Audi Q7 2014 help 3.0TDI
david_80
C?ID=438395
I started out with this, more to contue
Sunday,09,May,2021,12:07:11:06101
VIN: WAUZZZ4L6ED021518   License Plate: PX14
Mileage: 104690km-65051mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 3D 42 46 4F 52 55 56
          5F 62 6C 6D 6F 72
VIN: WAUZZZ4L6ED021518   Mileage: 104690km-65051miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H41 0003
   Revision: 53H41---    Serial number:
   Coding: 2A2A4012A52701020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2313E52CDB548543B21-8076
5188 - Diesel Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:51:38
                    Engine RPM: 742.50 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 57 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.020 V
                    P Flt Ld fac Ash Cor: 0.9437
                    Particul.filter diff.pressure: 7 hPa
                    Exh t Adap T Oxi Cat Ds: 42.6 °C
                    Exh t Adap TP Flt Ds: 222.0 °C
                    Exhaust gas jet volume in particle filter: 59.1 m³/h
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
4667 - Accelerator Position Sensors (G79) / (G185)
          P2138 00 [167] - Implausible Correlation
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:46:54
                    Engine RPM: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.000 V
                    Accelerator pedal: sensor voltage 1: 2839.6 mV
                    Accelerator pedal: sensor voltage 2: 371.2 mV
                    Accelerator pedal: switch positions-Bits 0-7: 8
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 17
                    Limitation: torque: 0.0 Nm
                    Control Module temperature: 30.1 °C
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:51:38
                    Ambient temperature: 12.8 °C
                    DPF: offset for differential pressure: 1 hPa
                    Particle filter: soot mass measured: 5.39 g
                    Particle filter: soot mass calculated: 65.38 g
                    Particle filter: kilometers since last regeneration: 2511709 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  002 2447
   Coding: 001578
   Shop #: WSC 99999 999 83333
   ROD: EV_TCMAL991031_002.rod
   VCID: 76B5EC78384640EBA5F-8022
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2200689
   VCID: 34311670623A12FB5BB-8060
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 14
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:46:51
                    Count: 128
                    Count: 4421
                    Count: 8196
                    Count: 43776
01486 - System Function Test Activated
                    Reset counter: 14
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:46:51
                    Count: 128
                    Count: 4421
                    Count: 320
                    Count: 43776
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702100682
   Coding: 0000211
   VCID: 2517FB34D9E07B73DC5-8070
   Subsystem 1 - Part No: 4F0 910 220 D
   Component: jôIíÃIC6 IDG   H01 0054
   Coding: 09598208
   Shop #: WSC 43280
   Subsystem 2 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H04 0020
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000030312922
   Coding: 01009416
   VCID: 2517FB34D5E07B73DC5-8070
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0033121
   VCID: 6FBBD91C4B9C7123669-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931332201562
   Coding: 24031F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 343116706EBA12FB5BB-8060
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH44 0230
   Revision: 05H44000    Serial number: 00399D0D6A6Q
   Coding: 0014129
   VCID: 2E0504188C16382B2DF-807A
   Subsystem 1 - Serial number: 6332QSME3F382244G
   Subsystem 2 - Serial number: 6342QSME6739347CR
   Subsystem 3 - Serial number: 6352QSME6739537AR
   Subsystem 4 - Serial number: 6362QSME22383776G
   Subsystem 5 - Serial number: 63734SME763948522
   Subsystem 6 - Serial number: 63834SME76394052
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026132310047
   Coding: 0102142
   VCID: 2809F200AEF2661BE73-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 N    HW: 4L0 920 985 N
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2P02PKCE
   Coding: 3356630400012600010404
   VCID: 3FDB495C577CC1A3B69-806A
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 H
   Component: Heizgeraet      H10 0140
   Revision: 0000000A    Serial number: 00000009024928
   Coding: 0000101
   VCID: 6099AA208642DE5BEF3-8034
00664 - Fuel gauge
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0058
   Revision: LB700037    Serial number: 3700L13A2905EC
   Coding: 00CF07
   VCID: 3E2534585076C8ABBDF-806A
   Component: J367-BDM  H07 0125
   Serial number: 40312L26434121297536
   Serial number: 13315000174011200181
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 L    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7890
   Revision: --H04001    Serial number: 15.1528-0194.2
   Coding: 0015510
   VCID: 3333156C673415C3421-8066
                    Fault Status: 11101101
                    Reset counter: 14
                    Mileage: 104698 km
                    Date: 2021.05.09
