Trouble accessing module 09 Central electrics, 2019 e-tron 55 quattro Advanced
vihijtap
Finland
C?ID=432279
Hi,
I am having trouble accessing the 09 Central electrics module. Sometimes VCDS is unable to access the controller at all (asks if the doors are unlocked). Sometimes I get access to the module, but when trying to make adaptations I get an error message about intermittent communication issues and I cannot make any changes.
Any ideas?
Autoscan:
Monday,05,July,2021,14:02:12:04552
VIN: WAUZZZGE2KB003361   License Plate:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 51 52 5F 69 6C 6D 74
          75 81 8C A5 BB BC C5 C6 CD CE DE 8104
VIN: WAUZZZGE2KB003361   Mileage: 30128km-18720miles
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012007E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC36D2B63440CD32A1-801E
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2018.10.22.000000019
17179 - Databus
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:53
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 13.105 V
                    Unlearning counter according OBD: 33
                    Engine status: Stop
                    ECU_STATE: ENG_STOP
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
                    Drivetrain coordinator: brake fault status-ESP system error: No
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 63228000003028
   Coding: 008800BA3D940B9CD35308771878D2E025BEA10000BCD0CB10184B07A47D85
   Shop #: WSC 12000 205 00000
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 0849922732B227CBC73-805C
16641 - Engine Control Module
          U1226 00 [044] - Implausible Message
          [DEM_RTC_MOTOR_TS_03_STA_FAIL]
                    Mileage: 28875 km
                    Date: 2021.06.14
                    Time: 17:37:21
                    Unlearning counter according OBD-OBD unlearning counter: 255
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 0: 00
Address 09: Cent. Elect.
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: 7E61FF4B58082C0001038020000000BA4A1246494481009E01
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD400F540ECD9BD97-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 85
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:08
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: 5.70 m/s
                    Longitudinal acceleration: 1.20 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 106.200 °
                    Yaw_rate-Data: 4.270 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.072 °
                    Misalignment angle: horiz: fast algorithm: 0.167 °
                    Congestion pilot: status: OFF
                    Outside temperature: 13.50 °C
                    Sensor blindness: radar: no blindness detected
2102 - Databus
          [FAULT_ESP_CONTROL_FAIL]
                    Fault Frequency: 84
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:07
                    Vehicle speed: 4.89 m/s
                    Longitudinal acceleration: 1.40 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: 159.900 °
                    Yaw_rate-Data: 5.579 rad/s
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 234
                    Mileage: 29261 km
                    Date: 2021.06.18
                    Time: 21:36:46
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 14.0 V
                    Vehicle speed: 11.32 m/s
                    Longitudinal acceleration: 1.23 m/s²
                    Steering_angle-Data: -7.600 °
                    Yaw_rate-Data: -0.581 rad/s
                    Misalignment angle: horiz: 0.027 °
                    Misalignment angle: horiz: fast algorithm: 0.136 °
                    Outside temperature: 26.00 °C
0935 - Databus
          [FAULT_TRAILOR_LIGHT_DEFECTIVE]
                    Reset counter: 250
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:53
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 13.7 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Steering_angle-Data: -193.200 °
                    Yaw_rate-Data: 0.007 rad/s
                    Misalignment angle: horiz: 0.095 °
                    Misalignment angle: horiz: fast algorithm: 0.168 °
                    Outside temperature: 22.00 °C
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H36 3122
   Serial number: 003XPM00B22C
   Coding: AAFCF0C0002000009A5400FFF80D41A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 0B43AD2B23C44CD3EA1-805E
   Left seat belt tensioner:
   Serial number: 00AI2018338346700000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2018346619500000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 001 411 18
   Serial number: 35700000000A052CC53L
   Subsystem 4 - Part No SW: -----------    HW: 480 001 411 18
   Serial number: 3580000000077968953R
   Subsystem 5 - Part No SW: -----------    HW: 480 031 711 18
   Serial number: 351001C18E2E0250E87B
   Subsystem 6 - Part No SW: -----------    HW: 480 031 711 18
   Serial number: 352001C18E2E09402D48
   Subsystem 7 - Part No SW: -----------    HW: 480 021 211 18
   Component: FrontSensor_D  000 0149
   Serial number: 3550001102B81AA3011J
   Subsystem 8 - Part No SW: -----------    HW: 480 021 211 18
   Component: FrontSensor_P  000 0149
   Serial number: 3560001102B81AA4057V
   Crash sensor high-voltage system 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 021 211 18
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001062B81AA5070R
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 211 18
   Component: SideSens_B_Df  000 0149
   Serial number: 3520001062B81AA6841Z
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 410 18
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500019F2BE26367328
