2002 VW Passat 1.8T cranks ok but no start-ECU no communication
TFSI
Maryland, USA
C?ID=66650
Hello Folks,
This car was driving ok with no issues last night but after parking overnight today it wont start. Engine control module does not communicate suddenly. I found fuses on side of dashboard fuse #28 and 29 has no 12V supply but fuse is ok. Does anyone know where the supply to these fuse numbers come from?Anyone with WD?help appreciated.
Monday,05,July,2021,15:29:39:46890
VCDS Version: 21.3.0.0 (x64)
VIN:    License Plate: MY3B PASSAT
                Address 02: Auto Trans       Labels: 01V-927-156.lbl
Control Module Part Number: 3B0 927 156 AH
  Component and/or Version: AG5 01V 1.8l5VT USA 0810
           Software Coding: 0001104
            Work Shop Code: WSC 09144 444 59146
                      VCID: 6CDC0DA94C3CDDEB0F-5120
18258 - Powertrain Data Bus
            P1850 - 003 - Missing Message from ECU
                    (no units): 0.0
                    Torque: 0.0 Nm
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    (no units): 4.0
                Address 17: Instruments       Labels: 3B0-920-xx5-17.lbl
Control Module Part Number: 3B0 920 927 B
  Component and/or Version: KOMBI+WEGFAHRSP VDO V05
           Software Coding: 07235
            Work Shop Code: WSC 00000
           Additional Info: WVWVD63B12E258897     VWZ7Z0A4357038
                      VCID: 244C2589B46CD5AB87-5102
01312 - Powertrain Data Bus
            37-10 - Faulty - Intermittent
            49-00 - No Communications
            80-10 - Single-Wire Operation - Intermittent
                Address 46: Central Conv.       Labels: 1C0-959-799.lbl
Control Module Part Number: 1C0 959 799 C
  Component and/or Version: 0P Komfortgerát HLO 0003
           Software Coding: 00258
            Work Shop Code: WSC 05311
           Additional Info: 1C1959801   0P Tõrsteuer.FS KLO 0002
           Additional Info: 1C1959802   0P Tõrsteuer.BF KLO 0002
           Additional Info: 1C0959811   0P Tõrsteuer.HL KLO 0002
           Additional Info: 1C0959812   0P Tõrsteuer.HR KLO 0002
                      VCID: 3776E2C515FAAE3332-4AE6
01358 - Internal Central Locking Switch; Driver Side (E150)
TFSI
Maryland, USA
C?ID=66650
Additional checks shows no voltage supply to the Fuel pump so pump does not run..but fuel pump relay clicks ok during cranking. I have also installed new fuel pump relay but still no go..very wiered situation indeed
How about power to the ECU itself?
TFSI
Maryland, USA
C?ID=66650
Thanks, issue fixed now. Power supply to the ECU was the problem.
TFSI
Maryland, USA
C?ID=66650
Would you mind elaborating? What caused this?
What caused it?hmm the 10A mini fuse supplying the ECU, though was good had bad connection inside the fuse box. I cleaned the contacts inside fuse box and replaced the fuse then suddenly the fuel pump runs when key is on and the fuse 28 and 29 also became live. Then ecu started communicating with VCDS..what I cant seem to understand tho is the relationship between the ecu fuse, fuse #28 and #29. Probably some good WD will explain it
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I think 28 is fuel pump fuse. It's power by fuel pump relay. So now that ECM has power it grounds the relay and supplies the power to fuse 28.
Good Luck
TFSI
Maryland, USA
C?ID=66650
Thats corrrect-
This is what i didnt know..but some good WD would have been good.
Is there a cheaper source of Wiring diagram than from Erwin?
Orchid70
Sweden
C?ID=354348
Thats corrrect-
No, but you can buy one hour ticket and download the wiring diagram in pdf.
Its a pain to find correct things in there - but I usually manage in one hour.
Just be sure you are in correct Erwin - last time I managed to buy VW instead of Skoda.... So had to pay double.... And pick up a good day - you need patience.....
I don't think the NAR site offers a one-hour option. IIRC, the cheapest option is one day for $35.
TFSI
Maryland, USA
C?ID=66650
Uwe-
Whats IIRC please?