                    Time: 11:47:16
                    Error Code: 98
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440     HW: 8K0 907 440
   Component: STS             H04 0040
   Revision: S0H04000    Serial number: 00000000090951
   Coding: 01010101000000000001000202
   VCID: 6B83CD0C7F848D034A1-803E
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000082418185
   Coding: 011F06205061440004
   VCID: 48C9528002B2861B073-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01941521240000
   Coding: 3809787
   VCID: 382922407E52F69B773-806C
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000344221
   Coding: 0011101
   VCID: 5EE594D8BC36E8ABDDF-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000082432445
   VCID: 47CB51BC0FAC89630E9-8012
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 131114-0002-078
   Coding: 11476F1010000500
   ROD: EV_HeadlRegulBasic_AU56.rod
   VCID: 42DD40A8240EAC4BD97-8016
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109K/0D7800339
   Coding: 010103020100000000
   VCID: 2B030D0CB3044D030A1-807E
   Part No SW: 4L2 035 670 M    HW: 4L2 035 670 G
   Component: H-BNT-EU      H48 0941
   Revision: --------    Serial number: 220EV0F7526137
   Coding: 180101060004D3EF010003556F632003040000000100000000
   Shop #: WSC 51491 001 1048576
   VCID: 343116706E3A12FB5BB-8060
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130K20D2879528
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002148758
   Component: CD-Database  5571
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000082444683
   Coding: 010E06204061230004
   VCID: 46D55CB808A6906BF5F-8012
   Revision: --H09---    Serial number: 525PA8-J3X42SW
   Coding: 1021001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81CE107A8A8A3B43B-8038
   Subsystem 2 - Serial number: ,6
ó
   Subsystem 3 - Serial number: RD14.11.13--H57001002F0039ÿ
   Subsystem 4 - Serial number: 2F0039ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0078670228----
   Coding: 0000001
   VCID: 6597BB349960BB731C5-8030
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000082444867
End----------(Elapsed Time: 01:56, VBatt start/end: 14.5V/14.7V)-----------
david_80
C?ID=438395
I have replaced DPF and Dpf pressure sensor adapted and reset statistics for DPF.
then i erased all faults and was left exhaust gas temp sensor bank 1 sensor 3 fault, i checked the sensors temps and sensor 1 normal ambient temp sensor 2 reading 222 degrees sensor 3 reading 1000 degrees sensor 4 reading 222 degrees.
spoke with audi they said my exhaust dont have a sensor 4, which i thought was strange cos of the readings, anyway decided to replace sensor 3 solved that issue, now reading normal ambient temps obviously engine off sensor 2 and 4 still reading 222 degrees.
starting to get confused as to what audi have said to me.
david_80
C?ID=438395
now i am left with this no exhaust temp faults but sensor 2 and 4 still reading 222 degrees and engine aint even been turned over let alone started, also for got to mention i also replaced throttle pedal to
Tuesday,22,June,2021,18:40:55:06101
VIN: WAUZZZ4L6ED021518   License Plate: PX14VNC 22/6/21
Mileage: 104950km-65212mi   Repair Order:
          5F 62 6C 6D 6F 72
VIN: WAUZZZ4L6ED021518   Mileage: 104950km-65212miles
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:21
                    Coolant temperature: 24 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.560 V
                    Accelerator pedal: sensor voltage 1: 2961.6 mV
                    Control Module temperature: 26.6 °C
   Coding: 001578
   Revision: 00H02001
   Coding: 2200689
                    Reset counter: 25
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:18
                    Count: 4421
                    Count: 8196
                    Count: 42240
   Coding: 0000211
   Coding: 09598208
   Shop #: WSC 43280
   Coding: 01009416
   Coding: 0033121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 24031F
   Coding: 0014129
   Coding: 0102142
   Coding: 0000101
   Coding: 00CF07
   Coding: 0015510
                    Reset counter: 25
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:19
                    Error Code: 98
   Coding: 3809787
   Coding: 0011101
   Coding: 1021001
ó
   Coding: 0000001
End----(Elapsed Time: 01:55, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
david_80
C?ID=438395
          5F 62 6C 6D 6F 72
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:21
   Coding: 001578
   Revision: 00H02001
   Coding: 2200689
                    Reset counter: 25
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:18
                    Count: 4421
                    Count: 8196
                    Count: 42240
   Coding: 0000211
   Coding: 09598208
   Shop #: WSC 43280
   Coding: 01009416
   Coding: 0033121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 24031F
   Coding: 0014129
   Coding: 0102142
   Coding: 0000101
   Coding: 00CF07
   Coding: 0015510
                    Reset counter: 25
                    Mileage: 104958 km
                    Date: 2021.06.22
                    Time: 18:33:19
                    Error Code: 98
   Coding: 3809787
   Coding: 0011101
   Coding: 1021001
ó
   Coding: 0000001
Thanks moderator was wondering how that was done