1065478 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_FGE]
                    Reset counter: 226
                    Mileage: 28856 km
                    Date: 2021.06.14
                    Time: 16:56:13
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 22
                    Reset counter: 1
                    Mileage: 28030 km
                    Date: 2021.05.27
                    Time: 17:20:19
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 79AFE7E379584E43C8D-802C
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: 850400C87C9000080CA6E170B284680008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 46D55C1F7826F1BBF5F-8012
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 254
                    Mileage: 28435 km
                    Date: 2021.06.11
                    Time: 16:47:34
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF06042425101
   Coding: 02030005000100C000810000005B01329C8A004718000000090000DE00000000
   Shop #: WSC 04100 205 00000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 36352CDF08C6613B65F-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 7674960100181126050C
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 18289013306S00304401
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BatteryControl]
                    Reset counter: 250
                    Mileage: 28101 km
                    Date: 2021.05.29
                    Time: 14:15:40
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 162
                    Mileage: 28010 km
                    Date: 2021.05.27
                    Time: 09:54:08
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 162
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:03:48
16711991 - Ethernet Databus Branch 2
          U122D 00 [008] - No Communication
          [Ethernet_databus_no_communication_port_2]
                    Reset counter: 234
                    Mileage: 29263 km
                    Date: 2021.06.18
                    Time: 21:38:49
                    Ethernet counter checksum error: branch 2: 0
                    Ethernet counter connection interruptions: branch 2: 1
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000340825006
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343116D71EBA732B5BB-8060
   Serial number: 00000356599657
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        007 0387
   Serial number: 0000353284485
   Coding: 001FCA0152000480A001B002
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: B4110101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F1FC3E1A8460330D-8064
   Part No SW: 8W0 907 064 GP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0424
   Coding: 017400030FB103616309A0040C00C80200004000804F02582F0400000504823B001F0100010F13
   Shop #: WSC 44528 004 104857
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016.rod
   VCID: 1079BA474AE26F0B1F3-8044
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY182920YDR
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000045880885
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W700005X3
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11340301
   Antenna for short-range communication:
   Subsystem 5 - Part No SW: 4N1 927 753     HW: 4N1 927 753
   Component: NFCTGS  H13 0050
   Serial number:            382823425
   Antenna 2 for short-range communication:
   Subsystem 6 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Component: NFCMIKO  H41 0034
   Serial number: 4418000231080016
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 429 B    HW: 4KE 945 429 B
   Component: T2 LH ECE HD  H12 0403
   Serial number: A1WK0002MWX
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000549
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4KE 945 430 B    HW: 4KE 945 430 B
   Component: T2 RH ECE HD  H12 0403
   Serial number: A1WL0002MWY
65732 - Databus
          [Engine control module: Motor_14: no signal/no communication]
                    Reset counter: 241
                    Mileage: 28870 km
                    Date: 2021.06.14
                    Time: 17:28:24
                    Supply voltages-Terminal 30 power supply: 13.560 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.628 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.587 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
                    general_additional_freeze_frame-Vehicle speed: Not available
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 241
                    Mileage: 28043 km
                    Date: 2021.05.28
                    Time: 20:46:12
                    Supply voltages-Terminal 30 power supply: 12.827 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.908 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.854 V
65729 - Databus
          [Brake control module: ESP_05: no signal/communication]
                    Reset counter: 241
                    Mileage: 28029 km
                    Date: 2021.05.27
                    Time: 17:13:26
                    Supply voltages-Terminal 30 power supply: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.663 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H02 0010
   Revision: --------    Serial number: -00103.10.18000
   Coding: 01000000000000000000
   Shop #: WSC 44528 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D38EF3CDE855B817-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 08:50:31
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       007 0387
   Serial number: 0000349865601
   Coding: 001FCA015E000480A001B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 45D75B134520FAA3FC5-8010
   Part No SW: 4K0 035 063 D    HW: 4KE 035 063
   Component: MU-H-LND-EU   046 2711
