03:ABS, 01044 control module incorrectly coded
MLB
C?ID=348541
Hi, this is a new-to-me 2014 Audi RS5. Im just sorting out the car and have this ABS Fault, but no Dash Light. A number of other Faults, some related to brakes. Seems to me getting this ABS incorrect coding fixed may make some of the other faults disappear as well?
Auto Scan attached below:
Saturday,12,June,2021,15:40:02:35303
VIN: WUAC6AFR2EA901236   License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53
          56 5F 6C
VIN: WUAC6AFR2EA901236   Mileage: 76890km-47777miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Coding: 1A25003225A6080D3000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
   ROD: EV_ECM42FSI011_AU48.rod
   VCID: 3FDB4052F7F52283B69-806A
          U1113 00 [032] - -
                    Mileage: 76828 km
                    Date: 2021.06.10
                    Time: 07:48:16
                    Engine RPM: 0.00 /min
                    Coolant temperature: 34 ∞C
                    Intake air temperature: 35 ∞C
                    Voltage terminal 30: 12.133 V
                    Unlearning counter according OBD: 30
                    AFS dm: 0.0 kg/h
                    Mean injection time: 0.000 ms
                    Engine operating condition: Idle
          U1113 00 [032] - -
                    Mileage: 76828 km
                    Date: 2021.06.10
                    Time: 07:48:16
                    AFS dm: 0.0 kg/h
   Part No SW: 8T0 927 156 H    HW: 0B5 927 156 K
   Component: 0B5 42 FSINAR H02 0003
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 42DD49A684074F6BD97-8016
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 2C1D1A
   VCID: 45D752BA95A97853FC5-8010
                    Fault Frequency: 26
                    Reset counter: 94
                    Mileage: 76828 km
                    Date: 2021.06.10
                    Time: 07:48:17
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0017
                    Hex Value: 0x1097
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 HM    HW: 8K0 907 064 GM
   Component: BCM2 2.0      H13 0641
   Coding: 0D804040000000000000
   VCID: 025D89A6C4078F6B997-8056
   Subsystem 1 - Part No SW: 8K0 959 754 CB    HW: 8K0 959 754 CB
   Serial number: 0813000146632019
   Serial number: 0213000349540004
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000080942761
   Coding: 00037025002C00000000
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01311020130731
   Coding: 4802200000
   VCID: 392F2E4AE9510CB388D-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000056113601
   Coding: 06000091043C9FE0250048C3000039098F9CD388A2090221000008004000010200040034000000
   VCID: 7AADF146ACD7C7ABC17-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 251013  H15 0080
   Serial number: SWF13100255767
   Coding: 00FD11
   Serial number: 21905302
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002110130024
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R8DE803
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: B35846D6000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB0R89O
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD6186BC37972B117-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000G3BU
   Serial number: 6334MSME7F72686E
   Serial number: 6344MSME7F504B65R
   Serial number: 6352QSME6439165CN
   Serial number: 6362QSME3F392B7C/
   Serial number: 63732SME20393F7E9
   Serial number: 63832SME0C39385EB
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MJG0011N
   Coding: 000036
   VCID: 44D14FBE9E93415BEBB-8010
   Part No SW: 8T0 920 984 H    HW: 8T0 920 984 H
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9X48R4CE
   Coding: 831F01008B03D604020000
   Shop #: WSC 06325 123 12345
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z13A24006B
   Coding: 80E3031600
   VCID: 4CC1679EB6C3891B23B-8018
   Serial number: 5748931603
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 002410130001811
   VCID: 2F3B10122795D203269-807A
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [008] - -
          [ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
                    Reset counter: 123
                    Mileage: 76828 km
                    Date: 2021.06.10
                    Time: 07:48:14
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000080952916
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0317983327
   Coding: 010211
   Shop #: WSC 06324 000 00000
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0317879758
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 010F13225E00120102
   VCID: 56F585F6780FC3CB85F-8002
02117 - Motor for Mirror Folding
                    Reset counter: 87
                    Mileage: 76835 km
                    Date: 2021.06.10
                    Time: 20:17:00
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000001    Serial number: 0000141141
   Coding: 000000000000
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   Revision: 00002001    Serial number: 0318532766
   Coding: 01061E9A00FAC00580B0003200000000
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000757583
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA106976000004925217
   Revision: 00005001    Serial number: 94813022019903
   VCID: 2D070A1A2D19A013145-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55F782FA6509C8D38C5-8000
                    Reset counter: 87
                    Mileage: 76835 km
                    Date: 2021.06.10
                    Time: 20:17:00
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001385895
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F2E4AE9D10CB388D-806C
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 123
                    Mileage: 76828 km
                    Date: 2021.06.10
                    Time: 07:48:14
                    Voltage terminal 30: 12.1 V
                    Internal Fault ID: 188
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Revision: AB001007    Serial number: 156K40D7930376
   Coding: 020007010000000001
   VCID: 2411EF3E7ED3615BCBB-8070
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204KQ0D7624010
   Coding: 150200020306A1EF55028B5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130JR0D2852511
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001664066
   Component: CD-Database  5571
   Revision: --H08---    Serial number: 525PA8-J389362
   Coding: 1020008
   VCID: 38292B4EDE5B15BB773-806C
End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.0V)-----------
Hmm.. 2C1D1A does not strike me as entirely implausible for this car. For example, here is a very similar car with exactly the same ABS module, coded just like yours.
