4F AUDI A6 ABS/ESP coding help
Abdul999
Oslo, Norway
C?ID=282447
Hello guys,
unsure why account is not registered to post in normal forum yet, eventhoug received email from rosstech its approved. can any one from rosstech have a look?
Was wondering if some one can help, is there a code calculating guide similar to Audi A6 (4B) Brake Electronics (Bosch 5.7)?
this is for newer 2008/2009 model 4F does not seem to be anything online
the ABS/ESP module was replaced and no coding. first of all is it possible to calculate the coding? secondly is it possible to code through VCDS or ODIS a requirement (as i dont have ODIS)
info i have for now is VIN WAUZZZ4F38N105501 2L diesel engine 140hp
Will upload scan report once i get it
Bruce
Near Philadelphia, PA, USA
Someone will be along to look at the registration.
Help on ABS coding can be had but requires posting an Autoscan as you have indiciated you will post. Until it is posted, likely no one can begin.
How to post an Auto-Scan
Getting forum membership approved is not the same as being a Verified member. Please see:
Abdul999
Oslo, Norway
C?ID=282447
Thanks the new module was not connected properly and fuse (6) was blown for ABS module at side of steering wheel, so got that sorted and re calibrated angle sensor and etc most lights are gone just minor errors regarding communication with some modules and ABS posting below latest scan, engine light is on due to break switch... and on the cluster display one error comes on which seems like break pad, with im pretty sure is a light bulb or padlock in middle with cross on it. probably is due to the faulty light bulb as it shows on display back right?
Wednesday,30,June,2021,17:15:19:62826
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4F38N105501   License Plate: BD58041
Mileage: 258630km-160705mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 53
          55 56 61 62 69 72 76
VIN: WAUZZZ4F38N105501   Mileage: 258630km-160705miles
   Part No SW: 03G 906 016 MF    HW: 03G 906 016 MF
   Component: R4 2,0L EDC G000CG  1142
   Revision: --H06---    Serial number:
   Coding: 0022076
   Shop #: WSC 00040 218 80996
   VCID: 73E5A38C12404213CE-8026
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 9
                    Mileage: 258637 km
                    Date: 2021.06.25
                    Time: 16:35:53
                    Speed: 4.0 km/h
                    Voltage: 11.86 V
                    Bin. Bits: 11101010
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
053250 - Please Check Fault Codes in Comfort System Control Module (J393)
               U1002 - 000 -  - Intermittent
                    Mileage: 258637 km
                    Date: 2021.06.25
                    Time: 16:35:55
                    Speed: 4.0 km/h
                    Voltage: 11.86 V
                    Bin. Bits: 11101010
                    Torque: 0.0 Nm
                    Bin. Bits:  0 01  0
001393 - Brake Switch (F)
               P0571 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    RPM: 63 /min
                    Voltage: 9.73 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Bin. Bits:  0 00  0
006215 - Please check DTC Memory of ABS Controller
               P1847 - 000 -
                    Mileage: 258637 km
                    Date: 2007.05.16
                    Time: 12:00:13
                    Voltage: 11.70 V
                    Bin. Bits: 11101000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000100
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F9 910 155 B    HW: 01J 927 156 JG
   Component: V30 01J 2.0l PD RdW 0010
   Revision: --H03---    Serial number: 00000000000021
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2A5B7EE8850A43DBBD-807E
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 258637 km
                    Date: 2021.05.25
                    Time: 22:43:47
                    RPM: 96 /min
                    (no units): 1.0
                    Torque: 52.0 Nm
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 1
                    RPM: 96 /min
                    (no units): 1.0
                    Torque: 0.0 Nm
                    Temperature: 16.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
   Component: ESP8 front      H01 0070
   Coding: 0004472
   Shop #: WSC 02325 758 00200
   VCID: 65C1CDD4AC94ACA350-8030
                    Fault Status: 01100101
                    Reset counter: 153
                    Mileage: 258637 km
                    Date: 2007.05.16
                    Time: 12:04:26
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x001E
                    Hex Value: 0x3E90
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500988248
   Coding: 0000131
   Shop #: WSC 02323 785 00200
   VCID: 63C5D3CCA2A0D293BE-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H46 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 H    HW: 4E0 035 729
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 350IS087901086
   Coding: 0001002
   Shop #: WSC 00773 218 178555
   VCID: 285F84E09B0671CBAB-807C
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000975005
   Subsystem 3 - Serial number: 0123.01.080000000100010016ÿ
   Subsystem 4 - Serial number: 010016ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000053    Serial number: 00000000487207
   Coding: 0002324
   VCID: 1C37A830DF5EAD6B3F-8048
00657 - Positioning Motor for Central Vents (V102)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 153
                    Mileage: 258637 km
                    Date: 2007.05.16
                    Time: 12:04:26
                    Voltage: 11.50 V
                    Temperature: 26.0°C
                    (no units): 85.0
                    (no units): 88.0
                    Temperature: 24.0°C
                    Reset counter: 153
                    Mileage: 258637 km
                    Date: 2007.05.16
                    Time: 12:04:26
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0012122
   Shop #: WSC 02335 785 00200
   VCID: 31696984A8DC30037C-8064
   Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0390
   Revision: 00046002    Serial number: AUZ5ZBH4071824
   VCID: 1A3BAE28D56AD35B2D-804E
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 43 AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0W5HMY
   Coding: 0013363
   VCID: 295981E4800C48C3B4-807C
   Subsystem 1 - Serial number: 6332CSME32715520T
   Subsystem 2 - Serial number: 6342CSME37305A43/
   Subsystem 3 - Serial number: 6352QSME480F4F3B.
