VW TOAS 2021 - DONT READ
Papa Leguas
Brazil
C?ID=307965
Cound you help us?
because the ross tech didn´t read the enw car vw TAOS.
Below the full scan.
Friday,25,June,2021,14:36:29:39372
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: 8AWBJ6B2XNA801388   License Plate:
Chassis Type: B2 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 20 3C 42 44 4B 52 5F BB BC
          CA D6 D7
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWLA)       Labels: None
   Part No SW: 04E 906 027 NJ    HW: 04E 907 309 BP
   Component: R4 1.4l TFS   H23 1445
   Revision: RDH23---
   Coding: 011A003223641D003000
   Shop #: WSC 00059 790 00013
   ASAM Dataset: EV_ECM14TFS01104E906027NJ 001004
   ROD: N/A
   VCID: 79BAFE4FF8409E4384-802C
Unsupported vehicle.
No ASAM data for: "EV_ECM14TFS01104E906027NJ" ()
   Part No SW: 09G 927 158 EM    HW: 09G 927 158
   Component: AISIN AG6 G3  201 3812
   Coding: 0000000100000000010000000000000000000000
   Shop #: WSC 00059 790 00059
   ASAM Dataset: EV_TCMAQ250031 003018
   ROD: N/A
   VCID: 024899A39596DD9BD5-8056
No ASAM data for: "EV_TCMAQ250031" ()
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 50611000002191
   Coding: 89FB6A7EA020246DC57A060862CB3991560524A360469C7C3841F078D2824A0B00002E64121A03102F6263394D4A89E2
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: N/A
   VCID: 77BEF877CE548833F2-8022
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
0147 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 44
                    Mileage: 10 km
                    Date: 2021.06.09
                    Time: 05:36:35
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0564998535
   Coding: 132C0C0723
   ROD: N/A
   VCID: 45C242BFC4382AA3B0-8010
No ASAM data for: "EV_KessyHellaMQBAB" ()
1077250 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 66
                    Reset counter: 46
                    Mileage: 5 km
                    Date: 2021.05.21
                    Time: 17:25:04
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 5GM 907 044 AL    HW: 5GM 907 044 AL
   Component: Climatronic   H04 2601
   Revision: 00001K04
   Coding: 0902002420010C011004000010111010
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   ROD: N/A
   VCID: 0E50BD93D1CEA9FB41-805A
No ASAM data for: "EV_ACClimaBHBVW37X" ()
1048838 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 44
                    Reset counter: 46
                    Mileage: 5 km
                    Date: 2021.05.21
                    Time: 17:25:24
   Part No SW: 5Q0 937 084 DQ    HW: 5Q0 937 084 DQ
   Component: BCM MQBAB H   H42 0411
   Serial number: 1062001401ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 021001
   ROD: N/A
   VCID: 0A58B183ADA685DB9D-805E
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y21M02D23H23M29S31
   Coding: 0018DD
   Subsystem 2 - Part No SW: 6EA 951 171     HW: 6EA 951 171
   Component: Sensor, DWA  006 0115
   Serial number:  2FL0091405UCI000F74
   Subsystem 3 - Part No SW: 5Q1 953 521 GA    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0300140120210C202072
No ASAM data for: "EV_BCMMQB" ()
11530 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 43
                    Mileage: 6 km
                    Date: 2021.05.23
                    Time: 22:52:37
14858 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 43
                    Mileage: 6 km
                    Date: 2021.05.23
                    Time: 22:52:37
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000460608421037
   Coding: 0451155811
   Shop #: WSC 00059 790 00023
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: N/A
   VCID: 53E66CE73A6C84132E-8006
No ASAM data for: "EV_EPHVA18AU3700000" ()
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H04 0383
   Coding: 3204678218FF8748949C810580408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: N/A
No ASAM data for: "EV_ACCMRRCONTIVW376" ()
0110 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 78
                    Reset counter: 46
                    Mileage: 5 km
                    Date: 2021.05.21
                    Time: 17:25:05
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 CE    HW: 5Q0 959 655 CE
   Component: AirbagVW21    008 0421
   Serial number: 003J7M00UH4G
   Coding: 88CCC000000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   ROD: N/A
   VCID: 054282BF84B8EAA3F0-8050
   Subsystem 1 - Part No SW: -----------    HW: 480 000 203 21
   Serial number: 3570000000027A61AB4N
   Subsystem 2 - Part No SW: -----------    HW: 480 000 203 21
   Serial number: 35800000000FA921AB4Z
