2013 vw t5.1 cruise control fault
Sven Hatch
Hi everyone
I’ve got a fault with the ccs system on my 2.0 t5.1,
the switch on the stalk Used to display the cruise option on the cluster it no longer does, I’ve only got advanced measuring blocks in VCDS
when testing ccs system IDE00356 it’s value is 8 with clutch pedal in goes to 12 and with brake pedal in goes to 15 with just brake pedal goes to 11, it says switch position 0-7 in bits I’m I right in assuming the clutch switch is high in value ?
also where can I test the stalk on off switch in advanced blocks?
Many thanks
Sven
Trowbridge, UK
We definitely need you to post a full unedited VCDS Auto-Scan so we can see how your T5.1 is equipped.
  • Agree
Sven Hatch
Saturday,03,July,2021,16:13:46:50405
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4544.4
VIN: WV1ZZZ7HZDH105677   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 77 0B
VIN: WV1ZZZ7HZDH105677   Mileage: 123550km-76770miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   X45 8437
   Revision: 26X45---    Serial number: 00000000000000
   Coding: 01194012232400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003006
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77AB15388F410AE3BE9-8022
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A40A9A24A89178A96510
   Shop #: WSC 02736 790 49152
   VCID: 3A2DCC0CFC53D78B817-806E
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CA10A14B66729BBD3B-8028
   Part No SW: 7H0 937 087 K    HW: 7H0 937 087
   Component: BCM T5GP H+4  H32 0407
   Revision: BO032001    Serial number: 0533 051130234
   Coding: B0A0303A0A612431922848107C6B8C540080430F60840000320000000000
   Shop #: WSC 02736 790 12345
   VCID: 3C21CA14F667E9BB93B-8068
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 32961303401637
   Coding: 108001
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3A2DCC0CFCD3D78B817-806E
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00GBPBI
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3537DF30D5CD38F36C5-8060
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 760A01
   VCID: 2E05F05C309B0B2B2DF-807A
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H32 0407
   Revision: BO032001
   Coding: 042300
   VCID: 70B92E24EAAF5DDB7F3-8024
01304 - Radio
                    Reset counter: 57
                    Mileage: 123554 km
                    Date: 2015.11.24
                    Time: 16:11:27
   Component: IMMO          H06 0605
   VCID: 6A8D3C4CCCF3A70B317-803E
Address 56: Radio
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007664343921
   Coding: 0A01010000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VN75.rod
   VCID: 392FD300F9D5DC9388D-806C
          B104F 13 [009] - Short to GND
                    Reset counter: 57
                    Mileage: 123554 km
                    Date: 2021.07.03
                    Time: 16:11:23
          B104E 13 [009] - Short to GND
                    Reset counter: 57
                    Mileage: 123554 km
                    Date: 2021.07.03
                    Time: 16:11:23
0022 - Radio
          U1066 00 [009] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 57
                    Mileage: 123554 km
                    Date: 2021.07.03
                    Time: 16:11:24
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
Done hope this is correct
Thanks Sven
Did this vehicle come with CCS from the factory or is this a retrofit?
Sven Hatch
Factory fitted its high line spec
Sven Hatch
Thank you Uwe
Sven Hatch
Anyone help with this ?
Trowbridge, UK
A question for the experts - should this engine ECU show the G when cruise has been enabled?
Sven Hatch
Not yet I’ll check shortly thank you
iichel
Eindhoven, NB, NL
C?ID=284912
it's byte 5 bit 5 on most modern ECU's of the PQ era. byte 17 bit 7 of the bcm in PQ25.
you can have a look at advanced measurement values of the BCM, search for 'crui' and check all the four values. this way you can test the reception of signals for the bcm
