Passenger window doesn’t work with remote (07 MK5 GTI)
tcrow25031
US
C?ID=395964
Hey guys, weird issue. Bit of a noob with VCDS so excuse any dumb questions. Coded in the comfort/convenience option with remote enabled and was working (both windows) but the passenger side stopped after I tried to copy my key. All windows work as expected with the switches. Any and all help is greatly appreciated.
thanks!
tcrow25031
US
C?ID=395964
Thanks, Uwe. Will do.
Sunday,20,June,2021,21:38:18:55609
VIN: WVWEV71K97W027902   License Plate: NA
Mileage: 222570km-138298mi   Repair Order: Test 1
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 2E 42 44 46 52 55 56 65
          77
VIN: WVWEV71K97W027902   Mileage: 222570km-138298miles
02-Auto Trans -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Not registered 0011
1C-Position Sensing -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Not registered 0001
65-Tire Pressure -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH14---    Serial number: VWZ7Z0F8021487
   Coding: 0403010A18070160
   Shop #: WSC 09144 444 82784
   VCID: 2B0301F3FF08A3C30A1-807E
               P0300 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 218929 km
                    Time: 19:52:30
                    RPM: 1160 /min
                    Load: 57.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - Intermittent
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - Intermittent
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
008567 - Bank 1; System Too Lean off Idle
               P2177 - 001 -  - Intermittent
                    Fault Status: 00110001
                    Mileage: 218936 km
                    Time: 17:18:28
                    RPM: 2177 /min
                    Load: 27.0 %
                    Speed: 59.0 km/h
                    Temperature: 93.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
Readiness: 0110 0101
Address 02: Auto Trans
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 01279 785 00200
   VCID: 73B3D99367B8BB03821-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70B9D69F16AE801B7F3-8024
00756 - Left Vent Temp Sensor (G150)
            010 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
00709 - Sunlight Photosensor 2 (G134)
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005705307
   Coding: B78F8F214004150000140000001400000028770B5C0000
   Shop #: WSC 12345 111 45725
   VCID: 372B2D83334017237E9-8062
   Component: Wischer 070606 020  0501
   Coding: 00038805
   Shop #: WSC 12345
                    Fault Status: 01101010
                    Reset counter: 61
                    Mileage: 222561 km
                    Voltage: 12.90 V
                    Reset counter: 61
                    Mileage: 222561 km
                    Voltage: 12.95 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7E7016427
   VCID: 2A0D04F7F0F2BACBF17-807E
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 00:00:02
02788 - Internal Communications Error
                    Fault Frequency: 240
                    Reset counter: 101
                    Mileage: 218941 km
                    Time: 03:30:07
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Part No SW: 1K0 909 605 Q    HW: 1K0 909 605 Q
   Component: 5L AIRBAG VW8R  033 7900
   Revision: 04033000    Serial number: 0038LD09GGLL
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 3A2D34B700520A4B817-806E
   Subsystem 1 - Part No: 1K0 959 339 D
   Component: BF-Gewichtsens. 006 0006
   Subsystem 2 - Serial number: 6332MSME10767878F
   Subsystem 3 - Serial number: 6342MSME1139420C4
   Subsystem 4 - Serial number: 6352QSME0D41197DP
   Subsystem 5 - Serial number: 6362QSME0D0F132FR
   Subsystem 6 - Serial number: 63727SME0A3F1031-
   Subsystem 7 - Serial number: 63827SME0A3E59507
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0002022
   VCID: 7AADF4B740D2CA4BC17-802E
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0F8021487
   Coding: 0007203
   Shop #: WSC 05300 758 69175
   VCID: 313F139BDD24C91330D-8064
                    Fault Frequency: 102
                    Reset counter: 61
                    Mileage: 219327 km
                    Time: 11:55:16
                    Reset counter: 60
                    Mileage: 222561 km
                    Time: 09:05:36
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 050210F2001333
   Coding: ED801F07001612000000
   VCID: 698FBBFB357471D338D-803C
                    Fault Status: 01110100
                    Reset counter: 246
                    Mileage: 218929 km
                    Time: 19:51:32
                    Reset counter: 60
                    Mileage: 222561 km
                    Time: 09:05:37
                    Reset counter: 246
                    Mileage: 218929 km
                    Time: 19:51:36
                    Mileage: 218929 km
                    Time: 19:51:32
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 246
                    Mileage: 218929 km
                    Time: 19:51:36
03272 - Control Module for Audio Interface
                    Reset counter: 246
                    Mileage: 218929 km
                    Time: 19:51:36
Address 1C: Position Sensing
   Component: IMMO            VDD 1610
Address 2E: Media Player 3
   Component: Tuer-SG         005 0967
   Coding: 0001077
   VCID: 38292EBF3E5E185B773-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311A8F2236FC3B5BB-8060
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 139006885103083F0904058FB0080A0488BC00
   Shop #: WSC 01287 785 00200
   VCID: 74B1DA8F62B6BC3B9BB-8020
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 61
                    Mileage: 222561 km
                    Time: 09:10:30
   Coding: 0001076
   VCID: 392F2BBB0554015388D-806C
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No: 1T0 907 357
   Coding: 0000003
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: Radio         526 5321
   Revision: --------    Serial number: VWZZZ4Q5116728
   Coding: 00000400040005
   Shop #: WSC 00078 790 00217
   VCID: 45D7574B75AC75B3FC5-8010
00875 - Treble Speaker Front Right (R22)
                    Fault Status: 00111011
                    Reset counter: 98
                    Mileage: 218941 km
                    Time: 19:41:05
                    Reset counter: 247
                    Mileage: 218941 km
                    Time: 19:41:03
   Component:    RDK              0420
   Coding: 0100101
                    Reset counter: 252
                    Mileage: 219462 km
                    Time: 17:20:29
Address 77: Telephone
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
Wow, that car is a mess. ;)
I was kind of thinking you'd have a "Basic Settings" fault in the Passenger door module, but nope...
