to check in the morning
kjrehsi
C?ID=287868
No luck with setting Camera option in Module 10 Park/Steer assist :(
kjrehsi
C?ID=287868
Well guys i have checked the wiring again today and everything was fine.
I am now getting a short to ground error :(
Has the camera gone?
kjrehsi
C?ID=287868
For those who were/are interested I finally resolved the issue 😃
It was a faulty camera which probably short itself when I was disconnecting from the previous car 🤷‍♂️
Got a replacement camera with the hope it was the issue as a new module would have costed alot.
Luckily a new camera did the trick :)
Only thing to resolve now is recalibrating the camera.
