B7 2.0T
edvin11
California, USA
C?ID=435401
hello, I've been a master tech for about 10 years, I specialize in Toyotas.
initially when I received this car it had tons of faults, relating to fuel system. the codes I had were related to an open circuit fuse. after that car ran beautiful. until I stepped on it , car bugged down check engine light flashed and turned off So I stepped on it again this time it stayed on with the following codes. at this point I'm leaning toward another electrical fault possibly wiring issue. just wondering if I can any help isolate it. I just started using vcds any tips Wil be appreciated
car has new turbo assembly, high pressure and low pressure fuel pump, new intake cam, new oil Control valve seals.
Thursday,27,May,2021,17:09:14:23893
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
VIN: WAUDF78E57A102176   License Plate:
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E0 910 115 P    HW: 8E0 907 115 D
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 0104010A190F0120
            Work Shop Code: WSC 26149 444 84581
                      VCID: 2E0E64C83C12902B2DF-807A
7 Faults Found:
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
                    Mileage: 213153 km
                    RPM: 1890 /min
                    Load: 44.3 %
                    Speed: 20.0 km/h
                    Temperature: 94.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
004243 - Bank 1; Fuel Measuring System 2
               P1093 - 008 - Malfunction - Intermittent
                    Mileage: 213156 km
                    RPM: 1755 /min
                    Load: 9.8 %
                    Speed: 84.0 km/h
                    Temperature: 93.0°C
                    Temperature: 31.0°C
                    Voltage: 13.335 V
000307 - Oxygen (Lambda) Sensor B1 S1
               P0133 - 002 - Response too Slow
                    Fault Status: 01100010
                    Mileage: 213167 km
                    RPM: 2005 /min
                    Load: 55.3 %
                    Speed: 74.0 km/h
                    Temperature: 92.0°C
                    Temperature: 27.0°C
                    Voltage: 13.970 V
               P0300 - 008 -  - MIL ON
                    Fault Status: 11101000
                    Mileage: 213176 km
                    RPM: 1215 /min
                    Load: 51.4 %
                    Temperature: 31.0°C
                    Temperature: 31.0°C
                    Voltage: 13.081 V
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - MIL ON
                    Mileage: 213176 km
                    RPM: 1117 /min
                    Load: 64.7 %
                    Speed: 7.0 km/h
                    Temperature: 42.0°C
                    Temperature: 28.0°C
                    Voltage: 13.716 V
000136 - Fuel Rail/System Pressure
               P0088 - 001 - Too High - Intermittent
                    Fault Status: 00100001
                    Mileage: 213354 km
                    RPM: 2855 /min
                    Load: 9.8 %
                    Speed: 83.0 km/h
                    Temperature: 93.0°C
                    Temperature: 35.0°C
                    Voltage: 13.716 V
000769 - Cylinder 1
               P0301 - 008 - Misfire Detected - Intermittent
                    Mileage: 213379 km
                    RPM: 1117 /min
                    Load: 64.7 %
                    Speed: 7.0 km/h
                    Temperature: 42.0°C
                    Temperature: 28.0°C
                    Voltage: 13.716 V
Readiness: 0010 0101
Address 01: DTCs cleared
Wednesday,02,June,2021,12:05:27:23893
                    Mileage: 213406 km
                    RPM: 2639 /min
                    Load: 40.8 %
                    Speed: 122.0 km/h
                    Temperature: 93.0°C
                    Temperature: 26.0°C
                    Voltage: 13.970 V
                    Fault Status: 01101000
                    Mileage: 213409 km
                    RPM: 1429 /min
                    Load: 12.9 %
                    Speed: 42.0 km/h
                    Temperature: 48.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
                    Mileage: 213459 km
                    RPM: 1873 /min
                    Load: 47.8 %
                    Speed: 21.0 km/h
                    Temperature: 101.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.081 V
               P0300 - 001 -  - MIL ON
                    Fault Status: 11100001
                    Mileage: 213538 km
                    RPM: 5727 /min
                    Load: 91.3 %
                    Speed: 43.0 km/h
                    Temperature: 93.0°C
                    Temperature: 32.0°C
                    Voltage: 13.462 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - MIL ON
                    Mileage: 213538 km
                    RPM: 5727 /min
                    Load: 91.3 %
                    Speed: 43.0 km/h
                    Temperature: 93.0°C
                    Temperature: 32.0°C
                    Voltage: 13.462 V
                    Mileage: 213539 km
                    RPM: 2874 /min
                    Load: 9.8 %
                    Speed: 83.0 km/h
                    Temperature: 92.0°C
                    Temperature: 32.0°C
                    Voltage: 13.589 V
Readiness: 0010 0001
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I suggest a complete auto scan of all modules.
Being new to VCDS this is kinda required in all posts.
Welcome!
Good Luck
edvin11
California, USA
C?ID=435401
my apologies I had the log file instead of scan file. ran another auto scan on it. thanks
Saturday,12,June,2021,08:34:08:23893
          67 69 75 76 77
VIN: WAUDF78E57A102176   Mileage: 213640km-132749miles
   Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
   Revision: 5EH14---    Serial number:
   Shop #: WSC 26149 444 84581
                    Mileage: 213406 km
                    RPM: 2639 /min
                    Load: 40.8 %
                    Speed: 122.0 km/h
                    Temperature: 93.0°C
                    Temperature: 26.0°C
                    Voltage: 13.970 V
                    Mileage: 213409 km
                    RPM: 1455 /min
                    Load: 12.2 %
                    Speed: 55.0 km/h
                    Temperature: 80.0°C
                    Temperature: 22.0°C
                    Voltage: 14.224 V
                    Mileage: 213459 km
                    RPM: 1873 /min
                    Load: 47.8 %
                    Speed: 21.0 km/h
                    Temperature: 37.0°C
                    Voltage: 13.081 V
               P0300 - 001 -  - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 213538 km
                    RPM: 5727 /min
                    Load: 91.3 %
                    Speed: 43.0 km/h
                    Temperature: 93.0°C
                    Temperature: 32.0°C
                    Voltage: 13.462 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 213538 km
                    RPM: 5727 /min
                    Load: 91.3 %
                    Speed: 43.0 km/h
                    Temperature: 93.0°C
                    Temperature: 32.0°C
                    Voltage: 13.462 V
                    Mileage: 213539 km
                    RPM: 2874 /min
                    Load: 9.8 %
                    Speed: 83.0 km/h
                    Temperature: 92.0°C
                    Temperature: 32.0°C
                    Voltage: 13.589 V
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2,0TFSI USA 0040
   Revision: --H01---    Serial number:        4233275
   Coding: 0000002
   Shop #: WSC 06325 000 00000
   VCID: 2F3079CC3B189923269-807A
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
                    Fault Frequency: 11
                    Reset counter: 13
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0024
                    Hex Value: 0x01A9
                    Hex Value: 0x0001
                    Fault Status: 00101011
                    Reset counter: 6
                    Hex Value: 0x00C0
                    Hex Value: 0x4002
                    Hex Value: 0x0004
                    Hex Value: 0xB0A7
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BL
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6C8AAEC0CF9E223B43B-513C
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 00003
   Shop #: WSC 06325
   VCID: 3D2C5384E4647BB3A45-4B00
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0C4V9
   Coding: 0032607
   VCID: 3C2A5E80FA6E72BB93B-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3B8MD
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB403DC86A4$ÿ†63
   Subsystem 5 - Serial number: C86A4$ÿ†6342DRB403E35210Cÿ†63
   Subsystem 6 - Serial number: 35210Cÿ†6352ARB400E786A6Xÿ†63
   Subsystem 7 - Serial number: 786A6Xÿ†6362ARB400E7929C-ÿ†63
   Subsystem 8 - Serial number: 7929C-ÿ†63729RB4018096EF-ÿ†63
   Subsystem 9 - Serial number: 096EF-ÿ†63829RB40180A2B7Nÿ
   Subsystem 10 - Serial number: 0A2B7Nÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02021
   Shop #: WSC 06325
   VCID: 41D42F74989C1F53C0D-4B00
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H14 0120
   Revision: 0120        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 26110 444 11239
   VCID: 2E0E64C83C02902B2DF-5184
00438 - Fuel Supply Sensor 2 (G169)
   Coding: 0023261
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11820
   Shop #: WSC 06325
   VCID: 78A282908BC69E9BB73-4B00
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
01369 - Alarm triggered by Hood Switch
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 - -
End----------(Elapsed Time: 05:36, VBatt start/end: 14.0V/13.9V)-----------
This doesn't feel like an electrical problem to me. These cars are quite good at detecting and explicitly reporting electrical problems.
