- Mar 18, 2021
- 6
- 2
- Sacramento, CA, USA
- C?ID=437208
I am having issues resolving the SAI issues shown in the scan. I have done the following work to the car:
- Performed carbon buildup cleaning on the cylinder heads, verified passages are clear with a borescope
- Verified the pump motor is working and flowing
- Verified air pump is turning on at startup
- Checked that the hoses from the pump to the combi valves for leaks with a smoke test and also just by blocking one end and blowing into other
- Verified the combi valves are working by using a mighty vac and checking function to verify air flows when activated and no air passes when no vacuum is applied
I have also removed an O2 sensor on each cat to verify I am able to hear airflow into the exhaust. Not sure how to measure this flow, but they appear to sound like equal amounts of air is passing thru.
The car itself runs great. Starts right up, idles very smooth, runs strong. I am at a loss on what could be wrong but the code keeps coming back right after readiness is achieved.
Thursday,24,June,2021,11:44:58:09997
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WA1LKAFP5AA080984 License Plate:
Mileage: 182820km-113599mi Repair Order: 06242021
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
6D 72 77
VIN: WA1LKAFP5AA080984 Mileage: 182820km-113599miles
Address 01: Engine (J623-CALB) Labels:| 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H06 0004
Revision: --------
Coding: 0121000A190F0121
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
ROD: EV_ECM32FSI0218R0907559G.rod
VCID: 44D14665FE19AFFBEBB-8010
6129 - Fuel/Air Mixture Cylinder 5
P21A0 00 [032] - Unbalanced
Mileage: 182731 km
Date: 2021.06.18
Time: 08:44:28
Engine RPM: 705.00 /min
Normed load value: 20.0 %
Coolant temperature: 101 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.812 V
Unlearning counter according OBD: 31
Engine speed: actual: 672 /min
MAF_ENVD: 103.49411 mg/stroke
Coolant temperature (unfiltered): 101.3 °C
Engine: operating status: IS
Engine load: 19.921875 %
Vehicle speed: actual: 0 km/h
8931 - Secondary Air Injection System: Bank 1
P0491 00 [101] - Insufficient Flow
Mileage: 182814 km
Date: 2021.06.24
Time: 10:44:37
Engine RPM: 1338.00 /min
Normed load value: 32.2 %
Coolant temperature: 22 °C
Intake air temperature: 21 °C
Voltage terminal 30: 12.898 V
Engine speed: actual: 1312 /min
MAF_ENVD: 266.90588 mg/stroke
Coolant temperature (unfiltered): 22.5 °C
Battery voltage: 12.898438 V
STATE_LS_ENVD[1]: 2
8932 - Secondary Air Injection System: Bank 2
P0492 00 [101] - Insufficient Flow
Mileage: 182814 km
Date: 2021.06.24
Time: 10:44:37
STATE_LS_ENVD[1]: 2
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8R0 927 158 F HW: 0B6 927 156
Component: 0B6 32 FSIUSA H05 0005
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 40D94A75EA01B3DBCF3-8014
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 M HW: 8R0 907 379 M
Component: ESP8 quattro H06 0020
Coding: 041D18
VCID: 4ACD685DDCBD798B117-801E
03015 - ASR/ESP Button (E256) jammed
Reset counter: 18
Mileage: 182774 km
Date: 2021.06.19
Time: 18:46:38
Hex Value: 0x0240
Hex Value: 0x4086
Hex Value: 0x121C
Hex Value: 0x01A1
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0327
Coding: 090500
VCID: 04518665BE196FFBABB-8050
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0510000003165003
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000010861013
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01080220100137
Coding: 46012000
VCID: 7AADF89DCCDD290BC17-802E
Reset counter: 231
Mileage: 182731 km
Date: 2021.06.18
Time: 08:40:50
Temperature: 46.0°C
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000459834
Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
VCID: 3C213E858669D73B93B-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 100203 H10 0041
Serial number: 90243014100202015344
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10779436
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000402101833
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Reset counter: 231
Mileage: 182731 km
Date: 2021.06.18
Time: 08:40:00
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 D HW: 8R0 959 655 D
Component: AirbagVW-AU10 H39 0560
Serial number: 003FRD059MDL
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 45D75B61F52396F3FC5-8010
Subsystem 1 - Part No SW: 8R0 959 339 HW: 8R0 959 339
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900005VEQ
Serial number: 6334MSME4F443332B
Serial number: 6344MSME5114193B9
Serial number: 6352QSME3D4E4C3E1
Serial number: 6362QSME4E4E0834T
Serial number: 63732SME144F4A04+
Serial number: 63832SME514E532E5
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JB8000DN
Coding: 000017
VCID: 3D2733819D73DE33A45-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 B HW: 8R0 920 950 B
Component: KOMBIINSTR. H11 0255
Revision: 00100000 Serial number: CJE41T02A
Coding: 831722000300D705020000
VCID: 35372BA1A54306736C5-8060
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G102028288
Coding: 00C303
VCID: 50F97A353AE1435B5F3-8004
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140971878
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020302
VCID: 392F2791895BE21388D-806C
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010071528
Coding: 00581300000044440000
VCID: 40D94A75EA81B3DBCF3-8014
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010098423
Coding: 011D03205E00440004
VCID: 45D75B61F5A396F3FC5-8010
Revision: 00002001 Serial number: 0126474748
Coding: 0126023A207A749404B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000219709
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H01 0220
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F3B19C9471F3CA3269-807A
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010100010
VCID: 44D14665FE99AFFBEBB-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000430797
VCID: 343116A5AE391F7B5BB-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 343116A5A2391F7B5BB-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000008 Serial number: AUZ5Z6J1350808
Coding: 0402000201058503C3F90F0900
VCID: 46D55C6DC8A59DEBF5F-8012
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Fault Frequency: 19
Reset counter: 241
Mileage: 182731 km
Date: 2021.06.18
Time: 08:40:51
Bin. Bits: 00000000
Bin. Bits: 00000001
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 231
Mileage: 182731 km
Date: 2021.06.18
Time: 08:40:58
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102854164
Coding: 010C03204000240004
VCID: 42DD407DE48DA1CBD97-8016
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H27 0300
Revision: -------- Serial number: 8R0827851B
VCID: 3B233D998367D0039A1-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H27 0300
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102854139
Part No SW: 8T0 862 336 D HW: 8T0 862 336 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005069511
Coding: 0010370
VCID: 3C213E858A69D73B93B-8068
End----------(Elapsed Time: 01:54, VBatt start/end: 14.2V/14.2V)-----------
