TV-Tuner 4F0919129G
Vik-Werks
Washington, USA
C?ID=335812
Hello:
I wish to ask for some input/assistance in coding this TV Tuner in my SQ5. I checked the box for module 57-TV tuner - however, there is no visual information to aid in coding as it says to send a scan and controller channel maps. I'm unfamiliar in regards to what exactly is being requested, even after looking at your how to for this for channel maps. What else could be the issue? I suspect this may unit may be specific to EU (not NAR) but I want to be certain it is not a coding issue as I would like to have it coded to NAR. The current coding for the tv tuner is "03020100." No faults on VCDS regarding this. In regards to the two fault codes showing in the scan:
16-Steering wheel -- due to the upgrade of the stalk for lane assist and acc pending retrofit
5F-Information electronic -- due to aftermarket android module to have it do mirror-link requesting a simple green screen coding for it to function correctly.
Much obliged on the assistance and the matter as always.
Thursday,17,June,2021,15:18:07:50312
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WA1CCAFP0GA006085   License Plate: AUDI SQ5
Mileage: 117580km-73060mi   Repair Order: EGR FIX
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 36 3C 42 44 46 47 52 53 56
          57 5F 62 69 6C 6D 72 A9
VIN: WA1CCAFP0GA006085   Mileage: 117580km-73060miles
Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 2A2A0034053600060000
   Shop #: WSC 01832 002 1048576
   ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
   ROD: EV_ECM30TFS0218R0907551G.rod
   VCID: 3C34C298B7AF2F6BDF-8068
   Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1003
   Revision: --H19---
   VCID: 7DB20F9CEC35E663A8-8028
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 309D1801
   VCID: 116A432CC8ADF2035C-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 085C6E48BBF7B3CB8B-805C
   Serial number: 3215000090651002
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01210520151992
   Coding: 6601228000
   VCID: 77BE1DB4C609CC33F2-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001080605301
   Coding: 26000091877CAFE0150048C300003D0D0F9CE708A2090221000008004000030100000034000000
   Shop #: WSC 12345 123 61029
   VCID: 78BC1E88CB17C34BFB-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150518  H12 0050
   Serial number: 90243014150511052032
   Coding: 01DD13
   Serial number: 20311398
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000805151307
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01F14C7F
   Serial number: A80889A7000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED13SKZB
   Coding: 303635313832383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CD49258E70F9FEB6F-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R150000LRQ2
   Serial number: 6334MSME51687965K
   Serial number: 6344MSME51684228A
   Serial number: 6352QSME7156446CM
   Serial number: 6362QSME0C572150A
   Serial number: 63732SME7353537C1
   Serial number: 63832SME73535742-
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PCC000F3
   Coding: 0000F7
   VCID: 44C4BA78C75F57ABA7-8010
                    Reset counter: 159
                    Mileage: 113910 km
                    Date: 2021.05.05
                    Time: 17:59:08
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 C    HW: 8R0 920 982 C
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03T283K5G
   Coding: 8BBF22000301D705020000
   Shop #: WSC 06335 123 12345
   VCID: 3B36C184BAA12853D6-806E
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z155100E80
   Coding: 80C103FF00
   VCID: 7EB00890E933FD7BB1-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 0252556703
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02018E646E6E645A5A253D3E00
   Shop #: WSC 02391 785 00200
   VCID: 7CB40298FF2FEF6B9F-8028
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000149976267
   Coding: 00581B00000000000000
   VCID: 42C8BC60DD4B599B95-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0369618640
   Coding: 010221
   VCID: 3FCEB594A6B93473FA-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0369116461
   Coding: 010221
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000149989454
   Coding: 011D13215E00440004
   VCID: 4FEE85541E19A4F30A-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0020841143
   Coding: 100000010000
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 45C2A77CC4656EA3B0-8010
   Revision: 00002001    Serial number: 0368647548
   Coding: 0126063A20FA70958730053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000994882
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813044309806
   VCID: 2D12FFDC74D5B6E358-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000149853809
   VCID: 4ED098501913ADFB01-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000629534
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38C480BD9B115BCD-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156E%0F8268802
   Coding: 020007010000000001
   VCID: 24041AF8271F77AB87-8070
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H07 0550
   Revision: R0070000    Serial number: 76301302652801
   Coding: 03020100
   VCID: 302CE6A863E7DB0B73-8064
   Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 0937
   Revision: --------    Serial number: 523E%0FB004993
   Coding: 1A0200060205A1EF5582AF5E00000403140000000000000000
   VCID: 3C34C298BFAF2F6BDF-8068
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130E.0F3359764
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002244495
   Component: CD-Database  6208
03389 - Data Set Implausible
                    Reset counter: 80
                    Mileage: 113910 km
                    Date: 2021.05.05
                    Time: 17:59:36
                    Voltage: 12.00 V
                    Bin. Bits:      010
                    Fault Frequency: 38
                    Reset counter: 140
                    Mileage: 117583 km
                    Date: 2021.06.17
                    Time: 14:56:37
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000100
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000150914588
   Coding: 010C13204000240004
   VCID: 46C0A070F16365BBB9-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200400388
   Coding: 0200000000000000
   VCID: 3620D0B08183F53B29-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA4A8SX
   Coding: 1030010
   VCID: 3424EAB857FFE72B17-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D32CF9CA4B52663E8-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000150914587
   Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150514201399
End----------(Elapsed Time: 02:14, VBatt start/end: 14.4V/14.4V)-----------
I believe that's correct. TV tuners were never offered in NAR cars and most likely aren't compatible with US TV standards (which are different than those in Europe). Thus I really doubt that it can be made to work here (or even coded for NAR), but at the same time, I'd be thrilled if someone has a better answer.
Vik-Werks
Washington, USA
C?ID=335812
Thanks Uwe for the fast correspondence! Hence why I went with the Hybrid version in hopes of some success. Hopefully someone else has some insight. Worst case scenario is to just use it to plug in an emulation machine and call it good for the kiddo.
NEtech
Denmark
C?ID=56995
Have you tried coding for [57]: 06020100
And maybe for [16]: 0000FF
Vik-Werks
Washington, USA
C?ID=335812
NEtech much appreciated on the feedback. I did try your coding with no avail on receiving a signal for images on the screen. I presume since I live in a rural area versus the city may be culprit with regards to getting reception in order to see if the unit is functioning properly. See attached as I have no incoming signal per the information screen.
vhurtado85: Hi.
Don't get me wrong - I admire your tenacity at attempting to make the TV turner work, and I wish you well!
BUT, the likelihood of success in marrying a your country's NTSC (Never-The-Same-Colour) Standards with the rest of the world's PAL, or SECAM (or PAL/SECAM) protocols is .......at best, not good!!
Mrclopec
Nipomo, CA
C?ID=149231
NTSC (analog) has been largely discontinued for OTA broadcasting. DTV transmissions are now ATSC and audi does not offer a hybrid DVB-T/ATSC tuner... Your only benefit to this retrofit is the set of analog inputs you will gain from the device...
Good point. Don's map is quite outdated. This one should be more-or-less current:
But in the end, the issue is pretty much the same..
Vik-Werks
Washington, USA
C?ID=335812
Much appreciated. Thanks for the feedback to all. Looks like it will just be used for external input for Rear Seat Entertainment and or emulation for the kiddo.
