Unable to find a rod file
sufister
C?ID=275619
Sunday,20,June,2021,12:33:13:31334
VCDS Version: 21.3.0.0
VIN: VSSZZZ6JZCR044905   License Plate: YC12BCK
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
01-Engine -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (J623-CFHD)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 KR    HW: 03L 906 018 A
   Component: R4 2,0L EDC   H23 7936
   Revision: 43H23---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018KR 003003
   ROD: EV_ECM20TDI011_SE25.rod
   VCID: 0407FB058F6179ABE7-8050
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 130248DB837100B6C82E12E2C1D600821400
   Shop #: WSC 04941 000 00000
   VCID: 071DEC09B25752B382-8052
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.17
                    Time: 00:00:50
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x11A0
                    Hex Value: 0x139D
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Reset counter: 205
                    Mileage: 142367 km
                    Date: 2046.14.19
                    Time: 12:09:28
                    Hex Value: 0x0000
                    Hex Value: 0x0002
                    Hex Value: 0x1011
                    Hex Value: 0x259B
                    Hex Value: 0x0032
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF8
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
   Component: Climatronic   H07 0606
   Revision: S0000000
   VCID: 24479B8527A199AB87-8070
8 Faults Found:
                    Fault Status: 00101101
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:41
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:45
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 161
                    Mileage: 142161 km
                    Date: 2045.14.31
                    Time: 02:22:31
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 142161 km
                    Date: 2046.14.03
                    Time: 23:19:30
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2046.14.10
                    Time: 22:29:19
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2046.14.10
                    Time: 22:38:21
                    Reset counter: 205
                    Mileage: 142295 km
                    Date: 2046.14.17
                    Time: 16:52:23
                    Reset counter: 205
                    Mileage: 142367 km
                    Date: 2046.14.19
                    Time: 12:09:29
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0251
   Revision: BF046001    Serial number: 0434 225112057
   Coding: 34882BE888F32500923800006E0B0CC80080400F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45812601CCDB80A3B0-8010
   Subsystem 1 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3110
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3110
   Subsystem 7 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3110
03428 - Activation of Left Adaptive Light
                    Fault Status: 00101011
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:31
03429 - Activation of Right Adaptive Light
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:31
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.25
                    Time: 03:44:01
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.25
                    Time: 03:46:26
00538 - Reference Voltage
                    Fault Frequency: 13
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:32
00967 - Left Turn Signals
                    Fault Status: 00101010
                    Reset counter: 201
                    Mileage: 142169 km
                    Date: 2046.14.11
                    Time: 16:47:11
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10AirbagA07 H09 0020
   Revision: --------    Serial number: 003GZ000LW1M
   Coding: 003037
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4C971325E7B171EB6F-8018
   Serial number: 3495RRB405T0LCOSBPA/
   Serial number: 3505RRB40650LCOSKPGO
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 142295 km
                    Date: 2110.14.17
                    Time: 14:17:44
12670208 - Databus
                    Reset counter: 205
                    Mileage: 142367 km
                    Date: 2110.14.19
                    Time: 12:09:27
12674816 - Databus
                    Reset counter: 205
                    Mileage: 142367 km
                    Date: 2110.14.19
                    Time: 12:09:28
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 6J0 920 903 C    HW: 6J0 920 903 C
   Component: KOMBI         H02 0504
   Coding: 410A00
   ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04113
   ROD: N/A
   VCID: 2A5B75BD4D854FDBBD-807E
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0251
   Revision: BF046001
   Coding: 022300
   VCID: 70EFA7D5A3D9750B33-8024
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2046.14.10
                    Time: 22:29:16
                    Fault Frequency: 13
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:32
                    Reset counter: 205
                    Fault Frequency: 12
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.20
                    Time: 01:12:32
                    Reset counter: 205
                    Mileage: 142367 km
                    Date: 2046.14.19
                    Time: 12:09:29
   Component: IMMO          H02 0504
   VCID: 6ADBB5BD8D058FDB7D-803E
   Part No SW: 6J0 035 342 E    HW: 6J0 035 342 E
   Revision: A1001003    Serial number: 7660472475
   Coding: 020000
   VCID: 2643818D519D6BBB99-8072
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 06402
   VCID: 2F6D64A9EA672AF36A-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Coding: 0000002
   Shop #: WSC 77005 000 00000
   VCID: 316962D1A8533C037C-8064
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2L1953688
   Coding: 0003040002
   VCID: 2A5B75BD45854FDBBD-807E
00856 - Radio Antenna
                    Fault Status: 00111011
                    Reset counter: 201
                    Mileage: 142161 km
                    Date: 2043.14.25
                    Time: 03:30:24
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660633386
   Coding: 0200000001010110
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 356156C1943B102320-8060
13635840 - Supply voltage
          U1011 00 [000] - Voltage too Low
          U1400 00 [000] - -
End-------------------------(Elapsed Time: 04:03)--------------------------
_Val
Latvia
C?ID=356659
Instrument cluster?
There is some gibberish in ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04113
Could be related.
  • Agree
Could be related.
Not just "could be". Is.