   Coding: 01157601FF0A000043111101C00802302F0001E4037008008E
   VCID: 2411E697AE5AE3ABCBB-8070
   Subsystem 1 - Part No: V03 959 807 SE
   Component: MIB2P_EU_Q420  0490
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00119091800130138
   Compact disc data bank:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004418000229020010
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00115091800140133
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800690324010
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 234
                    Mileage: 29263 km
                    Date: 2021.06.18
                    Time: 21:39:02
                    Voltage terminal 30: 14.2 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: 38 °C
                    Temperature of MOST transceiver-Up-to-date: 38 °C
7237 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 216
                    Mileage: 30105 km
                    Date: 2021.07.05
                    Time: 12:54:45
                    BAP-BAP_Function_ID: 02
1561 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 234
                    Mileage: 29261 km
                    Date: 2021.06.18
                    Time: 21:36:46
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0500244408
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [008] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:52
   Component: RVC Compact   H15 0250
   Coding: 0215060103002005C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 333315CB1BB47413421-8066
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 33B0
   VCID: 4ACD682F6C3E15DB117-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 0611181032
   Coding: 98D8607BDA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45A43F50D679FB0DF-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130436323
   Coding: 303030
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F110204
   Coding: 01C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809F2A7D27207CBE73-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145RLA00070
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C213EF736EABB6B93B-8068
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 41DF4F035108D683C0D-8014
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 A
   Component: BJB_MLBBEV  H12 0369
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Coding: 0421840000000000000C060000D4462E189E57000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F5B09FB677C6073F69-802A
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 85
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:08
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       006 0387
   Serial number: 0000354796509
   Coding: 000FC80100000480A000B000
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   VCID: 48C952277232E7CB073-801C
   Component: TSG HBFS      006 0387
   Serial number: 0000354796516
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0012129
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.6V.1A20370031
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 B    HW: 4G0 816 797 B
   Component: J842 EKK es33  H03 0004
   Serial number: 00000000018100200150
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Coolant heating:
   Subsystem 5 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.7V.4C20370097
   Expansion valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150492381
   Shut-off valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130452272
   Shut-off valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130452271
   Shut-off valve 4 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130452092
   Shut-off valve 5 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130452243
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181114020103052736
   Radiator louver 2:
   Subsystem 12 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V550KJS2  H12 0109
   Serial number: 20181110020103053781
   Coolant valve 1:
   Subsystem 13 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000022208
   Coolant valve 2:
   Subsystem 14 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000013520
   Coolant valve 3:
   Subsystem 15 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000032532
   Coolant valve 4:
   Subsystem 16 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000025527
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F58C5FA886413B85F-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190703030206084246
2097938 - Charging Socket B; Charging Plug Lock
          P33E9 00 [032] - Mechanical Malfunction
13705549 - Databus
          U1121 00 [040] - Missing Message
          [DCDC_01_Timeout]
                    Reset counter: 34
                    Mileage: 29830 km
                    Date: 2021.06.28
                    Time: 18:01:10
13709330 - Unknown Error Code
          U15C9 00 [032] - -
          [LMSF_intervention]
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 35372BD315C06A236C5-8060
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H02 0010
   Revision: --------    Serial number: -00118.10.18000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E2534FF20F6A97BBDF-806A
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 08:50:31
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 A    HW: 4N0 035 773 A
   Component: WLC Front NFC H11 0061
   Coding: 808000
   VCID: 2C010EB7C68A2BEB03B-8078
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDB49FB27FCA073B69-806A
End----------(Elapsed Time: 02:43, VBatt start/end: 13.1V/13.1V)-----------
I'm sure the RT staff and other members will be along shortly....... In the mean time, try opening the hood and then see if that 09 module "wakes up" ! (doors closed and unlocked, hood open) ???
