Reset transmission adaptions? - 2005 Bentley Continental GT W12
lewiswbarwick
Stockport, UK
C?ID=444188
I have a 2005 Bentley Continental GT with the W12 engine.
I've just purchased the VCDS tool so that I can diagnose the car should any faults pop up.
I am wanting to reset the adaptive parameters of the automatic transmission following changing the fluid and filter.
Can anyone explain the procedure to do this in VCDS? (Autoscan below)
Many thanks,
Lewis
Wednesday,16,June,2021,20:43:45:36663
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 21.3.0.0  HEX-V2 CB: 0.4544.4
VIN: SCBCE63W65C024006   License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W65C024006   Mileage: 122760km-76279miles
Address 01: Engine        Labels: 07C-906-018-BEB1.clb
   Part No: 07C 906 018 AE
   Component: BY-6.0L-TT      G  ™6485
   Revision: 14ˇTT       Serial number:  000-00021.07.
   Coding: 0000173
   VCID: 6889B1BEBE6B283B273-513D
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 C    HW: GS1 904 1
   Component: AG6 09E 6.0L W12TT  1903
   Coding: 0000101
   Shop #: WSC 00083 000 00000
   VCID: 303919DE463BA0FB3F3-5161
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 D
   Component: ESP 5.7 4WD     H01 0021
   Coding: 0007878
   Shop #: WSC 52971 000 00000
   VCID: 36352FC6A45F8ECB65F-51F3
   Part No SW: 3D0 909 135 L    HW: 5WK 470 22
   Component: 0M Kessy            6400
   Coding: 0147693
   VCID: 2E0507A65C0FB60B2DF-5161
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   Shop #: WSC 86250 156 70962
   VCID: 47CB5202D3B507430E9-5161
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 MX
   Component:    ZAB COCKPIT      0251
   Coding: 0000000
   VCID: 0E45A726FC4F960B0DF-5161
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 B
   Component: Climatronic BY614   0030
   Coding: 0000001
            014 - Defective
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: 2F3B1AA25B05BF03269-5161
Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
   Revision: 28ˇTT       Serial number:  000-00021.07.
   Coding: 0000173
   Part No: 3D0 909 601 E
   Component: 0P Airbag 8.4E+ H10 0936
   Coding: 0012368
   VCID: 2517F88A09F9F553DC5-5161
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No: 3W0 920 840 M
   Component: KOMBIINSTRUMENT RB8 0402
   Coding: 0021400
   VCID: 3E2537E68C6F468BBDF-5161
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 00092 106 61198
   VCID: 70B9D9DE86BBE0FB7F3-5161
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3W0 907 553
   Component: LUFTFDR.-CDC- 3C1V0 7014
   Coding: 0015500
   VCID: 77ABE2C2E3D5B7C3BE9-5161
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   VCID: 3FDB4AE28B654F83B69-5161
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 B
   Component:    NAVIGATION       0168
   Coding: 0400000
   VCID: 46D55F06D4BF1E4BF5F-5161
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0703
   Coding: 0000157
   VCID: 36352FC6A45F8ECB65F-5161
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 H
   Component: 0K HSG              0200
   Coding: 0000032
   VCID: 353728CAB95985D36C5-4B01
   Subsystem 1 - Part No: 3W2 959 701
   Component: Tuersteuergeraet FS 0702
   Subsystem 2 - Part No: 3W2 959 702
   Component: Tuersteuergeraet BF 0702
   Subsystem 3 - Part No: 3W3 959 703
   Component: Tuersteuergeraet HL 0702
   Subsystem 4 - Part No: 3W3 959 704
   Component: Tuersteuergeraet HR 0702
   Subsystem 5 - Part No: 7L0 907 719
   Part No: 3W0 035 456 C
   Component: 12K-AUDIOVERST      4121
   VCID: 343115CEB2239CDB5BB-5161
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
   Component: EPB  BC6HX23    HC6 X230
   Coding: 0022413
   VCID: 353728CAB95985D36C5-5161
                    Reset counter: 103
                    Voltage: 13.56 V
                    Count: 231
01487 - System Function Test
                    Voltage: 0.72 V
                    Count: 184
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: 303919DE433BA0FB3F3-51CF
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 6597B88A497935531C5-5161
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No: 3D0 907 273 G
   Component: Reifendruckueberw.  0026
   Coding: 0210330
   VCID: 2A0D0BB660E7DA2BF17-5161
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 E
   Component: Wische&
   Shop #: WSC 00000 725 65552
   VCID: 392F24FA954161B388D-5161
00003 - Control Module
            014 - Defective
01308 - Control Module for Roof Electronics (J528)
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: 2313E69207CD0B63B21-5161
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283
   Component: 02 Einparkhilfe     0203
   VCID: 7AADFBF6D0C7AAABC17-5161
Address 77: Telephone        Labels: None
   Part No: 3W0 035 729 K
   Component: Telefon             0252
End----(Elapsed Time: 07:55, VBatt start/end: 12.0V/11.9V. VIgn 0.0V)------
DrPeter
16.4905° S, 151.7375° W
Hi there,
I have been out of the office, finishing up a whole house HVAC installation at the in-laws, sorry about the delay!
Based on the information found in the Official Factory Repair Information, when you re-fill the Automatic Transmission with the initial fill and then the final fluid level check, you are going to want to use the VCDS tool to start checking(top off) the level when the engine is running and when the transmission fluid temperature is at 35°C to 50°C.
There are no Basic Settings for these transmission that I have ever seen or found. There is an Adaptation to "Reset the Clutch Adaptation Values", use channel [01] and the [Save] a new Value of '0'.
Please see this Ross-Tech wiki page linked below for more information about the [09E] transmissions:
Hope this helps,
drpeter