Have a look at what's going on with fuel rail pressure in MVB 106.1.
Camshaft adjustment can be monitored in MVB 091; look for a divergence between field 3 (specified) and 4 (actual).
edvin11
California, USA
C?ID=435401
I added the photos of the mvb, let me know if there is any other easier way to attach the photos, not sure how to record data, one photo is at idle operating temp, and other is at 2500rpm. I noticed when raising rpm to 4k theres is a high pitch whistling noise coming from the fuel line. Thanks
https://www.reddit.com/r/automotive/comments/nzrjiv
Please see:
My guess is snapshots like this aren't going to a difficult way to see catch the problem(s).
See the [Log] button in the lower right-hand corner? Have a look here:
edvin11
California, USA
C?ID=435401
Took the car for a spin for data logging. I only did it with the 2 parameters you asked for 091 and 106. When I got back the exhaust head was glowing red. My guess you'll need more parameters to look at, if so plz let me know the parameters needed so I can data log again. Do I just upload what I have as excel file the same way I did with autoscan? Or is there there a specific way you need the file attached, I saw how I can submit the file from vcds but I'm guessing it's going to start a new thread, is that ok?
edvin11
California, USA
C?ID=435401
Wednesday    16    June    2021    21:57:10:23893-VCID:2E0E64C83C12902B2DF-807A    VCDS Version: Release 21.3.0 (x64)    Data version: 20210226 DS325.0
8E0 910 115 P        2.0l R4/4V TFSI     0020
    Group A:    '091                Group B:    '106                Group C:
        Engine Speed    Cam. Adjustment    Cam. Adjustment    Cam. Adjustment        Fuel Rail    Electric Fuel    Electric Fuel    Fuel Pump
    TIME    (G28)    Intake Bank 1    Intake B1 (spec.)    Intake B1 (act.)    TIME    Pressure (actual)    Pump 1/2    Pump 3/4    Shut-Off Time    TIME
Marker    STAMP     /min     %    °KW    °KW    STAMP     bar     %         s    STAMP
    0.07    2400    46.7    11    12    0.2    101.17    69.8         655.35
    0.35    2040    43.9    16.5    17    0.49    100.18    69         655.35
    0.61    1840    40.8    18    17.5    0.74    97.69    68.6         655.35
    0.88    1920    42    18    18    1.01    99.83    69         655.35
    1.13    1960    42.4    18    18    1.26    101.29    69         655.35
    1.38    1960    42.4    18    18    1.51    101.66    69         655.35
    1.64    1960    42.4    18    18    1.77    102.2    69.4         655.35
    1.89    2000    43.1    18    18    2.02    102.42    69.4         655.35
    2.14    2000    41.2    18    17.5    2.26    104.9    69.4         655.35
    2.4    2040    42    18    18    2.52    109.94    70.6         655.35
    2.66    2120    44.3    18    18    2.81    110.35    71.4         655.35
    2.95    2600    37.6    24    22.5    3.09    111.18    76.1         655.35
    3.23    3120    41.2    26    25.5    3.37    110.68    77.3         655.35
    3.53    3200    43.1    26    26    3.65    111.78    75.7         655.35
    3.79    3240    42.4    26    26    3.93    111.74    75.3         655.35
    4.07    3320    40.8    26    25.5    4.2    109.7    75.7         655.35
    4.33    3360    42.4    26    26    4.47    111.16    76.1         655.35
    4.6    3440    41.2    26    26    4.75    110.54    76.1         655.35
    4.89    3480    44.7    26    26    5.03    109.79    76.1         655.35
    5.16    3520    41.6    26    25.5    5.3    110.81    76.1         655.35
    5.43    3560    43.5    26    26    5.55    109.18    76.5         655.35
    5.67    3600    39.6    26    25.5    5.8    111.18    76.9         655.35
    5.93    3680    42.4    26    26    6.05    109.66    77.3         655.35
    6.17    3760    38.8    26    25.5    6.3    110.04    78.4         655.35
    6.43    3840    41.6    26    25.5    6.55    110.53    78.8         655.35
    6.67    3920    42.7    26    26    6.8    110.31    79.6         655.35
    6.92    4000    42.4    26    25    7.05    111.41    80.4         655.35
    7.17    4040    42.4    26    26    7.3    110.53    80.8         655.35
    7.42    4120    40.4    26    25.5    7.56    108.94    81.2         655.35
    7.7    4240    44.7    26    26    7.84    109.35    82.4         655.35
    7.98    4320    42    26    26    8.11    111.33    82.4         655.35
    8.27    4400    44.3    26    26    8.4    111.44    82.7         655.35
    8.55    4480    41.2    26    25.5    8.68    111.93    83.1         655.35
    8.82    4560    41.2    26    25.5    8.97    111.18    83.9         655.35
    9.11    4640    42.7    26    26    9.24    111.06    84.7         655.35
    9.38    4720    43.1    26    26    9.52    114.41    85.5         655.35
    9.65    4800    36.5    26    25.5    9.79    111.7    86.3         655.35
    9.93    4880    43.5    26    26    10.07    109.07    87.5         655.35
    10.21    4960    43.5    26    26    10.34    111.35    87.8         655.35
    10.48    5040    38.4    26    25    10.61    112.43    88.2         655.35
    10.74    5120    37.3    26    25    10.86    122.13    88.2         655.35
    10.99    5200    33.3    26    25    11.11    113.59    88.2         655.35
    11.24    5280    37.3    26    25.5    11.36    104.68    88.6         655.35
    11.49    5360    45.5    26    26    11.63    107.58    88.2         655.35
    11.76    5400    37.3    26    25.5    11.91    105.55    88.6         655.35
    12.04    5480    37.3    26    25.5    12.18    109.7    88.6         655.35
    12.31    5560    47.1    26    26.5    12.44    142.36    88.6         655.35
    12.57    5600    39.6    26    25.5    12.71    179.67    89         655.35
    12.85    5680    43.5    26    26.5    12.97    178.22    87.8         655.35
    13.09    5520    6.3    28    28    13.22    188.71    72.2         655.35
    13.35    5600    6.3    28    27.5    13.47    189.07    69.8         655.35
    13.59    5520    6.3    28    27.5    13.72    188.41    70.2         655.35
    13.84    5120    6.3    28    28    13.97    183.7    69.4         655.35
    14.09    4400    6.3    28    28.5    14.22    187.16    71         655.35
    14.35    4160    6.3    28    28    14.47    183.5    68.6         655.35
    14.59    4120    6.3    28    27    14.72    182.54    68.2         655.35
    14.84    4120    6.3    28    28    14.97    188.41    68.2         655.35
