A4 B8 2.0T intermittent no start
alpo
Idaho, USA
C?ID=444864
2014 US model intermittently cranks but won't start when warm. Sometimes opening the throttle will help it start. Used to be once a month or so but now it is several times/week. Searched forum and others and the problem shows up in earlier models as a crank position sensor but have not seen a confirmed repair on the B8. Any ideas or help in troubleshooting? Daughter's car bought about a year ago, used 1-owner from original selling dealer (also serviced there); no mods. Thanks for any help. Here is a full VCDS Auto-Scan I pulled last night:
Monday,14,June,2021,17:31:23:00732
VIN: WAUKFAFLXEN011xxx   License Plate:
Mileage: 181070km-112511mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72
VIN: WAUKFAFLXEN011xxx   Mileage: 181070km-112511miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 27848 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D2730CECDF18323A45-8068
4106 - Bank 1; System too Rich at Idle
          P2188 00 [096] - -
                    Mileage: 180952 km
                    Date: 2021.06.13
                    Time: 15:47:04
                    Engine RPM: 819.00 /min
                    Normed load value: 29.0 %
                    Coolant temperature: 98 °C
                    Intake air temperature: 57 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 13.970 V
                    Engine status: COENG_RUNNING
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 47CB52269F2DD9F30E9-8012
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CF    HW: 8K0 907 379 CF
   Component: ESP8 quattro  H09 0050
   Coding: 2D1D1801
   Shop #: WSC 02391 785 00200
   VCID: 7F5B0AC687FD5133F69-802A
   Part No SW: 8K0 907 064 HP    HW: 8K0 907 064 GP
   Component: BCM2 2.0      H13 0641
   Coding: 0D814040000000000000
   VCID: 0557982EE5210BE3BC5-8050
   Serial number: 0213000286919001
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01270720130522
   Coding: 6480208000
   VCID: 392F24DED959BF0388D-806C
                    Fault Status: 00101101
                    Reset counter: 12
                    Mileage: 179808 km
                    Date: 2021.06.01
                    Time: 18:03:35
                    Temperature: 60.0°C
                    RPM: 760 /min
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000654982902
   Coding: 26000091863CAFE00100488300003D0D0F9CD308A2090221000008004000010200040030000000
   VCID: 7AADFBD29CDF741BC17-802E
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA030713  H18 0461
   Serial number: 13062607021340
   Coding: 004577
   Serial number: 21615734
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001707130166
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R74RL03
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: F3D8CDB6000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB09EEH
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 47993 001 1048576
   VCID: 4ACD6B128C3F249B117-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R130000E84G
   Serial number: 6334MSME793344115
   Serial number: 6344MSME7C0552229
   Serial number: 6352QSME074D0574H
   Serial number: 6362QSME54331A66G
   Serial number: 63732SME18423558Z
   Serial number: 63832SME54363B46%
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MGP001P3
   Coding: 000036
   VCID: 48C9511A92B3D68B073-801C
00886 - Turn Signal Switch (E2)
                    Reset counter: 28
                    Mileage: 180632 km
                    Date: 2021.06.10
                    Time: 11:20:34
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWC71WU7E
   Coding: 8BB609000B01D705020000
   VCID: 382921DAE253A60B773-806C
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z13712801F
   Coding: 80C303FF00
   VCID: 4CC16D0A86CB3AAB23B-8018
   Serial number: 3847051003
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000068000354
   Coding: 00581B00000000000000
   VCID: 3B233ED6D3658D139A1-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0311483909
   Coding: 010211
   VCID: 3FDB4AC6C7FD9133B69-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0311409987
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56F58F624807707B85F-8002
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0024705773
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343115EAFEBB426B5BB-8060
   Revision: 00002001    Serial number: 0312160377
   Coding: 0106023A00FA410580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000709350
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813018061403
   VCID: 2D07008E1D1113A3145-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55F7886E55017B638C5-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 30000000083573
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F24DED9D9BF0388D-806C
   Revision: AB001007    Serial number: 156G-0D7830190
   Coding: 020007010000000001
   VCID: 2411E5AA4EDBD2EBCBB-8070
   Part No SW: 8R1 035 746 D    HW: 8R1 035 746 D
   Component: H-BNT-NA      H40 0738
   Revision: --------    Serial number: 204GZ0D7593207
   Coding: 0F0200000006A1EF55028B4E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130G-0D2789406
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001580690
   Component: CD-Database  5298
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59EF845E39195F03A8D-800C
   Revision: --H08---    Serial number: 525PA8-J36915E
   Coding: 1000006
   VCID: 382921DAEE53A60B773-806C
   Component: TSG HR        H07 0305
End----------(Elapsed Time: 01:55, VBatt start/end: 13.5V/13.9V)-----------
Readiness Status: 0000 0000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
                Address 01: Engine
Control Module Part Number: 8K5 907 115 N
  Component and/or Version: 2.0l R4/4V TF H09 0005
           Software Coding: 4A2A0013242600062000
            Work Shop Code: WSC 27848
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: ECH09---
     Date: 24.07.13
     Manufacturer number: 1618
     Test stand number: 0568
Flash Status
     Programming Attempts(application): 1/1/1/1/2
     Successful Attempts(application): 1/1/1/1/2
     Flash Date: 17.06.02
Misc.
