- Apr 16, 2021
- 8
- 0
- California, USA
- C?ID=435401
hello, I've been a master tech for about 10 years, I specialize in Toyotas.
initially when I received this car it had tons of faults, relating to fuel system. the codes I had were related to an open circuit fuse. after that car ran beautiful. until I stepped on it , car bugged down check engine light flashed and turned off So I stepped on it again this time it stayed on with the following codes. at this point I'm leaning toward another electrical fault possibly wiring issue. just wondering if I can any help isolate it. I just started using vcds any tips Wil be appreciated
car has new turbo assembly, high pressure and low pressure fuel pump, new intake cam, new oil Control valve seals.
Thursday,27,May,2021,17:09:14:23893
VCDS Version: 21.3.0.0 (x64) HEX-NET2 CB: 0.4543.4
VIN: WAUDF78E57A102176 License Plate:
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E0 910 115 P HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0104010A190F0120
Work Shop Code: WSC 26149 444 84581
VCID: 2E0E64C83C12902B2DF-807A
7 Faults Found:
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Mileage: 213153 km
RPM: 1890 /min
Load: 44.3 %
Speed: 20.0 km/h
Temperature: 94.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Mileage: 213156 km
RPM: 1755 /min
Load: 9.8 %
Speed: 84.0 km/h
Temperature: 93.0°C
Temperature: 31.0°C
Voltage: 13.335 V
000307 - Oxygen (Lambda) Sensor B1 S1
P0133 - 002 - Response too Slow
Fault Status: 01100010
Mileage: 213167 km
RPM: 2005 /min
Load: 55.3 %
Speed: 74.0 km/h
Temperature: 92.0°C
Temperature: 27.0°C
Voltage: 13.970 V
P0300 - 008 - - MIL ON
Fault Status: 11101000
Mileage: 213176 km
RPM: 1215 /min
Load: 51.4 %
Temperature: 31.0°C
Temperature: 31.0°C
Voltage: 13.081 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - MIL ON
Mileage: 213176 km
RPM: 1117 /min
Load: 64.7 %
Speed: 7.0 km/h
Temperature: 42.0°C
Temperature: 28.0°C
Voltage: 13.716 V
000136 - Fuel Rail/System Pressure
P0088 - 001 - Too High - Intermittent
Fault Status: 00100001
Mileage: 213354 km
RPM: 2855 /min
Load: 9.8 %
Speed: 83.0 km/h
Temperature: 93.0°C
Temperature: 35.0°C
Voltage: 13.716 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
Mileage: 213379 km
RPM: 1117 /min
Load: 64.7 %
Speed: 7.0 km/h
Temperature: 42.0°C
Temperature: 28.0°C
Voltage: 13.716 V
Readiness: 0010 0101
Address 01: DTCs cleared
Wednesday,02,June,2021,12:05:27:23893
Mileage: 213406 km
RPM: 2639 /min
Load: 40.8 %
Speed: 122.0 km/h
Temperature: 93.0°C
Temperature: 26.0°C
Voltage: 13.970 V
Fault Status: 01101000
Mileage: 213409 km
RPM: 1429 /min
Load: 12.9 %
Speed: 42.0 km/h
Temperature: 48.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Mileage: 213459 km
RPM: 1873 /min
Load: 47.8 %
Speed: 21.0 km/h
Temperature: 101.0°C
Temperature: 37.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.081 V
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 213538 km
RPM: 5727 /min
Load: 91.3 %
Speed: 43.0 km/h
Temperature: 93.0°C
Temperature: 32.0°C
Voltage: 13.462 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Mileage: 213538 km
RPM: 5727 /min
Load: 91.3 %
Speed: 43.0 km/h
Temperature: 93.0°C
Temperature: 32.0°C
Voltage: 13.462 V
Mileage: 213539 km
RPM: 2874 /min
Load: 9.8 %
Speed: 83.0 km/h
Temperature: 92.0°C
Temperature: 32.0°C
Voltage: 13.589 V
Readiness: 0010 0001