    15.11    4040    6.3    28    27.5    15.25    182.43    67.8         655.35
    15.39    3800    6.3    28    27    15.53    178.52    67.5         655.35
    15.67    3360    6.3    28    27    15.81    149.54    67.1         655.35
    15.95    3000    6.3    28    26.5    16.09    123.01    66.7         655.35
    16.23    3000    6.3    28    26.5    16.37    100.06    66.7         655.35
    16.51    3000    6.3    28    26.5    16.65    78.35    66.3         655.35
    16.79    3000    6.3    28    27    16.93    84.72    83.9         655.35
    17.07    2960    6.3    28    27    17.19    78.57    83.9         655.35
    17.31    2920    6.3    28    27    17.44    82.77    83.9         655.35
    17.57    2840    6.3    28    26.5    17.7    83.87    83.9         655.35
    17.84    2800    6.3    28    27    17.97    83.06    83.9         655.35
    18.1    2760    6.3    28    26.5    18.23    79.61    83.9         655.35
    18.37    2680    6.3    28    27    18.49    79.32    83.9         655.35
    18.61    2640    6.3    28    27    18.74    80.39    83.5         655.35
    18.86    2600    6.3    28    27    18.99    78.41    83.5         655.35
    19.11    2560    6.3    28    26.5    19.24    78.74    83.5         655.35
    19.36    2480    6.3    28    27    19.49    76.06    82.4         655.35
    19.61    2480    6.3    28    27    19.74    73.48    82.4         655.35
    19.86    2440    6.3    28    27    19.98    70.76    82.4         655.35
    20.11    2400    6.3    28    27    20.23    68.29    82.4         655.35
    20.36    2360    6.3    28    27    20.5    65.88    82.4         655.35
    20.64    2320    6.3    28    27    20.78    63.64    82.4         655.35
    20.92    2280    6.3    28    27    21.06    61.38    82.4         655.35
    21.2    2240    6.3    28    27.5    21.34    59.26    82.4         655.35
    21.49    2240    6.3    28    27.5    21.62    57.29    82.4         655.35
    21.76    2200    6.3    28    27    21.9    55.38    82.4         655.35
    22.02    2200    6.3    28    27    22.16    53.92    82.4         655.35
    22.29    2200    6.3    28    27    22.43    52.45    82.4         655.35
    22.58    2160    6.3    28    27    22.72    50.91    82.4         655.35
    22.85    2160    6.3    28    27    22.97    49.54    82.4         655.35
    23.09    2160    6.3    28    27    23.22    48.47    82.4         655.35
    23.36    2160    6.3    28    27    23.5    47.13    82.4         655.35
    23.63    2120    6.3    28    27    23.78    45.88    82.4         655.35
    23.92    2120    6.3    28    27    24.05    44.86    82.4         655.35
    24.17    2120    6.3    28    27    24.31    43.79    82.4         655.35
    24.45    2120    6.3    28    27.5    24.57    42.9    82.4         655.35
    24.69    2080    6.3    28    27    24.82    41.91    82.4         655.35
    24.96    2080    6.3    28    27.5    25.08    41.03    82.4         655.35
    25.2    2080    6.3    28    27    25.33    40.25    82.4         655.35
    25.46    2040    6.3    28    27    25.58    39.47    82.4         655.35
    25.7    2040    6.3    28    27.5    25.83    38.68    82.4         655.35
    25.96    2040    6.3    28    27.5    26.08    37.94    82.4         655.35
    26.2    2000    6.3    28    27    26.33    37.09    82.4         655.35
    26.46    2000    6.3    28    27.5    26.59    36.42    82.4         655.35
    26.74    1960    6.3    28    27.5    26.88    35.69    82.4         655.35
    27    1920    6.3    28    27.5    27.14    34.89    82.4         655.35
    27.28    1920    6.3    28    27.5    27.42    34.11    82.4         655.35
    27.56    1880    6.3    28    27.5    27.7    33.46    82.4         655.35
    27.84    1880    6.3    28    27.5    27.98    32.88    82.4         655.35
    28.11    1840    6.3    28    27    28.26    58.08    83.9         655.35
    28.41    1920    50.6    16.5    19    28.54    47.77    88.6         655.35
    28.67    2160    44.3    18    18    28.81    43.39    89.8         655.35
    28.96    2080    41.2    18    17.5    29.08    48.06    89.8         655.35
    29.2    2000    42    18    17.5    29.33    50.56    89.8         655.35
    29.47    2320    42.4    18    17.5    29.6    56.8    91         655.35
    29.72    3360    49.8    16.5    18.5    29.86    62.17    90.6         655.35
    29.99    3880    40    23.5    22    30.13    185.67    88.2         655.35
    30.25    4400    49.8    26    26    30.39    190.49    91         655.35
    30.53    5200    44.3    26    26    30.67    189.91    90.2         655.35
    30.8    5200    44.3    26    26    30.95    191.07    90.2         655.35
    31.1    5240    43.9    26    26    31.23    187.42    90.2         655.35
    31.37    5240    43.1    26    25.5    31.49    191.74    90.2         655.35
    31.61    5200    6.3    28    27.5    31.74    188.7    85.5         655.35
    31.88    5160    6.3    28    28    32    188.24    85.5         655.35
    32.13    5120    6.3    28    28    32.26    187.82    85.5         655.35
    32.38    5080    6.3    28    27.5    32.5    188.78    85.5         655.35
    32.64    5040    6.3    28    28.5    32.76    190.78    85.5         655.35
    32.89    4960    6.3    28    28    33.03    188.87    85.9         655.35
    33.16    4920    6.3    28    27.5    33.29    188.58    85.9         655.35
    33.42    4880    6.3    28    27.5    33.56    189.56    85.5         655.35
    33.7    4840    6.3    28    28.5    33.84    190.14    85.5         655.35
    33.98    4760    6.3    28    27.5    34.12    193.43    85.5         655.35
    34.26    4720    6.3    28    28    34.4    185.33    82.4         655.35
    34.53    4640    6.3    28    27    34.67    186.6    82.4         655.35
    34.81    4520    6.3    28    27.5    34.95    184.77    82.4         655.35
    35.09    4080    6.3    28    27.5    35.22    186.6    85.1         655.35
    35.35    3280    6.3    28    26.5    35.49    174.98    85.1         655.35
    35.61    2960    6.3    28    27    35.74    170.82    84.3         655.35
    35.87    2840    6.3    28    27    36    170.58    83.9         655.35
    36.14    2920    6.3    28    27    36.28    170.97    83.9         655.35
    36.42    2880    51.4    21.5    24.5    36.56    168.78    86.7         655.35