I'd still try re-syncing that window.
tcrow25031
US
C?ID=395964
It’s a project car, but runs perfectly. Just need to sort some things, but it’s been running driving since 2017 (drivetrain). Swapped to a 2007 body, and here we are. Daily car, zero drivability issues.
tcrow25031
US
C?ID=395964
Any help on “the mess” is greatly appreciated! 😊
OK, let's start with the obvious stuff:
* Where's the Transmission Controller that the Gateway wants to see? Does this car have a manual trans?
* Ditto for the Headlight Range Controller and the TPMS and the Telephone modules? Have they been removed?
Or is this a case where the Gateway from a different car was swapped in and the Gateway Installation List was never adjusted?
tcrow25031
US
C?ID=395964
Ah. That’s definitely more clear. Let me enlighten you. RCD 330 swapped from the factory radio. CarPlay head unit. All the BS 2007 crap is gone. No TPMS sensors. Aftermarket rims. Never installed them. Tried to code out most of those nonessential things but no idea how. 6 speed 02Q transmission.
[Select]
[19-CAN Gateway]
[Installation List]
- Remove the checkmark next to each module that shows "Cannot be reached" in the list at the top of your scan.
- Put a checkmark next to 0F-Digital Radio.
[Save Coding]
Exit VCDS. Cycle the ignition. Clear all fault codes. Cycle the igniton again and make/post a fresh scan so we can see where were are now.
n4s
Portugal
C?ID=351319
This module is responsible for TPMS, you can see in part number is same
In #46 coding try to find the option that activate TPMS and remove it.
Do also what Uwe suggest to clear the CAN errors, and remove also gearbox because it is manual.
tcrow25031
US
C?ID=395964
Thanks Uwe. Will do. 👍
[Select]
[19-CAN Gateway]
[Installation List]
[Save Coding]
Tuesday,22,June,2021,19:27:13:55609
Mileage: 222570km-138298mi   Repair Order: test2
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
56-Radio -- Status: Not registered 0011
                    Mileage: 218929 km
                    Time: 19:52:30
                    RPM: 1160 /min
                    Load: 57.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 14.224 V
000769 - Cylinder 1
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
000772 - Cylinder 4
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
                    Mileage: 218936 km
                    Time: 17:18:28
                    RPM: 2177 /min
                    Load: 27.0 %
                    Speed: 59.0 km/h
                    Temperature: 93.0°C
                    Temperature: 20.0°C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 12345
                    Reset counter: 61
                    Mileage: 222577 km
                    Voltage: 12.10 V
                    Reset counter: 61
                    Mileage: 222577 km
                    Voltage: 12.10 V
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:50
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:49
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Coding: 0013644
   Coding: 0002022
   Coding: 0007203
   Coding: E9801F06001102000000
                    Mileage: 222577 km
                    Time: 01:37:51
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:55
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:55
   Coding: 0001077
            014 - Defective
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:49
   Coding: 0001076
   Coding: 0000003
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:51
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:49
End----------(Elapsed Time: 01:04, VBatt start/end: 12.1V/12.1V)-----------
OK, we missed:
1C - Position Sensing -- needs to be un-checked.
55 - Headlight Range -- needs to be checked.
And then we gotta ask: What kind of backup camera is installed in this car?
tcrow25031
US
C?ID=395964
It’s due for a carbon cleaning so I’m sure that’s likely the misfires, or an injector issue. Thanks again everyone!
OK, we missed:
just a generic one. (Camera)
SCAN
Tuesday,22,June,2021,20:11:28:55609
Mileage: 222570km-138298mi   Repair Order: TEST3
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 55 56
                    Mileage: 218929 km
                    Time: 19:52:30
                    RPM: 1160 /min
                    Load: 57.6 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 14.224 V
000769 - Cylinder 1
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
000772 - Cylinder 4
                    Mileage: 218929 km
                    Time: 19:53:09
                    RPM: 1317 /min
                    Load: 31.8 %
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
                    Mileage: 218936 km
                    Time: 17:18:28
                    RPM: 2177 /min
                    Load: 27.0 %
                    Speed: 59.0 km/h
                    Temperature: 93.0°C
                    Temperature: 20.0°C
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 12345
                    Reset counter: 61
                    Mileage: 222577 km
                    Voltage: 12.10 V
                    Reset counter: 61
                    Mileage: 222577 km
                    Voltage: 12.10 V
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:50
                    Reset counter: 101
                    Mileage: 222577 km
                    Time: 01:37:49
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Coding: 0013644
   Coding: 0002022
   Coding: 0007203
   Coding: E9811F06000102000000
                    Mileage: 222577 km
                    Time: 01:37:51
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:55
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:55
   Coding: 0001077
            014 - Defective
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:49
   Coding: 0001076
   Coding: 0000003
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:51
                    Reset counter: 61
                    Mileage: 222577 km
                    Time: 01:37:49