     Hardware number: 8K2 907 115 L
     Workshop System Name: DET
     ASAM Dataset Revision: 001006
Car Info
     Chassis Number: WAUKFAFLXEN011643
     Engine code: CPMB
VCDS Info:
       Labels: 06H-907-115-CDN.clb
       Readiness: No script available
Jef
HQ
Is there a gasoline odor in the engine oil? Doing a fuel rail pressure test, do you get good results?
DrPeter
16.4905° S, 151.7375° W
Thanks for posting your question and including the full vehicle Auto-Scan!
The fault code in the [01-Engine], P2188- Bank 1; System too Rich at Idle, could be an indication there is an external source of fuel entering into the combustion chamber. This is typically happening when one (or both) of the following is happening:
1) N80-EVAP Canister Purge Regulator Valve is leaking small amounts of fuel vapor into the intake.
(Sometime the EVAP, small leak code sets when this happens)
2) Fuel has contaminated the oil and the breather system is 'feeding' the engine the extra fuel/crankcase gases
(HPFP- High Pressure Fuel Pumps can weep fuel in to the engine crankcase, check the oil for fuel smell/overfull!)
3) Leaking Injector, check fuel rail pressures when hot after the key is on, engine is off, pressures should rise.
I would also not rule out any of the possible causes found here, on this Ross-Tech wiki page too...
http://wiki.ross-tech.com/wiki/index.php/16556/P0172/000370
You can use VCDS to view the Advanced Measuring Values and compare them to this 'Non-Broken Car'
https://forums.ross-tech.com/index.php?threads/21275/
Look for: "Long term adaptation of mixture formation bank 1" - should be under (+/-) 10% when above 80°C
Hope this helps,
drpeter
alpo
Idaho, USA
C?ID=444864
Thanks, Jef and Dr. Peter! I will run the fuel smell and pressure tests when I can get my hands on the car again, probably tomorrow night. This diagnosis may drag out a bit because I will be away from the car Thurs - Sat. I appreciate the response.
alpo
Idaho, USA
C?ID=444864
Ok, I have the car for a bit. No fuel smell in oil. Fuel rail pressure test appears to be ok. With UDS protocol the pressures were in mpa, not bar. Hot running pressure was very close to 4 MPa which was also the specified value; 2 min after shutdown it had risen to nearly 5 MPa and was still climbing.
Jef
HQ
Your results of the fuel rail pressure test implies leaking injectors. Generally speaking, one should expect a 20 bar increase in 2 minutes with a hot engine where as you state you didn't even make it +10 bar in 2 minutes.
Now having said that, IMHO injectors leaking at that rate wouldn't cause an extended cranking.... I've seen worse test results and engines still fire right up.
Double check your testing. I would use IDE00589-ENG167462 Fuel pressure (search for 00589), it will be a kPa value, something like 3500 to 4000 kpa would be my guess at idle (35 to 40 bar).
If you kind of end up with the same results, hot engine off, round about 5000 kPa after 2 minutes, again, not looking good for the injectors but I don't see that flooding the engine out.
Maybe a cam position sensor issues.... but no codes so not too likely.
alpo
Idaho, USA
C?ID=444864
Thanks, Jef. I'll repeat the test on Sunday. If still a bit low, would running injector cleaner in the fuel help out?
alpo
Idaho, USA
C?ID=444864
Jef and DrPeter, I repeated the test today with worse results. Here is the hot running idle snapshot:
Address 01: Engine (8K5 907 115 N)
13:58:09
IDE00021 Engine RPM 799 /min
IDE00025 Coolant temperature 99 °C
IDE00188 Fuel high-pressure: actual value 3.9940 MPa
IDE00201 High fuel pressure: specified value 4.0000 MPa
IDE00407-ENG57549 Rail pressure regulation: status-Bits 0-7 1
IDE00589 Fuel pressure 3950 kPa rel
Engine off, 2.5 min after shutdown:
14:00:40
IDE00021 Engine RPM 0 /min
IDE00025 Coolant temperature 102 °C
IDE00188 Fuel high-pressure: actual value 3.9690 MPa
IDE00201 High fuel pressure: specified value 3.9680 MPa
IDE00407-ENG57549 Rail pressure regulation: status-Bits 0-7 0
IDE00589 Fuel pressure 3870 kPa rel
5.5 min:
14:03:41
IDE00025 Coolant temperature 100 °C
IDE00188 Fuel high-pressure: actual value 4.2095 MPa
IDE00589 Fuel pressure 4110 kPa rel
So, looks like injectors are leaking down, correct? Any other possibilities?
