ABS control module coding lost as Instrument cluster replaced
ilyas
India
C?ID=303580
Greetings of the Day,
Skoda Yeti (Model year 2010) lost ABS coding due to Instrument cluster changed (swapped) and make maters worst immobilizer is disabled by locksmith.
Engine is starting normally, but the problem is ABS light flashing.
Requesting your help for coding ABS module.
Auto scanning report.
Friday,11,June,2021,14:41:40:26154
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: TMBMDL5L7AA700443   License Plate: MH04EX3357
Mileage: 47350km-29421mi   Repair Order: 0123456
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 08 09 10 16 17 19 22 25 42 44 46 52 56 62 72
VIN: TMBMDL5L7AA700443   Mileage: 47350km-29421miles
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 EK    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H22 6821
   Revision: 42H22---    Serial number: 00000000000000
   Coding: 00190012040700080000
   Shop #: WSC 10002 663 98319
   ASAM Dataset: EV_ECM20TDI01103L906018EK 003005
   ROD: EV_ECM20TDI01103L906018EK.rod
   VCID: 77BE0D1FCEAB6E33F2-8022
4710 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Mileage: 47358 km
                    Date: 2021.06.10
                    Time: 04:07:19
                    Engine RPM: 819.50 /min
                    Normed load value: 25.5 %
                    Coolant temperature: 42 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 14.160 V
                    selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [167] - -
                    Mileage: 47358 km
                    Date: 2021.06.10
                    Time: 04:07:19
                    Engine RPM: 822.50 /min
                    Normed load value: 25.1 %
                    Voltage terminal 30: 14.100 V
                    Immobilizer snapshot A-Sia Error Snap A: 14 80 0A
                    Immobilizer snapshot B-Sia Error Snap B: 02 00 00
8169 - Terminal 30
          U140A 00 [175] - Open Circuit
          [Terminal 30Open circuit]
                    Mileage: 47358 km
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 13.000 V
                    Limitation: torque: 0.0 Nm
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.00 %
Readiness: 1 1 0 0 1
   Revision: 00H31001
   Shop #: WSC 33361 790 00999
   VCID: 76A0001BC1A1173BE9-8022
                    Reset counter: 230
                    Date: 2021.06.10
                    Time: 04:06:05
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 50432
                    Fault Status: 01100101
                    Reset counter: 230
                    Mileage: 47358 km
                    Date: 2021.06.10
                    Time: 04:05:56
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 295
                    Count: 49664
                    Count: 65280
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000001002
   Shop #: WSC 73430 790 00999
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 393ACB27B83FB843C4-806C
   Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
   Component: BCM PQ35  M   103 0615
   Revision: 00103 AD
   Coding: 48180AB8A00508C04010008011000164400000AE526D81605C0040000040
   VCID: 3522C7179C275C2320-8060
   Subsystem 1 - Part No: 5L2 955 119 A  Labels: 1KX-955-119.CLB
   Component: SK356  26  0604
   Coding: 00D7B7
   Component: RLS 071010 05  54  0403
   Coding: 0730ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 230
                    Mileage: 47358 km
                    Date: 2021.06.10
                    Time: 04:08:09
                    Voltage: 12.85 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66601028801068
   Coding: 100006
   VCID: 40CCA6C3D3E5E98B83-8014
   Part No SW: 5K0 953 521 BJ    HW: 5K0 953 569 C
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101008300957
   Coding: 5080040000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 75A20717D4A71C23E0-8020
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
                    Fault Frequency: 47
                    Reset counter: 15
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:02:00
227334 - Windshield Wiper Switch
          B1145 12 [008] - Short to Plus
                    Fault Frequency: 37
                    Reset counter: 15
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:03:10
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Fault Frequency: 46
                    Reset counter: 15
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:02:00
          B1149 13 [008] - Open Circuit
                    Fault Frequency: 46
                    Reset counter: 15
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:02:00
   Part No SW: 5L0 920 800 H    HW: 5L0 920 800 H
   Component: KOMBI         H06 0405
   Coding: 120A00
   Shop #: WSC 73430 031 00999
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 2C14E273476D1DEB4F-8078
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 061010F1003200
   Coding: 69A27F0600020200006303
   Shop #: WSC 00046 000 00000
   VCID: 6D922F7774F7D4E318-8038
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 227
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:01:39
00469 - Infotainment Databus in Single Wire Operation
                    Fault Frequency: 154
                    Reset counter: 230
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:01:39
Address 22: AWD
Address 25: Immobilizer
   Part No SW: 7N0 959 793     HW: 7N0 959 793
   Component: TSG FA        H03 0201
   Revision:             Serial number: 0000011485557
   Coding: 011402208001231004
   VCID: 7F4EE53FEE9B5673BA-802A
02123 - Door Warning Light / Entry Light
                    Fault Status: 01101100
                    Reset counter: 227
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:02:15
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 312AF307A84F70037C-8064
                    Fault Status: 11100101
                    Mileage: 47343 km
                    Date: 2021.06.01
                    Time: 01:01:53
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 33.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 7N0 959 792     HW: 7N0 959 792
   Component: TSG BF        H03 0201
   Revision:             Serial number: 0000011457854
   Coding: 011400208001231004
   VCID: 7EB0183BE9915F7BB1-802A
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2K8417898
   Coding: 0D0004000001
   VCID: 312AF307684F70037C-8064
03138 - Input AUX IN
                    Reset counter: 230
                    Mileage: 47358 km
                    Date: 2021.06.10
                    Time: 04:17:56
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0201
   Revision:             Serial number: 0000011500708
   Coding: 010000200001531004
   VCID: 014A63C7986F2083CC-8054
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0201
   Revision:             Serial number: 0000011500951
   VCID: 55E267973C677C23C0-8000
End----(Elapsed Time: 00:58, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
Regards
ilyas
iichel
Eindhoven, NB, NL
C?ID=284912
do you by any chance have a scan of the car with the previous cluster installed?
