- Feb 26, 2016
- 141
- 34
- Czech Republic
- C?ID=91614
Hello
i made retrofit for Keyless go:
2x Antena 8K0907247
1x 5th door switch 4G0959831B 5PR
1x 5th door unit 3AA962243D + antena + cable
4x Door handle sensor 4G8927753B (ALIExpress) + cables
1x 46 Comfort unit 4H0907064GP - fitted in AUDI service with key programming
After swap 46 Comfort unit in Audi before i made kessy retrofit - from 4H0907064FN to 4H0907064GP - everytime i would like to start car, in Instrument cluster is warning - attach the keys to the dashboard!
Then it starter. In unit was error about missing antenas.
So ok, i think that it is problem of this antenas.
But now i have all units retrofited and also code it and Keyless does not still work. Any idea?
I tried in VCP also upload file A7_start_auth_4h0907064BP,BR,BT,DB,DC,Dx,Ex,Fx,Gx.zdc to 46
But it ended with error :-/
Also new ventilated seats with massage was retrofited but not sure how i clean this error in 88 and 89???
Here is scan:
2x Antena 8K0907247
Here is scan:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 36 3B 3C 42 44 46 52
53 55 5F 62 6D 72 88 89 AC
VIN: WAUZZZ4G6FN044702 Mileage: 240017km-149139miles
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 1649
Revision: 85H23---
Coding: 12254012232401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ_002.rod
VCID: 79BA196AF8E9F24384-802C
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 G HW: 0CJ 927 156
Component: 0CK 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000002243
Coding: 100001
Shop #: WSC 30838 004 1048576
ASAM Dataset: EV_TCMDL382021 002028
ROD: EV_TCMDL382021_AU49.rod
VCID: 2E10FA367127E5FB61-807A
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041170332003398
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 06A29E41604579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FCEB772A64D1C73FA-806A
Part No SW: 4H0 907 064 GP HW: 4H0 907 064 GP
Component: BCM2 2.0 H37 0572
Coding: 0189700E000000000000
VCID: 7DB20D7AE4C1CE63A8-8028
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0157
Revision: AA000000 Serial number: 00000152599056
Coding: C018320085006201010001010101112030303333283333
VCID: 3A38C666B56F395BCD-806E
Part No SW: 4G0 820 043 CE HW: 4G0 820 043 CE
Serial number: 17041800040902
Coding: 3402097E210000
VCID: 6484581E6F6B1FAB47-8030
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000956571002
Coding: 0105001450F49FE001014084E0001800CF9CC6082608020100000814E111140200400024030000
Shop #: WSC 22675 401 12345
VCID: 71AA214AA899BA033C-8024
Component: WWS57X 141109 H37 0080
Serial number: 141114150030
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23501075
Coding: 03006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 22 11 2014 00000555
Serial number: AD188E57000000000001
Revision: -------- Serial number: 003P1002E079
Coding: 30333130313830313833554A304C34473053
VCID: 3B36C362B2550053D6-806E
Serial number: 3575HRB40692QMKADH6
Serial number: 3585HRB40572ORMG1OPI
Serial number: 3515JRB404T32I4KK8EP
Serial number: 3525JRB404T32I4KDHCQ
Serial number: 3554VRB405H32PV6C85W
Serial number: 3564VRB405732PV6CGJ2
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862NKP001J4
Coding: 000035
VCID: 3B36C362BA550053D6-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 04 11 2014 10007750
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H07 0043
Revision: 03001036 Serial number: 658261114592008
Coding: 03AF12000B410008080000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E30CA76A147157BF1-806A
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001644078
Coding: C0CD074418
VCID: 75A2155AD4F19623E0-8020
Serial number: 2715675003
Voltage stabilizer:
Serial number: 14091800000000000059
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CB4007EFFDBC76B9F-8028
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 27111400040081
Coding: 20
VCID: 3D32CD7AAC410E63E8-8068
Component: MEM-FS H04 0157
Revision: AA000000 Serial number: 00000152598571
Coding: C018330085016201010001010101112030303333203333
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720DTZMG
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3326EB429A05C8130E-8066
Component: SWA Master H08 0070
Serial number: 0432084805
Coding: 040311
Shop #: WSC 22675 401 00000
VCID: 393AD96AB8693243C4-806C
Component: SWA Slave H08 0070
Serial number: 0431896700
Coding: 040311
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17015E00620002080012
VCID: 47DEAF92F69D54B342-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0013202325
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0403807976
Coding: 01001E3820B930818320090000030F4F0000000000000000000000000000
Subsystem 1 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93933666
Component: TSG BF H03 0507
Coding: 011F17015E00620002080002
VCID: 46C0A296F1974DBBB9-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001285373
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D12FD3A7C219EE358-8078
Component: MxB-ECU 001 0100
Coding: 04DA06102A630200
VCID: 3424E85E9F0BCF2B17-8060
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 044 M HW: 4G1 035 044
Component: MU-H-LN-EU 040 1425
Serial number: A589K0E7501633
Coding: 01750201FF0A000013110001000A00102F0006E5F1700100FF
VCID: 291A092A48C982C3B4-807C
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9EY8007PM
Serial number: 90349NKM000ZO
Compact disc data bank:
Component: Gracenote2 --- 1012
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 49DAA9AAE089A2C354-801C
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 325400984
Coding: 093205C030
ROD: EV_HDSGAu571.rod
VCID: 3620D2568977DD3B29-8062
Component: TSG HR H03 0507
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4G8 881 073 HW: 4G8 881 073
Component: P2G H02 0032
Serial number: 0F5R4MU
Coding: 767FF0
ASAM Dataset: EV_P2GDriveSideFrnt 001006
ROD: EV_P2GDriveSideFrnt.rod
VCID: 6E903A36B1A7A5FB21-803A
Valve block 1 in front seat driver side:
Subsystem 1 - Part No SW: 4G8 907 181 HW: 4G8 907 181
Component: PSLB H02 0023
Serial number: 00000000000000F5T5E2
Valve block 2 in front seat driver side:
Subsystem 2 - Part No SW: 4G8 907 182 HW: 4G8 907 182
Component: PSML H02 0023
Serial number: 00000000000000F5J44C
Valve block 3 in front seat driver side:
Subsystem 3 - Part No SW: 4G8 907 182 HW: 4G8 907 182
Component: PSMR H02 0023
Serial number: 00000000000000F5J2A9
0018 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Funktionseinschränkung wegen fehlender CAN-Botschaft]
Reset counter: 186
Mileage: 240016 km
Date: 2021.07.02
Time: 10:27:27
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 0F5R5QW
Coding: 366FF0
ASAM Dataset: EV_P2GPasseSideFrnt 001006
ROD: EV_P2GPasseSideFrnt.rod
Valve block 1 in front seat passenger side:
Serial number: 00000000000000F5V571
Valve block 2 in front seat passenger side:
Serial number: 00000000000000F5J2C6
Valve block 3 in front seat passenger side:
Serial number: 00000000000000F5J2BZ
U1111 00 [009] - -
Reset counter: 186
Mileage: 240016 km
Date: 2021.07.02
Time: 10:27:27
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 143110282
ROD: EV_RDCMA00100.rod
VCID: 2B16F322423590D346-807E
