Hi Everyone
Have Golf MK7.5 SE someone fit GTE LED headlight and Bumper including DRL
First, I have no communication with D6 Module but was wiring wrong done
now I have communication to D6 D7 Module
The issue I have no Indicators, no High Beam, no DRL
I've done a full scan and look like need help coding as Car still Register Standard Headlight
and 09 Module in Coding Have all 0000000000000000000
Any Help will be appreciated
Regards Chris
Regards Chris
Thursday,01,July,2021,13:53:54:65482
VCDS Version: 21.3.0.0 (x64) HEX-NET2 CB: 0.4544.4
VIN: WVWZZZAUZJW071385 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F D6 D7
VIN: WVWZZZAUZJW071385 Mileage: 53140km-33019miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS X26 2833
Revision: R7X26---
Coding: 0125003223641D082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6B88AEEC130A0CF34A1-803E
Center armrest control head 1:
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:21
Engine RPM: 0.00 /min
Coolant temperature: 17 °C
Intake air temperature: 19 °C
Voltage terminal 30: 11.991 V
Outside temperature: 16 °C
Absolute intake pressure: 100 kPa abs
Engine torque: 0.0 Nm
Fuel level: 5.00 l
Oxygen sensor B1: sensor 1: specified value: 15.9998
Intake camshaft B1 active operating state-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0000
Part No SW: 0CW 300 041 HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1010
Revision: 00005026 Serial number: CU501708138517
ROD: EV_TCMDQ200021_VW26.rod
VCID: 72B6B3883420DD3B897-8026
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62177000001965
Coding: 01FA8AA12427216D477A060840C82980512484E26002947338225078C202430000000012121212B835351919323200
VCID: 77A0829C5F42B813BE9-8022
8192 - Databus
[FCAN: ACC_07 message is not received]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:20
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:20
Part No SW: 5G0 907 426 AQ HW: 5G0 907 426 AQ
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00120004200110001000000000000002
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 7AA69BA86C50A57BC17-802E
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:20
Outside temperature: 17.0 °C
Engine RPM: 0 /min
Temperature downstream of evaporator: 18.0 °C
System run time-Terminal 15 on: 255 s
Part No SW: 5Q0 937 084 CN HW: 5Q0 937 084 CE
Component: BCM MQBAB M H36 0253
Serial number: 01001723500224
ROD: EV_BCMBOSCH_018.rod
VCID: 065EFF5828A8D19BB5F-8052
Wiper motor control module:
Component: WWS 170728 042 0551
Serial number: 170814194637
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S6Y17M08D28H19M15S45
Coding: 00A8DD
Serial number: 000000000ZY172040QE3
Serial number: 00000000000070353102
5130 - Bulb for Front Left Turn Signal
B11E8 15 [009] - Open or Short to Plus
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 12:50:34
5386 - Bulb for Front Right Turn Signal
B11EA 15 [009] - Open or Short to Plus
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 12:50:31
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617230
Coding: 0471051811
ROD: EV_EPHVA18AU3700000.rod
VCID: 4BC80E6C734AECF32A1-801E
12727553 - Databus
[Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:21
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR378BPI
Coding: 98CCC000000000005C0000CF008800000065
VCID: 0944F46439B6BEE3D8D-805C
Left seat belt tensioner:
Serial number: 34169677E28081741024
Coding: 333135
Right seat belt tensioner:
Serial number: 34169676E28081750460
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 808 17
Serial number: 3570000000037D5C772S
Subsystem 4 - Part No SW: ----------- HW: 480 002 808 17
Serial number: 358000000006865CD72W
Subsystem 5 - Part No SW: ----------- HW: 480 402 608 17
Serial number: 35100019F266F481759B
Subsystem 6 - Part No SW: ----------- HW: 480 402 408 17
Serial number: 3520001C92527AF5F73H
Subsystem 7 - Part No SW: ----------- HW: 480 402 408 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C92527AF4D66J
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 23081708490441
Coding: 0410
VCID: 0256E3480480EDBB997-8056
Part No SW: 5G1 920 940 C HW: 5G1 920 940 C
Component: KOMBI 202 0310
Coding: 27A529082780060001886B011401000000000000
VCID: 280291E0C27CE7EBE73-807C
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:22
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 433 4303
Revision: -------- Serial number: 0006722670
Coding: 030100047F085700FB00005C1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 3338768C0BBA9433421-8066
Generator:
Serial number: 39170002007400077282
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 3976035104
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:20
Terminal 30 power supply: 11.9 V
Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
U0047 00 [008] - Performance
[Globaler Timeout CAN-Extended]
Reset counter: 12
Mileage: 53140 km
Date: 2021.07.01
Time: 11:59:41
Terminal 15: OFF
Component: TSG FS 020 0041
Serial number: 120817EHB32452
Coding: 00310220D001048000001000
VCID: 43D8264C5B1A24B3D21-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000015935934
Coding: 0D0000
65608 - Lamp for Ambient Speaker Illumination
B13C8 01 [008] - Electrical Failure
Reset counter: 12
Mileage: 53140 km
Date: 2021.07.01
Time: 12:35:33
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45DC3854552E1A83FC5-8010
Component: TSG BFS 020 0041
Serial number: 120817EHB15606
Coding: 00310020DE01048000801000
VCID: 42D6234844002DBBD97-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000016026756
Coding: 150000
Reset counter: 12
Mileage: 53140 km
Date: 2021.07.01
Time: 12:35:33
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER H41 0449
Serial number: VWZAZ2T1570407
Coding: 02731001FF00000051110101008808001F0501C601200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 32367388F4A09D3B497-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT2312807
Data carrier:
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:21
Voltage terminal 30: 11.9 V
BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 227
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:22
Voltage terminal 30: 12.0 V
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EAE97B87078895BFDF-802A
0272 - Databus
U1121 00 [237] - Missing Message
[can message LED_Soll_Fktx missing]
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0336 - Databus
[can message AFS_Soll_Fkt missing]
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0337 - Databus
[can message LWR_Soll_Fkt missing]
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0338 - Databus
[can message LCM_Soll_Fkt missing]
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0774 - Light Bulb for Low Beam
C1198 29 [174] - Signal Implausible
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 12:50:27
1061 - Supply Voltage for Logic
C121F 13 [175] - Open Circuit
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
0272 - Databus
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0336 - Databus
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0337 - Databus
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
0338 - Databus
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 12:50:27
Reset counter: 0
Mileage: 53140 km
Date: 2021.07.01
Time: 11:51:19
End----(Elapsed Time: 01:23, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