    36.7    3040    48.6    7.5    10    36.84    165.94    89         655.35
    36.98    3080    46.3    -4    -3    37.12    160.33    89         655.35
    37.25    2520    33.7    -3.5    -7    37.38    155.92    89.8         655.35
    37.51    2520    39.2    16    14    37.66    147.21    89.8         655.35
    37.78    2520    45.1    12    13.5    37.91    143.42    89.4         655.35
    38.03    2520    43.9    11.5    11.5    38.15    139.97    89.4         655.35
    38.28    2480    44.7    11.5    11.5    38.41    134.02    89.4         655.35
    38.53    2600    41.2    11    10    38.67    128.59    89.8         655.35
    38.8    3200    47.1    3    4.5    38.92    123.75    89.4         655.35
    39.05    3280    40.4    4.5    4    39.17    118.25    89.4         655.35
    39.3    3280    38    6.5    5    39.42    113.21    89         655.35
    39.55    3320    40.4    7    6    39.68    109.75    89         655.35
    39.8    3320    43.9    8    8    39.93    109.35    89         655.35
    40.05    3320    44.7    9    9    40.18    108.48    89         655.35
    40.32    3320    44.3    9    9    40.47    110.32    89.4         655.35
    40.61    3320    49.8    8.5    9    40.75    108.62    89         655.35
    40.89    3360    43.5    10.5    10    41.03    108.98    89.4         655.35
    41.17    3400    39.6    12.5    12    41.31    110.02    89.4         655.35
    41.44    3400    40    13.5    13    41.57    107.89    89         655.35
    41.69    3360    21.6    23    16.5    41.83    104.28    84.3         655.35
    41.96    3360    6.3    28    27    42.08    104.5    83.9         655.35
    42.21    3360    51.8    18.5    21    42.33    102.08    88.2         655.35
    42.46    3400    44.7    13    13.5    42.58    101.17    89         655.35
    42.72    2880    49.4    4    6    42.85    100.99    89         655.35
    42.97    2720    38    -3    -4.5    43.09    103.23    89         655.35
    43.21    2760    49.8    -4    -4    43.34    107.59    89         655.35
    43.47    2760    40.4    -4    -5    43.6    106.9    89         655.35
    43.73    2760    44.7    -4.5    -4.5    43.88    107.5    89         655.35
    44.01    2760    43.9    -5    -5    44.13    108.56    89         655.35
    44.27    2720    44.7    -3.5    -3.5    44.41    107.71    89.4         655.35
    44.55    2720    41.6    -2    -2.5    44.67    107.6    89.4         655.35
    44.81    2760    40    -1.5    -2.5    44.95    108.23    89.4         655.35
    45.1    2760    46.3    -3    -3    45.23    107.84    89.4         655.35
    45.37    2760    43.1    -4.5    -4.5    45.51    107.27    89.4         655.35
    45.66    2760    42.4    -4.5    -5    45.79    106.91    89.4         655.35
    45.94    2800    37.6    -6    -6.5    46.07    107.03    89.4         655.35
    46.21    2840    44.3    -7    -7    46.35    107.15    89.4         655.35
    46.49    2840    43.5    -9    -9    46.63    105.31    89         655.35
    46.76    2840    41.6    -9.5    -10    46.9    100.58    86.3         655.35
    47.04    2800    23.9    9    2    47.16    98.61    83.9         655.35
    47.28    2560    6.3    28    27    47.41    98.02    83.9         655.35
    47.54    2240    6.3    28    27    47.65    95.62    83.5         655.35
    47.78    2080    6.3    28    27.5    47.91    95.92    83.5         655.35
    48.04    2080    6.3    28    27    48.15    95.79    83.5         655.35
    48.28    2040    6.3    28    27.5    48.41    95.42    83.5         655.35
    48.54    1840    6.3    28    27.5    48.66    94.37    83.5         655.35
    48.78    1640    6.3    28    27    48.91    93.8    83.5         655.35
    49.05    1600    6.3    28    27    49.19    92.9    83.5         655.35
    49.33    1600    6.3    28    27.5    49.47    92.95    83.1         655.35
    49.61    1600    6.3    28    27    49.76    92.49    83.1         655.35
    49.9    1600    6.3    28    27    50.04    92.22    83.1         655.35
    50.18    1600    6.3    28    27    50.32    91.83    83.1         655.35
    50.44    1600    6.3    28    27.5    50.57    91.03    83.1         655.35
    50.69    1600    6.3    28    27    50.82    90.49    83.1         655.35
    50.95    1600    6.3    28    27    51.07    90.25    83.1         655.35
    51.19    1600    6.3    28    27.5    51.31    89.45    83.1         655.35
    51.44    1560    6.3    28    27    51.56    88.91    83.1         655.35
    51.69    1600    6.3    28    27    51.81    88.43    83.1         655.35
    51.94    1560    6.3    28    27    52.06    87.9    83.1         655.35
    52.19    1560    6.3    28    27    52.31    87.29    83.1         655.35
    52.43    1560    6.3    28    27    52.58    87.94    83.5         655.35
    52.72    1560    6.3    28    27    52.86    86.71    83.5         655.35
    53    1520    6.3    28    27.5    53.13    85.55    82.4         655.35
    53.26    1520    6.3    28    27    53.4    82.24    82.4         655.35
    53.54    1520    6.3    28    27.5    53.68    78.86    82.4         655.35
    53.83    1520    6.3    28    27    53.97    76.09    82.4         655.35
    54.1    1520    6.3    28    27.5    54.24    73.94    82.4         655.35
    54.39    1520    6.3    28    27.5    54.52    71.66    82.4         655.35
    54.65    1480    6.3    28    27.5    54.79    69.56    82.4         655.35
    54.93    1480    6.3    28    27    55.05    67.76    82.4         655.35
    55.18    1480    6.3    28    27    55.3    66.09    82.4         655.35
    55.43    1480    6.3    28    27.5    55.55    64.58    82.4         655.35
    55.68    1480    6.3    28    27    55.81    63.12    82.4         655.35
    55.95    1440    6.3    28    27    56.06    61.73    82.4         655.35
    56.19    1440    6.3    28    27.5    56.32    60.46    82.4         655.35
    56.44    1440    6.3    28    27    56.58    59.24    82.4         655.35
    56.72    1440    6.3    28    27    56.86    58.02    82.4         655.35
    57    1440    6.3    28    27.5    57.14    56.85    82.4         655.35
    57.27    1400    6.3    28    27    57.39    55.92    82.4         655.35
    57.52    1400    6.3    28    27    57.65    54.89    82.4         655.35
    57.8    1400    6.3    28    27.5    57.93    54.09    82.4         655.35
    58.07    1400    6.3    28    27.5    58.21    53.19    82.4         655.35
