2015 Audi Q5 - What am I missing?
JTT1603
Mississippi, USA
C?ID=426526
2015 Audi Q5 Premium
Windshield Washer pump failed, so I disconnected the battery, removed the left front wheel and replaced the washer motor. Upon starting the vehicle every time since then, the tpms light flashes and then stays lit after one minute, and the ESC and ABS lights are lit.
Below is the latest scan. Usually it's only DTC 01486 but sometimes it's paired with error 02115. I have researched the driving test and understand how to complete it; however, the vehicle will not acknowledge the start of the test: when the brake is depressed after starting the vehicle (have tried many different variations of force on the brake pedal), the ESC and ABS lights do not change indicating the test has begun.
Is there some form of magic required to start the driving test? Does the TPMS malfunction light give any clues as to why I can't start the driving test?
Wednesday,23,June,2021,10:24:37:43565
VIN: WA1CFAFP5FA01XXXX   License Plate:
Mileage: 232810km-144661mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 6D
          72 77
VIN: WA1CFAFP5FA01XXXX   Mileage: 232810km-144661miles
Address 01: Engine (LANG-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 L    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0001
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0118R1907115L 001002
   ROD: EV_ECM20TFS0118R1907115L.rod
   VCID: 3E25358BD0FD172BBDF-806A
   Part No SW: 8R0 927 158 AS    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H18 1001
   Revision: --H18---
   VCID: 0E45A54BA0DDC7AB0DF-805A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 151D1803
   Shop #: WSC 06335 000 00000
   VCID: 117FBE37B163D85310D-8044
01486 - System Function Test Activated
                    Reset counter: 239
                    Hex Value: 0x0000
                    Hex Value: 0x0200
                    Hex Value: 0x0019
                    Hex Value: 0x319B
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 JN    HW: 8K0 907 064 JN
   Component: BCM2 2.0      H14 0650
   Coding: 09854040000000000000
   VCID: 05579A67F52B84F3BC5-8050
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0814000086611001
   Serial number: 0214000109047014
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AP    HW: 8K1 820 043 AP
   Revision: C0000000    Serial number: 01120620140389
   Coding: 6481208000
   VCID: 76B5EDABB8CD9F6BA5F-8022
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000838070201
   Coding: 26000091863CAFC00000480000003D0D0F1C460822090221000008004000030100000000000000
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140530  H12 0050
   Serial number: 90243014140526211137
   Coding: 01DD13
   Serial number: 22782755
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001206145531
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RC3CR03
   Serial number: 65384537000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED125JWQ
   Coding: 303634313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC16F439641B5BB23B-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000LEJ4
   Serial number: 6334MSME464B6346H
   Serial number: 6344MSME462D0148C
   Serial number: 6352QSME75440B7ET
   Serial number: 6362QSME1642574CJ
   Serial number: 63732SME7C4638488
   Serial number: 63832SME7C46357AB
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NFM000AK
   Coding: 000017
   VCID: 48C9535382B9599B073-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 R    HW: 8R0 920 950 R
   Component: KOMBIINSTR.   H07 0564
   Revision: 00300000    Serial number: ZCW25GJ6F
   Coding: 8B9622000301D705020000
   VCID: 45D75A67B5AB44F3FC5-8010
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V14602010F
   Coding: 80C303FF00
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 3257953703
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392F2697C953301388D-806C
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000107308726
   Coding: 011D03204000440004
   VCID: 4FFB784F67D78EA3469-801A
                    Reset counter: 24
                    Mileage: 232706 km
                    Date: 2021.06.21
                    Time: 10:15:17
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H40 0509
   Revision: 00001000    Serial number: 0004659329
   Coding: 100000000000
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3FDB488FD7F71E23B69-806A
   Revision: 00002001    Serial number: 0337256822
   Coding: 0126023A20FA700084B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000854398
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 H    HW: 8R0 035 223 F
   Component: DSP STD       H11 0470
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 313F1EB71123F85330D-8064
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000106709927
   VCID: 4EC5654B60DD87AB4DF-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000465122
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D399BCCD53B0B817-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2051720
   Coding: 04020002010585004359070800
   VCID: 43D3447FBB9F7AC3D21-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000106554907
   Coding: 010C03204000240004
   VCID: 46D55D6B88AD4FEBF5F-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D273287DD7B0C33A45-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H53 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000106560967
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005375131
   Coding: 0010370
   VCID: 3E25358BDC7D172BBDF-806A
End----------(Elapsed Time: 01:48, VBatt start/end: 14.2V/14.2V)-----------
This vehicle does not have a addressable TPMS module so I expect it has "indirect" TPMS, meaning the ABS does it all based on wheel speeds. This also means TPMS will not be happy until the ABS is.
