Seat Ibiza 2017 ABS Coding Lost
gary1234
England
C?ID=375602
Need long coding for abs
Part No SW: 2Q0 614 517 AA HW: 2Q0 614 517 N
Component: ESC_base_vFGS H22 0222
Serial number: 08508138170511
Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00049 770 00114
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 6D863C0C5D188893545-8038
gary1234
England
C?ID=375602
Tuesday,06,July,2021,16:15:38:38767
VIN: VSSZZZKJZJR015758   License Plate: PE67KVL
Mileage: 54098km-33614mi   Repair Order:
Chassis Type: KJ-SE27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: VSSZZZKJZJR015758   Mileage: 54098km-33614miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AP    HW: 04C 907 309 BE
   Component: R3 1.0l MPI   H20 3983
   Revision: 33H20000
   Coding: 01110012020405080000
   Shop #: WSC 00049 770 00138
   ASAM Dataset: EV_ECM10MPI01104C906057AP 001001
   ROD: EV_ECM10MPI01104C906057AP.rod
   VCID: 73B22A743B3C5E63821-8026
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:29
                    Engine RPM: 998.00 /min
                    Normed load value: 50.6 %
                    Coolant temperature: 43 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.489 V
                    selected gear-Bits 0-7: 0
2737 - Throttle Actuator (G186)
          P1558 00 [167] - Electrical Malfunction
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:29
                    Engine RPM: 995.00 /min
                    Normed load value: 50.2 %
                    Engine torque: 19.0 Nm
                    Fuel level: 11.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:30
                    Voltage terminal 30: 14.512 V
                    Engine torque: 17.7 Nm
                    Fuel level: 11.00 l
Readiness: 1110 0001
0887 - Control Module
          C104A F0 [008] - Incorrect VIN
                    Reset counter: 202
                    Mileage: 53838 km
                    Date: 2020.06.13
                    Time: 00:00:18
0896 - Coding invalid
          U10DA 00 [009] - -
          [VarCodVinMismatch]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:13:22
0883 - Control module not coded
          U1013 00 [137] - -
          [VehicleConfigUncoded]
                    Reset counter: 162
                    Mileage: 53838 km
                    Date: 2020.06.13
                    Time: 00:09:20
0797 - Rear Left Wheel Speed Sensor
          C101C 4A [137] - Incorrect component(s) installed
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
0798 - Rear Right Wheel Speed Sensor
          C101D 4A [137] - Incorrect component(s) installed
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
   Part No SW: 6F2 820 045 F    HW: 6F2 820 045 F
   Component: SG_AC_Manuell H01 0202
   Coding: 010100000800010011000400020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_SE27.rod
   VCID: 270A0E24BF6462C3EE9-8072
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:25
                    Refrigerant pressure: 1.0 bar
                    Outside temperature: 19.5 °C
                    Temperature downstream of evaporator: 21.3 °C
                    System run time-Engine running time: 64 s
                    System run time-Terminal 15 on: 70 s
                    Engine RPM: 997 /min
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H96 0914
   Serial number: 06001715200101
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77AA1E642F443243BE9-8022
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000014152119
   Coding: 1D000C
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000013390218
   Coding: 05000C
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600100FF8728749C8145004087
   VCID: 3E24CB4040FEC30BBDF-806A
8 Faults Found:
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 56 °C
0815 - Databus
          [FAULT_ESP_WEGIMPULS_HL_ERROR]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:49
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:49
0855 - Databus
          [FAULT_EGO_FZG_GIERRATE]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
0854 - Databus
          [FAULT_EGO_FZG_LAENGSBESCHLEUNIGUNG]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
0863 - Databus
          [FAULT_ESP_QBIT_WEGIMPULS]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    Voltage terminal 15: 14.3 V
196808 - Databus
          [VDY_VEH_YWR_NOT_AVAIL]
                    Reset counter: 221
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
   Part No SW: 5QF 959 655 A    HW: 5QF 959 655 A
   Component: Airbag VW22   006 0498
   Revision: --------    Serial number: 003SEPACXZD1
   Coding: 88CCC0C000000000585400CF008800000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 54F089E8DE72395B7BB-8000
   Subsystem 1 - Part No SW: -----------    HW: 454 002 805 17
   Serial number: 35700000000436E8F42S
   Subsystem 2 - Part No SW: -----------    HW: 454 002 305 17
   Serial number: 3580000000084A6DB52W
   Subsystem 3 - Part No SW: -----------    HW: 454 800 805 17
   Serial number: 3510090F1B00E000000G
   Subsystem 4 - Part No SW: -----------    HW: 454 800 805 17
   Serial number: 3520001E4B00E000000B
   Subsystem 5 - Part No SW: -----------    HW: 454 800 805 17
   Component: FrontSensor_D  307 0189
   Serial number: 349001D62FC0F000000.