    58.34    1400    6.3    28    27.5    58.48    52.41    82.4         655.35
    58.62    1360    6.3    28    27    58.74    51.64    82.4         655.35
    58.86    1360    6.3    28    27    58.99    50.94    82.4         655.35
    59.11    1360    6.3    28    27.5    59.24    50.29    82.4         655.35
    59.37    1360    6.3    28    27    59.49    49.6    82.4         655.35
    59.61    1360    6.3    28    27    59.74    48.96    82.4         655.35
    59.87    1360    6.3    28    27    60.03    48.27    82.4         655.35
    60.17    1320    6.3    28    27    60.31    47.59    82.4         655.35
    60.43    1320    6.3    28    27    60.55    47.13    82.4         655.35
    60.68    1320    6.3    28    27    60.81    46.55    82.4         655.35
    60.94    1320    6.3    28    27    61.08    45.99    82.4         655.35
    61.22    1320    6.3    28    27    61.37    45.5    82.4         655.35
    61.5    1280    6.3    28    27.5    61.64    44.98    82.4         655.35
    61.76    1280    6.3    28    27    61.9    44.47    82.4         655.35
    62.02    1280    6.3    28    27    62.15    44    82.4         655.35
    62.27    1280    6.3    28    27.5    62.4    43.62    82.4         655.35
    62.54    1280    6.3    28    27.5    62.66    43.27    82.4         655.35
    62.79    1280    6.3    28    27    62.92    56.74    83.5         655.35
    63.05    1200    6.3    28    27    63.17    51.11    83.5         655.35
    63.3    1240    6.3    28    27.5    63.43    53.55    83.5         655.35
    63.55    1360    6.3    28    27.5    63.68    57.22    83.5         655.35
    63.81    1480    6.3    28    27.5    63.95    59.97    83.5         655.35
    64.08    1560    6.3    28    27.5    64.2    60.5    83.5         655.35
    64.33    1520    6.3    28    27    64.46    59.86    83.5         655.35
    64.58    1480    6.3    28    27    64.71    59.65    83.5         655.35
    64.83    1440    6.3    28    27.5    64.95    59.34    83.1         655.35
    65.08    1400    6.3    28    27    65.21    58.82    83.1         655.35
    65.33    1400    6.3    28    27.5    65.45    58.51    83.1         655.35
    65.6    1360    6.3    28    27.5    65.74    57.96    83.1         655.35
    65.87    1320    6.3    28    27.5    66.01    57.94    83.1         655.35
    66.15    1280    6.3    28    27.5    66.29    57.45    83.1         655.35
    66.43    1240    6.3    28    27    66.57    57.21    83.1         655.35
    66.71    1280    6.3    28    27.5    66.86    57.21    83.1         655.35
    66.99    1480    6.3    28    27    67.11    60.52    83.1         655.35
    67.26    1440    6.3    28    27    67.39    58.96    83.1         655.35
    67.53    1400    6.3    28    27    67.67    58.75    83.1         655.35
    67.82    1360    6.3    28    27.5    67.96    58.14    83.1         655.35
    68.09    1320    6.3    28    27    68.23    57.55    83.1         655.35
    68.38    1280    6.3    28    27    68.52    56.91    83.1         655.35
    68.66    1240    6.3    28    27    68.79    56.34    83.1         655.35
    68.94    1200    6.3    28    27    69.08    56.33    83.1         655.35
    69.21    1160    6.3    28    27    69.36    56.43    83.1         655.35
    69.5    1240    6.3    28    27.5    69.63    56.08    83.1         655.35
    69.77    1320    6.3    28    27.5    69.9    57.15    83.1         655.35
    70.04    1320    6.3    28    27.5    70.18    56.82    83.1         655.35
    70.32    1200    6.3    28    27.5    70.46    55.63    83.1         655.35
    70.59    1120    6.3    28    27    70.7    55.34    83.1         655.35
    70.84    1080    6.3    28    27.5    70.96    54.79    83.1         655.35
    71.08    1040    6.3    28    27.5    71.2    55.21    83.1         655.35
    71.33    960    6.3    28    27.5    71.45    52.41    83.1         655.35
    71.58    880    6.3    28    28    71.7    55.26    83.1         655.35
    71.85    800    6.3    28    28    71.98    53.84    83.1         655.35
    72.12    720    6.3    28    27    72.27    45.76    83.5         655.35
    72.4    760    6.3    28    27    72.53    47.98    83.1         655.35
    72.67    800    6.3    28    27.5    72.81    55.99    83.5         655.35
    72.94    800    6.3    28    27.5    73.07    51.37    83.5         655.35
    73.19    800    6.3    28    27    73.32    46.56    83.1         655.35
    73.45    800    6.3    28    27    73.59    50.09    83.5         655.35
    73.73    800    6.3    28    27.5    73.88    50.43    83.5         655.35
    74.01    800    6.3    28    27.5    74.15    46.43    83.5         655.35
    74.29    840    6.3    28    27.5    74.42    48.93    83.5         655.35
    74.55    840    6.3    28    27.5    74.67    54.65    83.5         655.35
    74.8    760    6.3    28    28    74.93    50.01    83.1         655.35
    75.05    680    6.3    28    27    75.17    46.69    83.1         655.35
    75.3    680    53.3    19.5    22.5    75.44    41.07    83.1         655.35
    75.58    760    50.6    18    19    75.72    51.91    83.9         655.35
    75.86    1080    49.8    16.5    18    76    53.23    83.9         655.35
    76.14    1160    45.9    6.5    7.5    76.28    55.79    85.1         655.35
    76.42    1440    49    -0.5    0.5    76.56    58.16    85.5         655.35
    76.7    1520    43.5    -3.5    -4    76.84    60.84    85.5         655.35
    76.98    1560    42    -4.5    -5    77.12    63.48    85.9         655.35
    77.26    1560    44.7    -5.5    -5.5    77.4    66.56    85.5         655.35
    77.52    1560    41.6    -4    -5    77.64    68.95    85.5         655.35
    77.77    1600    45.5    -4.5    -4.5    77.9    66.98    85.9         655.35
    78.03    1600    43.5    -12    -12    78.16    66.26    84.7         655.35
    78.28    1480    43.9    -12    -12.5    78.41    64.13    84.7         655.35
    78.53    1480    43.9    -11.5    -11.5    78.66    62.83    84.7         655.35
    78.79    1480    45.9    -12    -11.5    78.91    61.85    84.3         655.35
    79.04    1520    45.1    -12    -12    79.16    61.2    84.3         655.35
    79.29    1520    42.4    -12    -13    79.43    62.84    84.7         655.35
    79.57    1560    42.7    -12    -12.5    79.69    63.09    84.3         655.35
    79.82    1600    42.4    -12    -13    79.94    64.41    65.9         655.35
