Hi, this is a new-to-me 2014 Audi RS5. Im just sorting out the car and have this ABS Fault, but no Dash Light. A number of other Faults, some related to brakes. Seems to me getting this ABS incorrect coding fixed may make some of the other faults disappear as well?
Auto Scan attached below:
Saturday,12,June,2021,15:40:02:35303
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WUAC6AFR2EA901236 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
56 5F 6C
VIN: WUAC6AFR2EA901236 Mileage: 76890km-47777miles
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1A25003225A6080D3000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
ROD: EV_ECM42FSI011_AU48.rod
VCID: 3FDB4052F7F52283B69-806A
U1113 00 [032] - -
Mileage: 76828 km
Date: 2021.06.10
Time: 07:48:16
Engine RPM: 0.00 /min
Coolant temperature: 34 ∞C
Intake air temperature: 35 ∞C
Voltage terminal 30: 12.133 V
Unlearning counter according OBD: 30
AFS dm: 0.0 kg/h
Mean injection time: 0.000 ms
Engine operating condition: Idle
U1113 00 [032] - -
Mileage: 76828 km
Date: 2021.06.10
Time: 07:48:16
AFS dm: 0.0 kg/h
Part No SW: 8T0 927 156 H HW: 0B5 927 156 K
Component: 0B5 42 FSINAR H02 0003
Revision: --H02---
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501021.rod
VCID: 42DD49A684074F6BD97-8016
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 2C1D1A
VCID: 45D752BA95A97853FC5-8010
Fault Frequency: 26
Reset counter: 94
Mileage: 76828 km
Date: 2021.06.10
Time: 07:48:17
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0017
Hex Value: 0x1097
Hex Value: 0x0000
Part No SW: 8K0 907 064 HM HW: 8K0 907 064 GM
Component: BCM2 2.0 H13 0641
Coding: 0D804040000000000000
VCID: 025D89A6C4078F6B997-8056
Subsystem 1 - Part No SW: 8K0 959 754 CB HW: 8K0 959 754 CB
Serial number: 0813000146632019
Serial number: 0213000349540004
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000080942761
Coding: 00037025002C00000000
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01311020130731
Coding: 4802200000
VCID: 392F2E4AE9510CB388D-806C
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000056113601
Coding: 06000091043C9FE0250048C3000039098F9CD388A2090221000008004000010200040034000000
VCID: 7AADF146ACD7C7ABC17-802E
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 251013 H15 0080
Serial number: SWF13100255767
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21905302
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000002110130024
Component: USHL4.2 H30 0030
Serial number: 0000002274555R8DE803
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: B35846D6000000000001
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJDB0R89O
Coding: 303343334830303030304A55304C38543053
VCID: 4ACD6186BC37972B117-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000G3BU
Serial number: 6334MSME7F72686E
Serial number: 6344MSME7F504B65R
Serial number: 6352QSME6439165CN
Serial number: 6362QSME3F392B7C/
Serial number: 63732SME20393F7E9
Serial number: 63832SME0C39385EB
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372MJG0011N
Coding: 000036
VCID: 44D14FBE9E93415BEBB-8010
Part No SW: 8T0 920 984 H HW: 8T0 920 984 H
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: Z9X48R4CE
Coding: 831F01008B03D604020000
Shop #: WSC 06325 123 12345
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z13A24006B
Coding: 80E3031600
VCID: 4CC1679EB6C3891B23B-8018
Serial number: 5748931603
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 002410130001811
VCID: 2F3B10122795D203269-807A
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [008] - -
[ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
Reset counter: 123
Mileage: 76828 km
Date: 2021.06.10
Time: 07:48:14
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000080952916
Coding: 001B7B25002C00000000
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0317983327
Coding: 010211
Shop #: WSC 06324 000 00000
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0317879758
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 010F13225E00120102
VCID: 56F585F6780FC3CB85F-8002
02117 - Motor for Mirror Folding
Fault Status: 01101011
Reset counter: 87
Mileage: 76835 km
Date: 2021.06.10
Time: 20:17:00
Part No SW: 8K0 909 144 Q HW: 8K0 909 144 L
Component: RCevo H54 0702
Revision: 00000001 Serial number: 0000141141
Coding: 000000000000
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
Revision: 00002001 Serial number: 0318532766
Coding: 01061E9A00FAC00580B0003200000000
Shop #: WSC 06324 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000757583
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106976000004925217
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813022019903
VCID: 2D070A1A2D19A013145-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55F782FA6509C8D38C5-8000
Reset counter: 87
Mileage: 76835 km
Date: 2021.06.10
Time: 20:17:00
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 00000001385895
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F2E4AE9D10CB388D-806C
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 123
Mileage: 76828 km
Date: 2021.06.10
Time: 07:48:14
Voltage terminal 30: 12.1 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156K40D7930376
Coding: 020007010000000001
VCID: 2411EF3E7ED3615BCBB-8070
Part No SW: 8R1 035 746 E HW: 8R1 035 746 D
Component: H-BNT-NA H41 0756
Revision: -------- Serial number: 204KQ0D7624010
Coding: 150200020306A1EF55028B5E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Component: DU7 High H42 0104
Serial number: A130JR0D2852511
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001664066
Component: CD-Database 5571
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H08--- Serial number: 525PA8-J389362
Coding: 1020008
VCID: 38292B4EDE5B15BB773-806C
End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.0V)-----------
