2013 Audi S4 No Start
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Hello, long time lurker first time poster. Would like to run my situation by you guys and see if some light could be shed. Long story short, customers 13 S4 arrived from dealer with New ECU installed and a no start (I have more background info if needed but trying to keep it short). Found no comm with ECU, Diagnosis found t94 connector pins 67,68 for CAN bad/loose connection. Replaced both pins (2 pins on one wire from dealer). Comm with ECU has been restored. Tried to the best of my ability with long code helper to properly code ECU, still no start. DTC's set in ECU for park neutral switch input circuit ... Here's where I'm starting to get lost ... Attempt to perform basic setting on trans neutral position sensor IDE03545 but do not have correct security code to complete it. Go to TCU and attempt basic setting for trans range switch IDE00963 and will abort for safety reasons setting a DTC for 9725 Starter Interlock Signal P1724 00 [167] - Short to Ground.
I have access to alldata, wiring diagrams etc. Vehicle did start and run prior to ECU replacement. ECU was originally replaced because customer thought loss of comm was due to internal failure of ECU which was later proven incorrect. No modifications or repairs done to transmission, only repair made was above stated t94 pin 67,68. Any help would be greatly appreciated, auto-scan posted below :)
Tuesday,06,July,2021,07:32:14:51523
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WAUKGAFL3DA089460
Mileage: 96480km-59949mi   Repair Order:
Chassis Type: 8R0
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
          5F 62 6C 72 A9
   Mileage: 96480km-59949miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0002
   Revision: --H07---
   Coding: 0A250016042600060000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 383CD7B4839AC84B3B-806C
6516 - Throttle Valve Controller
          P1545 00 [036] - Malfunction
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 16:33:49
                    Engine RPM: 0.00 /min
                    Coolant temperature: 32 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.476 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 32.25 °C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
                    Vehicle speed: actual: 0 km/h
6536 - Throttle Actuator (J338)
          P1579 00 [036] - Adaptation Not Started
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 16:34:08
                    V_TPS_1_ENVD: 0.74219 V
                    V_TPS_2_ENVD: 4.19922 V
                    Coolant temperature (unfiltered): 28.50 °C
                    TIA_AM_SCHA: 29.25 °C
                    Battery voltage: 11.578125 V
6548 - Engine Control Module Incorrectly Coded
          P1612 00 [037] - -
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 16:33:52
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.375000 V
6408 - Park/Neutral Switch Input Circuit
          P0850 00 [165] - Open or Short to Plus
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 16:33:48
                    Coolant temperature (unfiltered): 26.25 °C
Readiness: 1110 1101
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0004
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021.rod
   VCID: 40CCBF54DB4A808B83-8014
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   VCID: 0444734487D25CABE7-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0D814000000000000000
   VCID: 014A7A5098C04983CC-8054
   Serial number: 2312000118100002
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01190620120017
   Coding: 6600228000
   VCID: 393AD2B0B090D143C4-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000435868102
   Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000010200020030000000
   Shop #: WSC 20955 004 1048576
   VCID: 7AB80DBCF5161A5B8D-802E
   Component: WWS 140612  H07 0080
   Serial number: SWF12060145165
   Coding: 00FD11
   Serial number: 20343665
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001206124045
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 73888436000000000001
02258 - Door Opener Transmitter
                    Reset counter: 222
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:55
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90C2LD
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 25711 001 1048576
   VCID: 4AD89D7CED764ADB5D-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200009PD9
   Serial number: 6334MSME67516706B
   Serial number: 6344MSME69116749H
   Serial number: 6352QSME20171060.