    80.08    1640    44.7    -12    -12    80.22    64.06    65.1         655.35
    80.36    1560    43.9    -8    -7.5    80.49    62.63    64.7         655.35
    80.64    1600    40.8    -7    -8    80.78    62.41    64.7         655.35
    80.91    1600    40    -6    -6.5    81.06    62.66    65.1         655.35
    81.2    1640    47.8    -9    -8    81.34    65.72    65.5         655.35
    81.48    1680    47.1    -12    -11.5    81.62    68.24    67.1         655.35
    81.74    1760    41.6    -12    -13    81.86    71.98    67.8         655.35
    81.99    1800    42    -11    -11    82.11    75.08    68.2         655.35
    82.24    1840    43.5    -9    -9    82.36    78.74    68.6         655.35
    82.49    1920    40.8    -10    -10.5    82.61    83.04    69         655.35
    82.74    1960    41.6    -11    -11.5    82.86    87.31    69.4         655.35
    82.99    2000    42    -11.5    -12    83.11    89.11    69         655.35
    83.24    2040    44.3    -12    -11.5    83.36    86.8    69         655.35
    83.48    2000    43.9    -12    -12    83.61    86.48    67.1         655.35
    83.73    1600    27.5    10    5.5    83.87    85.04    66.3         655.35
    83.99    1240    6.3    28    27.5    84.12    81.95    65.9         655.35
    84.23    1240    6.3    28    27    84.36    83.01    65.9         655.35
    84.48    1200    6.3    28    27.5    84.61    82.61    65.9         655.35
    84.73    1160    6.3    28    27    84.87    82.48    67.1         655.35
    85    1120    6.3    28    27.5    85.13    81.99    67.8         655.35
    85.25    1040    6.3    28    27    85.38    81.64    68.2         655.35
    85.5    1040    6.3    28    27    85.63    81.47    68.6         655.35
    85.75    1000    6.3    28    27    85.88    81.7    69         655.35
    86    960    6.3    28    27    86.13    77.93    69         655.35
    86.25    920    6.3    28    27    86.38    75.4    69.4         655.35
    86.5    880    6.3    28    27    86.63    76.55    69         655.35
    86.75    800    6.3    28    27    86.88    77.23    69.4         655.35
    87    760    6.3    28    28    87.12    72.59    69.4         655.35
    87.26    760    6.3    28    27.5    87.38    69.13    69.4         655.35
    87.5    760    6.3    28    27.5    87.65    75.11    69         655.35
    87.79    800    6.3    28    28    87.93    74.2    69         655.35
    88.07    800    6.3    28    28    88.19    67.34    69         655.35
    88.34    800    6.3    28    28    88.48    67.17    68.6         655.35
    88.62    800    6.3    28    27.5    88.76    66.41    68.6         655.35
    88.9    840    6.3    28    27    89.04    62.38    68.2         655.35
    89.18    720    6.3    28    27    89.31    59.03    68.6         655.35
    89.45    680    6.3    28    27.5    89.59    58.21    68.6         655.35
    89.72    760    6.3    28    28    89.87    61.71    68.6         655.35
    90.01    720    6.3    28    27.5    90.15    56.48    68.2         655.35
    90.29    720    6.3    28    27    90.43    53.55    68.6         655.35
    90.55    760    6.3    28    27.5    90.68    52.18    68.6         655.35
    90.8    760    6.3    28    27    90.93    48.93    68.6         655.35
    91.07    760    6.3    28    27.5    91.21    50.96    68.6         655.35
    91.33    760    6.3    28    27.5    91.46    49.97    68.6         655.35
    91.58    760    6.3    28    27    91.71    45.08    68.6         655.35
    91.85    760    6.3    28    27.5    91.97    51.25    68.6         655.35
    92.1    760    6.3    28    28    92.22    55.18    68.6         655.35
    92.35    800    6.3    28    26.5    92.47    49.98    68.6         655.35
    92.6    720    6.3    28    27.5    92.73    47.34    68.6         655.35
    92.87    720    6.3    28    28    92.99    47.17    69.4         655.35
    93.11    720    6.3    28    27.5    93.23    52.62    69         655.35
    93.37    720    6.3    28    27.5    93.49    51.98    69.4         655.35
    93.63    720    6.3    28    27.5    93.76    47.89    69.4         655.35
Wednesday    16    June    2021    22:00:46:23893-VCID:2E0E64C83C12902B2DF-807A    VCDS Version: Release 21.3.0 (x64)    Data version: 20210226 DS325.0
    0.06    2160    38    -0.5    -3.5    0.2    96.83    69         655.35
    0.32    2240    43.9    1    0.5    0.44    98.67    69         655.35
    0.57    2080    44.7    3.5    3.5    0.71    96.88    68.2         655.35
    0.85    1920    45.1    18    15.5    0.98    101.84    70.2         655.35
    1.13    2160    43.5    18    18    1.26    109.62    71         655.35
    1.4    2320    42    19.5    19    1.53    110.51    71.4         655.35
    1.66    2480    39.2    23.5    22.5    1.79    110.48    73.3         655.35
    1.93    2920    42.4    25.5    25    2.06    111.05    76.9         655.35
    2.2    3080    42.7    26    25.5    2.35    111.7    74.5         655.35
    2.48    3280    47.5    26    26    2.62    112.67    74.9         655.35
    2.74    3400    42    26    25.5    2.87    110.82    76.1         655.35
    3.01    3600    43.9    26    25.5    3.15    110.8    76.9         655.35
    3.29    3800    48.2    26    26    3.42    110.65    77.3         655.35
    3.56    3920    42.7    26    25.5    3.68    111.45    77.6         655.35
    3.8    4080    46.7    26    26    3.93    111.65    79.2         655.35
    4.05    4240    35.3    26    25    4.18    110.42    80         655.35
    4.31    4400    37.6    26    26    4.43    111.99    81.2         655.35
    4.57    4560    45.1    26    26    4.69    108.76    82.7         655.35
    4.81    4720    46.3    26    26    4.94    115.33    84.3         655.35
    5.08    4920    54.1    26    26.5    5.21    113.51    86.3         655.35
    5.34    5120    58.4    26    27.5    5.49    112.72    87.5         655.35
    5.62    5320    60.8    26    26    5.76    104.91    87.8         655.35
    5.91    5520    63.9    26    27    6.04    107.98    87.8         655.35
    6.19    5680    44.7    26    25.5    6.33    178.19    87.1         655.35
    6.48    5840    47.1    26    26    6.59    179.59    87.8         655.35
    6.72    6000    47.1    26    26    6.85    176.87    88.2         655.35
    6.98    6120    48.2    26    26.5    7.1    177.71    88.2         655.35
