Hello I am new to the forums and to VCDS. I have a 2020 GLI S with DSG and my brother-in-law has a 2020 GLI Autobahn Manual. We purchased the VCDS cable to adjust some things on our cars but are having trouble with a few settings either not working or not having any ECU info available.
Successful changes:
-Comfort close windows from fob
-Unlock Android Auto in motion
-Unlock all vehicle menus in motion
-Show fan speed in Auto mode
-Recirculation memory
-Adjust temperature warning (I think, but ideally I'd like to disable this chime entirely)
-Adjust brightness of reverse lights (Have not tested side-by-side, but I set them to 127)
-Disable seatbelt chime/warning (We both wear seatbelts religiously and do not need a reminder when moving the car at home)
Unsuccessful:
-Rain sensing window close
I was able to set these settings:
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
Aussenlicht_Bling
Komfortblinken Blinkzykien
Value: 1-5 Value 3 (Standard – 3x blinking)
-Disable door chime/alarm ignition on (Very obnoxious, the following setting did not work):
Thanks in advance!
Successful changes:
Unsuccessful:
- Go to [09] Central Electronics
- Go to Secuity Access and enter 31347
- Go to adaptation channels and set the following:
- - (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
- - (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
- - (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the ifotainment screen)
- 9 Central Electronics
- Rain and light sensor
- Byte 0…Enable Bit 2 “Regenschliessen aktiv”. (rain closing active)
- Bit 1 should be active too….Regenlicht aktiv (rain light active)
- My Old coding…..00A8DD
- My New coding….06A8DD
Security access
Access Code 31347
Adaptation
Aussenlicht_Bling
- 17 Instruments
- Adaptations
- Ignition active message; Trigger
- Change to "No display" (default value: driver's door)
- 17 Instrument
- Coding -> Function 10
- Byte 1
- Enable bit 0
Thanks in advance!
