Bentley fault codes
drswami
C?ID=411991
Trying to pinpoint the cause of various DTC's any suggestions welcome . I suppose sensors showing intermittent need replacing . ABS fault remains despite new sensor and manual wire trace
Saturday,19,June,2021,17:44:07:09935
Dealer/Shop Name: Marshal Rothman
VIN: SCBLF34F15CH10239   License Plate:
Chassis Type: 4F (3Z - Bentley Arnage (2007 > 2010))
Scan: 01 02 03 15 19 47 56 65 77
   Part No: PB1 061 06P U
   Component: ME711 BL S/WCAT G   06AA
   Revision: 00000000    Serial number: VWZ1Z0D2652930
   Shop #: WSC 00017 000 98304
   VCID: 6597B59D2973AAD31C5-5184
15 Faults Found:
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0544 - 001 - Circuit Malfunction - Intermittent
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - MIL ON
005206 - Exhaust Gas Temp Regulation for Bank 1
               P1456 - 002 - Limit Reached - Intermittent
001840 - Gear Ratio Monitoring
               P0730 - 008 - Incorrect Gear Ratio - Intermittent
000804 - Knock Regulation
               P0324 - 001 - Malfunction - Intermittent
000338 - Oxygen (Lambda) Sensor B2 S1
               P0152 - 001 - Signal too High - Intermittent
               P0300 - 008 -  - Intermittent - MIL ON
000769 - Cylinder 1
               P0301 - 008 - Misfire Detected - Intermittent - MIL ON
000775 - Cylinder 7
               P0307 - 008 - Misfire Detected - Intermittent - MIL ON
000774 - Cylinder 6
               P0306 - 008 - Misfire Detected - Intermittent - MIL ON
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - Intermittent - MIL ON
000776 - Cylinder 8
               P0308 - 008 - Misfire Detected - Intermittent - MIL ON
000771 - Cylinder 3
               P0303 - 008 - Misfire Detected - Intermittent
000770 - Cylinder 2
               P0302 - 008 - Misfire Detected - Intermittent
End-----(Elapsed Time: 02:18, VBatt start/end: 9.6V/8.7V. VIgn 0.0V)-------
drswami
C?ID=411991
Battery is in need of replacing . Was the autoscan I sent not complete?
drswami
C?ID=411991
I am a competent mechanic , have a factory shop manual and the car has no mods or after market parts. I assume I have one sensor sending bad info to the ECU which is causing the other fault codes .
I am thinking the EGT sensor for bank 1 is the likely culprit. The intermittent cooling fault for cylinder 1 is somewhat confusing as I dont believe each cylinder has a separate cooling system . The code could refer to bank one which could explain the EGT fault . I just dont know where that sensor would be and the engine temp reading is normal. The engine runs fine , this is to get it smogged .Understand this is an old Cadillac designed pushrod motor which Bentley added twin intercooled tubos and Bosch fuel injection to . Plus my model was not yet fully integrated into the AUDI diagnostic system not to mention the limited manual that the factory provides .
PS.the car has two batteries and that should not cause these faults
Mari
C?ID=150535
Autoscan is not complete, shows only 01 - Engine
drswami
C?ID=411991
The scan I sent had all that the system could access , as I mentioned this model is not fully integrated and this system is not designed to handle my year model
Westbury, UK
Did you have the ignition on when you did the scan? - sometimes Vign reports 0V (as your scan does) even when the ignition is on - which it should always be when doing an Auto-Scan.
drswami
C?ID=411991
I had the ignition on of course . VGN does not speak the same language as some of my controllers.
drswami
C?ID=411991
Threads have been merged.
Then surely you have a battery charger. ;)
Is there some reason you are obsessed with the battery .. that is not the problem . it will be fixed in due course
Westbury, UK
When the battery voltage is as low as shown in your scan many of the controllers cannot operate correctly and show spurious faults - this has been seen many times on here.
So when we see battery voltage much lower than 12V the first suggestion is always to sort the battery voltage out, clear the fault codes (to get rid of the spurious ones) and post a new Auto-Scan with a 'proper' battery voltage.
BTW what type of VCDS cable are you using - HEX-what?
  • Agree
drswami
C?ID=411991
Hex-V2 As I mentioned the car has two batteries , the one showing low voltage was drained down in the shop doing tests. The faults showed up prior and I cleared them and they retuned all while the batteries were fully charged . That said it is easy enough to change the battery . I will also pull the EGT sensor and have a look , may be simply coked up .
I'm not with the battery itself; only its state-of-charge.
Pro-tip: Use a battery charger to prevent that while "doing tests".