advanced ID of cluster and ecu please?
ilyas
India
C?ID=303580
Hi iichel,
unfortunately don't have scan with previous cluster but previous report of ECU below.
Tuesday,20,April,2021,16:14:21:26154
VIN: TMBMDL5L7AA700443   License Plate: FAROK-YETI
                Address 01: Engine       Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 EK    HW: 03L 906 018 BR
  Component and/or Version: R4 2,0L EDC   H22 6821
           Software Coding: 00190012040700080000
            Work Shop Code: WSC 10002 663 98319
              ASAM Dataset: EV_ECM20TDI01103L906018EK 003005 (SK35)
4922 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [032] - -
          [Invalid Data Received FromInstrument Panel Cluster Control Module]
                    Date: 2094.14.19
                    Time: 00:00:08
                    Coolant temperature: 31 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 11.960 V
                    Exhaust gas temperature sensor 1: 20.0 °C
                    Exhaust gas temperature sensor 2: -0.0 °C
                    Exhaust gas temperature sensor 3: -273.0 °C
                    Exhaust gas temperature sensor 4: -273.0 °C
                    Shut-off timer: last engine shut-off time: 9 s
          U0151 00 [047] - -
                    Mileage: 67143 km
                    Date: 2094.14.03
                    Time: 03:37:17
                    Coolant temperature: 64 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.260 V
                    Limitation: accelerator pedal: 126.6 Nm
4715 - No Communication with Instrument Cluster
          U0155 00 [172] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Coolant temperature: 29 °C
The fact that 25-Immobilizer and 22-AWD both "Cannot be reached" is puzzling.
Is this car actually AWD?
Please post Advanced ID data from both the ECU and Instrument Cluster.
ilyas
India
C?ID=303580
Hi Uwe,
yes the car is AWD.
Advanced ID data of ECU and cluster below.
Sunday,13,June,2021,12:43:13:26154
VIN: TMBMDL5L7AA700443   License Plate: MH04EX3357 AD ID
                Address 01: Engine
Advanced Identification/FAZIT
     Identification: BPG-810
     Revision: 42H22---
     Date: 05.10.10
     Manufacturer number: 1236
     Test stand number: 0295
Flash Status
     Programming Attempts(application): 0/0/0/0
     Successful Attempts(application): 0/0/0/0
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 906 018 BR
     Workshop System Name: J623
     ASAM Dataset Revision: 003005
Car Info
     Chassis Number: TMBMDL5L7AA700443
     Engine code: CLCB
VCDS Info:
       Readiness: No script available
Cluster data
Sunday,13,June,2021,12:50:06:26154
VCDS Version: Release 21.3.0 (x64)
Control Module Part Number: 5L0 920 800 H
  Component and/or Version: KOMBI         H06 0405
           Software Coding: 120A00
            Work Shop Code: WSC 73430
     Identification: VD1-048
     Date: 13.04.11
     Manufacturer number: 7392
     Test stand number: 8484
Flash Status
     Programming Attempts(application): 0/0/24/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Programming Status: 00000000
Software
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5L0 920 800 H
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04089
Car Info
     Chassis Number: TMBMDE5LXBA701339
VCDS Info:
       Labels: 5K0-920-xxx-17.clb-SRI1
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod[/cod]e
Regards,
ilyas
You have different VINs in the ECU and the Cluster. I suspect there's no way to make an MK60EC1 ABS module happy while that is the case.
ilyas
India
C?ID=303580
Hi Uwe,
what is the way forward, swaping cluster will do the job? please let me know.
Regards,
ilyas
Spacewalker
Poland
C?ID=159607
1) roll back all , and recode ABS to be sure it accpet coding
( ABS will lost coding ONLy when you swap cluster., not because of different VIn in ECU )
2) if you can not match immo, change VIN in CLUSTER to be sure is genuine and ABS will keep current coding , or recode ABS to new VIN
ilyas
India
C?ID=303580
Spacewalker thanks a lot for your advice
