VW T6 California Ocean CCS Coding
ViceGripKev
Scotland
C?ID=407010
Hi,
I have eventually got round to finishing retrofitting cruise control, via new stalks to my MY18/19 T6 California. Unfortunately I hit a problem when trying to do the coding, the engine module long coding helper comes up with an error "Sorry, no coding information is available for this ECU". I am assuming this is because the engine ECU has no labels?? Sorry I'm very new to VCDS.
Is there a way to enable CCS with this problem?
Sunday,20,June,2021,16:23:27:33794
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4544.4
VIN: WV2ZZZ7HZKH008778   License Plate:
Mileage: 23150km-14384mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 55 5F 61 69 0B
VIN: WV2ZZZ7HZKH008778   Mileage: 23150km-14384miles
Address 01: Engine (J623-CXEC)       Labels: None
   Part No SW: 04L 906 056 LS    HW: 04L 907 445 A
   Component: R4 2.0l BTD   H03 6911
   Revision: 23101001
   Coding: 0025401C430601080000
   Shop #: WSC 00012 790 50316
   ASAM Dataset: EV_ECM20BTD03004L906056LS 004005
   ROD: EV_ECM20BTD030_VN75.rod
   VCID: 094F98B319B10263D8D-805C
Readiness: N/A
   Part No SW: 0BT 300 012 C    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5304
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_VN75.rod
   VCID: 2F3B162BC7950C53269-807A
   Revision: 00000000    Serial number: 62138000002635
   Coding: 617E809865628486867C017DA68A219279F100
   VCID: 3FDB466B17F5FCD3B69-806A
   Serial number: 01081813471776
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FB6F507F35DBFDF-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 S    HW: 7E0 907 040 S
   Component: ClimatronicT5 H04 0613
   Revision: 00001K04
   Coding: 0004000103
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 33331A5B2BBD28B3421-8066
   Slave 1:
   Subsystem 1 - Part No SW: 7E7 907 049 C    HW: 7E7 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0013107180015044
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 213180053
   Coding: B8AC393A0B61341293284F406CEB8F54C010738960CD79603304003F0820
   Shop #: WSC 66305 512 174603
   VCID: 2C010127F603774B03B-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 070818 05  50  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU009081882211994
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU009081882213073
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180001474410098285
   Coding: A4FFFF
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261814200819
   Coding: 31810C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BFD05311215AA370D-8024
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0108180439A59C
   Coding: 00005000FE1779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635234F38CF3D9B65F-8062
   Part No SW: 7E0 959 655 K    HW: 7E0 959 655 K
   Component: VW10Airbag01S 010 0018
   Revision: --------    Serial number: 003EM001B22C
   Coding: 000000000000000000000000000000003153
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3E253B6F10FFF5DBBDF-806A
   Serial number: 3495ZRB404T56H2KIPEN
   Serial number: 3505ZRB404T56H2KF8UB
   Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
   Component: KOMBI         H02 2030
   Coding: 440F010400
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 290FF833F9716263F8D-807C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B03023BF38D70730A1-807E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042305
   VCID: 6889BD37227B9B6B273-803C
   Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
   Component: Haldex4Motion H53 7620
   Serial number: HA1-00008.06.18
   Coding: 0501
   VCID: 54F179C78E730F8B7BB-8000
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A8DC73F3CF7A97B317-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCE020001000000
   Shop #: WSC 02748 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2D377F0CD7D9FB817-806E
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0472
   Serial number: VWZAZ2U0958803
   Coding: 06570000FF00000011111101008808001F0100D60020010003
   ROD: EV_MUStd4CTSAT_VN35.rod
   VCID: 2C010127F683774B03B-8078
   Part No SW: 7E0 907 534     HW: 7E0 937 090 D
   Component: Batt.regelung H82 0762
   Coding: 530B1A73
   Shop #: WSC 00012 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000018071001A8
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 30391557DA2B13AB3F3-8064
Address 0B: Sec. Air Heating        Labels: None
   Part No: 7E0 819 006 M
   Component: J604  Standheizung  0401
   Revision: L100400A    Serial number: 00000000000000
   VCID: 313F1053DD311AA330D-5160
End----------(Elapsed Time: 02:05, VBatt start/end: 12.2V/12.1V)-----------
VWT6
Finland
C?ID=295527
Predecessor of CXEC engine was CXEB, which is associated in scans with label 04L-907-309-V2.clb
Meanwhile, for engine change byte 5 from 06 to 26. However, with factory installed towbar coding 36 is used instead.
