I am having trouble accessing the 09 Central electrics module. Sometimes VCDS is unable to access the controller at all (asks if the doors are unlocked). Sometimes I get access to the module, but when trying to make adaptations I get an error message about intermittent communication issues and I cannot make any changes.
Any ideas?
Thanks
Autoscan:
Any ideas?
Thanks
Autoscan:
Monday,05,July,2021,14:02:12:04552
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
VIN: WAUZZZGE2KB003361 License Plate:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 51 52 5F 69 6C 6D 74
75 81 8C A5 BB BC C5 C6 CD CE DE 8104
VIN: WAUZZZGE2KB003361 Mileage: 30128km-18720miles
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
CD-Laser Scanner -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623- ) Labels: None
Part No SW: 4KE 907 558 E HW: 4KE 907 558
Component: I99 99.9l XXX H02 0001
Coding: 2A0A0012007E040034080000000000000000000000000000
ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
ROD: EV_VCU00XXX0204KE907558E.rod
VCID: 4BC36D2B63440CD32A1-801E
Parking lock:
Subsystem 1 - Part No SW: 0MA 341 601 B HW: 0MA 341 601 B
Component: V682 ParkLock H23 0611
Serial number: 2018.10.22.000000019
17179 - Databus
Mileage: 29915 km
Date: 2021.07.01
Time: 10:57:53
Engine RPM: 16383.75 /min
Normed load value: 100.0 %
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 13.105 V
Unlearning counter according OBD: 33
Engine status: Stop
ECU_STATE: ENG_STOP
ACC variants (coding): ACC with braking until standstill / Stop & Go
Part No SW: 4KE 909 059 AC HW: 4KE 909 059 G
Component: ESC H09 0078
Revision: 00000000 Serial number: 63228000003028
Coding: 008800BA3D940B9CD35308771878D2E025BEA10000BCD0CB10184B07A47D85
Shop #: WSC 12000 205 00000
ASAM Dataset: EV_BRSContiMKC1AU516 009376
ROD: EV_BRSContiMKC1AU516_009.rod
VCID: 0849922732B227CBC73-805C
16641 - Engine Control Module
U1226 00 [044] - Implausible Message
[DEM_RTC_MOTOR_TS_03_STA_FAIL]
Mileage: 28875 km
Date: 2021.06.14
Time: 17:37:21
Unlearning counter according OBD-OBD unlearning counter: 255
History Data-History data 1: 00
History Data-History data 2: 00
History Data-History data 3: 00
History Data-History data 4: 00
History Data-History data 5: 00
History Data-History data 6: 00
History Data-History data 7: 00
History Data-History data 8: 00
History Data-History data 9: 00
History Data-History data 10: 00
History Data-History data 11: 00
History Data-History data 12: 00
History Data-History data 13: 00
History Data-History data 14: 00
History Data-History data 15: 00
History Data-History data 16: 00
History Data-History data 17: 00
History Data-History data 18: 00
History Data-History data 19: 00
History Data-History data 20: 00
History Data-History data 21: 00
History Data-History data 22: 00
History Data-History data 0: 00
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4KE 907 561 B HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: 7E61FF4B58082C0001038020000000BA4A1246494481009E01
Shop #: WSC 00046 412 00046
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 42DD400F540ECD9BD97-8016
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Fault Frequency: 85
Reset counter: 254
Mileage: 28006 km
Date: 2021.05.27
Time: 09:04:08
Control Module temperature: 32 °C
Voltage terminal 15: 14.3 V
Vehicle speed: 5.70 m/s
Longitudinal acceleration: 1.20 m/s²
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: 106.200 °
Yaw_rate-Data: 4.270 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.072 °
Misalignment angle: horiz: fast algorithm: 0.167 °
Congestion pilot: status: OFF
Outside temperature: 13.50 °C
Sensor blindness: radar: no blindness detected
2102 - Databus
[FAULT_ESP_CONTROL_FAIL]
Fault Frequency: 84
Reset counter: 254
Mileage: 28006 km
Date: 2021.05.27
Time: 09:04:07
Vehicle speed: 4.89 m/s
Longitudinal acceleration: 1.40 m/s²
Adaptive distance regulation: status: ACC_StandBy
Steering_angle-Data: 159.900 °
Yaw_rate-Data: 5.579 rad/s
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 234
Mileage: 29261 km
Date: 2021.06.18
Time: 21:36:46
Control Module temperature: 36 °C
Voltage terminal 15: 14.0 V
Vehicle speed: 11.32 m/s
Longitudinal acceleration: 1.23 m/s²
