ECU communication problems
Ben Eeles
England
C?ID=390144
Tuesday,22,June,2021,10:36:59:11265
VIN: TMBMG65J075019517   License Plate:
Chassis Type: 5J (5J - Skoda Roomster (2006 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBMG65J075019517   Mileage: 181450km-112747miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 NR
   Component: 1,9l R4 EDC G000SG  9134
   Coding: 00102
   Shop #: WSC 27998
   VCID: 74B0273647A9EFBB9BB-4B3C
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No: 6R0 907 379 C
   Component: ABS 8.0 front   H05 0002
   Coding: 0002085
   Shop #: WSC 73430 790 00000
   VCID: 3E24C51E3C6575EBBDF-50D0
No Faults Found
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 5J0 820 045
   Component: Klimaanlage        X0840
   VCID: 629C516EED5D710BF97-50D0
            07-00 - Signal too Low
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3C20CF162F7967FB93B-50D0
   Part No: 1C0 909 605 F
   Component: Q5 AIRBAG VW61 Q1Q2 0003
   Coding: 20789
   Shop #: WSC 73430
   VCID: 270A007AC6FFD423EE9-50D0
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 910 C
   Component: KOMBIINSTR.    V2721446
   Coding: 17402
   Shop #: WSC 27998
   Part No: 6N0 909 901
   Component: 003B GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70B82B2633B1D39B7F3-50D0
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2721446
   Coding: 17402
   Shop #: WSC 27998
   TMBMG65J075019517     SKZ7Z0F3801562
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 5J0 959 433 A
   Component: 01 Komfortgerát     0001
   Coding: 00258
   Shop #: WSC 24066
   VCID: 313EEE22F83B9A9330D-4B3C
   Subsystem 1 - Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Subsystem 2 - Part No: Steuerger
   Component: t Beif. antwortet nicht
   Subsystem 3 - Part No: Steuerger
   Component: t HL    antwortet nicht
   Subsystem 4 - Part No: Steuerger
   Component: t HR    antwortet nicht
Address 56: Radio        Labels:
   VCID: 55F67AB2AC0396B38C5-FFFE
End----(Elapsed Time: 03:46, VBatt start/end: 12.2V/12.1V. VIgn 0.0V)------
Hi,
I am having problems with my car (again!), I took it to our local VAG specialist who has ODIS (legit version) to have the instrument cluster changed, the original one having been fried by the previous owner, they tried but said ODIS was not communicating with the ECU so they couldn't do it (did charge me though for the work).
I went away and got a replacement ECU (second hand) and booked it in to have it changed over.
They tried again and couldn't do it with either ECU's as ODIS was unable to communicate with them, they did manage to recode my spare keys in though.
Either I've been very unlucky with ECU's, something is wrong with my car or their system is glitchy, They couldn't explain it.
Has anyone else had this problem or any ideas as to how to go forward?
Regards
Ben
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I have a hard time believing what the specialist it telling you. That ODIS not communicating with ECU.
VCDS is communicating with ECU.
How did ODIS communicate with ECU to program keys?
I would think is something wrong with car not ECU.
What kinda VAG specialist with legit version of ODIS would blame ECU.
Just doesn't make sense. I'd have more faith if they said we don't know why? Cause I believe that to be the truth.
But I wouldn't go down the road of another ECU.
Good Luck
I hate to wax pedantic, but keys are programmed to to the Immobilizer (which is a virtual module in the instrument clsuter in this car), not the ECU.
I hate to wax pedantic, but keys are not programmed to the Immobilizer (which is a virtual module in the instrument clsuter in this car), not the ECU.
hmmm.......... in a battle of pedants, I'm not sure which of us would prevail- BUT, waxing equally pedantically, I suspect you intended to say: :)
"keys are not programmed to the Immobilizer (which is a virtual module in the instrument clsuter cluster in this car), not the ECU."
vwtech
Wilkes-Barre, PA
C?ID=7573
Okay good enough answer for me on keys.
Why can VCDS communicate with ECU if ODIS can't?
Good Luck
Spacewalker
Poland
C?ID=159607
Did odis recognize CAR VIN ?
you know something more
or only that - "they cant " ?
Ben Eeles
England
C?ID=390144
Hi
They must have recognized the vin as they were able to code the two spare keys in after I replaced the chips, but just said after the second visit that they just didn't know why it was not talking. They are not a fly by night outlet as they have three branches all specializing in VAG group cars.
I tried VCDS when I got home and that communicated ok, I found out today that the VAG Eeprom programmer tool wont work on Roomsters so no getting the codes that way for a VCDS code in.
It also seems the K-Can commander line of thought is also out as that wont work either (returns wrong codes).
I did contact Skoda to ask them why it didn't communicate but no reply as yet, although I dont think they will.
With regards to the car, I dont think there is anything wrong with it if VCDS can communicate with the ECU when scanning.
Spacewalker
Poland
C?ID=159607
so you know all already