   Serial number: 6362QSME3F170D44P
   Serial number: 63732SME7314064E
   Serial number: 63832SME7314075C$
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120621000100
   Coding: 000036
   VCID: 51EA8A10082079031C-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 L    HW: 8K0 920 982 L
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBN644J6D
   Coding: 8BB709008B01D705020000
   VCID: 3D32C6A0A4B8ED63E8-8068
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z1252800F8
   Coding: 80C303FF00
   VCID: 46C0A94CF16EAEBBB9-8012
   Serial number: 1984827601
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 000806120001039
   VCID: 2F2EECE876D40FF36A-807A
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000031306339
   Coding: 00581B00000000000000
   VCID: 3B36C8B8BAACE353D6-806E
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H16 0040
   Serial number: 0174367323
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3E30C1ACA1BEF67BF1-806A
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H16 0040
   Serial number: 0177657983
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13204E00410001
   VCID: 56E0790C21CE1E3BC9-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0004627784
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424E3849FF22C2B17-8060
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschläge nicht angelernt]
                    Fault Frequency: 29
                    Reset counter: 222
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:58
                    Write only channel
   Revision: 00002001    Serial number: 0178662636
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000534915
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 222
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:56
   Revision: 00005001    Serial number: 94813004073402
   VCID: 2D12F6E074D87DE358-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55E27E003CC81523C0-8000
   Part No SW: 8K0 907 801 K    HW: 8K0 907 801 J
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 10000000060449
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 373ED4888E84C73332-8062
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156F 0C7606445
   Coding: 020007010000000001
   VCID: 210A1AD03800A983EC-8074
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204FU0C7506327
   Coding: 110200000206A1EF55028B4E00000403140000000000000000
   VCID: 3620D98C818E3E3B29-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130FB0CS191629
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001192606
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C13204000210001
   VCID: 59FA723050D03143E4-800C
   Revision: --H07---    Serial number: 525PA8-J2491LZ
   Coding: 1000006
   VCID: 383CD7B44B9AC84B3B-806C
   Component: TSG HR        H07 0304
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120527201377
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72A8259CA566621BC5-8026
End----(Elapsed Time: 02:08, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Jef
HQ
A bit of a shot in the dark, but please try the following for the ECM coding:
0A250034052608060000
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Hey Jef, thanks for the reply! I'll try and update the coding. Any thoughts on the ECU dtc P0850 park neutral switch input? I can see P,R,N,D in trans mvb while I move the gear selector, I'd assume that message is making across to ECU on CAN fine.
Jef
HQ
What I suspect (but unsure of) is the coding is making the ECM look for something that isn't there for it, hence the issue. IMHO, it is possible there no real issue with a P/N switch... just a confused ECM.
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Gave the new coding a shot this morning and its giving me the "error 22: conditions not correct or request sequence error"
*edit - Jef, I agree with your hypothesis. Vehicle did start prior to new ECU, theres no way something got damaged while being towed between the dealership and our facility. Tried some other coding variations using long code helper and most get error 22'd.
*edit 2.0 - Dealership threw out original ECU, and is a bit unwilling to help. So its up to me and you guys! lol
Jef
HQ
ST?ID=99288
Hmmm... I'm pretty sure the coding should work. If some one can double check my suggestion as a sanity check that would be nice. Also, if you ran an Auto-Scan at some point with the original ECM, that would have the coding. If there is a past Auto-Scan, section 3 here shows how to find it. If you have an old Auto-Scan, post it.
If you had the engine running when trying to code it, don't... key on, engine off. Be sure battery voltage is +12V.
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Appreciate your reply's Jef, I gave it another shot this morning with same results. Battery was on a tender +12v, key on engine off, went right into 01-ECU and into 7-Coding, copy pasted your advised coding into the new field and got the same error 22 rejection. Wonder why it wont accept hmm.
Also we never saw the vehicle prior to this so we have no past scans unfortunately :/
NEtech
Denmark
C?ID=56995
First:
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 444 23456
[Save]
[Close VCDS]
Start VCDS
Use battery charger.
I would test: 0A250034052600060000
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Followed NEtech's instructions and the coding took! no more incorrectly coded ecu dtc. I do still get a hard dtc of P0850 - park neutral saftey switch input circuit open or short to plus. Attempt to clear, dtc will set immediately.
So I believe the only remaining obstacle to getting this cranking is figuring out why that P0850 sets. I tried to go back into TCU and perform IDE00963 adaptation of trans range switch and basic setting will run for 20 seconds or so then abort for saftey, dtc for starter interlock will set, but this dtc will ONLY set when I attempt to perform IDE00963.
