2013 Audi S7 Fault Codes / EPC light on but no CEL - Help please
Soulphire
Colorado, USA
C?ID=401960
My car just threw a EPC light so I ran a scan, which I will attach. A couple days later the light is off and I drove it a couple times (about 40 miles), no issues. Then yesterday got back in and started driving and the light popped back on. Vehicle runs smoothly, no vibrations,strange noises or RPM limitations.
Some history on the vehicle. Just got it back from the dealer, they replaced the Oil Separator / Breather Valve and I had them go ahead and replace the turbo screens while they were at it. Other than that, oil changes every 5k miles...no issues.
Vehicle:
2013 Audi S7 4.0T
APR Stage 1 ECU Tune
APR Stage 1 TCU Tune
Resonators, mufflers and tips removed, replaced with a single crossover muffler where the suitcase muffler was.
Valve simulators installed at tips to prevent error codes. Cats are untouched.
Thanks in advance.
List of only the faults:
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H61 0009
   Revision: NCH61---
   Coding: 1A2500326546000E1000
   Shop #: WSC 04035 003 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
   ROD: EV_ECM40TFS0114G0906014B.rod
   VCID: 211FE379014C0C53A0D-8074
10530 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
                    Mileage: 80494 km
                    Date: 2021.06.10
                    Time: 09:35:25
                    Engine RPM: 1294.00 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 30 ∞C
                    Intake air temperature: 30 ∞C
                    Ambient air pressure: 800 mbar
                    Voltage terminal 30: 13.947 V
                    Engine status: COENG_RUNNING
18604 - Oil pressure Switch 3
          P168D 00 [237] - Malfunctuon
                    Mileage: 80508 km
                    Date: 2021.06.14
                    Time: 11:19:40
                    Engine RPM: 2921.00 /min
                    Normed load value: 7.8 %
                    Vehicle speed: 41 km/h
                    Coolant temperature: 76 ∞C
                    Intake air temperature: 50 ∞C
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AA
   Component: J533--Gateway H11 0035
   Revision: --------    Serial number: 00000000635155
   Coding: 00E1034800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_GatewPkoUDS 001016
   VCID: 71BFD339912CFCD370D-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790880177
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 94
                    Mileage: 80455 km
                    Date: 2021.06.07
                    Time: 13:47:38
                    Voltage terminal 30: 11.4 V
                    Voltage terminal 15: 11.5 V
                    Control Module temperature: 41 ∞C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
ddress 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Revision: 00002001    Serial number: 0181569478
   Coding: 0126063A20FAF08580B00A80020102000000000000000000000000000000
   VCID: 7BA3F111C3E08683DA1-802E
   Component: GTO BF  H01 0080
   Serial number: 00000000000000099852
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1706037+
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001756457
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA103990000001763808
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                    Reset counter: 103
                    Mileage: 80463 km
                    Date: 2021.06.08
                    Time: 12:25:48
   Part No SW: 4G1 035 465     HW: 4G1 035 465
   Component: BO G3 C7 ANC  H03 0130
   Revision: 09S00000    Serial number: 0010694
   Coding: 020101
   VCID: 6393A9715B505E43F21-8036
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 00207120021157
00419 - Left Front DSP Midrange Speaker (R103)
                    Fault Status: 00101011
                    Reset counter: 103
                    Voltage: 11.20 V
                    Temperature: 18.0∞C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 19.0∞C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000572704
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: 6695B065A8E22B6B15F-8032
0306 - Actuator 2 for Drivetrain Mounts
          C1132 13 [009] - Open Circuit
                    Reset counter: 54
                    Mileage: 80455 km
                    Date: 2021.06.07
                    Time: 13:45:48
End----(Elapsed Time: 03:00, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Trowbridge, UK
It's always better to post the unedited Auto-Scan (and easier for you too!) as knowing the complete picture of the vehicle configuration very often gives important clues.