Thanks.
Jef
HQ
It does appear the injectors are leaking.... 3.9940 MPA (40 BAR) at idle, then +2 minutes after shutting the engine off... still right at 40BAR. Fuel rail pressure should of been hitting around 6.000MPa (60 BAR) at the 2 minute mark.
Now I've consulted with a lot of people dealing with leaking injectors, many with worse numbers than what you are posting, and the cars still start up fine. We are kind of of in a grey area in that, IMHO you most likely need all new injectors (purchased from the dealer), but I can't be sure that will resolve the extending cranking.
alpo
Idaho, USA
C?ID=444864
Thanks, Jef. Interesting that injectors would have to be replaced. Does injector cleaner not work for this situation? Pretty sad when injectors only last 100k miles.
WtA3WtQ5
C?ID=139976
A heavy dose of injector cleaner (Techron) won't hurt anything and may just help. Worth a try for how easy and cheap to do.
It may postpone changing out injectors so you can do it on your schedule.
alpo
Idaho, USA
C?ID=444864
That's what I was thinking; thanks. It's already in the tank!
BB tt
TX, USA
C?ID=281085
so interesting i have been having similar issue only after short trips though 5-10 minutes run in to store come back out then wont start. It never happens after long drives only on short trips and is really intermittent. Fuel rail pressure steadily rises to ~160bar after sitting a few minutes so i was thinking something like vapor lock or or issue with fuel rail pressure being to high for starting. it will usually start after about 15 minutes and multiple attempts Anyway happened other day And I had computer so was able to gather some data first 4 tries wouldn't start on the 5th try it started but noticed oil temp was registering 170 f on all 5 attempts but on the 5th attempt oil dropped to 14f right before it started stayed there for a few seconds then returned to 170 something. Would a bad oil level/thermal sensor cause warm start issues? I hate to just throw parts at it. Will grab an autoscan 2moro. car is a4 b8 with caeb engine med17.
alpo
Idaho, USA
C?ID=444864
I don't know that I can help you but I do owe the forum an update on my daughter's car. We ran 3 tanks of fuel with injector cleaner, to no avail. Replaced the injectors and all seemed well at first, with shut-down fuel pressure rising as it should. It has done the no-start when hot 1 time since then; confounded now. Maybe the experts can chime in with their opinion. Thanks
alpo
Idaho, USA
C?ID=444864
Jef/Dr. Peter, any more leads? Car has hot start problem every day now after new injectors, with passing fuel pressure test.
NZDubNurd
New Zealand
C?ID=230482
This is an easy valve to check, and fails regularly - the carbon canisters also fail and fill the valve with crud. Of 4 2006 ish model VW's that have been in my drive recently there were 4 faulty ones! All leaked to varying degrees, and one was pretty much wide open and was the only one to throw a code. Mine leaked marginally, and I had an intermittant hot start issue, which hasn't happened since the valve change. If mine had extended cranking, a good stab on the throttle would result in it starting straightaway (MK5 R32 engine).
alpo
Idaho, USA
C?ID=444864
Thanks, NZDubNurd! Where is this purge valve located?
alpo
Idaho, USA
C?ID=444864
Purge valve does not leak.
alpo
Idaho, USA
C?ID=444864
I did the fuel pressure test again today, and it failed. Recent history: replaced injectors and the fuel pressure test was good afterward, climbing to 60 bar. Sent the car off with daughter and she complained a couple weeks later that the hot start problem had resurfaced. Checked purge valve and it does not leak, unless it's intermittently doing so. Performed fuel pressure test again today and could barely get from 40 bar to 45 bar at 2 minutes. No codes set. Someone please tell me if I am wrong, but is the HPFP the only other component that could leak pressure down? Or could a pressure regulator do the same? There is no smell of fuel in the oil, nor is the level rising. Thanks for any help!
Jef
HQ
Just to be clear, no start meaning cranking over but not firing? If so, does the tachometer show cranking RPM?
The fuel pressure concern, having deal with this all the time, based on your numbers, I don't see that causing a no fire issue. On the note of fuel pressure, where did those injectors come from?