   Subsystem 3 - Part No SW: -----------    HW: 480 400 303 21
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A8C1BE764799M
   Subsystem 4 - Part No SW: -----------    HW: 480 400 302 21
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001222C00995630I
   Subsystem 5 - Part No SW: -----------    HW: 480 400 303 21
   Component: FrontSensor_D  005 6149
   Serial number: 355000198C34279087EB
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 17: Instruments (J285)       Labels: None
   Part No SW: 17A 920 320 A    HW: 17A 920 320 A
   Component: KOMBI         502 5175
   Coding: 04A448082F88000801882249500000000000080A
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: N/A
   VCID: 1A78C1C31D06755B2D-804E
No ASAM data for: "EV_DashBoardVDDMQBA0" ()
16777020 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 46
                    Mileage: 20 km
                    Date: 2021.06.22
                    Time: 15:32:51
16711685 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 46
                    Mileage: 6 km
                    Date: 2021.05.24
                    Time: 02:00:44
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 03032100841562
   Coding: 030100047F085708FB0002DA1C0F00010001070000000000000000000000
   Shop #: WSC 00059 790 00010
   ROD: N/A
   VCID: 74A4CF7BDF22E32BD7-8020
   Component: 4-01-02-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 N    HW: 3G0 959 442 N
   Component: E221__MFL-YLG  H07 0110
   Serial number: YLG-0700084058210571
   Coding: 2D2900
   Serial number: 5253487900
No ASAM data for: "EV_GatewNF" ()
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Part No SW: 3G0 857 511 BE    HW: 3G0 857 511 BE
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0404000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: N/A
   VCID: 6C94D71B87123BEB0F-8038
No ASAM data for: "EV_HighBeamAssisAU33X" ()
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00000569912378
   Coding: 5294C620
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: N/A
   VCID: 393A3E4FB8C05E43C4-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 00000563997363
No ASAM data for: "EV_HREntryHellaGen3Kl15" ()
   Part No SW: 5Q4 959 593 N    HW: 5Q4 959 593 N
   Component: TSG FS        010 0820
   Serial number: 96028109600855
   Coding: 003F1320D000028008001000
   ROD: N/A
   VCID: 50EC63EB0B7AFF0B13-8004
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000007942306
No ASAM data for: "EV_DCU2DriveSideMAXHCONT" ()
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-144.clb
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 851F0000
   ROD: N/A
   VCID: 51EA66EF0070F6031C-8004
No ASAM data for: "EV_SteerAssisMQB" ()
Address 4B: Multifunc. Module (J745)       Labels:. 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 01042000841783
   Coding: 0000000709000B4A02000F00000000000000000000000000000000000000
   ROD: N/A
   VCID: 373E38778ED4483332-8062
No ASAM data for: "EV_MultiModulContiVW48X" ()
   Part No SW: 5Q4 959 592 N    HW: 5Q4 959 592 N
   Component: TSG BFS       010 0820
   Serial number: 97028110000163
   Coding: 003F1120DC00028000001000
   ROD: N/A
   VCID: 4FEE60971644E0F30A-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004518071
   Coding: 090000
No ASAM data for: "EV_DCU2PasseSideMAXHCONT" ()
   Part No SW: 2GM 035 180 C    HW: 2GM 035 180 C
   Component: MU-R--R2      H07 0367
   Serial number: VWZ7Z2Y4134116
   Coding: 23165400000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001008
   ROD: N/A
   VCID: 3A382143BDC6555BCD-806E
No ASAM data for: "EV_MUREGIO" ()
1562 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 0
                    Reset counter: 0
1637 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 49
                    Mileage: 54 km
                    Date: 2021.06.24
                    Time: 17:36:41
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address CA: Sunroof (J245)       Labels:. 4M0-907-594.clb
   Coding: 40804073163C
   ROD: N/A
   VCID: 75A2F27FD458FA23E0-8020
No ASAM data for: "EV_SunRoofCONTIAU736" ()
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: N/A
   VCID: 6680A53399FE01BB59-8032
No ASAM data for: "EV_LLPGen3LKEBODPO68X" ()
   Component: LED1R         H08 9202
   ROD: N/A
No ASAM data for: "EV_LLPGen3RKEBODPO68X" ()
End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.2V)-----------
Cound you help us?
Try this Beta version please.
Note: You will have to put your HEX-NET on the Beta Channel for updates too (on the Advanced tab in VCIConfig), and then update the HEX-NET before it will work.
Once you have it working, please post a new Auto-Scan.
