Golf 2013 1.4 Blue Motion Charge Pressure Control Actuator Mechanical Malfunction.
Mountain Mechanics
Australia
C?ID=370883
Hi all ,
I Have a golf 2013 Replace the pressure control Actuator tried carrying out basic settings but keep being told (Aborted Due to Safety reasons) Car Drives fine But engine light is on.
any help on this matter would be great.
Friday,11,June,2021,18:16:57:18295
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WVWZZZAUZDW162513   License Plate: CQH-119
Mileage: 107330km-66691mi   Repair Order: Lawson Kebabs
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDW162513   Mileage: 107330km-66691miles
Address 01: Engine (J623-CMBA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CN    HW: 04E 907 309 A
   Component: 1.4l R4 TSI   H08 6037
   Revision: WAH08---
   Coding: 01250012242415082000
   ASAM Dataset: EV_ECM14TFS01104E906016CN 002005
   ROD: EV_ECM14TFS01104E906016CN.rod
   VCID: 70ACDE2CABE4640B33-8024
16433 - Charge Pressure Control Actuator
          P334B 00 [175] - Mechanical Malfunction
                    Mileage: 107329 km
                    Date: 2021.06.11
                    Time: 14:03:17
                    Engine RPM: 729.00 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 39 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 14.324 V
                    Charge pressure actuator: specified position: 140.00 %
                    Bypass valve f high press turboch turbine inlet: actual value: 33.14 %
                    Charge pressure actuator: adaptation for lower stop: 4492.0 mV
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 55
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 19
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 7
                    Bypass valve for high press turboch turbine inlet: uncond volt: 2306.2 mV
                    Charge air pressure: actual value: 930.47 hPa
Readiness: 1110 0001
   Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5244
   Revision: 00043014    Serial number: CU501304216191
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 49DA53C8E8FE75C354-801C
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA8AA12026126E037C060101C62980510448C0608094F3002A0028C1
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DB2F718ECB61963A8-8028
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
   Component: AC Manuell    H01 0503
   Revision: 00001K06
   Coding: 00120004200100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 322814246568161B05-8066
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 084 M    HW: 5Q0 937 084 M
   Component: BCM MQBAB B   H14 0106
   Serial number: 00011311300354
   Coding: 03001842C24100530FA44000000403081000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 42C844E4D5C8A69B95-8016
   Component: WWS    130419  042 0551
   Serial number:         130423202010
   Coding: 0E4DD5
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R04RMT3
   Coding: 98CCC000000000005C00000000C800000065
   VCID: 40CC4EECDBC4B48B83-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 35767000000074393D0O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 358670000009D760DC03
   Subsystem 3 - Part No SW: -----------    HW: 480 402 404 13
   Serial number: 3516502BF0FBDE3521B.
   Subsystem 4 - Part No SW: -----------    HW: 480 402 404 13
   Serial number: 3526502B31012331333E
   Subsystem 5 - Part No SW: -----------    HW: 480 401 804 13
   Serial number: 3556502C50FEADA440E+
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 25041304401013
   Coding: 0500
   Shop #: WSC 40195 333 37120
   VCID: 79BAE308F89E254384-802C
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         236 0580
   Coding: 27A401082380000800082A00040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 6582BF786426B1A350-8030
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1109
   Revision: --------    Serial number: 0000518730
   Coding: 030100342B086400EF0000481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 332611209A721F130E-8066
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
H14 0035
   Serial number: 23130000502290030291
   Coding: 280000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 7821090403
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 23041306070098
   Coding: 003002208001040000001000
   VCID: 3D323718AC36D963E8-8068
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001297660
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 20041306070202
   Coding: 003000208001040000801000
   VCID: 3C343A1CB72CD06BDF-8068
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001230583
   Coding: 050000
   Part No SW: 5G0 035 819     HW: 5G0 035 819
   Component: MU-S--ER      039 0170
   Serial number: V1C02304131836
   Coding: 02730000FF00000011510001000900001F0100860100010001
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6680B8749920BABB59-8032
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9N2402S26
End----------(Elapsed Time: 01:03, VBatt start/end: 14.7V/13.4V)-----------
DrPeter
16.4905° S, 151.7375° W
Thank you for posting your question and including the Auto-Scan! Based on some research there appears to be two different versions of the V465-Charge Pressure Positioner and this information along with the correct "Removing and installing" procedure can be found in the Official Factory Repair Information. So be sure you have the correct parts!
Be sure to clear the fault codes before you try the and try again. Here is a Ross-Tech forum post that should help..
Let us know how this works!
drpeter
Mountain Mechanics
Australia
C?ID=370883
Hi DrPeter,
Thanks for the info i will have a look at the car again tomorrow, i will report back god or bad , I'm hoping for the good on a Friday.
Mountain Mechanics
Australia
C?ID=370883
Hi Everyone,
well i finally got to get back to the Golf ! with not much success at all.
I followed the procedure and needed to use SA no problem their at all could get the actuator to move in output tests But once out of their and went back to SA and basic settings loaded the file i was no where near the required mV required . The actuator that i removed from the car had a adjustable rod and the rod also had a ball joint on it to all it drive straight
. New unit from the dealer has a solid shaft and fixed (Welded end) Tried first adaption and it just times out. Car drive down a little on power but have EPC light on
Thank for the help in advance
