VW Sharan 2012 canbus errors related to ABS/Steering/Parkassist
emkay
Sweden
C?ID=242663
Posting two autoscans below, one before clearing the logs, and one taken immediately after.
There are NOx and EGR, Injector errors since before so focus on the rest.
In the first log, at 202274km there was a bunch of stuff lighting up, that is where i believe some kind of canbus issue happened since so many modules were affected.
And after that, it seems like it's "only" ABS and Steering assist modules who are sending codes.
What can this be, can it be the rear right wheel sensors from the first log causing this because of some short, or is the ABS module dead, which fuses could this be?
There are no driveability issues, steers and breaks like one would expect but christmastree dash lights.
Address 03: ABS Brakes
03842 - RPM Sensor Rear Right: Incorrect Signal
Address 10: Park/Steer Assist (J791)
13637397 - Databus
Address 44: Steering Assist
Address 53: Parking Brake
AUTOSCAN 1, before clearing.
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 4F 52 53 56
          61 62 69 6C 6D 72 BE BF
VIN: WVWZZZ7NZBV007072   Mileage: 203960km-126734miles
18-Aux. Heat -- Status: Malfunction 1010
BE-Slid. Door Rear Left -- Status: Malfunction 0010
BF-Slid. Door Rear Right -- Status: Malfunction 0010
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H23 9980
   Revision: 44H23---    Serial number:
   Coding: 001D003A043401080000
   Shop #: WSC 40510 222 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003015
   ROD: EV_ECM20TDI01103L906018HJ_VW36.rod
   VCID: 79C1AF32F872F44384-802C
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [109] - Electrical Fault
                    Mileage: 202317 km
                    Date: 2021.05.24
                    Time: 14:56:28
                    Engine RPM: 846.00 /min
                    Normed load value: 42.7 %
                    Coolant temperature: 15 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.020 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 900 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 7
                    Glow cycles below temperature threshold-Bits 0-7: 8
                    Glow cycles below temperature threshold-Bits 0-7: 222
                    Outside temperature: 18.5 °C
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
4891 - EGR Valve (N18)
          P0403 00 [237] - Malfunction
                    Fault Frequency: 80
                    Mileage: 202303 km
                    Date: 2021.05.23
                    Time: 15:55:21
                    Engine RPM: 2189.00 /min
                    Normed load value: 41.2 %
                    Vehicle speed: 104 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.180 V
                    Air mass: actual value (mg/stroke): 605.9 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 99.98 %
                    EGR valve: offset closed: 7.26 %
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 19
                    High press EGR actuator: actual unconditioned volt val: 782.8 mV
4892 - EGR Valve (N18)
          P0403 00 [104] - Malfunction
                    Fault Frequency: 29
                    Mileage: 202308 km
                    Date: 2021.05.23
                    Time: 18:29:54
                    Engine RPM: 1256.00 /min
                    Normed load value: 36.5 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 44 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.360 V
                    Air mass: actual value (mg/stroke): 597.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 33.72 %
                    Actuator for high pressure EGR: status-Bits 0-7: 3
                    High press EGR actuator: actual unconditioned volt val: 2771.0 mV
Readiness: 1 2 0 0 0
   Part No SW: 02E 300 052 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2202
   Revision: 05151112    Serial number: 00001007260491
   Shop #: WSC 00020 000 90108
   VCID: 1B0D95BADA0E665336-804E
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 H
   Component: J104   C3 450M VD10 0009
   Revision: --H07---    Serial number: 00000003044983
   Coding: 0027418
   Shop #: WSC 40518 222 88249
   VCID: 3745690A46E6223332-8062
                    Fault Status: 00111000
                    Reset counter: 51
                    Mileage: 203489 km
                    Date: 2015.10.28
                    Time: 16:10:51
                    Speed: 89.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 27
                    Hex Value: 0x0000
                    Fault Frequency: 41
                    Reset counter: 16
                    Mileage: 203489 km
                    Date: 2015.10.28
                    Time: 16:11:01
                    Speed: 90.0 km/h
                    Hex Value: 0x0100
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
                    Reset counter: 51
                    Mileage: 203489 km
                    Date: 2015.10.28
                    Time: 16:10:51
                    Speed: 89.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 27
                    Hex Value: 0x0000
                    Fault Frequency: 47
                    Reset counter: 11
                    Mileage: 203745 km
                    Date: 2015.10.30
                    Time: 11:19:15
                    Hex Value: 0x0000
                    Voltage: 12.50 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
   Component: Clima-Sharan  H11 0103
   Coding: 0000000109
   Shop #: WSC 00020 999 00000
   VCID: 2F55516A76B6EAF36A-807A
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20130603000000119353