ViceGripKev
Scotland
C?ID=407010
Sorry for delay, work got in the way. So today I've got round to trying this out.
So I changed byte 5 from 06 to 26 in the engine module 01, which it accepted and also changed byte 17 bit 7 in central electrics 09, but the CCS isn't working.
I don't have a factory towbar installed, but I did fit a westfalia towbar last year, so tried changing code 05 to 36 in the engine module 01, but still no luck with it working.
Below is the autoscan when I tried byte 5 to 26.
Wednesday,30,June,2021,15:10:13:33794
VIN: WV2ZZZ7HZKH008778   Mileage: 23220km-14428miles
   Revision: 23101001
   Coding: 0025401C432601080000
Readiness: N/A
   Revision: 00H11V01
   Coding: 01
   Revision: 00001K04
   Coding: 0004000103
   Slave 1:
   Coding: B8AC393A0B61341293284F406CEB8F54C090738960CD79603304003F0820
   Coding: 0228DD
   Coding: 1400B1
   Coding: 0400A1
   Coding: A4FFFF
   Coding: 31810C
   Coding: 440F010400
   Coding: 4101
   Revision: B9082001
   Coding: 042305
   Coding: 0501
   Coding: 000002
   Coding: 530B1A73
End----------(Elapsed Time: 02:00, VBatt start/end: 12.6V/12.4V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Can you please got to 09 central electrics, advanced measurement values, type crui... and select all four cruise control values.
No use all the switches on the stalk to see if it responds.
ViceGripKev
Scotland
C?ID=407010
I shall go and try and report back
ViceGripKev
Scotland
C?ID=407010
Just tried and nothing on the stalks responds
Main switch. OFF
Cancel Switch. Not Oper
SET/Decelerate. Not Oper
RESET/Accelerate. Not Oper
iichel
Eindhoven, NB, NL
C?ID=284912
So then we need to go back to your retrofit.
Did you fit the correct stalks? Did you correctly fit the wiring? Do the stalks receive power?
VWT6
Finland
C?ID=295527
Central electrics coding looks right to me for cruise on stalk (byte 17, bit 7).
ViceGripKev
Scotland
C?ID=407010
Thanks, I’ll go back and start from the beginning. I started it last year, but never got round to extending the ECU cable, which I done a couple of weeks ago.
The stalk PN is 6R0 953 507 B which I bought from ebay with the wiring harness. Everything else with the stalks work, it’s just the CCS. Hopefully I’ve missed pinned a cable and it’s a easy fix.
iichel
Eindhoven, NB, NL
C?ID=284912
i'd suggest the positive wire to a fuse/+15 power source.
or is the stalk simply in the off position? (the switch on top with on/cancel/off)
ViceGripKev
Scotland
C?ID=407010
I tried the switch in various positions, but still no response. I‘ll take the trim off tonight and see what I can find.
VWT6
Finland
C?ID=295527
Are you sure this is compatible with T6? It is used on T5.1. However, T6 (04/2015...12/2019) seem to have stalk part number beginning 7E0 953 507....
ViceGripKev
Scotland
C?ID=407010
I was advised by the company selling they were compatible with the T6 and have now proved it, as I have got it working.
So after coding, it wouldn’t work, so back tracking what I had done previously, I found the inline fuse not fully seated in the holder. A quick road test and it works a treat.
Thank you all for your help :thumbs:
iichel
Eindhoven, NB, NL
C?ID=284912
great, thanks for sharing
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I missed this thread initially, so this took longer than it should have. We should have this ECM properly covered with the next update/data version.
