- Jan 18, 2015
- 22
- 19
- USA
- C?ID=235721 (his son)
Well after a very interesting weekend for me and my father, swapping out my automatic 09A and replacing it with the manual 02M transmission, we have some interesting new fault codes that have shown up. So far everything seems to run fine in the car with the manual (except the fact that I currently have no speedometer at the moment because of a missing plug). we ran vcds to see how pissed off the vehicle was for throwing all sorts of gizmo's at it and surprisingly it was only these two codes.
Now I have no idea what these fault codes mean or if it is something easy or hard to fix. Either way I would very much appreciate some helpful info as to what this is. Thank you in advance.
Sunday,19,April,2015,18:04:51:31462
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VWSR69M25M033882 License Plate:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 997 016 R HW: 028 101 181 2
Component and/or Version: R4 1,9L EDC G000SG 0282
Software Coding: 0150031
Work Shop Code: WSC 05232 444 85902
VCID: AD124E4B356B5849759-5184
19460 - Relay for Low-Output Preheating of Coolant (J359)
P3004 - 000 - Open or Short to Ground
RPM: 882 /min
Torque: 44.0 Nm
Voltage: 13.91 V
Bin. Bits: 00101000
Load: 48.2 %
Bin. Bits: 11000001
19462 - Relay for High-Output Preheating of Coolant (J360)
P3006 - 000 - Open or Short to Ground
RPM: 882 /min
Torque: 44.0 Nm
Voltage: 13.91 V
Bin. Bits: 00101000
Load: 48.2 %
Bin. Bits: 11000001
Readiness: 0 0 1 1 1