Steering_angle-Data: -7.600 °
Yaw_rate-Data: -0.581 rad/s
Misalignment angle: horiz: 0.027 °
Misalignment angle: horiz: fast algorithm: 0.136 °
Outside temperature: 26.00 °C
0935 - Databus
[FAULT_TRAILOR_LIGHT_DEFECTIVE]
Reset counter: 250
Mileage: 29915 km
Date: 2021.07.01
Time: 10:57:53
Voltage terminal 15: 13.7 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Steering_angle-Data: -193.200 °
Yaw_rate-Data: 0.007 rad/s
Misalignment angle: horiz: 0.095 °
Misalignment angle: horiz: fast algorithm: 0.168 °
Outside temperature: 22.00 °C
Address 15: Airbags (J234) Labels:* None
Part No SW: 4KE 959 655 HW: 4KE 959 655
Component: AirbagVW32 H36 3122
Serial number: 003XPM00B22C
Coding: AAFCF0C0002000009A5400FFF80D41A800C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
ROD: EV_AirbaVW31SMEAU65x.rod
VCID: 0B43AD2B23C44CD3EA1-805E
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018338346700000
Coding: 03F002
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018346619500000
Coding: 03F002
Subsystem 3 - Part No SW: ----------- HW: 480 001 411 18
Serial number: 35700000000A052CC53L
Subsystem 4 - Part No SW: ----------- HW: 480 001 411 18
Serial number: 3580000000077968953R
Subsystem 5 - Part No SW: ----------- HW: 480 031 711 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C18E2E0250E87B
Subsystem 6 - Part No SW: ----------- HW: 480 031 711 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C18E2E09402D48
Subsystem 7 - Part No SW: ----------- HW: 480 021 211 18
Component: FrontSensor_D 000 0149
Serial number: 3550001102B81AA3011J
Subsystem 8 - Part No SW: ----------- HW: 480 021 211 18
Component: FrontSensor_P 000 0149
Serial number: 3560001102B81AA4057V
Crash sensor high-voltage system 1:
Subsystem 9 - Part No SW: ----------- HW: 480 021 211 18
Component: HVSensor_gSat 000 0149
Serial number: 3510001062B81AA5070R
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 10 - Part No SW: ----------- HW: 480 021 211 18
Component: SideSens_B_Df 000 0149
Serial number: 3520001062B81AA6841Z
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 11 - Part No SW: ----------- HW: 480 022 410 18
Component: SideSens_B_Pf 000 0149
Serial number: 35500019F2BE26367328
1065478 - Databus
[NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_FGE]
Reset counter: 226
Mileage: 28856 km
Date: 2021.06.14
Time: 16:56:13
1065477 - Databus
[NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
Fault Frequency: 22
Reset counter: 1
Mileage: 28030 km
Date: 2021.05.27
Time: 17:20:19
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 79AFE7E379584E43C8D-802C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4KE 920 795 B HW: 4KE 920 795
Component: FHybRDWACC--- H13 0031
Coding: 850400C87C9000080CA6E170B284680008000000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 46D55C1F7826F1BBF5F-8012
16777046 - Charger for HV Battery
U1139 00 [008] - No Communications
[BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
Reset counter: 254
Mileage: 28435 km
Date: 2021.06.11
Time: 16:47:34
Part No SW: 4K1 907 468 D HW: 4K1 907 468 C
Component: Gateway H04 0322
Serial number: 1DF06042425101
Coding: 02030005000100C000810000005B01329C8A004718000000090000DE00000000
Shop #: WSC 04100 205 00000
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 36352CDF08C6613B65F-8062
Subsystem 1 - Part No SW: 4N0 951 523 G HW: 4N0 951 523 G
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Subsystem 2 - Part No SW: 4N0 915 181 D HW: 4N0 915 181 D
Component: J367-BDMConti H03 1051
Serial number: 7674960100181126050C
Steering Wheel Touch Recognition Control Module:
Subsystem 3 - Part No SW: 4N0 419 508 HW: 4N0 419 508
Component: J1158 KLR H44 0030
Serial number: 18289013306S00304401
262693 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[BAP_Timeout_BatteryControl]
Fault Frequency: 6
Reset counter: 250
Mileage: 28101 km
Date: 2021.05.29
Time: 14:15:40
8913155 - Development Code 4
B2F04 00 [009] - -
[RWB_TME_Init_Abwurf_Dauerinit]
Reset counter: 162
Mileage: 28010 km
Date: 2021.05.27
Time: 09:54:08
8913156 - Development Code 5
B2F05 00 [009] - -
[RWB_BCME_Init_Abwurf_Dauerinit]
Reset counter: 162
Mileage: 28006 km
Date: 2021.05.27
Time: 09:03:48
16711991 - Ethernet Databus Branch 2