Attempt to perform basic setting in ECU IDE03545 - Adapt trans neutral position sensor and it still requires security access, that of which I do not have.
Any insight on the P0850? Again timeline goes ... vehicle starting, loss of comm with ecu, customer had dealer put new ecu in, dealer said still no start, customer had vehicle towed to me. I believe park/neutral sensor resides in mech unit. I doubt it was damaged from towing or at dealer. MVB in TCU shows P,R,N,D changes and cluster reports P,R,N,D changes as well. Attached below is an auto-scan from today after new coding was accepted.
Thursday,08,July,2021,13:25:49:51523
Workshop Code: 444 12345 023456
Chassis Type: 8R0
          5F 62 6C 72 A9
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 12345 444 23456
                    Mileage: 96484 km
                    Date: 2021.07.08
                    Time: 13:09:11
                    Coolant temperature: 24 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.202 V
                    Coolant temperature (unfiltered): 24.00 °C
   Revision: --H01---
   Coding: 291D1A
   Coding: 6600228000
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
                    Reset counter: 222
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:55
   Coding: 000036
   Coding: 80C303FF00
                    Reset counter: 7
                    Mileage: 96484 km
                    Date: 2021.07.08
                    Time: 09:46:02
                    Bin. Bits:    00000
                    Voltage: 13.10 V
                    Count: 7
   Coding: 010211
   Coding: 010211
                    Fault Frequency: 51
                    Reset counter: 222
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:58
                    Write only channel
                    Fault Status: 00101001
                    Fault Frequency: 17
                    Reset counter: 6
                    Mileage: 96484 km
                    Date: 2021.06.28
                    Time: 10:55:56
   Coding: 1000006
End----------(Elapsed Time: 02:08, VBatt start/end: 13.4V/13.3V)-----------
NEtech
Denmark
C?ID=56995
Can be problem with P and/or N signal wire from aut.gearbox.
Check wiring and measvalue "Starter control Interlock or P/N status"
Could be this: ENG100919 Starter control: interlock switch
Jef
HQ
Looking at the factory wiring diagram for the transmission, 7-speed DSG transmission 0B5 (S tronic), wiring diagram #95. Go to page 7, on current track 79 is the F305, the Transmission Park Selector Switch. One side of the F305 is grounded, and oddly, the other side is wires to the J393.
46-08-042
field 1 = start/stop button
field 2 = Interlock switch/clutch switch (CAN signal)
field 3 = Gear Selector Lever (CAN signal)
field 4 = P/N or interlock switch P input (hardware signal)
What data do you get there? Does it change if you pull the gear selector out of P or N?
Any chance there is a wiring issue from the F305? Or a faulty F305 itself (which is part of the N110 shift lock solenoid)?
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Hey guys, I did check "ENG100919 Starter control: interlock switch" and its just a string of 0's that don't change values when brake is pressed, attempt to start, gear selector in different positions.
Secondly I did take a look at the factory wiring diagram current track 79 and I do see what Jef is talking about there. F305 (as an assembly with N110) does get grounded and 1 wire leading to J393.
Taking a deeper look into the mvb 042 as you suggested I will detail out my results below (all initial values are with key on, foot off brake, gear selector in park)
Field 1 = 00 (when start/stop button pressed values change to) = 11
Field 2 = Not Installed (value does not change with anything I try)
Field 3 = 5.0 (as I move gear selector down values change to R = 6.0 N = 7.0 D = 9.0)
Field 4 = 11 (when in park, foot off brake) value changes to (foot on brake) = 01 (foot on brake gear selector in R) = 00 (gear selector in neutral) = 01 (gear selector in D) = 00
Some conclusions I can draw with the new info so far I believe is that maybe J393 needs to see "01" in field 4 to allow a start, which it does with foot on brake and in park or in neutral, so I think we're good there. Field 3 seems to be fine, values changing when gear selector changes position. Field 1 seems to be fine as well.
