2015 Audi Allroad
avedian
Los Angeles, USA
C?ID=429889
Getting the following errors:
Stabilizer Control
TPMS
Recently installed the CTS intake and ESC diverter valve spacer. In 3rd and 4th gear, with heavy throttle, there is some hesitation at 5k rpm. Any ideas?
Here is my scan:
Tuesday,22,June,2021,22:21:57:10110
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
VIN: WA1UFAFL3FA132917   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WA1UFAFL3FA132917   Mileage: 101100km-62820miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 722A0013242600062000
   Shop #: WSC 39427 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D273234ADF3D903A45-8068
          U1113 00 [047] - -
                    Mileage: 101041 km
                    Date: 2021.06.22
                    Time: 18:32:04
                    Engine RPM: 1292.00 /min
                    Normed load value: 33.3 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 13.782 V
                    Engine status: COENG_RUNNING
5667 - Mass Air Flow Sensor (G70)
          P0101 00 [237] - Implausible Signal
                    Mileage: 101041 km
                    Date: 2021.06.22
                    Time: 18:32:03
                    Engine RPM: 1283.50 /min
                    Normed load value: 34.1 %
                    Vehicle speed: 52 km/h
                    Intake air temperature: 43 °C
5671 - Boost Pressure Regulation
          P0299 00 [100] - Control Range Not Reached
                    Mileage: 101087 km
                    Date: 2021.06.22
                    Time: 21:49:17
                    Engine RPM: 2394.50 /min
                    Normed load value: 79.6 %
                    Vehicle speed: 116 km/h
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.735 V
Readiness: 0010 0001
   Part No SW: 8K0 927 158 AE    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H19 1005
   Revision: --H19---
   VCID: 79AFE624F95B2523C8D-802C
2505 - Torque Management Feedback Signal A
          P2637 00 [047] - -
                    Mileage: 101041 km
                    Date: 2021.06.22
                    Time: 18:32:06
                    Voltage terminal 30: 13.645 V
                    Transmission output speed: 1234.00 /min
                    Driving position: d
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: regulated
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 50.40 km/h
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K9 907 379 P    HW: 8K9 907 379 P
   Component: ESP8 quattro  H09 0020
   Coding: 0E1D1801
   Shop #: WSC 06335 000 00000
   VCID: 4FFB78FC17DF5B93469-801A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 65
                    Mileage: 100977 km
                    Date: 2021.06.22
                    Time: 14:51:40
                    Hex Value: 0x6F00
                    Hex Value: 0x4006
                    Hex Value: 0x120B
                    Hex Value: 0x46B2
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D824040000000000000
   VCID: 084993E0B2314CABC73-805C
   Serial number: 3215000067650008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01250420150562
   Coding: 6480208000
   VCID: 77ABE01CCFCF3353BE9-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001058045002
   Coding: 260000918634AFE00100408300003D0DCF9CC708A2090221000008004000030100000030000000
   Shop #: WSC 06335 123 12345
   VCID: 78A9E320C2D13C2BB73-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA160315  H19 0461
   Serial number: 1503130603451
   Coding: 004577
   Serial number: 20262076
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000904150153
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01EF29F2
   Serial number: AAD884A7000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED13LR5O
   Coding: 303844354A32383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC16FF0E649608B23B-8018
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R150000M3F7
   Serial number: 6334MSME505E0F4EU
   Serial number: 6344MSME505D4840D
   Serial number: 6352QSME5F532B7C.
   Serial number: 6362QSME655323507
   Serial number: 63732SME774F415CB
   Serial number: 63832SME0F5A16442
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862ODK000DA
   Coding: 000037
   VCID: 48C953E0F2B18CAB073-801C
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61U78RU3G
   Coding: 83BF29020301D705020000
   VCID: 382923208251FC2B773-806C
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z154150FA3
   Coding: 80C303FF00
   VCID: 4CC16FF0E6C9608B23B-8018
   Serial number: 3493906203
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000144968173
   Coding: 00581B00000000000000
   VCID: 3B233C2CB367D7339A1-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0366805496
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3FDB483CA7FFCB13B69-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0366545613
   Coding: 010211
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000146823404
   Coding: 011C13205E00410001
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0007694440
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E253538A0F5C21BBDF-806A
   Revision: 00002001    Serial number: 0363538786
   Coding: 0126063A20BA7095803002320000004F
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000975205
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Revision: 00005001    Serial number: 94813043222306
   VCID: 2D0702747D134983145-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000147224702
   VCID: 4EC565F810D5529B4DF-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000365751
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D3928BCDDEE3B817-806E
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 65
                    Mileage: 100977 km
                    Date: 2021.06.22
                    Time: 14:51:40
                    Voltage terminal 30: 14.1 V
                    Internal Fault ID: 188
                    Vehicle speed: 110 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156D00F8256528
   Coding: 020007010000000001
   VCID: 2411E7502ED988CBCBB-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523H20F7545645
   Coding: 100200050106E1EF55028F5E00000403140000000000000000
   Shop #: WSC 19251 002 1048576
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130DN0F3333480
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002213024
   Component: CD-Database  5950
02244 - Button in Control Head is Stuck
                    Reset counter: 65
                    Mileage: 101100 km
                    Date: 2021.06.22
                    Time: 22:17:53
                    Voltage: 12.20 V
                    Hex Value: 0x0005
                        not available
03389 - Data Set Implausible
                    Reset counter: 62
                    Mileage: 100823 km
                    Date: 2021.06.21
                    Time: 22:22:07
                    Voltage: 12.10 V
                    Bin. Bits:      010
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000146587718
   Coding: 010C13204000210001
   VCID: 46D55DD8F8A59ADBF5F-8012
   Revision: --H09---    Serial number: 525PA8-JA290TS
   Coding: 1000007
   Shop #: WSC 06325 000 00000
   VCID: 382923208E51FC2B773-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E253538A075C21BBDF-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000146587726
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.2V)-----------
So did these faults start right after installing those FOD parts?
avedian
Los Angeles, USA
C?ID=429889
Only after i installed the ESC diverter valve spacer. But the Stabilizer Control and TPMS warning comes and goes. The check engine lights stays on.
Well, if it were mine, I'd remove the diverter valve spacer to see if that helps.
