How to disable DRL on Golf 7 ?
Riddick20
Italy
C?ID=245838
Hi guys,
I need to disable ONLY the DRLs of the left headlight.
do not tell me to do it from the menu because I have already activated this option, where I can choose to activate or deactivate them but I need something different.
I have to disable ONLY the left headlight.
I think there is a specific adaptation (LEUCHTE) ... can you tell me which ones are in charge of the DRLs so I can do some tests?
Thank you.
Ovidel
Vittorio Veneto, Italy
C?ID=390851
If you post an auto scan and the adaptation backup of 09 central electric ,will be easier to us helping you 😉
Riddick20
Italy
C?ID=245838
I can also do it and put it on but it is useless for what I asked for.
I don't have an error whose nature I don't know.
I did a retrofit for which the left DRLs are not connected and therefore an error appears rightly in the instrument panel and in the scan with VCDS.
I want to remove the error and to do this I have to disable the left DRL channel in the adaptations.
langers2k
C?ID=224085
So post the autoscan and adaption map from the BCM. We can then see how the car is configured and therefore which channels may need changing...
Bruce
Near Philadelphia, PA, USA
I did a retrofit ... I want to remove the error and to do this I have to disable the left DRL channel in the adaptations.
Allow me to pose a question: Do you go to the doctor and as the doctor is doing his diagnostic scan on you, do you say, "Doctor, I know about all the problems I have. Please stop doing your diagnostic?" Or do you answer the questions posed and give the doctor a point of reference?
In order for this community to help you with your desired retrofit, we need information - a point of reference. That information is contained in an autoscan and in the adaptation maps that have been requested.
Should you continue to be offended that we have asked for information by which someone here may be able to assist, expect us to ignore your posts.
Riddick20
Italy
C?ID=245838
of course I will post it to you without any problem and I am absolutely not offended.
Riddick20
Italy
C?ID=245838
Guys I found the solution, and fortunately it was what I imagined.
I still post the scan (with error of the left DRL) as promised.
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 32 42 44 47 52 55 5F A9
VIN: WVWZZZAUZEW144891   Mileage: 39460km-24519miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0009
   Revision: --H13---
   Coding: 091900122424050B2000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001013
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6BD25F9F8244AAD306-803E
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 626830000007B8
   Coding: 01FA6BA154242970037F060941C46980D62A94C0608296F700400079C009
   VCID: 071A032FBEEC6EB382-8052
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 17G 907 044 A    HW: 17G 907 044 A
   Component: AC Automat    201 R662
   Revision: 20K04000    Serial number: 00000A00530197
   Coding: 0002000420001001000400400010142A
   Shop #: WSC 34447 004 1048576
   ASAM Dataset: EV_ACTouchPrehVW37X 001005
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 28586093533241CBAB-807C
No ASAM data for: "EV_ACTouchPrehVW37X" (VW37)
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 01001928102463
   Coding: 00000A46C24122FB4BE4400000080708100A000000000000000000000000
   Shop #: WSC 00046 000 00000
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DF661C7EC303463A8-8028
   Component: WWS    130926  042 0551
   Serial number:         130927225315
   Component: RLFS  024 0042
   Serial number: Y13M09D28H19M20S59S1
   Coding: 06A8DD
8 Faults Found:
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 126
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:28
197123 - Lock Module for Central Locking; Rear Left
          B12DB 07 [008] - Mechanical Failure
                    Fault Frequency: 39
                    Reset counter: 176
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:23:44
197128 - Lock Module for Central Locking; Rear Left
          B12DB 29 [009] - Signal Implausible
                    Reset counter: 127
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 16:56:33
197379 - Lock Module for Central Locking; Rear Right
          B12DC 07 [008] - Mechanical Failure
                    Fault Frequency: 39
                    Reset counter: 176
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:23:44
197384 - Lock Module for Central Locking; Rear Right
          B12DC 29 [009] - Signal Implausible
                    Reset counter: 127
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 16:56:33
555797 - Databus
                    Reset counter: 133
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:31
1048836 - Lamp 1 for Ambient Lighting of Cup Holder
          U1172 00 [009] - No Communications
                    Reset counter: 126
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:33
1049092 - Lamp 2 for Ambient Lighting of Cup Holder
          U1174 00 [009] - No Communications
                    Reset counter: 126
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:33
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R00ZNE.
   VCID: 418EDD37D04890838C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 109 13
   Serial number: 35767000000A1A759D0/
   Subsystem 2 - Part No SW: -----------    HW: 480 001 009 13
   Serial number: 35867000000ED8409D04
   Subsystem 3 - Part No SW: -----------    HW: 480 402 709 13
   Serial number: 3516502AD1118A543091
   Subsystem 4 - Part No SW: -----------    HW: 480 402 709 13
   Serial number: 3526502AD1118A557255
   Subsystem 5 - Part No SW: -----------    HW: 480 402 509 13
   Serial number: 3556502C31142C83511-
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 24091304220220
   Coding: 0400
   VCID: 75E679E7D4006C23E0-8020
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 03AD11002B80000C040A7F000C00000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2B529F9F42C46AD346-807E
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005526889
   Coding: 030100042B085900EF00066B080F00010001000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CF06CC3F72A3D6B9F-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130002010240093502
   Coding: 2A0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 7070981403
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8038
   Serial number: HA1-00013.09.13
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001001
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 479AC32FFE6CAEB342-8012
   Serial number: 050215BB301568
   Coding: 001F0320D000040000001000
   VCID: 428CD23BD54E8B9B95-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002846731
65649 - Lamp for Ambient Illumination
          B1325 13 [009] - Open Circuit
                    Fault Frequency: 55
                    Reset counter: 136
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:28
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 0101
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 336287FF9AF432130E-8066
   Revision: 00000001    Serial number: VWZ8Z1GBA02UBX/
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001002
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 6DD65187BC50A4E318-8038
   Serial number: 29081406070299
   Coding: 001F0120DE00040000801000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002832675
   Coding: 090000
                    Fault Frequency: 55
                    Reset counter: 136
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:28
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01000B010200
   VCID: 3D76A1C7ACB0F463E8-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5NA 035 043 A    HW: 5NA 035 043
   Component: MU-H-N-EU     H41 1161
   Serial number: A599E0F7520138
   Coding: 027310010000000011110002000800001F0103B401200C01FE
   VCID: 346084E39FFA352B17-8060
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0911385
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact disc data bank:
   Component: Gracenote2  --- 1013
          B201A 00 [009] - -
                    Reset counter: 134
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:36
                    Voltage terminal 30: 12.5 V
                    Status_Software_Version_Management-module_name: BDUV624/Main
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 126
                    Mileage: 39254 km
                    Date: 2021.06.12
                    Time: 15:10:33
                    Voltage terminal 30: 12.4 V
                    BAP-BAP_Function_ID: 02
   Component: SAS-GEN 2     H06 0011
   Serial number: 130725200355
in practice I have disabled the left DLR and then now everything is ok ... no errors about it.
I found this photo which was of great help.
in my case I simply made this change:
