Cant access individual controllers or OBD2 function
jay86galway
Ireland
C?ID=305408
Hi All,
Looking for help with my 2013 VW Crafter. I only bought the van 6 months ago and it had been running fine up until 4/5 weeks ago when the van started to go into limp mode and had the glow plug light flashing. VCDS told me it was coolant pump 2 and I ordered it. In the mean time while waiting for the part I had to use my van one of the days and drive it while in limp mode. Unfortunately while doing this the DPF light also came on. So I fitted the new coolant pump last week but it has made no difference. The glow plug went out for all of 2 days but the DPF light remained on. I tried doing a passive regeneration of the DPF with high revs motorway run for 30plus minutes but to no avail. I know I can complete a forced regeneration with VCDS but that's why I'm posting this message here today. My VCDS wont communicate to the engine module whatsoever. I can complete an autoscan by selecting my chassis (2E) in the dropdown list, but if I try clear the DTC's it will fail. Also when I try access the individual engine module for the forced regen, even using the LT3 tab along the top it tells me that this is not possible and the module fails to open. It also fails to communicate using OBD2. I'm really at a loss as how to proceed. Here is a scan of my van,
Tuesday,22,June,2021,11:14:10:56033
VIN: WV1ZZZ2EZD6026351   License Plate:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTC)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 C    HW: 03L 906 012 A
   Component: R4 2.0l TDI   H26 9977
   Revision: 72H26---    Serial number: VWXDZ0M1005179
   Coding: 0119401020040C080000
   ASAM Dataset: EV_ECM20TDI01103L906012C 002018
   ROD: EV_ECM20TDI01103L906012A_002.rod
   VCID: 2412E5F38E56513BCBB-8070
5188 - Diesel Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 242 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine RPM: 2281.50 /min
                    Normed load value: 12.5 %
                    Vehicle speed: 46 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.280 V
                    Counter for regeneration time of particulate filter: 644.40 s
                    Particle filter: kilometers since last regeneration: 413336 m
                    Particle filter: soot mass measured: 0.25 g
                    Particle filter: soot mass calculated: 40.01 g
                    Particle filter: differential pressure: dynamic offset: 6 hPa
4875 - Coolant Pump 2
          P261A 00 [040] - Open circuit
                    Fault Frequency: 53
                    Mileage: 99394 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine RPM: 1942.00 /min
                    Normed load value: 70.6 %
                    Vehicle speed: 89 km/h
                    Coolant temperature: 56 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 14.620 V
                    Coolant temperature at radiator outlet: actual value: 55.7 °C
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 37
                    EGR cooling function: status-Bits 0-7: 0
                    exh.gas recirc. (EGR) cooler pump: specified value: 95.00 %
                    EGR Vacuum Regulator Solen.val.: activation: 65.36 %
                    Exhaust gas temperature sensor 1: 408.8 °C
Readiness: 1 2 0 0 0
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 A    HW: 906 900 270 2
   Component: IMMO          0805  1246
   Revision: 00805000    Serial number: VWXDZ0M1005179
   VCID: 2514F8F789ECA833DC5-8070
01176 - Key
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F48837958CF8B38C5-8000
9186 - CAN info: Signal "Vehicle Speed" not received
            Test Complete - Stored
919E - CAN info: Signal "Driven distance" not received
919D - CAN info: Signal packet "Date" not received
Address 95: LT3 ESP
   Part No HW: 0009015901
   Serial number: 000901590110851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069023301    HW: 9069019600
   ASAM Dataset: 32 791
   ROD: CRFT_KOMBI_32_791.rod
   VCID: 015C8C673184A41380D-8054
9128 - Voltage: Lower limit not reached
Address 99: LT3 Ign. Switch
   Part No HW: 9069002702
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  1246
   Revision: 00805000    Serial number: 12345678901234
00171 - Key 1 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9068205626
   ASAM Dataset: 33 260
   ROD: CRFT_FTUHR_33_260.rod
Address B4: LT3 Central Elec.
   Part No SW: 9069022001    HW: 9069013100
   ASAM Dataset: 33 833
   ROD: CRFT_EZE_33_1088.rod (*)
   VCID: 7DA4F0974D7CC0F3E45-8028
90A1 - Engine Coolant Level (ECL) Sensor (G32): Short to Plus
90D5 - Center Instrument Panel Control Head (J819): No communication
            Test Complete - Active/Stored
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 06569F7B18AA832BB5F-8052
End----------(Elapsed Time: 00:50, VBatt start/end: 12.1V/12.2V)-----------
Tuesday,22,June,2021,14:07:24:56033
                    Mileage: 242 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Fault Frequency: 53
                    Mileage: 99394 km
                    Date: 2047.15.31
                    Time: 31:63:63
01176 - Key
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
End----------(Elapsed Time: 01:11, VBatt start/end: 12.2V/12.2V)-----------
I also get this message after completing a scan
Any help would be greatly appreciated.
Thanks,
Jay
Eric
HC800000
We're working on this issue, but in the meantime you should be able to enter 01 if you reboot your HEX-v2 after the autoscan, or go to 01 directly after plugging in the HEX-v2 without doing an autoscan. Please let us know whether that works or not.