          B13BC F2 [137] - No function
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:30
1060614 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:35
1060615 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:35
1060617 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 182
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:35
   Part No SW: 6F0 920 940     HW: 6F0 920 940
   Component: KOMBI         206 0450
   Coding: 24A4010021800600018822011000000000000000
   Shop #: WSC 26265 005 1048576
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_AU27.rod
   VCID: 649059288ED2C9DB0BB-8030
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
                    Date: 2020.06.04
                    Time: 21:31:54
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:30
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H96 0914
   Coding: 030100046F086400E8000040000F00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_SE27.rod
   VCID: 6FBA260457147A83669-803A
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000H0750230517
   Coding: 002000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1000411D
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 H    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6023
   Serial number: 0030870CB3H1533
   Coding: 00000000000000000001020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 008014
   ROD: EV_SteerAssisTRWG4LMQBA0_008.rod
   VCID: 3828DD5862DAFD3B773-806C
13 Faults Found:
10494976 - Databus
          [DEM_WHEEL_SPD_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    Engine RPM: 1008 /min
                    System status: Driving mode
                    Terminal 15 status: On
                    Voltage terminal 30: 14.52 V
                    Power steering current consumption: 0.5 A
                    max.value: 14.4 A
                    End stage temperature: 28 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 32 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
10535168 - Databus
          [DEM_CAN_YAW_RATE_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
                    Engine RPM: 1018 /min
                    Voltage terminal 30: 14.55 V
                    max.value: 14.4 A
                    Engine angle: 32 °
10535424 - Databus
          [DEM_CAN_LONG_ACCEL_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
                    max.value: 14.4 A
                    Engine angle: 32 °
10535680 - Databus
          [DEM_CAN_LAT_ACCEL_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:31
                    max.value: 14.4 A
                    Engine angle: 32 °
10536448 - Databus
          [DEM_WHEEL_PULSES_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
10624768 - Databus
          [DEM_MOTOR_TORQUE_QBIT_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    Engine RPM: 1017 /min
                    max.value: 14.4 A
                    Engine angle: 32 °
10625024 - Databus
          [DEM_CAN_WHEEL_PULSE_RL_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
10622976 - Databus
          [DEM_CAN_WHEEL_PULSE_RR_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    Engine RPM: 1007 /min
                    Voltage terminal 30: 14.50 V
                    max.value: 14.4 A
                    Engine angle: 32 °
10624256 - Databus
          [DEM_VEH_MOT_RL_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
10624512 - Databus
          [DEM_VEH_MOT_RR_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
11143680 - Databus
          [DEM_MOTOR_TORQUE_NOMINAL_QBIT_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
11143936 - Databus
          [DEM_MOTOR_TORQUE_SUM_INERTIA_QBIT_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
11144192 - Databus
          [DEM_MOTOR_TORQUE_THRUST_QBIT_INVALID_FAULT]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:32
                    max.value: 14.4 A
                    Engine angle: 32 °
   Part No SW: 6F0 035 869     HW: 6F0 035 869
   Component: MU-E-D-ER     052 7305
   Serial number: 20051700020868
   Coding: 04720000BE00000011110101018008002F0000860000010000
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 6B823214630C86A34A1-803E
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:22
                    Voltage terminal 30: 14.6 V
                    BAP-BAP_Function_ID: 00
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 181
                    Mileage: 54098 km
                    Date: 2020.07.06
                    Time: 00:09:22
End----------(Elapsed Time: 00:41, VBatt start/end: 13.5V/13.5V)-----------
Hi and welcome. I'm not sure who can build a coding for this; this is not an ABS we see very often.
Curious: What was done to this car that made the ABS lose its coding? Have any parts been replaced?
gary1234
England
C?ID=375602
Hi fitted a used instrument cluster and coded it on line using odis forgot to scan with vcds before fitting unit
Have tried coding abs with odis but it keeps failing
have also tried these codings I found on line but get error 31 request out of range
Address 03: ABS Brakes (J104) Labels: None
Serial number: 08500310170903
Coding: 510D4B5715478AB2D203A81D24DC42A649124D26224A242444541254452442659248B26444522424222A482AA249D6427D926B42BE
Shop #: WSC 00049 770 00112
ROD: N/A
VCID: 6DD674CFBC5A102D6E-8038
Serial number: 08508561170511
Coding: 510D4C5735428AB13204AC1B24DE42A649124D26224A242444541254452442659248B26444522424222A482AA249D6427D926B42BE
Shop #: WSC 00049 770 00135
ROD: N/A
VCID: 6DDB277ABCE6C92932-8038
What error message is it giving?
The coding for this ABS almost certainly has parts of the car's VIN embedded it it, meaning a coding from some other car will never work. This also raises the question:
Do the VINs in the ECU and the cluster/immobilizer match, and do they match the physical VIN of the car?
NEtech
Denmark
C?ID=56995
^Any info on Uwe's questions?
There is not much info on this ABS Coding.
You may try this coding:
514A158A52A82442A649124926114A242444541254452442659248926488522424222A482AA251D6423D926B42BC
Yes coding is shorter!
First use showed SA (S12345), after you copied this file, to C:\Ross-Tech\VCDS\Labels\User
@Uwe, I guess this thread should be moved from LCode?
gary1234
England
C?ID=375602
with odis it says coding unsuccessful
and yes the vins do match in the instrument cluster and ecu
Thanks will try that coding and report back
gary1234
England
C?ID=375602
tried coding came up with this error
Coding rejected
Error 13 incorrect message length or invalid form
NEtech
Denmark
C?ID=56995
Was SA accepted ?
If so try this:
510D4A5715428AB25203A81B24E242A649124926114A242444541254452442659248926488522424222A482AA251D6423D926B42BC
gary1234
England
C?ID=375602
yes sa was accepted
will try coding and report back
thanks
gary1234
England
C?ID=375602
Hi tried coding
Coding rejected
Error 13 incorrect message length or invalid format