   Subsystem 4 - Serial number: 6362QSME4536781FR
   Subsystem 5 - Serial number: 63734SME503B4B0D5
   Subsystem 6 - Serial number: 63834SME4C6D7835H
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0410
   Revision: 00H04000    Serial number: 90054073550476
   Coding: 0002242
   VCID: 275D87DC96187EB3A2-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
   Component: KOMBIINSTR. M73 H22 0240
   Revision: 00000000    Serial number: 72U33WH18
   Coding: 3072158
   Shop #: WSC 80093 222 69422
   VCID: 234593CCE2209293FE-8076
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 L
   Component: Heizgeraet      H08 0060
   Revision:        C    Serial number: 09011480
   Coding: 0000111
   Shop #: WSC 02145 785 00200
   VCID: 1B35AB2CDA50AA5336-804E
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B08112818C
   Coding: F7599E7730220600
   VCID: 2D5175F4B4E454E358-8078
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 364AR087751931
   Shop #: WSC 00027 218 65955
   VCID: 306F6C80A3D6390B73-8064
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0210
   Revision: 00-00000
   Coding: 0003690
   Shop #: WSC 02327 785 00200
   VCID: 2C5778F08FFE5DEB4F-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H26 0210
   Revision: 02100026    Serial number: 01092790850000
   Coding: 0139909
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 152
                    Mileage: 258090 km
                    Date: 2021.05.19
                    Time: 10:08:58
02932 - Control Circuit for Brake Light in Trunk/Hatch Lid; Right
                    Fault Frequency: 62
                    Reset counter: 153
                    Mileage: 258335 km
                    Date: 2021.05.21
                    Time: 21:57:21
02931 - Control Circuit for Brake Light in Fender; Left
                    Fault Frequency: 31
                    Reset counter: 153
                    Mileage: 258637 km
                    Date: 2021.05.25
                    Time: 22:43:50
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
   Component: Amp.-ASK-RD   H07 0270
   Revision: S1300000
   Coding: 080001
   Shop #: WSC 02399 823 56573
   VCID: 285F84E05B0671CBAB-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000262598
   Coding: 0001004
   VCID: 5EB3E23889C2FF7B91-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0210
   Revision: 00-00000
   Coding: 0003690
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000131
   VCID: 204F9CC0F336898BE3-8074
   Part No: 8P0 907 357 H
   Coding: 0000003
   VCID: 3F8D3FBC6E88D673FA-806A
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394AS087856212
   Coding: 0000001
   Shop #: WSC 02324 785 00200
   VCID: 2E5372F8B9E22FFB61-807A
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000003788
   VCID: 244790D0E72E95AB87-8070
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  580113D1RA
   Coding: 344630393135313035452056413035383031313344315241
   Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0003114
Address 69: Trailer (J345)       Labels:. 4F0-907-383.clb
   Part No SW: 4F0 907 383 C    HW: 4F0 907 383 C
   Component: Anhaenger     H14 0080
   Revision: 2B002001    Serial number: 00000107164938
   Coding: 0103030000000000
   VCID: 2B557BEC4AF05AD346-807E
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0003114
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06240802302376
   Coding: 0011016
End-------------------------(Elapsed Time: 02:38)--------------------------
Wednesday,30,June,2021,17:40:57:62826
Gateway Installation List:  4L0 910 468 A
Hi, I think I would start here (Besides getting verified! ie, post #3)
1 Fault Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation
It looks like your "coding" for ABS Address 03 is intact!
Abdul999
Oslo, Norway
C?ID=282447
yes it was an issue with the fuse and pins bent on the ABS controller correcting these fixed the issue, and unlike the earlier bosch 5.7 i think the newer 8.0 kept the coding after it was disconnected and swapped, without needing to recode.
The next step to resolve would have been missing message / communication issues with the vehicle however it was a friends vehicle and he was happy to just drive away with all the lights off even though ABS didnt fully seem to work, possibly due to the errors. but the lights where off the dash!
