VW Golf MK7.5 GTE Headlight Coding
chrisogor
C?ID=151011
Hi Everyone
Have Golf MK7.5 SE someone fit GTE LED headlight and Bumper including DRL
First, I have no communication with D6 Module but was wiring wrong done
now I have communication to D6 D7 Module
The issue I have no Indicators, no High Beam, no DRL
I've done a full scan and look like need help coding as Car still Register Standard Headlight
and 09 Module in Coding Have all 0000000000000000000
Any Help will be appreciated
Regards Chris
Thursday,01,July,2021,13:53:54:65482
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4544.4
VIN: WVWZZZAUZJW071385   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F D6 D7
VIN: WVWZZZAUZJW071385   Mileage: 53140km-33019miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   X26 2833
   Revision: R7X26---
   Coding: 0125003223641D082000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B88AEEC130A0CF34A1-803E
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:21
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.991 V
                    Outside temperature: 16 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 5.00 l
                    Oxygen sensor B1: sensor 1: specified value: 15.9998
                    Intake camshaft B1 active operating state-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0000
   Part No SW: 0CW 300 041     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1010
   Revision: 00005026    Serial number: CU501708138517
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 72B6B3883420DD3B897-8026
   Revision: 00000000    Serial number: 62177000001965
   Coding: 01FA8AA12427216D477A060840C82980512484E26002947338225078C202430000000012121212B835351919323200
   VCID: 77A0829C5F42B813BE9-8022
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:20
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:20
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120004200110001000000000000002
   VCID: 7AA69BA86C50A57BC17-802E
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:20
                    Outside temperature: 17.0 °C
                    Engine RPM: 0 /min
                    Temperature downstream of evaporator: 18.0 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001723500224
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065EFF5828A8D19BB5F-8052
   Component: WWS    170728  042 0551
   Serial number:         170814194637
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S6Y17M08D28H19M15S45
   Coding: 00A8DD
   Serial number: 000000000ZY172040QE3
   Serial number: 00000000000070353102
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:50:34
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:50:31
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617230
   Coding: 0471051811
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC80E6C734AECF32A1-801E
12727553 - Databus
          [Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:21
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR378BPI
   Coding: 98CCC000000000005C0000CF008800000065
   VCID: 0944F46439B6BEE3D8D-805C
   Left seat belt tensioner:
   Serial number: 34169677E28081741024
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E28081750460
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 808 17
   Serial number: 3570000000037D5C772S
   Subsystem 4 - Part No SW: -----------    HW: 480 002 808 17
   Serial number: 358000000006865CD72W
   Subsystem 5 - Part No SW: -----------    HW: 480 402 608 17
   Serial number: 35100019F266F481759B
   Subsystem 6 - Part No SW: -----------    HW: 480 402 408 17
   Serial number: 3520001C92527AF5F73H
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 17
   Serial number: 3550001C92527AF4D66J
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23081708490441
   Coding: 0410
   VCID: 0256E3480480EDBB997-8056
   Part No SW: 5G1 920 940 C    HW: 5G1 920 940 C
   Component: KOMBI         202 0310
   Coding: 27A529082780060001886B011401000000000000
   VCID: 280291E0C27CE7EBE73-807C
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:22
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006722670
   Coding: 030100047F085700FB00005C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3338768C0BBA9433421-8066
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39170002007400077282
   Coding: 2CFFFF
   Serial number: 3976035104
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:20
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Globaler Timeout CAN-Extended]
                    Reset counter: 12
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:59:41
                    Terminal 15: OFF
   Serial number: 120817EHB32452
   Coding: 00310220D001048000001000
   VCID: 43D8264C5B1A24B3D21-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000015935934
   Coding: 0D0000
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Reset counter: 12
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:35:33
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45DC3854552E1A83FC5-8010
   Serial number: 120817EHB15606
   Coding: 00310020DE01048000801000
   VCID: 42D6234844002DBBD97-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000016026756
   Coding: 150000
                    Reset counter: 12
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:35:33
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    H41 0449
   Serial number: VWZAZ2T1570407
   Coding: 02731001FF00000051110101008808001F0501C601200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 32367388F4A09D3B497-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT2312807
   Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:21
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 227
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:22
                    Voltage terminal 30: 12.0 V
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EAE97B87078895BFDF-802A
0272 - Databus
          U1121 00 [237] - Missing Message
          [can message LED_Soll_Fktx missing]
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0336 - Databus
          [can message AFS_Soll_Fkt missing]
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0337 - Databus
          [can message LWR_Soll_Fkt missing]
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0338 - Databus
          [can message LCM_Soll_Fkt missing]
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0774 - Light Bulb for Low Beam
          C1198 29 [174] - Signal Implausible
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:50:27
1061 - Supply Voltage for Logic
          C121F 13 [175] - Open Circuit
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0272 - Databus
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0336 - Databus
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0337 - Databus
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
0338 - Databus
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 12:50:27
                    Reset counter: 0
                    Mileage: 53140 km
                    Date: 2021.07.01
                    Time: 11:51:19
End----(Elapsed Time: 01:23, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Trowbridge, UK
Later modules do not use coding, everything is configured using adaptation channels, so do not be surprised if you are asked for an adaptation map of 09.
chrisogor
C?ID=151011
yes you right
langers2k
C?ID=224085
I'm not 100% but I thought that D6 and D7 need a 4B module installed to function correctly?
@langers2k yes for hex D6/7 = Part No SW: 7P5 941 591 AD and HW: 7P5 941 591 A - see HERE
The other niggling oddity about this car is the mid-level BCM - seems like a "courageous" retrofit - but I don't have access to ETKA
vastechnics
C?ID=143747
True story. 4b module is needed
downtime
Finland
C?ID=280813
And you’re 100% about that? I had D6 and D7 in Tiguan and it had module 55. And it had DLA lights and all from factory.
@downtime: true - but your hexD6/D7= Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A ?
Do you have ETKA account?
vastechnics
C?ID=143747
That is true, but for MK7,5 that's not possible. This only work with 4B module. Tiguan in beginning 2016/2017 work with 55 module and after that also go to 4B module. Tiguan can connect both ways. MK75 not. You also need to check which headlights you are using. 3 different types. D6 and D7 work with special versions according the headlights
downtime
Finland
C?ID=280813
Ok. That explains it. BCM version on Tiguan seemed at least be one factor when you need 4B. If you go to DC BCM for example then 4B is needed.
chrisogor
C?ID=151011
Thank You all for your input will fit the original headlights as-is no my project