    7.22    6160    46.3    26    26    7.35    183.16    87.8         655.35
    7.49    5080    44.7    26    25.5    7.61    180.39    84.3         655.35
    7.74    4280    46.3    26    26    7.86    176.76    82.7         655.35
    7.98    4280    43.9    26    25    8.12    177.86    82.4         655.35
    8.25    4360    45.5    26    25.5    8.4    181.27    83.1         655.35
    8.53    4360    46.3    26    26    8.68    181.56    83.1         655.35
    8.81    4440    49    26    26    8.95    174.44    83.5         655.35
    9.1    4520    43.9    26    25.5    9.23    179.36    83.9         655.35
    9.37    4600    49    26    26.5    9.51    180    84.3         655.35
    9.64    4680    44.3    26    25.5    9.76    178.02    84.7         655.35
    9.88    4720    49    26    26.5    10.01    179.03    85.5         655.35
    10.13    4800    49.4    26    26.5    10.26    175.91    85.9         655.35
    10.38    4880    49.8    26    26    10.51    176.48    86.7         655.35
    10.64    4960    46.7    26    26    10.77    180.92    94.9         655.35
    10.89    5000    44.3    26    25.5    11.03    180.03    94.9         655.35
    11.17    5080    38.4    26    25.5    11.31    177.9    94.9         655.35
    11.45    5120    39.2    26    25    11.59    184.34    89.8         655.35
    11.73    5160    45.1    26    25.5    11.87    192.61    85.1         655.35
    12.01    5120    6.3    28    28    12.15    195.06    84.7         655.35
    12.29    5040    6.3    28    28.5    12.43    192.54    84.7         655.35
    12.56    5040    48.2    26    27    12.69    188.63    89.4         655.35
    12.82    4120    43.5    26    26    12.95    183.03    88.6         655.35
    13.08    3880    44.7    24.5    24.5    13.21    187.54    89         655.35
    13.33    3880    47.1    24.5    24.5    13.46    181.03    89         655.35
    13.58    3880    47.1    24    24.5    13.71    184.28    89         655.35
    13.84    3800    6.3    28    27    13.96    179.11    83.9         655.35
    14.09    3680    6.3    28    27    14.22    179.72    83.9         655.35
    14.35    3320    6.3    28    27.5    14.48    172.85    83.5         655.35
    14.61    2840    6.3    28    27.5    14.74    157.5    83.5         655.35
    14.87    2760    6.3    28    27.5    14.99    143.93    83.5         655.35
    15.11    2760    6.3    28    27    15.24    128.74    83.5         655.35
    15.37    2680    6.3    28    26.5    15.5    115.12    83.5         655.35
    15.62    2480    6.3    28    28    15.75    100.79    83.5         655.35
    15.89    2160    6.3    28    27.5    16.02    95.3    83.5         655.35
    16.17    2160    6.3    28    27.5    16.3    94.47    83.1         655.35
    16.45    2160    6.3    28    27.5    16.59    97.57    83.5         655.35
    16.73    2120    6.3    28    27    16.87    97.44    83.1         655.35
    17.02    2120    6.3    28    27    17.15    96.81    83.1         655.35
    17.3    2080    6.3    28    27    17.44    96.96    83.1         655.35
    17.58    2040    6.3    28    27.5    17.71    96.72    83.1         655.35
    17.85    2040    6.3    28    28    17.98    97.01    83.1         655.35
    18.11    2000    6.3    28    27.5    18.24    96.44    83.1         655.35
    18.37    1960    6.3    28    28    18.5    95.91    83.1         655.35
    18.64    1920    6.3    28    28    18.78    95.31    83.1         655.35
    18.92    1880    6.3    28    27.5    19.06    95.17    83.1         655.35
    19.2    1840    6.3    28    28    19.33    94.58    83.1         655.35
    19.47    1800    6.3    28    27.5    19.61    95.01    83.5         655.35
    19.74    1800    6.3    28    27.5    19.86    93.96    83.1         655.35
    19.99    1720    6.3    28    28    20.12    92.2    82.4         655.35
    20.25    1680    6.3    28    27.5    20.36    88.72    82.4         655.35
    20.49    1680    6.3    28    27.5    20.62    85.98    82.4         655.35
    20.76    1640    6.3    28    28    20.9    82.65    82.4         655.35
    21.02    1600    6.3    28    27.5    21.14    80.13    82.4         655.35
    21.27    1560    6.3    28    28    21.39    77.57    82.4         655.35
    21.54    1520    6.3    28    28    21.66    75.33    82.4         655.35
    21.78    1520    6.3    28    27.5    21.92    73.16    82.4         655.35
    22.04    1520    6.3    28    28    22.15    71.22    82.4         655.35
    22.29    1520    56.9    23.5    27    22.43    71.17    84.7         655.35
    22.56    1640    56.1    10.5    13    22.69    75.98    87.8         655.35
    22.85    2040    48.6    18    18.5    22.99    83.06    89         655.35
    23.12    2520    47.5    18.5    19    23.27    87.98    91         655.35
    23.41    3160    54.1    9    11.5    23.55    97.98    91         655.35
    23.69    3440    60    17.5    19.5    23.83    103.96    89.4         655.35
    23.97    3520    50.2    18    19    24.11    109.05    89.4         655.35
    24.24    3520    51    18.5    19    24.37    109.35    89         655.35
    24.51    3520    51.8    18    19    24.63    109.82    88.6         655.35
    24.76    3520    29.8    18    17    24.9    109.95    88.6         655.35
    25.05    3560    50.2    18.5    19    25.16    110.08    89         655.35
    25.29    3560    54.1    19    20    25.41    110.12    89         655.35
    25.54    3600    32.5    19.5    18.5    25.67    109.72    89         655.35
    25.82    3560    55.3    19.5    20    25.96    110.75    89         655.35
    26.09    3600    42    19.5    19.5    26.24    109.75    88.6         655.35
    26.38    3560    6.3    28    25.5    26.51    105.58    83.9         655.35
    26.63    3520    42    26    26.5    26.77    103.79    86.7         655.35
    26.92    3760    43.5    22.5    21.5    27.07    109.67    88.6         655.35
    27.2    3400    34.9    18    18    27.34    108.4    89         655.35
    27.48    3320    60.8    5.5    8    27.61    111.48    88.6         655.35
    27.75    3680    47.1    21.5    21.5    27.89    108.4    88.2         655.35
    28.03    3680    40    21    20.5    28.16    109.38    88.2         655.35
    28.29    3680    42.7    21    20.5    28.42    109.87    88.6         655.35
    28.57    3680    60.8    21    22    28.7    110.23    88.6         655.35
    28.84    3640    41.6    20.5    20    28.98    110.08    89         655.35
