Trouble accessing 09 Long coding
bspex
Japan
C?ID=443392
This is the Autoscan from 2019 VW Golf7.5. I am still new to VCDS but having an issue accessing module 09 Long coding.
Current coding is showing all 00000000000000000000000000000000000000000000000000000000000
Any advice would be appreciated. Thanks
Wednesday,30,June,2021,09:21:30:16075
VIN: WVWZZZAUZKW134902   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 42 44 4B 52 57 5F A5 D6 D7
VIN: WVWZZZAUZKW134902   Mileage: 51791km-32181miles
Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CE    HW: 04E 907 309 A
   Component: R4 1.2l TFS   H13 9096
   Revision: WAH13---
   Coding: 01250012236401083000
   ASAM Dataset: EV_ECM12TFS01104E906016CE 001006
   ROD: EV_ECM12TFS01104E906016CE.rod
   VCID: 678BB291AFEE38832E9-8032
   Part No SW: 0CW 300 043 A    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501902076773
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 353728D9A5C29A136C5-8060
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60409000000770
   Coding: 01FA8AA12023217047800600A0C52580510484E26005A4731822F078D2224B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AFE4E9C95ABE73C8D-802C
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0507843738
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34601FB1634A3D21-8016
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 00120004100100011105000010101022
   VCID: 6C81CDBDB6081BDB43B-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001904900139
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B43AE2193C6BCE3EA1-805E
   Component: WWS    190122  042 0551
   Serial number:         190201103321
   Component: RLHS  052 0107
   Serial number: SBY19M02D22H19M33S32
   Coding: 31E8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000013021904221177
          B1263 01 [009] - Electrical Failure
                    Reset counter: 20
                    Mileage: 51775 km
                    Date: 2021.06.23
                    Time: 18:28:06
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3300074159FFC728949C810580400600000000000000000004
   VCID: 44D1451DFE18339BEBB-8010
   Part No SW: 5Q0 959 655 CA    HW: 5Q0 959 655 CA
   Component: AirbagVW21    007 0403
   Serial number: 003FPR50KHH0
   Coding: 98FCC0C0000000005C5400CF008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 015F8C09A18AE6B380D-8054
   Left seat belt tensioner:
   Serial number: 34169677E20021921491
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E19021930511
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 802 19
   Serial number: 357000000007C860893P
   Subsystem 4 - Part No SW: -----------    HW: 480 001 802 19
   Serial number: 35800000000C955DC93+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 902 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001B12E4B1B59575
   Subsystem 6 - Part No SW: -----------    HW: 480 402 102 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001182C009A6D51Z
   Subsystem 7 - Part No SW: -----------    HW: 480 401 902 19
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A92E6E372E71H
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27A402186F80000E02886A031400000080000000
   VCID: 2B030EA17386DCE30A1-807E
   Serial number: 08011910523549
   Coding: 030100047F085708FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C7B58014E9CB6DF-803A
   Generator:
   Component: 0-00-02-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39190000035460059046
   Coding: 2DFFFF
   Serial number: 3785410405
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000022635003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1CC951AAB63330D-8064
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SB20033D
   Coding: 00311320D001048000001000
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000027609975
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 11170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D5DDEE38C31B9BB-8020
   Component: FCM MQB Low   002 0345
   Serial number: 05021910523580
   Coding: 000000070900164600000101020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SA90540A
   Coding: 00311120DC01048000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000027659696
   Coding: 150000
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 129 F    HW: 8V0 919 129 D
   Component: JP-DTV        H12 2110
   Coding: 02041C0000000100000002
   ASAM Dataset: EV_TVMELC 001039
   ROD: EV_TVMELC_VW37.rod
   Part No SW: 5NA 035 050 D    HW: 5NA 035 050
   Component: MU-H-N-JP     055 1101
   Serial number: K5F AW7ZF196YV
   Coding: 02731006FF00000051380001001038001F0100F601200400FE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJW0470276
   Subsystem 2 - Part No SW: V03 959 801 BR    HW: -----------
   Component: JPN 2018/2019  --- 8011
   Control module for chip card reader:
   Subsystem 3 - Part No SW: 4K0 919 813     HW: 4K0 919 813
   Component: ETC2.0 UNIT  H03 0002
   Serial number: 547148152745
   Traffic data antenna:
   Subsystem 4 - Part No SW: 8V0 035 504 C    HW: 8V0 035 504 C
   Component: VICS Antenna  H08 0002
   Serial number: 551140020102
   Compact disc data bank:
   Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 2017
2570 - Control Module for Smart Card Reader
          B128F 31 [008] - No Signal
                    Reset counter: 63
                    Mileage: 43978 km
                    Date: 2020.11.23
                    Time: 13:41:08
                    Voltage terminal 30: 13.0 V
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 14091815K21351
   Coding: 0003070000000501000223448140A90084000E200000
   VCID: 3C213DFD86E84B5B93B-8068
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025D8305A48CFDAB997-8056
   Component: LED1R         H07 0009
0832 - Static Cornering Light
          C119A F6 [032] - Over-Temp Protection Active
End----(Elapsed Time: 01:35, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Trowbridge, UK
That's because some newer modules no longer use coding, all configuration is done using adaptation channels.
