2019 VW CRAFTER traction control off option
MXCrafter
Mexico
C?ID=325524
Hi, new to the forum and I have a 2019 VW Crafter van. It does not have a traction control off button, and the process shown on utube ( flashers on, pump gas pedal 5 times) also does not work. Can it be turned of by coding and if so how ? Thanks !
Hi and welcome.
Please post an Auto-Scan so people can see how the van is equipped and configured.
MXCrafter
Mexico
C?ID=325524
Sorry if this is not the correct way to show the AutoScan. but here it is:
( I would also like to increase the electric steering assist at highway speeds if possible )
Monday,12,July,2021,14:11:02:14517
VIN: WV1FHKSY3K9005330   License Plate:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 BB BC
VIN: WV1FHKSY3K9005330   Mileage: 2751km-1709miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA)       Labels: None
   Part No SW: 04L 906 056 RF    HW: 04L 907 445 K
   Component: R4 2.0l TDI   H01 5799
   Revision: 23202001
   Coding: 001941146304000800000000000000000000000000000000
   Shop #: WSC 00069 790 00013
   ASAM Dataset: EV_ECM20TDI03004L906056RF 005005
   ROD: EV_ECM20TDI03004L906056RF.rod
   VCID: 025D7735448C9A4B997-8056
15907 - Glow Plug Control Module (J179)
          P0684 00 [096] - Implausible Signal
                    Mileage: 1786 km
                    Date: 2021.03.26
                    Time: 23:40:40
                    Engine RPM: 838.00 /min
                    Normed load value: 47.8 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 11.757 V
                    Unlearning counter according OBD: 28
                    Pre-glow time: 0.6 s
                    Glow status: Post-heat
                    Outside temperature sensor 1: B1: raw value: 24.0 °C
27237 - Power Supply Terminal 15
          P3325 00 [032] - Implausible
                    Mileage: 2712 km
                    Date: 2021.05.24
                    Time: 23:00:00
                    Engine RPM: 0.00 /min
                    Coolant temperature: 91 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.851 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.54 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 840 mbar
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 11
                    Index of next requested engine mode: 11
                    Index of engine target mode: 11
27277 - System Voltage
          P0562 00 [032] - Too Low
                    Mileage: 1373 km
                    Coolant temperature: 22 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 12.406 V
                    Unlearning counter according OBD: 23
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 1.42 %
                    Charge air pressure: specified value: 0.003 bar
                    Index of current engine mode: 8
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2N0 907 379 C    HW: 2N0 907 379 C
   Component: ESC_base      H02 0850
   Serial number: 08501262180617
   Coding: 25A82477483DB287A44A246312434D062C0000F8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 3635DBE558C4F6EB65F-8062
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 7C0 907 426 AE    HW: 7C0 907 426 AE
   Component: AC Manuell    H01 0401
   Coding: A03010000800000000000800000101000000000000080000000000000000
   Shop #: WSC 00069 790 00012
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 6C81398D56087C3B43B-8038
   Rear A/C Control Head 1:
   Subsystem 1 - Part No SW: 7C0 907 049 H    HW: 7C0 907 049 H
   Component: E857  H02 0201
   Serial number: 00001067120418160201
          B10CD 00 [008] - -
          [Funktionseinschränkung durch Energiemanagement Ruhestrom]
                    Reset counter: 84
                    Mileage: 2313 km
                    Date: 2021.05.13
                    Time: 02:28:22
                    Voltage terminal 30: 12.0 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001820400899
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B435A1173C6DB03EA1-805E
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 83
                    Mileage: 2245 km
                    Date: 2021.04.07
                    Time: 22:59:44
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 54
                    Mileage: 126 km
                    Date: 2021.02.16
                    Time: 04:21:24
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
                    Reset counter: 87
                    Mileage: 2712 km
                    Date: 2021.05.24
                    Time: 23:00:02
   Part No SW: 3Q0 959 655 BG    HW: 3Q0 959 655 BG
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W3PEYC0SM
   Coding: 8800C00000000000400000CF000800000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 0451712D5E98947BABB-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 802 205 18
   Component: FrontSensor_D  305 0109
   Serial number: 3550089F49C14000000W
   Subsystem 2 - Part No SW: -----------    HW: 454 802 205 18
   Component: FrontSensor_P  305 0109
   Serial number: 35600B9EB9C14000000%
   Part No SW: 5Q0 953 521 A    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20180714400902
   Coding: 0200
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3039EDFDBAA0D8DB3F3-8064
   Part No SW: 7C0 920 741 B    HW: 7C0 920 741 B
   Component: KOMBI         211 2500
   Coding: 07A411002000000800080A000400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 231312B1FB567343B21-8076
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 2712 km
                    Date: 2021.05.24
                    Time: 23:00:01
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008206486
   Coding: 010000080005730000000000000E00000001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_AU27.rod
   VCID: 3D27C4C97DF225B3A45-8068
   Generator:
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000330720239
   Coding: 00300B208000020100001000
   VCID: 46D5AB252824666BF5F-8012
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 E    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7021
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002001
   ROD: EV_SteerAssisMNB.rod
   VCID: 2F3BEE81A79EC723269-807A
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000328472237
   VCID: 45D7AC2915226D73FC5-8010
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:46, VBatt start/end: 12.2V/12.2V)-----------
