Esp problems.
Sharpygti
HUC-2H
Hello. I have a audi a3 8p 55 plate. I think it's a 2006. It's a 2.0 tfsi quattro, I was doing some bits to it but have decided to sell it. My problem is I brought some 2010 s3 clocks for it and I tried them In to see what they would look like. It had safe on them where the mileage was and I knew they would need coding to get them working. So until I could get this sorted I put my standard clocks back in and this is when all the trouble started.
Straight away I had a esp light on and the yellow steering wheel light. The steering wheel light went off as soon as I drove the car but the esp light has never hone out. When I read the codes it has no basic settings and I cant seem to sort it out. Just wondering if anyone can help me out. These are the codes I'm getting
01423
01435
00778
01279
Sharpygti
HUC-2H
Hello. Yes I have read a few things and I guessed this had happened but i dont know how to to sort it. I'll do a auto scan tomorrow and up load it.
Thanks for your reply.
Saturday,12,June,2021,14:28:33:22772
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ8P36A081904   License Plate: BSZ1083
Mileage: 127500km-79224mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56
VIN: WAUZZZ8P36A081904   Mileage: 127500km-79224miles
   Part No SW: 8P0 907 115     HW: 8P0 907 115
   Component: 2.0l R4/4V TFSI  00 0130
   Revision: --H01---    Serial number: AUX7Z0E9FN503Z
   Coding: 01030003180F0060
   Shop #: WSC 06314 123 12345
   VCID: 6FE6A8057EC5F8F32A-803A
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Fault Status: 01100010
                    Mileage: 127485 km
                    Date: 2021.06.09
                    Time: 19:41:34
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.811 V
Readiness: 0000 0001
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 S    HW: 1K0 614 517 S
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00T12001
   Coding: 0021122
   Shop #: WSC 06314 000 00000
   VCID: 377650654615703332-8062
   Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
   Component: KlimavollautomatH17 0200
   Revision: 247210      Serial number: 8P0820043H
   VCID: 31626E7DA871AE037C-8064
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H36 1201
   Revision: 00H36000    Serial number: 00000002235150
   Coding: EF8C5F07A014100000000000000000000009FA175C0600
   Shop #: WSC 06314 123 08192
   VCID: 40843BB913DB378B83-8014
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00150573
   Shop #: WSC 06314
00061 - Footwell Lights
                    Fault Status: 01101100
                    Reset counter: 147
                    Mileage: 127422 km
                    Date: 2021.01.10
                    Time: 18:34:00
                    Voltage: 11.95 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 H    HW: 8P0 959 655 H
   Component:    Airbag 9.41  H11 3520
   Revision: 91H1135    Serial number: 0037W000X9WU
   Coding: 0071612
   VCID: 479620A536F500B342-8012
   Subsystem 1 - Serial number: 63328RB400AA0A63H
   Subsystem 2 - Serial number: 63428RB400AA11236
   Subsystem 3 - Serial number: 63528RB400AA0AAAU
   Subsystem 4 - Serial number: 63628RB400AA11137
   Subsystem 5 - Serial number: 63729RB400BBCEADB
   Subsystem 6 - Serial number: 63829RB400BBCED57
   Part No SW: 8P0 953 549 E    HW: 8P0 953 549 E
   Component: Lenksäulenmodul H34 0070
   Coding: 0002012
   Component: Lenkradmodul    H06 0030
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 D    HW: 8P0 920 981 D
   Component: KOMBIINSTR. VDO H80 0420
   Revision: D06         Serial number: 2249ED06002429
   Coding: 0005403
   Shop #: WSC 01229 210 166787
   VCID: 3972565D70016643C4-806C
16346 - Control Module - ROM Error
            014 - Defective
                    Fault Status: 00000011
                    Mileage: 43551 km
                    Date: 2008.09.12
                    Time: 09:29:02
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105926936D
   Coding: BD0F0342070101
   VCID: 2A50791185A7DDDBBD-807E
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 B
   Component: HALDEX 4Motion      0107
   Coding: 0000001
   VCID: 2C5C7F098F53C3EB4F-8078
   Revision: D06         Serial number: AUX7Z0E9FN503Z
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000120
   Shop #: WSC 06435 000 00000
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 336E6475526D9C130E-8066
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H03 0040
   Coding: 188000187F28850F489AC63300
   VCID: 79F2965D3081A64384-802C
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H03 0020
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH27 0160
   Revision: 00005       Serial number: 30659525709847
   VCID: 70E4AB7963FBE70B33-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Component: Tuer-SG         020 0070
   Coding: 0000632
   VCID: 41823EBD18D13E838C-8014
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H52 0060
   Revision:      05S    Serial number: AUZ2Z3C1349443
   Coding: 0001001
End-------------------------(Elapsed Time: 01:40)--------------------------
Address 01: DTCs cleared
Sharpygti
HUC-2H
Hello. I have tried these basic setting and it wont let me. Just says error in red.
I have some pictures but dont no how to put them up on here.
Please see:
Sharpygti
HUC-2H
ss9fDGC[img]
Sharpygti
HUC-2H
[/url]
Sharpygti
HUC-2H
Sorry. I've uploaded some pictures to Imgbb and I have found the url bbcode but I cant seem to get it to work
Sharpygti
HUC-2H
Sharpygti
HUC-2H
Sharpygti
HUC-2H
I also have this code bit not sure what it means
16346 - Control Module faulty/defective (ROM Error)
Did you do the Coding II or Security access before attempting the Basic Settings?
I notice your steering angle reads exactly 0.00. Does it change when you turn the steering wheel?
Yes, but that's in your instrument cluster and I don't think this should affect your ability to do Basic Settings in the ABS.
Sharpygti
HUC-2H
I didnt do them no but if I remember the login 11 is shadowed over so I cant use it. The security one is ok but I have done anything with that.
Yes it does move if you turn the wheel. It was on 3. Something when I checked the mega blocks first, I turned it to get it between +1.5 -1.5 but got it smack on.
Sharpygti
HUC-2H
Hi. So tonight I went out and tried again. This time I clicked the security access and put the 40168 code in. Then went to basic settings. It came up green with the no/off/next button but when I clicked it the red error writing came up.....
after I had clicked the button once they all said error. I would have to go out of the controller and start again. I tried them all but they all went red with error.
one thing I did notice was last night when i turned the wheel it went up and down in mega blocks but tonight it just stayed on 0.00
I'm stumped.
But since this thread definitely involved VCDS, it doesn't belong in General VW/Audi Repair. Moving to New Users section.
Sharpygti
HUC-2H
I'm really stuck with this. I'm not sure what to do next. Could the clocks be bad and that's why it wont work? Would it have anything to do with bleeding the abs unit? I've had all the brakes off??
Well the Instrument Cluster certainly thinks it is bad, but again, I don't see how that would prevent Basic Settings in the ABS module from working.
NEtech
Denmark
C?ID=56995
Don't click on the [ON/OFF/Next] button, as you can see in 2 of your pictures, "Adjustment Status" show Ok.
Wait about 30 sec. then go to Security Access again and then do the next Basic Setting.
Sharpygti
HUC-2H
Im not sure how but its all sorted now. I dont have any lights on the dash but the steering wheel light is yellow when I turn the ignition on, then goes red and then stays on a little bit longer than the other light when the engine is started.... is this normal? I cant remember what it did before.
Thanks for your help anyway. :):D