    29.11    3680    51    21    21.5    29.25    109.94    88.6         655.35
    29.4    3680    37.6    21    20.5    29.53    110.02    88.2         655.35
    29.67    3720    54.9    21    22    29.79    107.38    85.9         655.35
    29.93    3680    6.3    28    27    30.05    110.75    83.9         655.35
    30.18    3600    6.3    27.5    27    30.31    146.33    87.1         655.35
    30.43    3880    35.3    23.5    23    30.56    167.57    89.8         655.35
    30.7    3160    45.1    17.5    19    30.83    106.77    88.6         655.35
    30.96    3360    35.7    6    6.5    31.09    113.01    88.6         655.35
    31.22    3720    43.9    23.5    23    31.35    144.19    87.5         655.35
    31.47    3760    46.3    22.5    22.5    31.6    185.42    88.6         655.35
    31.74    3760    52.9    22.5    23    31.9    177.76    89         655.35
    32.03    3800    48.6    22.5    23    32.17    180.05    89.4         655.35
    32.31    3800    60.8    22.5    23.5    32.45    183.52    89         655.35
    32.59    3800    58    22.5    23.5    32.74    181.96    88.6         655.35
    32.87    3800    35.7    23    21.5    32.99    186.6    88.6         655.35
    33.12    3840    32.2    23    22.5    33.24    176.56    89         655.35
    33.37    3840    47.1    23.5    24    33.49    181.61    89         655.35
    33.61    3880    41.6    24    24    33.73    179.4    89         655.35
    33.87    3880    47.8    24    24.5    33.99    178.39    88.6         655.35
    34.11    3880    49.8    24    25    34.26    176.84    89         655.35
    34.39    3920    43.5    24.5    25.5    34.53    177.72    89         655.35
    34.67    3920    52.2    24.5    25.5    34.81    183.5    85.1         655.35
    34.95    3840    6.3    28    28    35.09    182.6    84.3         655.35
    35.23    3800    6.3    28    28    35.36    179.25    84.3         655.35
    35.49    3760    6.3    28    27.5    35.62    184.57    83.9         655.35
    35.74    3440    6.3    28    27.5    35.87    172.78    83.9         655.35
    35.99    3000    6.3    28    26.5    36.12    146.73    84.3         655.35
    36.24    2880    6.3    28    27    36.36    122.85    83.9         655.35
    36.5    2760    6.3    28    27    36.62    104.79    83.5         655.35
    36.75    2800    6.3    28    26.5    36.88    98.83    83.5         655.35
    37.01    2720    6.3    28    27    37.13    97.26    83.5         655.35
    37.25    2520    6.3    28    27.5    37.38    96.44    83.5         655.35
    37.51    2240    6.3    28    28    37.63    96.11    83.1         655.35
    37.75    2040    6.3    28    27    37.88    95.98    83.1         655.35
    38    2000    6.3    28    28    38.13    96.03    83.1         655.35
    38.25    1960    6.3    28    28    38.38    95.78    83.1         655.35
    38.51    1760    6.3    28    27.5    38.63    94.93    83.1         655.35
    38.75    1560    6.3    28    27    38.88    94.77    83.1         655.35
    39.01    1520    6.3    28    28    39.13    94.49    83.1         655.35
    39.26    1600    6.3    28    27.5    39.38    94.32    83.1         655.35
    39.5    1600    6.3    28    28    39.63    94.32    83.1         655.35
    39.76    1600    6.3    27    28    39.88    93.07    83.9         655.35
    40    1720    59.2    15    19    40.14    98.07    87.8         655.35
    40.28    2000    47.5    18    18.5    40.42    106.16    89         655.35
    40.56    2520    60.4    16    19.5    40.7    110.32    90.6         655.35
    40.84    2960    49.4    6    8    40.98    111.01    89.8         655.35
    41.11    3680    44.3    17    14    41.25    113.21    89         655.35
    41.37    3680    50.6    21    21    41.52    111.75    88.6         655.35
    41.65    3720    42.4    21.5    21    41.78    109.79    88.2         655.35
    41.9    3720    49.8    21.5    22    42.03    111.18    88.2         655.35
    42.15    3680    52.2    21    22    42.27    108.08    88.2         655.35
    42.4    3720    42    21    20.5    42.53    109.58    88.2         655.35
    42.64    3720    38.8    21.5    21    42.77    111.94    88.2         655.35
    42.9    3720    44.3    22    21.5    43.02    109.09    88.6         655.35
    43.15    3760    53.7    22    22.5    43.27    111.21    88.2         655.35
    43.4    3760    57.6    22    22.5    43.52    111.15    88.2         655.35
    43.66    3760    49    22    22.5    43.79    111.89    88.2         655.35
    43.91    3760    48.2    23    23    44.03    106.54    84.3         655.35
    44.16    3680    6.3    28    27.5    44.28    107.59    83.5         655.35
    44.41    3640    6.3    28    27    44.53    163.28    83.9         655.35
    44.66    3480    6.3    28    27.5    44.79    180.5    83.5         655.35
    44.91    3040    6.3    28    27.5    45.03    163.84    83.9         655.35
    45.18    2760    6.3    28    27.5    45.31    134.86    83.9         655.35
    45.45    2640    6.3    28    27    45.59    117.5    83.5         655.35
    45.73    2680    6.3    28    27.5    45.88    101.9    83.5         655.35
    46.02    2600    6.3    28    27.5    46.15    98.21    83.5         655.35
    46.3    2400    6.3    28    27.5    46.44    98.18    64.7         655.35
    46.57    2160    6.3    28    27    46.71    97.59    64.7         655.35
    46.84    1960    6.3    28    28    46.96    97.83    65.5         655.35
    47.09    1920    6.3    28    28    47.2    97.92    65.9         655.35
    47.34    1880    6.3    28    28    47.46    97.58    66.3         655.35
    47.58    1720    6.3    28    27.5    47.71    96.78    66.7         655.35
    47.83    1520    6.3    28    28    47.96    96.23    67.1         655.35
    48.09    1480    6.3    28    27    48.21    96.35    67.8         655.35
    48.33    1520    6.3    28    27.5    48.46    95.88    68.2         655.35
I'm not seeing anything in that data that jumps out at me and screams, "Here's the problem!".
Question: Did you start out with the engine faults cleared, and were any faults set during your "spin"?
edvin11
California, USA
C?ID=435401
Codes cleared, stepped on it around 5500 rpm check engine light started flashing , misfired. I think we need more parameters to look at just don't know the designations. Mvb. Is there a list I can look up.
