At this point, I believe that your 793a module may be defective. Maybe a cracked solder on the electronic circuit (if you can open the enclosure and inspect the pcb, you may notice a problem).Here is video. Now codding is correct.
Per curiosity, these values refer to what position in EEPROM?
bit | function | worth | status |
0 | Ambient lighting when the mirrors are folded in | 0 / 1 | (0) active / (1) disabled |
1 | Reversal of the folding motor | 0 / 1 | active / disabled |
2 | Unfolding mode of the mirrors | 0 / 1 | ignition on / driver door open |
3 | ? | ||
4 | Foldable mirror via remote control | 0 / 1 | (0) disabled / (1) active |
5 | Power window motor reversal | 0 / 1 | disabled / active |
6 | ? | ||
7 | ? |
Can inspect it, but, I have installed before other 2 modules (from Skoda), that have other, but similar problems too (it is in first post of theme).At this point, I believe that your 793a module may be defective. Maybe a cracked solder on the electronic circuit (if you can open the enclosure and inspect the pcb, you may notice a problem).
address 189 (0xBD), 206 (0xCE) and 223 (0xDF)
bit function worth status 0 Ambient lighting when the mirrors are folded in 0 / 1 (0) active / (1) disabled 1 Reversal of the folding motor 0 / 1 active / disabled 2 Unfolding mode of the mirrors 0 / 1 ignition on / driver door open 3 ? 4 Foldable mirror via remote control 0 / 1 (0) disabled / (1) active 5 Power window motor reversal 0 / 1 disabled / active 6 ? 7 ?
