Audi Q7 2014 DPF
david_80
C?ID=438395
Hi all just curious as to what torq the copper nuts that connect cat down pipe to dpf is suppose to be on 3.0 TDI 245 hp and also the egr valve torq as well please thank yo.
DrPeter
16.4905° S, 151.7375° W
Hi there, great question... I have to answer it with another question, what is the engine code? Because it may be different for this particular engine.
Here in the states the Official Factory Repair Information says for the:
Workshop ManualAudi Q7 2007 ➤
6-cylinder TDI engine (3.0 ltr. 4-valve common rail -generation II)
- (inc. Eng. Codes: CJGA, CJGC, CJMA, CRCA, CLZB, CNRB)
Step 1 - Bolts 1 through 8 in sequence = [Hand tight]
Step 2 - Bolts 1 through 8 in sequence = [15nm]
Step 3 - Bolts 1 through 8 in sequence = [25nm]
- "Renew nuts"
- "Coat threads of nuts with high-temperature paste"
Hope that helps,
drpeter
david_80
C?ID=438395
Interesting info but not those nuts just the 3 nuts that connect dpf cat converter down pipe
DrPeter
Ahh.... For some reason I read manifold nuts... :p
Looks like all the Nuts & Bolts in that part of the exhaust should be tightened to 23nm, they still recommend to replace (renew) the Nuts too. You may want to double check my answer with the Official Factory Repair Information ;)
drpeter
Those are typically two "uga-duga's" or in German "gud-n-tight"
david_80
C?ID=438395
Sorry for late reply, thank you for replying with your help and advice
david_80
C?ID=438395
not sure if posting here is here, but now I have separate issue exhaust gas temperature sensor bank 1 sensor 3…..does anybody know exactly which one that is and also how to adapt exhaust pressure sensor with latest software.
DrPeter
Hi, what is that old saying?? "... if you give a man a fish he is hungry again in an hour. If you teach him to catch a fish you do him a good turn."
The answers you seek are found within the "Official Factory Repair Information" manuals.
drpeter
