Audi A6 4G 2013Full Led Facelift headlights retrofit
Utelius
Targovisre, ROMANIA
C?ID=297267
Hello
On an Audi A6 4G 2013 I upgraded the headlights from Xenon to Full LED facelift (no matrix), no AFS
I replaced :
09. Cent. Elect. (J519)
19. CAN Gateway (J533)
55. Headlight Range (J745)
I rebuilt the wiring according to ElsaWin, I deactivated C.P. I coded after seeing here on the forum.
Everything works well, except that in the instruments it displays "main beam assist system fault" at each start, and in auto-scan errors appear in ABS (03) and CAN (19).
If anyone can help me with some advice or other coding ....
Thank you.
I will immediately post an Auto-Scan
Utelius
Targovisre, ROMANIA
C?ID=297267
Wednesday,16,June,2021,10:06:09:30753
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WAUZZZ4G7DN127942   License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 69 6C 72 85 8B 8E 8F 90
VIN: WAUZZZ4G7DN127942   Mileage: 253594km-157576miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A034012244401080000
   Shop #: WSC 41161 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
   ROD: EV_ECM20TDI01103L906018HA.rod
   VCID: F5A281D054B9972360-80A0
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G2 927 155 D    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000000690
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: AE106EBCF16FE4FBE1-80FA
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 06A187016085E180FB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: B83C48E4032B2A4BBB-80EC
0784 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [SCL_LWR_Hoehenwert_VL_Invalid]
   Part No SW: 4H0 907 064 CP    HW: 4H0 907 064 CP
   Component: BCM2 2.0      H33 0433
   Coding: 05A82F46000000000000
   Shop #: WSC 02391 785 00200
   VCID: F9BA8DE070A1F34304-80AC
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0086
   Serial number: 12031300040062
   Coding: 34010078A5
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   VCID: E288CA8CF537109B35-80B6
   Part No SW: 4H0 907 063 DK    HW: 4H0 907 063 AK
   Component: BCM1 2.0      H20 0311
   Revision: 1702007S    Serial number: 00001913450901
   Coding: 0105801441B49FE00101404780001800CF9CE7082608020100000814E101140300400019030000
   Shop #: WSC 00009 009 00009
   VCID: F4A4BCD457C38E2B57-80A0
   Component: WWS57X 130215  H36 0080
   Serial number:         130225062232
   Coding: 0045F7
   Serial number: 21068350
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 02 03 2013  00000988
   Serial number: 2D580796000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061307101726
   Coding: A9EB05
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: F1AAB5C020D1BB03BC-80A4
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: A81C98A4D38BBACB2B-80FC
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00C72N$
   Coding: 30323436313230303131554A304C34473053
   VCID: B62046DC093FDC3BA9-80E2
   Serial number: 3575HRB404T1TEI45HE%
   Serial number: 3585HRB401A50EP2IGKJ
   Serial number: 3515JRB401I50FFID9SP
   Serial number: 3525JRB400G50EGQQ1T.
   Serial number: 3554VRB404T526MKC9N7
   Serial number: 3564VRB404T526MKC18S
   Revision: --------    Serial number: 90372MC60009H
   Coding: 0000FC
   VCID: B73E4BD806352533B2-80E2
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 28 02 2013  D0171101
   Part No SW: 4G8 920 932 M    HW: 4G8 920 932 M
   Component: TDieRdwAcc    H79 0515
   Revision: 28460208    Serial number: 658090313596009
   Coding: 138709000F5100080D0000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: B93A4DE03821334344-80EC
   Part No SW: 4G5 907 468 K    HW: 4G0 907 468 AC
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000003092883
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: BD3259F02C090F6368-80E8
   Serial number: 1826120103
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 130109000000000003C6
1046 - invalid data record
          B2005 00 [009] - -
1047 - Data Set Implausible
          B2012 00 [009] - -
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0086
   Serial number: 08031300040944
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [009] - Signal Amplitude Too High
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000039464
   Coding: 01010101000000000001000203
   VCID: E484CC94E7231EABC7-80B0
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000053328210
   VCID: F7BE8BD846B5E53372-80A2
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202WDDL
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   Coding: 0010101
   VCID: B02C70C4235BF20BF3-80E4
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F08.03.1300H03000AMS16380˙
   Subsystem 4 - Serial number: S16380˙
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F17005E20628002080013
   VCID: C5C231104CD947A330-8090
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0017279503
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B2287ACCE557C01B85-80E6
   Revision: 00002001    Serial number: 0302563139
   Coding: 011A0E3800B90881832008042C030E0F0000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 3AA 962 243 C    HW: 3AA 962 243 C
   Component: GEB.F.Heckoef  H15 0721
   Serial number: 94009999
   Revision: CJ007001    Serial number: 00000000038516
   Coding: 030000
   VCID: 9D72B97084C96F6348-80C8
   Component: TSG BF        H03 0507
   Coding: 011F17005E20628002080002
   VCID: C6C0361C71DF4CBB39-8092
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000617700
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AB1667A8C27D91D3C6-80FE
   Coding: 05FA021022200200
   VCID: B4247CD41F43CE2B97-80E0
   Coding: E02000
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02000
   Part No SW: 4G0 035 061 J    HW: 4G0 035 061
   Component: Radio U DAB   H60 0123
   Revision: AB001007    Serial number: 109DY0D7627234
   Coding: 010103010000000001
   Shop #: WSC 06325 000 00000
   VCID: A4048C94A7A35EAB07-80F0
   Part No SW: 4G0 035 670 L    HW: 4G0 035 670 H
   Component: H-BNT-EU      H50 0659
   Revision: --------    Serial number: 190CX0D7532932
   Coding: 050100000003E9EF7D90EB3E00000003000001000000000000
   VCID: AC1464B4CF7396EBCF-80F8
   Subsystem 1 - Part No: 8R0 060 884 AR
   Component: ECE 2013  1505
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDCD000U16L
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MC7000NR
   Component: CD-Database  4949
   Component: TSG HL        H03 0507
   Coding: 010F15004020628002080002
   VCID: C9DA3D2060C1A3C3D4-809C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Towbar module H07 0100
   Coding: 0109080000000000
   VCID: F1AAB5C028D1BB03BC-80A4
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J32G0OG
   Coding: 1090004
   VCID: A600969C119FACBB19-80F2
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: A600969CD99FACBB19-80F2
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000121303137
   Coding: 04C0B81C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: B12A75C0E051FB03FC-80E4
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:41, VBatt start/end: 12.0V/12.0V)-----------
I'm wondering what's causing the data record / data set faults in the Gateway. Was the original Gateway swapped with a different one, or....?
Utelius
Targovisre, ROMANIA
C?ID=297267
This AUDI A6 from 2013 with xenon headlights, has been modified front, front bumper, full led headlights model 2016.
I had to change the three modules for LED headlights:
09. Cent. Elect. (J519) from 4H0 907 063 CF to 4H0 907 063 DK
19. CAN Gateway (J533) from 4G0 907 468 AC to 4G5 907 468 K
55. Headlight Range (J745) from 4H0 907 357 B to 4H4 907 357 E
It seems this belongs in Retrofits, not Car Repair Support. Moving...
nugentp
C?ID=353561
Hello
I replaced :
Thank you.
Would you be so kind to post an AUTO SCAN for that car while it had the factory bixenons fitted ?