U122D 00 [008] - No Communication
[Ethernet_databus_no_communication_port_2]
Reset counter: 234
Mileage: 29263 km
Date: 2021.06.18
Time: 21:38:49
Ethernet counter checksum error: branch 2: 0
Ethernet counter connection interruptions: branch 2: 1
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000340825006
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: 343116D71EBA732B5BB-8060
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000356599657
Coding: 00581A400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 593 M HW: 4M0 959 593 J
Component: TSG FS 007 0387
Serial number: 0000353284485
Coding: 001FCA0152000480A001B002
ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: B4110101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F1FC3E1A8460330D-8064
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 GP HW: 8W0 907 064 DP
Component: BCM2 MLBevo 025 0424
Coding: 017400030FB103616309A0040C00C80200004000804F02582F0400000504823B001F0100010F13
Shop #: WSC 44528 004 104857
ASAM Dataset: EV_BCM2HellaAU736 016016
ROD: EV_BCM2HellaAU736_016.rod
VCID: 1079BA474AE26F0B1F3-8044
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY182920YDR
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000045880885
left tail lamp 1:
Subsystem 3 - Part No SW: 4KE 945 423 HW: 4KE 945 423
Component: T1 LH ECE HD H10 0403
Serial number: A1W700005X3
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11340301
Antenna for short-range communication:
Subsystem 5 - Part No SW: 4N1 927 753 HW: 4N1 927 753
Component: NFCTGS H13 0050
Serial number: 382823425
Antenna 2 for short-range communication:
Subsystem 6 - Part No SW: 4N0 959 428 A HW: 4N0 959 428 A
Component: NFCMIKO H41 0034
Serial number: 4418000231080016
left tail lamp 2:
Subsystem 7 - Part No SW: 4KE 945 429 B HW: 4KE 945 429 B
Component: T2 LH ECE HD H12 0403
Serial number: A1WK0002MWX
Right rear tail lamp 1:
Subsystem 8 - Part No SW: 4KE 945 424 HW: 4KE 945 424
Component: T1 RH ECE HD H10 0403
Serial number: A1WD0000549
Right rear tail lamp 2:
Subsystem 9 - Part No SW: 4KE 945 430 B HW: 4KE 945 430 B
Component: T2 RH ECE HD H12 0403
Serial number: A1WL0002MWY
65732 - Databus
[Engine control module: Motor_14: no signal/no communication]
Reset counter: 241
Mileage: 28870 km
Date: 2021.06.14
Time: 17:28:24
Supply voltages-Terminal 30 power supply: 13.560 V
Supply voltages-Supply voltage Terminal 30 - 2: 13.628 V
Supply voltages-Supply voltage Terminal 30 - 3: 13.587 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: Not available
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
65605 - Databus
[Brake control module: ESP_21: no signal/communication]
Fault Frequency: 6
Reset counter: 241
Mileage: 28043 km
Date: 2021.05.28
Time: 20:46:12
Supply voltages-Terminal 30 power supply: 12.827 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.908 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.854 V
65729 - Databus
[Brake control module: ESP_05: no signal/communication]
Fault Frequency: 7
Reset counter: 241
Mileage: 28029 km
Date: 2021.05.27
Time: 17:13:26
Supply voltages-Terminal 30 power supply: 12.609 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.663 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
Address 51: Electric Drive (J841) Labels: None
Part No SW: 0EF 907 080 G HW: 0EF 907 080 C
Component: CUFZD683Q0AD2 H02 0010
Revision: -------- Serial number: -00103.10.18000
Coding: 01000000000000000000
Shop #: WSC 44528 004 1048576
ASAM Dataset: EV_DMCMHITACAU516 003007
ROD: EV_DMCM2HITACAU516_003.rod
VCID: 3A2D38EF3CDE855B817-806E
13828096 - Component protection
U1115 00 [047] - No basic setting for SHE key
[CmpntPrtctn_SHEKeyNoCnfg]
Mileage: 28006 km
Date: 2021.05.27
Time: 08:50:31
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 592 M HW: 4M0 959 592 J
Component: TSG BFS 007 0387
Serial number: 0000349865601
Coding: 001FCA015E000480A001B000
ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
VCID: 45D75B134520FAA3FC5-8010
Part No SW: 4K0 035 063 D HW: 4KE 035 063
Component: MU-H-LND-EU 046 2711
Coding: 01157601FF0A000043111101C00802302F0001E4037008008E
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 2411E697AE5AE3ABCBB-8070