9601321 - Humidity sensor
          B1281 29 [008] - Signal Implausible
                    Reset counter: 49
                    Mileage: 202618 km
                    Date: 2021.05.30
                    Time: 12:57:15
   Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
   Component: BCM PQ35 M    011 0035
   Revision: BC011001
   Coding: 40510A3B8125F3C0500800C0540081E441511308626DAD626480C70000C1
   Shop #: WSC 40518 222 91713
   VCID: 3745690A86E6223332-8062
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110925  31  0032
   Serial number:         111007154523
   Coding: 000D9D
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y10M08D11h14m18s48S1
   Coding: 0380BB
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Component: LIN BACKUP HO  H11 9004
                    Reset counter: 29
                        Term 15 Off
                    Voltage: 12.75 V
                    Reset counter: 29
                        Term 15 Off
                    Voltage: 12.75 V
                    Fault Status: 00101001
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2015.10.14
                    Time: 15:04:13
                        Term 15 Off
                    Voltage: 12.75 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 A    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0005
   Revision: --------    Serial number: 56731015401495
   Coding: 31830D
   ASAM Dataset: EV_EPHVA2C000000000 001004
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 39416F32B8F23443C4-806C
13637397 - Databus
                    Reset counter: 9
                    Mileage: 203489 km
                    Date: 2021.06.06
                    Time: 16:10:50
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag012 H07 0013
   Serial number: 003GFPHR04F-
   Coding: 003132
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E4B7C2EA1DC137BF1-806A
   Serial number: 3493ETS6091BBD60CDDD
   Serial number: 3503ETS607A02D70CDD-
   Serial number: 3513ETS6072E3D60CDD0
   Serial number: 3523ETS60A9FDD60CDDM
   Serial number: 35540TS604A81C40CDDS
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100831200820
   Coding: 1982240000
   VCID: 6AE3807E8DD44FDB7D-803E
   Coding: E20000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Component: KOMBI         H17 0404
   Coding: 140F00
   VCID: 305752166B88F50B73-8064
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2021.05.23
                    Time: 15:03:43
   Part No: 7N0 963 271 A
   Component: Zuheizer        051 2630
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   Shop #: WSC 00020 790 00000
   VCID: 3253581EAD84C71B05-8066
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2015.10.14
                    Time: 15:03:44
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 300511F6000012
   Coding: 350000
   Shop #: WSC 40518 222 10847
   VCID: 315157126882FC037C-8064
                    Fault Status: 00110100
                    Reset counter: 54
                    Mileage: 202322 km
                    Date: 2015.10.15
                    Time: 15:06:59
   Component: IMMO          H17 0404
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H04 0007
   Serial number: VWZAZ2K8320574
   Coding: 000004310400000000021000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60F7E2567BE8058BA3-8034
   Part No SW: 7N0 959 793 B    HW: 7N0 959 793
   Component: TSG FA        H04 0360
   Revision:             Serial number: 0000107013221
   Coding: 01102E208000411011
   VCID: 41B107D2D8226C838C-8014
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.281 0802
   Revision: 1AH03729    Serial number: 00102390119701
   Coding: 0000258
   VCID: 3B4D753A7ACE0653D6-806E
                    Fault Status: 11101101
                    Fault Frequency: 41
                    Reset counter: 16
                    Mileage: 203489 km
                    Date: 2015.10.28
                    Time: 16:10:51
                    RPM: 2216 /min
                    Speed: 89.0 km/h
                    (no units): 7.0
                    Voltage: 13.20 V
   Component: EZE_2         H35 0614
   Coding: 050B0501
   VCID: 6FD5916ABE36AAF32A-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 7N0 959 792 B    HW: 7N0 959 792
   Component: TSG BF        H04 0360
   Revision:             Serial number: 0000107085082
   VCID: 40B702D6D328658B83-8014
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000066911
   Coding: 0024067
                    Fault Status: 01101101
                    Fault Frequency: 37
                    Reset counter: 16
                    Mileage: 203489 km
                    Date: 2015.10.28
                    Time: 16:10:51
                    Voltage: 13.20 V
                    Count: 107
                    Speed: 90.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Component: Batt.regelung H35 0614
   Coding: 030B085A
   VCID: 71D19712A802BC033C-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900780531
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 D    HW: 7N0 959 795 B
   Component: TSG HL        H03 0360
   Revision:             Serial number: 0000107091138
   Coding: 01006C200000411001
   VCID: 44BF0EC6C73079ABA7-8010
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H07 0101
   Revision: 3I001002    Serial number: 00000133844253
   Coding: 410C040001000000
   VCID: 73DD9D1AD21E8E13CE-8026
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J080165
   Coding: 0030011
   VCID: 6EEB8C6E793CA3FB21-803A
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2015.10.14
                    Time: 15:03:44
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2015.10.14