Hopefully someone else will have some idea(s) as to what's going on here.
Hi, its a bit of a long shot but it was common for the RS5 owners to retrofit carbon ceramic front brakes (rotors and calipers) or remove them , if originally present, and place iron rotors and matching calipers. I would check the PR codes to verify which brake package came with the car originally. The carbon brakes have a feature where the caliper pistons "pulsate" to keep some heat in the rotors for efficient / responsive pedal response ; perhaps something going on there as well if the system was converted (or removed). Just something that came to my mind when I read Uwe's reply.
MLB
C?ID=348541
Thanks very much. Just gotta say again how great it is to get this support and feedback!
I think I have everything from ErWin for the RS5, (stunned how inexpensive a 1 or 3 day subscription is, compared to the $80-ish I paid for a Bentley CD years ago for my 2002 S8) and that included a nifty document that lists VIN-specific vehicle info including the PR codes. According to the VIN-based report:
"Disk brakes in front; Con.No. 22, No. 1LM, Family BAV.
(I dont see a reference to ceramic brakes, or even rear brakes)
MLB
C?ID=348541
Oh! and BTW, the previous owner tells me the engine has been replaced in this car. I will never know what really happened, but I considered that unrelated to the brake Fault so I didnt think to mention it before.
Still...
Maybe mistakes were made when 'coding' the replacement engine? Is that a thing?
When an engine is replaced, it's normally done with a like engine and there are no changes to the ECU.
MLB
C?ID=348541
A follow up on this: I took a look at the 03-ABS Brakes module > Coding > Long Coding Helper and the Drive Select feature was not turned on.
(That option line was not checked)
This car has the Drive Select feature in the MMI (Comfort/Auto/Dynamic/Individual), so shouldn't that box be checked? (Bit 5 Audi Drive Select (ADS) installed [PR-1N7] ) This would change the coding from 2C1D1A to 2C3D1A. Can I try this coding without risk of "trouble" ?
AutoScan, ignition ON engine OFF, after clearing codes and then going for a short drive:
Saturday,26,June,2021,18:07:18:35303
          56 5F 6C
VIN: WUAC6AFR2EA901236   Mileage: 77230km-47988miles
47-Sound System -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
   Revision: NAH04---
Readiness: 0000 0001
   Revision: --H02---
   Coding: 2C1D1A
                    Reset counter: 111
                    Mileage: 77207 km
                    Date: 2021.06.26
                    Time: 07:35:02
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x0017
                    Hex Value: 0x108F
                    Hex Value: 0x0000
   Coding: 4802200000
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 000036
   Coding: 80E3031600
00384 - Optical Databus
                    Reset counter: 111
                    Mileage: 77234 km
                    Date: 2021.06.26
                    Time: 13:54:27
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 9
                    Bin. Bits:    00000
   Coding: 010211
   Coding: 010211
   Coding: 010F13220E00120102
   Coding: 01061E9A00FEC00580B0003200000000
Address 56: Radio
   Coding: 1020008
End----------(Elapsed Time: 01:33, VBatt start/end: 12.0V/12.0V)-----------
MLB
C?ID=348541
Hmm, I don't understand it but now I have fault-free AutoScans, so happy day!
I tried to make the ABS coding change to 2C3D1A and got a dialog box message: Coding rejected Error 33: Security access required
So I backed out of that, coding remained 2C1D1A.
(I'm now reading on the RossTech website about how Security Access works)
Also turned on and operated the radio in the hope that it would somehow 'fix' the radio fault code...?
Then I manually selected 'Clear codes'
Went for a short drive, ABS light was on for less than a minute then went out, so no dash lights.
Ran the following AutoScan in the driveway with engine running. No Fault Codes.
Now I wonder if I should try to 'turn on' the Drive Select feature under 03-ABS brakes, or leave well enough alone? The Drive Select functions all work correctly when Im driving the car.
--Michael
Saturday,26,June,2021,20:48:46:35303
          56 5F 6C
VIN: WUAC6AFR2EA901236   Mileage: 77250km-48000miles
   Revision: NAH04---
Readiness: 0100 1101
   Revision: --H02---
   Coding: 2C1D1A
   Coding: 4802200000
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 000036
   Coding: 80E3031600
   Coding: 010211
   Coding: 010211
   Coding: 1020008
End----------(Elapsed Time: 01:46, VBatt start/end: 14.2V/14.0V)-----------
If everything works as expected and you're free of faults, I would leave it alone.
MLB
C?ID=348541
Thanks Uwe, will do. But just out of curiosity,In this situation what difference is made if I changed the coding or not?