Given the number of Databus faults in this vehicle, I'm inclined to think there's something wonky in the vehicle itself.
But it sure can't hurt to have the hood open, then lock and unlock the doors...
Hi Uwe, I did notice all the "status: Malfunction" 0010 's (all Twelve of them!) , but I thought with such a new vehicle and only 18K mileage the scan was "inaccurate". Now that you've looked it over its legit. Starting to wonder if 09 module is even plugged in! (water ingress ????)
vihijtap
Finland
C?ID=432279
Thanks to both of you for such swift replies!
I indeed had the hood open, doors unlocked and closed. At one point I was, for a short period, able to access the module, so it is plugged. Water might be one possible cause, as I washed the car the day before autoscan.
I will have to take the car to the dealership for checkup, the number of faults is a bit worrisome, especially as they all seem to have occurred wit mileage >28000 km’s. A few of the messages however are related to my trailer. I bought the car two months ago with mileage of 26700. No malfunction messages in the log before I bought it 🧐
I was about to ask you if there was a "back story" to your vehicles faults ; perhaps you could unplug the trailer electrical connection and rescan ? Did you install the electrical trailer harness ? Is it a oem or custom harness ?
vihijtap
Finland
C?ID=432279
The trailer harness is a factory installed harness. The trailer hitch was never used before I started using it. The problem is in my trailers lights (backed it up to a rock a couple years back, never got it to work properly after that).
More telling than the number of modules that report malfunctions is the nature of those malfunctions. Most of them are databus type faults. I really don't know what to make of this. To my eyes at least, there's no clear pattern that points at a specific thing that might be causing it all.
V , is this by chance a boat trailer ? Was the trailer in water when you backed into "the rock"?
Uwe, why are Databus faults so concerning? Blocked , no data flow ?
Well, the main issue here is communication faults with the 09-BCM module...
Have you seen this before where the Gateway list shows 09 is status "ok" but the scan shows otherwise. ? I wonder what would happen if 09 was unplugged and then a new scan ?
I don't know how often the GW updates that status, and the OP did say he can communicate with the BCM sometimes.
vihijtap
Finland
C?ID=432279
No, it is not a boat trailer just an ordinary one. I will have to check the socket seal for moisture, since it has two cables attached in one socket with a single cable gasket (rubber sealing ring).
V , ultimately I hope you let the forum know what you find and how the faults sort out! Future autoscan after the correction/repair.
vihijtap
Finland
C?ID=432279
I just had the car checked by the dealer, and they cannot access the module either. Apparently the module functions fine as the car runs fine, but it cannot be accessed. I have a time reserved with a car electrics specialist at the dealer for 16th of August, hopefully I know more after that. I will also have to start discussions with the company that sold the car about who is going to pay for the checking and subsequent repairs. The specialist charges 136€/hour (abouy 160 USD/hour)...
  • Informative
I suppose that's not exactly good news for you, but at least it puts my mind to ease, knowing that this isn't a problem with VCDS.
Crashking
Stuart, Fl
C?ID=208398
I would like to add that the newer cars do seem to always have a slew of data bus faults stored. typically those are ignored and you go after the one that has a unique fault.
Also, there is a built in Diagnostic database firewall being equipped from the factory, to prevent the vehicle from being "hacked" and the hood must be opened to disable it. there is a time/mileage period when the vehicle is new its not active, and a time/mileage period after the hood is opened that it re-activates (I want to say 30 miles, its been awhile since I read about it in the SSP)