Have you tried the driving part of the System Function Test despite the fact that the ABS hasn't indicated that you've satisfied the initial requirement?
JTT1603
Mississippi, USA
C?ID=426526
Yes, I have attempted it approx. 15 times.
Did you also have to remove the wheel house liner ("splash shield") in order to access the pump? If so, there may be a wiring harness passing through up at the top area ; you may have pinched that wiring ? Also, the wheel speed sensor wiring is behind the brake rotor area, check to make sure you didn't accidently stretch or damage that wiring also.
Wow, that sure is alot of miles for a 4 year old vehicle (144K) ?
JTT1603
Mississippi, USA
C?ID=426526
I only had to detach part of the liner because the pump was very easily accessible behind the rear portion of the wheel house liner, but I will check both that harness and the wheel speed sensor wiring and report back.
Yes, she's been driven a lot, but very few issues mechanically so far.
JTT1603
Mississippi, USA
C?ID=426526
So I pulled out the liner and looked behind the rotor and don't see any issues with the wiring being disturbed or crimped. Any other thoughts about next steps?
I'm just not sure the WW pump and your faults are related ? I suppose it could be pure coincidence. Presuming your narrative is accurate (and I have no reason to doubt it) , this is going to sound insulting, but I assure you it is not meant to be..... are you certain that you were replacing / unplugging the washer pump??
If so, is the WW pump now working? :confused:
JTT1603
Mississippi, USA
C?ID=426526
I'm not sure they're related either, that repair was just the only thing that happened between the time the vehicle was turned off (with no prior warning lights) and turned back on (with ABS, ESC and TPMS warning lights). And yes, the new washer pump is now working fine.
JTT1603
Mississippi, USA
C?ID=426526
Shouldn't I get some type of error code if it's a faulty wheel speed sensor?
Yes, I believe you would.
If you jack up the vehicle one corner at a time Or maybe one end at a time (use jack stands also) , you can rotate the tire and check the sensor(s). I'm not sure in what area of VCDS it would be under: I think its under "output tests" ; you may have to look through the modules or check under "chassis" . I'm sure some others will chime in with suggestions.
03-ABS brakes ----->measuring blocks - 08 ------> group 001 (go) ------> rotate tire Or go for a ride and monitor (caution, keep your eye's on the road!) may need a helper.
This YT video may add a bit of insight also
[EDIT] Here is another EXAMPLE (not your car) ;in fact I'm not familiar
with the configuration of your system ; I think the tone ring is built into the wheel bearing. Note how it does not take much of a rust or corrosion problem to cause clearance problems and thus fault codes. Again, this video is only for basic knowledge. If yours turns out to be a tone ring, you will need to change the wheel bearing as the two are integrated / built together. Please keep us posted!
JTT1603
Mississippi, USA
C?ID=426526
Thanks. The lack of a fault code is what has been throwing me off. The sensor ring on the wheel bearing may be the issue. I don't know that it would throw a code if damaged or faulty. I'll take a look at that next.
@JTT1603: for clarity and apropos of @Uwe suggestion regarding your 01486 ABS DTC - have you been to the forum wiki page (click-on the number)?
