Pin code and skc tools
nicos2014
Cyprus
C?ID=178750
Hello
Can someone advice me which tools can provide me access to i can read pin codes and sck on vag vehicles?
As well from where can i buy these tools?
Your advises are appreciated
Thanks in advance
VR6 Bug
Elmer, NJ
C?ID=197078
Your'e not gonna get that info here.
NZDubNurd
New Zealand
C?ID=230482
It really depends what you're trying to do, I pulled the SKC from my R32 ecu's with an EEPROM reader - pull the whole file, then find the SKC positions - no need to pull the chip, if you have an EEPROM clip. You do need to open the ECU though.
Some of the software that does it have reputations for causing headaches, so I avoided it as much as I could.
There is no one tool that works on every model VAG car.
Best value for the money in a legitimate tool is probably VagTacho.
GaryM
Oxford, UK
C?ID=226919
AVDI can do it but it's not a cheap tool. 740 Euros for the base VAG compatible unit, another 1100 Euros for the pin extraction module, then 200 Euros per year subscription charges.