Data carrier:
Subsystem 1 - Part No: V03 959 807 SE
Component: MIB2P_EU_Q420 0490
Multimedia System 1:
Subsystem 2 - Part No SW: 4KE 919 605 C HW: 4KE 919 605
Component: DU AU516 High H41 0147
Serial number: INX00119091800130138
Compact disc data bank:
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000229020010
Multimedia System 5:
Subsystem 5 - Part No SW: 4KE 919 603 A HW: 4KE 919 603
Component: DU AU516 Bot H41 0147
Serial number: INX00115091800140133
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800690324010
6672 - Optical Data Bus for Display in Instruments
U10CF 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in instrument cluster display]
Reset counter: 234
Mileage: 29263 km
Date: 2021.06.18
Time: 21:39:02
Voltage terminal 30: 14.2 V
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: 38 °C
Temperature of MOST transceiver-Up-to-date: 38 °C
7237 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 216
Mileage: 30105 km
Date: 2021.07.05
Time: 12:54:45
BAP-BAP_Function_ID: 02
1561 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 234
Mileage: 29261 km
Date: 2021.06.18
Time: 21:36:46
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 E HW: 4M0 907 383
Component: Anhaenger H27 0253
Revision: 9C001003 Serial number: 0500244408
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
655882 - Bulb for Brake Light on Trailer
C10F3 15 [008] - Open or Short to Plus
Reset counter: 250
Mileage: 29915 km
Date: 2021.07.01
Time: 10:57:52
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H15 0250
Coding: 0215060103002005C20040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
VCID: 333315CB1BB47413421-8066
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C744-8781-0
Coding: 33B0
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 4ACD682F6C3E15DB117-801E
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4KE 907 777 AD HW: 4KE 907 777 A
Component: Fahrwerk-SG H52 2311
Serial number: 0611181032
Coding: 98D8607BDA4010
ASAM Dataset: EV_ChassContrContiAU651 003018
ROD: EV_ChassContrContiAU651_003.rod
VCID: 0E45A43F50D679FB0DF-805A
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130436323
Coding: 303030
Address 75: Telematics (J949) Labels:* None
Part No SW: 4K1 035 282 D HW: 4K1 035 282 B
Component: ConBox H09 0232
Serial number: 005CCA11F110204
Coding: 01C0E0FFC040800000
ASAM Dataset: EV_ConBoxAU651 002004
ROD: EV_ConBoxAU651_002.rod
VCID: 2809F2A7D27207CBE73-807C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4KL 713 041 A HW: 4KL 713 041
Component: GSM-LL H04 0036
Serial number: 92145RLA00070
ASAM Dataset: EV_GSMKLOAU516 001008
ROD: EV_GSMKLOAU516.rod
VCID: 3C213EF736EABB6B93B-8068
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 4KE 915 233 F HW: 4KE 915 233 B
Component: BMC_MLBCBEV H15 0231
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_VW53.rod
VCID: 41DF4F035108D683C0D-8014
Battery interrupt switch:
Subsystem 1 - Part No SW: 4KE 915 250 C HW: 4KE 915 250 A
Component: BJB_MLBBEV H12 0369
Cell module control module 1:
Subsystem 2 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 2:
Subsystem 3 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 3:
Subsystem 4 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 4:
Subsystem 5 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 5:
Subsystem 6 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 6:
Subsystem 7 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 7:
Subsystem 8 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 8:
Subsystem 9 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 9:
Subsystem 10 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 10:
Subsystem 11 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 11:
Subsystem 12 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Cell module control module 12:
Subsystem 13 - Part No SW: 4KE 915 215 HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AB HW: 4N0 907 107 G
Component: zFAS Var B H09 0291
Coding: 0421840000000000000C060000D4462E189E57000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 7F5B09FB677C6073F69-802A
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Fault Frequency: 85
Reset counter: 254
Mileage: 28006 km