                    Time: 15:03:44
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2015.10.14
                    Time: 15:03:44
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0803
   Revision: 41011001    Serial number: 233000200
   Coding: 0733334003
   ASAM Dataset: EV_HDSGVW428 201133
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 365B640E89ECDB3B29-8062
   Component: TSG HR        H03 0360
   Revision:             Serial number: 0000107090955
Address BE: Slid. Door Rear Left (J558)       Labels: None
   Part No SW: 7N0 959 243 A    HW: 7N0 959 243 A
   Component: Schiebetuer_l 005 2012
   Serial number: 10295470
   ASAM Dataset: EV_AST A03001
   ROD: EV_AST.rod
51719 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2021.05.23
                    Time: 15:03:43
                    Voltage terminal 30: 12.7 V
                    Sliding_Door_Motor_Current: 0.0 A
                    Sliding_Door_Clutch_Current: 0 A
                    Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                    Front button for automatic sliding door: Not operated
                    Rear button for automatic sliding door: Not operated
                    Installed on left side: Yes
                    Installed on right side: No
                    Pinch protection sensor: Not operated
                    Latch_Ajar: operated
                    Latch_Pawl: Not operated
                    Sliding door indicator lamp: not active
                    Sliding door indicator lamp 2: not active
                    Activation: motor for automatic sliding door: not active
                    Automatic sliding door coupling motor activation: not active
                    Motor activation for enabling ratchet release: not active
                    Sliding_Door_Feedback_Motor_Opening: not active
                    Sliding_Door_Feedback_Motor_Closing: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                    Sliding_Door_Feedback_Clutch_In: not active
                    Sliding_Door_Feedback_Clutch_Out: not active
                    Sliding_Door_Feedback_Indicator_Light_Front: not active
                    Sliding_Door_Feedback_Indicator_Light_Rear: not active
                    AD-Value clamping_Protection_Seal: 100
                    Position of automatic sliding door: 0
                    Status_Sliding_Door: latch secondary position
                    Play protection: motor for automatic sliding door: not active
                    Play protection: motor for enabling ratchet release: not active
                    Play protection: automatic sliding door coupling motor: not active
                    Status_Locking_Pawl_Motor: closed
                    Status_Clutch_Motor: closed
Address BF: Slid. Door Rear Right (J731)       Labels: None
   Component: Schiebetuer_r 005 2012
   Serial number: 10295536
   ROD: EV_AST.rod
          U1110 00 [008] - -
                    Reset counter: 29
                    Mileage: 202274 km
                    Date: 2021.05.23
                    Time: 15:03:43
                    Installed on left side: No
                    Installed on right side: Yes
AUTOSCAN 2, AFTER CLEARING, ABS CODES CAME RIGHT BACK
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
   Coding: 0027418
                    Reset counter: 16
                    Mileage: 203965 km
                    Date: 2015.11.02
                    Time: 13:37:27
                    Hex Value: 0x0000
                    Voltage: 14.50 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
                    Reset counter: 16
                    Mileage: 203965 km
                    Date: 2015.11.02
                    Time: 13:37:37
                    Hex Value: 0x0000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Coding: 0000000109
   Slave 1:
   Revision: BC011001
   Coding: 000D9D
   Coding: 0380BB
   Coding: 31830D
13637397 - Databus
                    Reset counter: 16
                    Mileage: 203965 km
                    Date: 2021.06.11
                    Time: 13:37:26
   Coding: 003132
   Coding: 1982240000
   Coding: E20000
   Coding: 140F00
   Coding: 0000041
   Coding: 350000
   Coding: 0000258
                    Reset counter: 16
                    Mileage: 203965 km
                    Date: 2015.11.02
                    Time: 13:37:27
                    RPM: 778 /min
                    (no units): 7.0
                    Voltage: 14.30 V
   Coding: 050B0501
   Coding: 0024067
                    Reset counter: 16
                    Mileage: 203965 km
                    Date: 2015.11.02
                    Time: 13:37:27
                    Voltage: 14.40 V
                    Count: 107
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 030B085A
   Coding: 0030011
   Coding: 0733334003
   ROD: EV_AST.rod
   ROD: EV_AST.rod
Wheel speed sensor. Broken, or incorrect part, or problem with encoder ring, or maybe even the wheel bearing.
emkay
Sweden
C?ID=242663
Thanks Uwe, have you seen sensor faults propagate to canbus errors going bananas like this?
South Molton, UK
Had even more errors than that on my MQB platform Skoda Octavia when the right rear wheel speed sensor failed - needed a new wheel bearing as the ABS sensor is an integral part of the bearing, cost over GBP500 to replace!
  • Informative
Yup. Many things in the car depend on wheel speed info from the ABS.
emkay
Sweden
C?ID=242663
Thanks.
This seems like a very cheap first thing to try.
I would hope its not likely that a broken abs ring or hub triggers alerts on standstill. Any coding required for such a dumb part?