Soulphire
Colorado, USA
C?ID=401960
Will do..thanks! Here it is:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90 A9 BA
Mileage: 80586km-50073 miles
BA-Motor Mounts -- Status: Malfunction 0010
   Revision: NCH61---
10530 - EVAP System
                    Mileage: 80494 km
                    Date: 2021.06.10
                    Time: 09:35:25
                    Mileage: 80508 km
                    Date: 2021.06.14
                    Time: 11:19:40
Readiness: 0010 0000
   Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
   Component: 0B5 40TFSINAR H01 0010
   Revision: --H01---
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3D273F099DF448B3A45-8068
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F03A66DF2C04B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 38292E1DB2D66D9B773-806C
   Coding: 0D8A2006000000000000
   Serial number: 2312000163181002
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 03081200041771
   Coding: 688320B85D
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629DAC7544CA574BF97-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001388487
   Coding: 0D072011013E8FE2A90008C7A0003820CF9CD308A2090221800308457B00
   VCID: 6FBBD5418798EA23669-803A
   Component: WWS57X 120717  H36 0080
   Serial number:         120723121023
   Coding: 0045F7
   Serial number: 20470330
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 03 08 2012  00000906
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2DVH02
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001205243776
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001205244446
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103816000001669440
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 7D48CC36000000000001
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001206202266
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001206202388
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061221300301
   Coding: A8E909
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77ABED21FF48A2E3BE9-8022
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809FE5D6276FD1BE73-807C
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D80029SJ$
   Coding: 303145313131303030324A55304C34473853
   VCID: 33331931ABB08EC3421-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H15 0045
   Serial number: 6940000Y120000GV430O
   Serial number: 3575HRB405L1G0QM70FK
   Serial number: 3585HRB40631G7FCCG51
   Serial number: 3515JRB40631AP60L8M5
   Serial number: 3525JRB40651DKAS6GLU
   Serial number: 3554VRB405J19PPQIORB
   Serial number: 3564VRB405H19PPQD164
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372RKJ00060
   Coding: 0004FC
   Shop #: WSC 62748 001 1048576
   VCID: 38292E1DB2566D9B773-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 06 06 2012  D0078930
   Part No SW: 4G8 920 983 T    HW: 4G8 920 983 T
   Component: TBenUsaAccNv  H76 0515
   Revision: 28460207    Serial number: 658010812596037
   Coding: 03CF01079F53D705020300
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 46D550E5C8220B6BF5F-8012
   Coding: 00E1034800
          U140B 00 [008] - -
                    Reset counter: 94
                    Mileage: 80455 km
                    Date: 2021.06.07
                    Time: 13:47:38
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 003107120001014
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 270BFD616F68F263EE9-8072
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 25071200041433
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 372B2D21BFC862E37E9-8062
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E0508454092A32B2DF-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000035241371
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77ABED21FFC8A2E3BE9-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E003C5Z
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-08
   Coding: 0000003
   VCID: 36352025B4429BEB65F-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F17.07.1200H02000AMS14852ˇ
   Subsystem 4 - Serial number: S14852ˇ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F57025E00628002000413
   VCID: 45D757E9F5A40073FC5-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0022744077
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1C3554AA87CB497-8066
   Coding: 101F00
                    Reset counter: 103
                    Mileage: 80463 km
                    Date: 2021.06.08
                    Time: 12:25:48
   Coding: 020101
                    Reset counter: 103
                    Voltage: 11.20 V
                    Temperature: 18.0∞C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 19.0∞C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D550E5C8A20B6BF5F-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000435015
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B0301517380D6030A1-807E
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 120731-0002-050
   Coding: 12236F601002A400
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: 2D070F494D94D833145-8078
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156H10C7620786
   Coding: 020007010000000001
   VCID: 211FE37901CC0C53A0D-8074
   Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0549
   Revision: --------    Serial number: 194H30C7508286
   Coding: 0A0200040203FDEF7D16CB1E00000003100001000000000000
   VCID: 2615F06568E2EB6BD5F-8072
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94025Z0Q
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LH3000PL
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF5BD9D9BCE41318D-801C
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0111
   Revision: 11001001    Serial number: 82330JF0051796
   Coding: 0206000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
   ROD: EV_CamerSysteTopViewAUDI_005.rod
   Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0039
   Revision: 12013001    Serial number: 184200524
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 42DD4CF5E40A374BD97-8016
   Component: TSG HR        H03 0506
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 G    HW: 4G8 919 604 G
   Component: HeadUpDisplay 010 0106
   Coding: DE0000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40078197
   Coding: 1411
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001216400682
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F0656862EB6BD5F-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000050208127
   Coding: 03C19A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F133951ACBCD330D-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120717201091
   VCID: 2C01024D768ED13B03B-8078
                    Reset counter: 54
                    Mileage: 80455 km
                    Date: 2021.06.07
                    Time: 13:45:48
EPC light is due to this:
Given the work that was just done on the car, I would be suspicious that something wasn't put back together quite right.
Soulphire
Colorado, USA
C?ID=401960
Ok thanks. I was thinking it was the motor mount....glad it's not.
For the Oil Pressure Switch, I believe that's located on the Oil Separator...if so it's absolutely their fault since it was replaced about a month ago.
Thanks again.