Date: 2021.05.27
Time: 09:04:08
Part No SW: 4M0 959 595 M HW: 4M0 959 595 J
Component: TSG HFS 006 0387
Serial number: 0000354796509
Coding: 000FC80100000480A000B000
ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
VCID: 48C952277232E7CB073-801C
Component: TSG HBFS 006 0387
Serial number: 0000354796516
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 4KE 965 429 C HW: 4KE 965 429
Component: TME-Max H08 0312
Serial number: 0012129
Coding: 00
ASAM Dataset: EV_ThermContrVISAU49X 002036
ROD: EV_ThermContrVISAU49X_AU58.rod
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Auxiliary Air Heater Control Module/PTC:
Subsystem 2 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00104.6V.1A20370031
A/C compressor sub:
Subsystem 3 - Part No SW: 4G0 816 797 B HW: 4G0 816 797 B
Component: J842 EKK es33 H03 0004
Serial number: 00000000018100200150
A/C pressure/coolant temperature sensor 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
Coolant heating:
Subsystem 5 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Serial number: -00104.7V.4C20370097
Expansion valve 2 for refrigerant:
Subsystem 6 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000150492381
Shut-off valve 2 for refrigerant:
Subsystem 7 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N640 AV2_KaMi H12 0102
Serial number: 00000000000130452272
Shut-off valve 3 for refrigerant:
Subsystem 8 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N641 AV3_KaMi H12 0102
Serial number: 00000000000130452271
Shut-off valve 4 for refrigerant:
Subsystem 9 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000130452092
Shut-off valve 5 for refrigerant:
Subsystem 10 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000130452243
Radiator shutter:
Subsystem 11 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V544KJS1 H12 0109
Serial number: 20181114020103052736
Radiator louver 2:
Subsystem 12 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V550KJS2 H12 0109
Serial number: 20181110020103053781
Coolant valve 1:
Subsystem 13 - Part No SW: 4KE 963 375 K HW: 4KE 963 375 K
Component: N632 V1_KUEMI 010 0103
Serial number: 00000000000000022208
Coolant valve 2:
Subsystem 14 - Part No SW: 4KE 963 375 J HW: 4KE 963 375 J
Component: N633 V2_KUEMI 010 0103
Serial number: 00000000000000013520
Coolant valve 3:
Subsystem 15 - Part No SW: 4KE 963 375 H HW: 4KE 963 375 H
Component: N634 V3_KUEMI 010 0103
Serial number: 00000000000000032532
Coolant valve 4:
Subsystem 16 - Part No SW: 4KE 963 375 N HW: 4KE 963 375 N
Component: N635 V4_KUEMI 010 0103
Serial number: 00000000000000025527
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 684 J HW: 5QE 915 684 J
Component: OBC KOSTAL H24 0023
Serial number: ---------------
Coding: 2B48844542080E000000
ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
ROD: EV_OBC2PhaseKLOMLBev14P.rod
VCID: 56F58C5FA886413B85F-8002
Flap 1 for charging socket:
Subsystem 1 - Part No SW: 4KE 862 277 A HW: 4KE 862 277 A
Component: F496LKL1 004 0004
Serial number: 20190703030206084246
2097938 - Charging Socket B; Charging Plug Lock
P33E9 00 [032] - Mechanical Malfunction
13705549 - Databus
U1121 00 [040] - Missing Message
[DCDC_01_Timeout]
Reset counter: 34
Mileage: 29830 km
Date: 2021.06.28
Time: 18:01:10
13709330 - Unknown Error Code
U15C9 00 [032] - -
[LMSF_intervention]
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 35372BD315C06A236C5-8060
Address CE: Drive Motor 2 (J944) Labels: None
Part No SW: 0EF 907 180 J HW: 0EF 907 180 C
Component: CUBZE683Q0AD2 H02 0010
Revision: -------- Serial number: -00118.10.18000
ASAM Dataset: EV_DMCM2HITACAU516 003007
VCID: 3E2534FF20F6A97BBDF-806A
Mileage: 28006 km
Date: 2021.05.27
Time: 08:50:31
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 4N0 035 773 A HW: 4N0 035 773 A
Component: WLC Front NFC H11 0061
Coding: 808000
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 2C010EB7C68A2BEB03B-8078
Address 8104: DC/DC Converter HV (A19) Labels: None
Part No SW: 4KE 907 171 B HW: 4KE 907 171 B
Component: DCDC Wandler H10 0400
ASAM Dataset: EV_DCDCHVTDKAU516 001004
ROD: EV_DCDCHVTDKAU516.rod
VCID: 3FDB49FB27FCA073B69-806A
End----------(Elapsed Time: 02:43, VBatt start/end: 13.1V/13.1V)-----------
