Audi TT 8S Auto Hold retrofit coding not possible
vastechnics
C?ID=143747
I'm trying to retrofit Auto Hold on Audi TT 2018 model. I have tried different security codes like:
24990 - refused
20103 - accepted no coding possible
40168 - accepted no coding possible
01153 - accepted no coding possible
I have tried coding same like 8V Audi A3. On german forum they say same. Correct me if im wrong.
byte 8 - 03
byte 19 - C0
byte 23 - F7
byte 25 - 41 (automatic)
Friday,02,July,2021,16:31:13:43540
VIN: TRUZZZFV8K1******   License Plate: KEVINWONGTT
Mileage: 20591km-12794mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 3C 42 44 47 52 55 5F 6C
          A5 A9
VIN: TRUZZZFV8K1004563   Mileage: 20591km-12794miles
Address 01: Engine (J623-DKTB)       Labels: None
   Part No SW: 8S0 906 259 N    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0A2540122426050B3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259N 001003
   ROD: EV_ECM20TFS0208S0906259N.rod
   VCID: 48C8AE8512395A0B073-801C
Readiness: 1010 0001
   Part No SW: 0GC 300 013 N    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2F3AE5199797ED33269-807A
   No subsystems:
   Part No SW: 8S0 907 379 K    HW: 8S0 907 379 F
   Component: ESC           H42 0542
   Revision: 00000000    Serial number: 63508000000524
   Coding: 32AAE08D0A9915AD4196006AC2949706334C0750A8820043E960CC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 49CEAB810933A30318D-801C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0502317528
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E24C85D40FD14BBBDF-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 19100000009000
   Coding: 400040000011101100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C8032156601562B43B-8038
   Humidity sensor: exterior:
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000052647
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001901301854
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA60F510D7BCFA3E45-8028
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 180723  038 0371
   Serial number: 00000001807170303943
   Coding: 1BC7F7
   Serial number: 21764231X81A955547A0
   Coding: 00005D
   Serial number: 05 09 2018  20001328
   Valve block 1 in front seat driver side:
   Subsystem 4 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0021
   Serial number: 7008173235E183605457
   Coding: 810500
   Valve block 1 in front seat passenger side:
   Subsystem 5 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H07 0021
   Serial number: 7008173235E183605536
   Coding: 810500
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 198
                    Mileage: 20591 km
                    Date: 2021.07.02
                    Time: 14:59:15
   Part No SW: 5Q0 919 294 M    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0545
   Revision: --------    Serial number: 39331900300848
   Coding: 0070151051
   ASAM Dataset: EV_EPHVA18AU3700000 003027
   ROD: EV_EPHVA18AU3700000_003.rod
   VCID: 45D6A7B1252B4763FC5-8010
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R02NEP.
   Coding: 88CCF0C00C8000005C5000CFC04800000065
   VCID: 4DC69F91FD5BBF23345-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: 35700000000D042DE63R
   Subsystem 2 - Part No SW: -----------    HW: 480 001 201 19
   Serial number: 35800000000A142DE63Q
   Subsystem 3 - Part No SW: -----------    HW: 480 010 201 19
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0DE8B2E62BF0U
   Subsystem 4 - Part No SW: -----------    HW: 480 400 301 19
   Serial number: 3550001142BF5A83C122
   Subsystem 5 - Part No SW: -----------    HW: 480 400 301 19
   Component: FrontSensor_P  004 6149
   Serial number: 3560001142BF5A84C1DF
   Subsystem 6 - Part No SW: -----------    HW: 480 401 412 18
   Component: PedP_Sensor_C  004 6149
   Serial number: 2300001162BF5AA154A0
   Subsystem 7 - Part No SW: -----------    HW: 480 001 001 19
   Serial number: I0M00000000FD89C963T
   Subsystem 8 - Part No SW: -----------    HW: 480 001 001 19
   Serial number: I0N000000001969C963A
   Part No SW: 8S0 907 129 BE    HW: 8S0 907 129 BE
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335SAL01162
   Coding: 281C
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 7EA4085D007DD4BBFDF-802A
   Part No SW: 8S0 920 790 D    HW: 8S0 920 790 D
   Component: FBenRDW       H45 0359
   Coding: 04A50040698E00080020E8C89000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001032
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 3A2CC44D5CD5389B817-806E
   Part No SW: 8S0 907 468 J    HW: 8S0 907 468 E
   Component: GW MQB TT3    023 0366
   Serial number: 16121811600749
   Coding: 030100042F025B004B00026A3C0B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013025
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 47CAADB91F2755730E9-8012
   Generator:
   Component: 1-01-0d-01-04
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20181016011153 00107
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 0400629604
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7756
   Serial number: HA1-00003.12.18
   Coding: 0101
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H06 0050
   Serial number: 0343605385
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA002551661C6ABD3B-8028
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H06 0050
   Serial number: 0344383481
   Coding: 030311
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RLB22765
   Coding: 001F53225000000100001402
   VCID: 44D0BAB52E117E6BEBB-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C20C25556E106AB93B-8068
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5C00E19G
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 3430EA757EB1CEEB5BB-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RJP2038A
   Coding: 001F53225400000100001402
   VCID: 43D2B9A92B1F7953D21-8016
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03EA02202B170200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 3634D07D68CDDCFB65F-8062
   Coding: E01400
   Coding: E01400
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01400
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01400
   Power module 1 for left matrix headlamp:
   Subsystem 5 - Part No SW: -----------    HW: -----------
   Component: MxB LeiMo li.  H05 S007
   Coding: E01400
   Power module 1 for right matrix headlamp:
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: MxB LeiMo re.  H05 S007
   Coding: E01400
   Part No SW: 8S0 035 021 M    HW: 8S0 035 021 K
   Component: MU-H-LND-EU   055 1339
   Serial number: A710A0KS010693
   Coding: 013304010000000011111102000A00332F0000E1007000009E
   VCID: 3332E9697BBFC9D3421-8066
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK119101800010137
   Compact disc data bank:
   Component: Gracenote2  --- 1017
   Component: RVC Compact   H15 0231
   Coding: 0233040102002001000040
   VCID: 392EDB4159D3338388D-806C
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000648429
   Coding: 0101040001010305000501010000000100
   ROD: EV_MFKBoschAU370.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8S0 907 159 E    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 181123200517
   VCID: 3FDAB55947F71DB3B69-806A
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