Field 2 value of "not installed" I think is our issue. Coding for J393 and TCU appears ok and correct. Only dtc is for a luggage compartment light set in J393. Everything I can see so far it appears that any change in gear selector is conveyed correctly.
I will take apart the center console to inspect F305 and N110 in the mean time. I do want to say you guys have been such a big help, sincerely thank you.
*Edit - Managed to get some time for more testing today and wanted to update. Found pin 25 (gy) of 46-comfort putting out .13V with key on, found .13V at pin 3 of F305. Wire resistance = 1.6 ohm. Also found an increase in voltage to 1.10v when brake is applied, gear selector position doesn't effect voltage. Also found 0V at all times on pin 4 (ground). I'd think I'd see voltage on pin 4 (ground) at some point right? .13 and 1.10 volts seem like an arbitrary number too? Connectors and wiring appear ok.
Jef
HQ
This may be for cool 3 pedal car people, not you 2 pedal car types. :) So not installed may be normal.
I suspect your values are good. There are two bits there.... XY. X looks to be the interlock, 1 being you can't pull the gear selector out of park. When you step on the brake pedal, the N110 fires up, pulls the pin back, value changes to 0. Y is "P input" as in Park (and neutral), so a value of 1, put it into gear and it goes to 0.
So field 4 reading 01 should be good IMHO. To that end, if that is good... WTF is the ECM's issue? :confused:
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Ahh I do see what you mean. I'm thinking the same thing, what the hell is that things issue lol
Any other areas/data points/connectors/wiring to check from any of you fine gentlemen would be appreciated, at this point I'm more or less at a loss.
Jef
HQ
So Access Start and CCM are the same box. I would expect them to report the same/similar data...
05-08-005
field 1 = Brake light switch (Term 54)
field 2 = P/N or interlock switch P input (hardware signal)
field 3 = P input (hardware signal)
field 4 = this space for rent
What shows up there?
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Hey guys, this morning got a second to see what the 05 start auth module reports. I'll detail the findings below ...
*All initial values are with gear selector in park and foot OFF brake*
05-08-005
Field 1 = 0 - brake applied value changes to 1
Field 2 = 1 - brake applied and gear selector shifted to R = 0 - into neutral = 1 - D = 0
Field 3 = 1 - brake applied = 0 - once shifted to R, N, D value stays at 0 even with brake on/off
It appears every action I take with gear selector or brake application is conveyed correctly in the 05 start auth module as well. I'd assume it wants to see field 1 = 1 field 2 = 1 field 3 = 0 to authorize a start and that is what I'm seeing in mvb.
Any thoughts on this data confirming I do not have a physical issue with park/neutral switch? I'd be happy to test wiring/voltages to/from start auth or ecu I just don't know exactly where, or what values I'd be looking for.
*Edit* - Was looking through the EWD for starting system and remembered I did go through and check starter relay's 1/2. Terminals 86 of both relays have 12v from fuse 16 40amp. 12v at terminal 30 of relay 2, continuity between terminal 87 of relay 2 and terminal 30 of relay 1. Continuity between terminal 87 of relay 1 and starter solenoid connector. Just some more info I thought pertinent to the situation. Starter relay side of things looking ok.
Jef
HQ
Under the ECM Basic Settings, I see this option:
IDE03545 -Adaptation of transmission neutral position sensor
I've never noticed this before on any car... ran this by Dana and we both are of the opinion "worth a shot, but don't know what to expect". To that end, proceeded at your own risk.
Our drunken guess is that when a dealer installs an ECM, part of the factory scan tool test plan would be to do this step... and maybe it wasn't done on your car for reasons unknown.
Phonicsmonkey89
Rochester, NY, USA
C?ID=346384
Hey Jef, I did see that under ECM and have attempted that but VCDS wants security access, that of which I do not have :( . I tried security access numbers 27971 and 79153 and still no go. I got those 2 numbers from THIS link.
Jef
HQ
.... well f##k. :banghead:
Coming up with Security Access codes is not my thing. I'm hoping some one can fill in the missing blank here.
NEtech
Denmark
C?ID=56995
Try 20103
