Volkswagen Transporter T30 SWB tdi - ABS Module coding help.
tgbauto
South Molton, UK
C?ID=245531
Good Morning, We have a 2007 transporter in currently with abs fault, The pump has been found faulty.. The code on the original pump is 7HO 614 117-- now this pump seem near impossible to get hold of second hand, We have tried a 7HO 614 517 also from a transporter -- Ive read differing opinions, but can this module be coded to our vehicle? The vehicle we have has no ESP, it does have a diff lock.
The VIN IS WV1ZZZ7HZ7H129667 Can any one give me some help with the correct ABS coding , if it is possible to code this other pump.
Any assistance will be greatly appreciated. Please note we are UK and this is Right hand Drive!
Friday,11,June,2021,10:16:38:38637
VCDS Version: 21.3.0.0 (x64)
VIN: WV1ZZZ7HZ7H129667   License Plate: T30
Mileage: 164930km-102482mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H129667   Mileage: 164930km-102482miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 997 016 M    HW: 070 997 016 M
   Component: R5 2,5L EDC  000SG  0860
   Revision: --H05---    Serial number: VWZ7Z0G5299748
   Coding: 0000132
   Shop #: WSC 00001 128 00032
   VCID: 2447AAF2E44D12AB87-515E
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 164939 km
                    Voltage: 13.68 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Readiness: 0 0 0 0 X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 Q    HW: 7H0 907 379 Q
   Component: ESP MK25E1          0103
   Revision: 00H31001
   Coding: 0000556
   Shop #: WSC 09817 005 104857
   VCID: 4385096E010335939E-5140
00812 - Brake Pressure Release Solenoid (F84)
                    Fault Status: 00101100
                    Mileage: 164939 km
                    Count: 128
                    Count: 12545
                    Count: 239
                    Count: 1
                    Fault Frequency: 9
                    Reset counter: 15
                    Mileage: 164939 km
                    Count: 128
                    Count: 4865
                    Count: 8214
                    Count: 1
                    Fault Frequency: 9
                    Mileage: 164939 km
                    Count: 128
                    Count: 4865
                    Count: 8200
                    Count: 1
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 12
                    Mileage: 164939 km
                    Count: 128
                    Count: 4865
                    Count: 199
                    Count: 2049
00814 - Solenoid for Brake Pressure (N247)
                    Fault Status: 01101100
                    Fault Frequency: 12
                    Mileage: 164939 km
                    Count: 128
                    Count: 4353
                    Count: 110
                    Count: 2049
00493 - ESP-Sensor Unit (G419)
                    Fault Frequency: 9
                    Mileage: 164939 km
                    Count: 128
                    Count: 4353
                    Count: 12288
                    Count: 1
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AE
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000004
   VCID: 75E1A7B61F57DB23E0-5140
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0010
   Coding: 13122
   Shop #: WSC 02756
   VCID: 224BACEAAE591C9BF5-5124
            32-00 - Resistance Too High
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Coding: 00413
   VCID: 3D717F9637E74363E8-5140
   WV1ZZZ7HZ7H129667     VWZ7Z0G5299748
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02756
   VCID: 70EF96A23035FE0B33-5124
01304 - Radio
Address 22: AWD        Labels: 7H0-907-554.clb
   Part No: 7H0 907 554 F
   Component: HALDEX 4Motion      2110
   Coding: 0000002
   Shop #: WSC 02756 790 00000
   VCID: 336559AE51A385130E-5124
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: CXL Komfortgerát     0004
   Coding: 00021
   Shop #: WSC 02756
   VCID: 326B5CAAFEB98C1B05-4B1C
End-------------------------(Elapsed Time: 06:15)--------------------------
If the vehicle didn't have ESP to begin with, you're not going to make an ABS/ESP module happy in that vehicle, and the 7H0-907-379-Q module that you've now installed is clearly that: "Component: ESP MK25E1"
PS: Moved to Car Repair Support
tgbauto
South Molton, UK
C?ID=245531
Yes this was our fear, thankyou for your response
tgbauto
South Molton, UK
C?ID=245531
We have no correctly matched all the part numbers but are still met with the fault code incorrectly coded module in ABS. ive attached a auto scan if anyone could help me that would be great
Wednesday,23,June,2021,11:28:26:38637
          57 6E 76 77 78 7D
   Coding: 0000132
                    Mileage: 164939 km
                    Voltage: 13.68 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 P    HW: 7H0 907 379 P
   Component: (M)ABS MK25E        0103
   Revision: 00H12001
   Coding: 0000616
   Shop #: WSC 02736 790 00000
   VCID: 428B0C6A1E193C9B95-5140
                    Mileage: 164939 km
                    Count: 128
                    Count: 4353
                    Count: 8200
                    Mileage: 164939 km
                    Count: 128
                    Count: 4865
                    Count: 199
   Coding: 0000004
   VCID: 75E1A7B61F57DB23E0-5124
00991 - Interior Lights
   Coding: 13122
   Shop #: WSC 02756
   Coding: 00413
01304 - Radio
   Coding: 00022
   Shop #: WSC 02756
   VCID: 70EF96A23035FE0B33-5140
01304 - Radio
   Coding: 0000002
   VCID: 336559AE51A385130E-5140
   Coding: 00021
   Shop #: WSC 02756
   VCID: 326B5CAAFEB98C1B05-4B02
Address 03,7H0 907 379 P,recoded (Short coding),from,0000616,to,0000540,(02736/790/00000),
Please see if this 03-ABS coding resolves any of the DTCs: 0000604
If you have any issues with that coding please post another scan.
Vehicle Identification No. WV1ZZZ7HZ7H129667
Model Transp. panel van
4Motion
TR
Date of production 02.04.2007
Year 2007
Sales type 7HA105
Engine Code BNZ
MM3 5-cyl. turbo diesel engine 2.5 l/96 kW unit-injector system base engine is T85/TM7
Transmission Code JKT
G0L 6-speed manual transmission for four-wheel drive vehicle
1Y4 Differential lock
K4A Panel Van
